How do I fully expand an expression a polynomial with a constant c and variable m ?
i did substitution but my result is so different from the author i think he just take the linear term of theta but i didn't do that so how take just linear term of that function and find unknwon , and how afeter replacing eq(12) inside eq(11) we can remove thus exponential and find w? also i think author did a mistake which the equation 12 is theta(x,t) not Q(x,t)
with(PDEtools)
undeclare(prime, quiet)
declare(u(x, t), quiet); declare(U(xi), quiet); declare(V(xi), quiet); declare(theta(x, t), quiet)
pde := diff(u(x, t), `$`(t, 2))-s^2*(diff(u(x, t), `$`(x, 2)))+(2*I)*(diff(u(x, t)*U^2, t))-(2*I)*alpha*s*(diff(u(x, t)*U^2, t))+I*(diff(u(x, t), `$`(x, 2), t))-I*beta*s*(diff(u(x, t), `$`(x, 3)))
diff(diff(u(x, t), t), t)-s^2*(diff(diff(u(x, t), x), x))+(2*I)*(diff(u(x, t), t))*U^2-(2*I)*alpha*s*(diff(u(x, t), t))*U^2+I*(diff(diff(diff(u(x, t), t), x), x))-I*beta*s*(diff(diff(diff(u(x, t), x), x), x))
T := u(x, t) = (sqrt(Q)+theta(x, t))*exp(I*(Q^2*epsilon*gamma+Q*q)*t); T1 := U = sqrt(Q)+theta(x, t)
u(x, t) = (Q^(1/2)+theta(x, t))*exp(I*(Q^2*epsilon*gamma+Q*q)*t)
U = Q^(1/2)+theta(x, t)
P := collect(eval(subs({T, T1}, pde)), exp)/exp(I*(Q^2*gamma*`ε`+Q*q)*t)
diff(diff(theta(x, t), t), t)+(2*I)*(diff(theta(x, t), t))*(Q^2*epsilon*gamma+Q*q)-(Q^(1/2)+theta(x, t))*(Q^2*epsilon*gamma+Q*q)^2-s^2*(diff(diff(theta(x, t), x), x))+(2*I)*(diff(theta(x, t), t)+I*(Q^(1/2)+theta(x, t))*(Q^2*epsilon*gamma+Q*q))*(Q^(1/2)+theta(x, t))^2-(2*I)*alpha*s*(diff(theta(x, t), t)+I*(Q^(1/2)+theta(x, t))*(Q^2*epsilon*gamma+Q*q))*(Q^(1/2)+theta(x, t))^2+I*(diff(diff(diff(theta(x, t), t), x), x)+I*(diff(diff(theta(x, t), x), x))*(Q^2*epsilon*gamma+Q*q))-I*beta*s*(diff(diff(diff(theta(x, t), x), x), x))
TT := Q = alpha[1]*exp(I*(k*x-t*w))+alpha[2]*exp(-I*(k*x-t*w))
Q = alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w))
S := eval(subs(TT, P))
diff(diff(theta(x, t), t), t)+(2*I)*(diff(theta(x, t), t))*(gamma*epsilon*(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^2+(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))*q)-((alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^(1/2)+theta(x, t))*(gamma*epsilon*(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^2+(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))*q)^2-s^2*(diff(diff(theta(x, t), x), x))+(2*I)*(diff(theta(x, t), t)+I*((alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^(1/2)+theta(x, t))*(gamma*epsilon*(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^2+(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))*q))*((alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^(1/2)+theta(x, t))^2-(2*I)*alpha*s*(diff(theta(x, t), t)+I*((alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^(1/2)+theta(x, t))*(gamma*epsilon*(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^2+(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))*q))*((alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^(1/2)+theta(x, t))^2+I*(diff(diff(diff(theta(x, t), t), x), x)+I*(diff(diff(theta(x, t), x), x))*(gamma*epsilon*(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))^2+(alpha[1]*exp((k*x-t*w)*I)+alpha[2]*exp(-I*(k*x-t*w)))*q))-I*beta*s*(diff(diff(diff(theta(x, t), x), x), x))
Download steps.mw
or for this equation
steps-2.mw
Prove:
If a is an irrational number, then the function
y(x) = cos(a*x) + cosx is not periodic.
Further question:
Since every irrational number can be represented as the limit of a sequence of rational numbers and all software "only" works with finite representations of numbers, it would be interesting to know at what number length for a this becomes in examples apparent in the plot for y(x).
I'm not sure exactly when this started but maple on one of my linux machines won't print more than one row of a matrix. I get dots like this:
Note that interface(rtablesize) is [10,10]. This happens with both maple2024 and maple2025.
On any of my other machines, maple works just fine. I have also tried deleting ~/.maple and ~/.maplesoft
Any idea why Maple dsolve can't find solution to this ode? From textbook
The strange thing, it solves if it asked for implicit solution. But the default, will give no solution.
Is this a defect? Should it not have returned the book solution automatically?   How is a user supposed to know the ode has a solution or not, if default call returns no solution?
SupportTools:-Version();
`The "Physics Updates" version in the MapleCloud is 1877 and is the same as the version installed in this computer, created 2025, July 11, 19:24 hours Pacific Time.`
ode:=v(x)*diff(v(x),x) = g;
ic:=v(x__0) = v__0;
sol:=dsolve([ode,ic]);
v(x)*(diff(v(x), x)) = g
v(x__0) = v__0
ic:=v(x__0) = v__0;
sol:=dsolve([ode,ic],'implicit');
v(x__0) = v__0
-2*g*x+v(x)^2+2*g*x__0-v__0^2 = 0
#why did not default call return this?
PDEtools:-Solve(sol,v(x))
v(x) = (2*g*x-2*g*x__0+v__0^2)^(1/2), v(x) = -(2*g*x-2*g*x__0+v__0^2)^(1/2)
Download dsolve_gives_no_solution_sept_2_2025.mw
I have bought Maple Flow 2025 and trying to use it in an effective way. While doing this I noticed some little issues that could be improved.
1. When typing text it would be nice that the cursor goes automatically to the next line when at the border of chosen paper size (e.g. A4).
2. It would be nice that you could separate the containers when they overlap by using 1 button. Now you can align containers vertically but it would be nice if you can do that also horizontally.
I also have a question, is it possible to place a section in another section as you can in Maple or is this not possible?
I test a lot of them but some of them make a problem i  don't know i am do it in wrong way or the author did wrong i need verifying thus solution of odes specially in case 4 when we have not equal sign how use that?
and case 5 is Weierstrass elliptic function which i don't know how set up and use i think is a on kinf of odes but why they use that sign for this function?
ode-17.mw
I'm struggling to construct a statistical Distribution involving Product.
This is likely a question of delayed evaluation but I'm not capable to fix it.
Can you please look to this  Product_error.mw  worksheet  and help me fixing the issue?
I’m having fun animating a beautiful geometric shape starting from a few trigonometric functions. I’m wondering if there’s a way to link each curve in the animation to its name.
plots:-animatecurve([sin(x), sin(x)^2, sin(x)^3, sin(x)^4, sin(x)^5, sin(x)^6, surd(sin(x), 2), surd(sin(x), 3), surd(sin(x), 4), surd(sin(x), 5), surd(sin(x), 6)], x = 0 .. Pi, thickness = 2.5, background = "AliceBlue", labels = ["", ""], size = [800, 800])
plot([sin(x), sin(x)^2, sin(x)^3, sin(x)^4, sin(x)^5, sin(x)^6, surd(sin(x), 2), surd(sin(x), 3), surd(sin(x), 4), surd(sin(x), 5), surd(sin(x), 6)], x = 0 .. Pi, thickness = 2.5)
Download Animation_Trigo.mw
How to get amultiple line plots in one graph for differnt values of E1 := .1,0.2,0.3,and 0.4 with differnt color line red,blue,black and green and how to get numerical values for the all E1 value in one matrix form
at E1=0.1 value of diff(g(x), x, x), diff(f(x), x, x),diff(f(x), x) and diff(g(x),  x).
AGM_method_single_line_plot.mw
I recently upgraded from Maple 23 to Maple 24. While many display issues have been resolved, I’ve encountered a new real problem: when entering operations or a factorial in a denominator or exponent, the cursor unexpectedly jumps to the inline position. This forces me to manually reposition the cursor using backspace plus left-arrow keys, and forgetting to do so can lead to errors. I have a perpetual Maple license through my university and haven’t purchased maintenance this time. Is there any way to fix or work around this cursor-jumping issue in Maple 24 without purchasing a new license?
The_Bohrs_Model_-_MaplePrimes.mw
Look at the equation (11) in the Maple's document. I would like to force Maple to let the variable "r" inside the squared root so to get the equation (12). Any idea of doing that?  Thank you in advance for your help.
Already  by Help of my favorite Dr.David he did find the thus three step for non schrodinger equation but in here i got some issue of coding which is so different from before, is about transformation of pdes to two parts od real and imaginary part and then substitution our function the functions is clear but combining them and findinf leading exponent and resonance point and finding function in step 3 in different and jsut the function is different with eperate the real and imaginary part for finding step one ...
note:=q=u*exp(#) then |q|=u
schrodinger-test.mw
paper-1
paper-2
(2500iw/(1+5iw) )+(200iw/1-10iw)+5 rationalize and simplify
Hello All
I have the system of 4 differential equations with retarted delay (t-tau) and advanced argument (t+tau). The problem is also considered as a two-value boundary problem since some variables have initial conditions and some have terminal ones.
Here is a model:
Data:
A := 10;
B := 5;
C := 2;
tau = 0.5;
T := 10;
 z := 5;
 N := 20;
System:
sys := diff(K(t), t) = A*Q(t - tau) + K(t), diff(Q(t), t) = l_Q(t)*z - N, diff(l_K(t), t) = B*Q(t - tau) + l_K(t), diff(l_Q(t), t) = l_K(t + tau)*K(t + tau) + C;
Initial and terminal conditions:
inc := K(0) = 50, Q(0) = 200, l_K(T) = -20, l_Q(T) = 0;
I will appreciate any direction/suggestion on how this system can be solved.
Dmitry
4 5 6 7 8 9 10 Last Page 6 of 2433
