If a polynomial is irreducible, you can use GroupTheory:-GaloisGroup or galois to compute its polynomial, for example:
G := GroupTheory:-GaloisGroup(x^5 - x + 1, x)
But what if polynomials are reducible? Such as x^5-x+15. How to compute its Galois group by maple? There are some examples to check at the end of this article
How can I determine a positive constant M such that the following inequality hold for any positive values of a, b,c.
More precisley, I determine M such that  f(a,b,c) greater or equal M a^2
The constant M is a positive constant depend only on alpha
find_positive_constant_M.mw
thank you for your help
I'm trying to plot the regions of a cube [0,1]x[0,1]x[0,1] that are defined by two inequalities
0<=x<=y<=z<=1
I tried the following but the result is not satisfying :
G1 := implicitplot3d(x = y, x = 0 .. 1, y = 0 .. 1, z = 0 .. 1, style = surface)
G2 := implicitplot3d(z = y, x = 0 .. 1, y = 0 .. 1, z = 0 .. 1, style = surface)
display({G1, G2})
Thank you for your help.
I would like to compute Hardy−Littlewood maximal function : we use polar coordinate for a radial function  and then evalaute integral with respect the radius r
Hardy_maximal_function.mw
u := c1*BesselK(0, alpha1*r) + c2*BesselI(0, alpha1*r) + c3*BesselK(0, alpha2*r) + c4*BesselI(0, alpha2*r) - A1*k^2*(k^2 - (-alpha^2*j*s + 4*c*s)/c)*BesselK(0, k*r)/((-alpha1^2 + k^2)*(-alpha2^2 + k^2)) - B1*k^2*(k^2 - (-alpha^2*j*s + 4*c*s)/c)*BesselI(0, k*r)/((-alpha1^2 + k^2)*(-alpha2^2 + k^2)) + ur*(-alpha^2*j*s + 4*c*s)/(c*(1 + c));
w := (-1 - c)/(2*s*(4.*c - alpha^2*j))*collect(diff(diff(r*diff(u, r), r)/r, r) + (alpha^2 - 4*c*s)*diff(u, r)/(1 + c) - A1*k^3*BesselK(1, k*r) + B1*k^3*BesselI(1, k*r), [c1, c2, c3, c4], factor);
om := (-1)/2*diff(u, r)/r;
fn1 := collect(simplify(subs(subs(r = 1, u))), [c1, c2, c3, c4], factor);
fn2 := collect(simplify(subs(subs(r = sigma, u))), [c1, c2, c3, c4], factor);
fn3 := collect(simplify(subs(r = 1, w)), [c1, c2, c3, c4], factor);
fn4 := collect(simplify(subs(r = sigma, w)), [c1, c2, c3, c4], factor);
soln := simplify(solve({fn1 = 0, fn2 = 0, fn3 = 0, fn4 = 0}, {c1, c2, c3, c4}));
I was translating some code from Mathematica to Maple. Why MmaTranslator does not know about Mathematica's CubeRoot function? This was added in 2012 (more than 11 years ago).
Is this known? How could one teach Maple's MmaTranslator to convert CubeRoot[x] to surd(x,3)? Is it possible to manually add missing translations to this package? Otherwise I would have to manually edit lots of code and do this myself each time.
with(MmaTranslator);
FromMma(`CubeRoot[9]`);
Gives CubeRoot(9) it should be surd(9, 3)
Version 2023 on windows 10
The Dominating set defination and Minimal dominating set definations given below
Code to generate the above.
A Function  F such that given the Graph G and vertex v as input the function should return me the number  of minimal dominating sets in the graph G contating the vertex v.
The logic to code seems to be above me Kind help some one please.
As manually doing is not that easy kind help.
I will surely acknowlege,
Kind help
We can read all the graphs in a file at once, or we can use an iterative approach. But can I specify a certain number of lines to read?
with(GraphTheory):
g:=ImportGraph("E:/5cc3free.txt", graph6, output=list)
The contents of 5cc3free.txt are as follows (all 5-vertex C_3 free connected graphs).  There are 6 lines.
D?{
D@s
DBw
DFw
DDW
DqK
The reason for wanting this kind of operation is that sometimes there are tens of thousands of graphs stored in a single file, and I want to read them in batches. For example, I want to extract the graph data from lines 1-2, 3-4, and 5-6 in batches. How can I accomplish this?
In the previous example, a small dataset was used for demonstration purposes. In the following example, which involves all 8-vertex connected graphs (see the attachment graph8c.txt), I want to extract the graphs from lines 200-300.
I found that readline always starts reading from the first line of a file, so the efficiency may not be very high.
For example - I have a for loop acting on a Matrix
a:=Matrix(20,20,rand(0..1.)
for i from 1 to 20 do
  for j from 1 to 20 do
    if a[i,j]<0.2 then a[i,j]:=0 end if:
Is there an equivalent sequence loop?  I tried to set up a double seq to set the values in the matrix but this fails
seq(seq(`if`(a[i,j]<0.2,a[i,j]:=0,a[i,j]),i=1..20),j=1..20)
I have list of lists I looking to Shuffle the entire List of lists in a very very non-sequencial manner everthing thing fully shuffled.
I tried but I am unable to find the right way.
Attached a code I tried
Code like below
toy_shuffle.mw
Inside a big running for loop
If a particular condition is satisfied I want loop to pause until i again press the enter key again
As if the condition is satisfied I want to note down the output results printed on screen when that condition is satisfied.
previously C I used to use like getch() for it to wait
Kind help please.
I dont want  breakpoint it will simply call the debugger so only.
H:= Fit(a*B+b*sinh(c*B), Bdata, Hdata, B)
can someone help me ? i have never used maple13 and i have to describe a code but i cant understand what this line does. can someone help me, please?!
thank u in advance.
How can I solve Einstein’s equation and calculus of the value of the K constant in Einstein's equation and the value of the tensor stress energy that fits in this equation?
QTBend.docxSqBend.mw
I m wondering if/how (i) can use the collect function twice:  collect(a, x, form, func ):
collect(a, x, form, collect(x)), but it seems I can't use a func with opt.
Can someone help please?
Merci
First 207 208 209 210 211 212 213 Last Page 209 of 2428
