cyclebasis.mw contains a computation of a graph on 14 vertices which has a two-cycle.  I was expecting CycleBasis to find this two-cycle, but it does not.  Anybody know why not?
I was also expecting CycleBasis to work on the original directed graph, but it did not, for reasons that I do not understand.
I think the issue is that the writer of this package had a different mental model of what graphs were; I freely admit that I am a novice with regard to graphs.
Comments welcome.
Ive got new "problems" with my math book. This time it is about differentiating like Gottfried Wilhelm Leibniz (https://en.wikipedia.org/wiki/Gottfried_Wilhelm_Leibniz), and his Leibniz notation.  (https://en.wikipedia.org/wiki/Leibniz%27s_notation).
dx/dy. Now that does sound like its just f'(x), of function f(x). But now they wanted something else i cannot produce. I could do the examples, and try to work it out like, but "im here to learn maple, not how to get my hands filthy with ink, and scratch on the paper when i make mistakes"... :P
It says: Determine the differential that is being asked.
No matter what i do, there wont be any solution that looks like the one given by the book.
I would like to be good at this, while a lot of old books do still have the Leibniz notation. So it is eccential to be good at this if you want to really study the origins of math and science.
Greetings,
The Function
I used to have this kind of code without problem:
myModule := module()
    option package;
    export myFunc;
    # local i;
    myFunc := proc()
        [seq(i, i in 1..10)]
end module;
But after upgrading to the latest version of Maple 2021, I get a warning
Warning, (in myModule:-myFunc) `i` is implicitly declared local |myModule.mpl:5|
I have to uncomment the local i declaration for the warning to go away. Has the behavior of seq changed in Maple 2021?
I have a function with 3 variables fr2, fr3, and fr4. I want to find how this function varies with these variables in such a way that fr2+fr3+fr4 = 0.5.  All three variables are non-negatives. Please help me in generating a sensitivity report as fr2, fr3, and fr4 each varies across 0 to 0.5 in increments of 0.01 subject to their sum is equal to 0.5
The function is fn1 = 1.150000000*10^11*fr3 + 1.150000000*10^11*fr4 - 1.374950000*10^10 - 1.549500000*10^10*fr2
sensitivity_help.mw
When I made a restraint system like bolow and used  GetEquations() , undefined external forces(Fx,Fy) was derived.
I want to know the reason or the principle of GetEquations() which is solving the dynamics of  a restraint system.
msim→2hand.msim
mw→2hand.mw
How to know the internal procedures of Maple for instance : taylor or laurent ? Thank you.
Dear I have
Vectors of locations points
X=[ 1 , 2] ;
Y =[ 6 , 7 ]
I would like to point of the point of this grid a vertical bars with different given length...how can I do this using maple or matlab
how to export my data in sheet excel for this file
Nnew.mw
I am trying to evalute symbolically a matrix looking like this:
V := (Matrix(3, 3, [[0, 0, 0], [0, 0, 0], [0, 0, 0]]) - (((1/2) . (Vector[row](3, [0, 0, 0]))) . (Matrix(3, 3, [[0, 0, 0], [0, 0, 0], [0, 0, 0]])))) . (Vector[column](3, [0, 0, 0]))
Here is the picture because the formatting is bad:
I need to have some equations in this form but maple wont allow me.
Let us say there is a function desribing an angle. And by deriving the math let us say the position is cos(theta). Theta is a function of time and cos is a function. How do i differentiate this and make maple see that theta is a function and not a variable.
i have tried this (x(t) is theta):
f := t -> sin(x(t));
Diff(f, t);
Did not work.What i want is the output to be.
cos(x(t))*x'(t)
Maple returns to me an algebraic expression that involves many RootOf expressions and I have found it hard to get all solutions behind this expression (by using "allvalues") - this keeps on running without terminating. Is there a way to get the number of solutions without asking Maple to return all solutions explicitaly?
Problem description
1) Define a function in terms of variables and parameters,
2) FInd the optimal solution
3) Plot the optimal solution in terms of a single parameter
Solution
What I have done is very basic since I haven't use Maple for many years. Here is an example
1) f(x;a,b,c):= ax^2+bx+c; (I don't knpw how to tell Maple that {a,b,c} is a set of parameters)
2) solve(f(x)=0,x); (I could use something like solve(f(x)=0,x,'parametric','real') but I am not interested in so detailed solution)
3) Here is my main problem. I want to save the first solution of x in optx(a;b,c) and the second in opttx(a;b,c) but I don't know how to do it (again, here a is my variable and b,c my parameters)
4) I also don't know hot to plot optx(a) as a increases, whereas the values of {b,c}={e.g., 2,3}
I would appreciate any resources/guidance
hello,my friends.I got a problem in using maple.
I want project a cuboid on a plane, and integrate function on that area.
for example, a cuboid which have a spatial diagonal between (0,0,0) and (1,2,1).
Then it was projected to a plane defined by three points (-1,0,0), (0,-1,0) and (0,0,-1).
Finally, a function x^2+y^2 was integrated on that projected area.
I found the cuboid can be defined with plottools:-cuboid and projected with plottools:-project in maple.
but how to integration next?
I can't find any commands in maple can do the integration with that irregular area.
I need some help.Thank you very much in advance.
Do you know why the sequence of output is difference than the handing output?
a := 1.4;
b := 0.3;
x[0] := 1;
y[0] := 1;
<x[n + 1], y[n + 1]> = <b*y[n] - x[n]^2 + a, x[n]>;
f := (n, m) -> (-n^2 + b*m + a, n);
g := (k, n, m) -> (f@@k)(n, m);
seq([g(a, x[0], y[0])], a = 0 .. 3);
        [1, 1], [0.3, 1], [0.61, 1.3], [-0.2701, -1.99]
[g(0, x[0], y[0])], [g(1, x[0], y[0])], [g(2, x[0], y[0])], [g(3, x[0], y[0])];
        [1, 1], [0.7, 1], [1.21, 0.7], [0.1459, 1.21]
First 374 375 376 377 378 379 380 Last Page 376 of 2429
