I was surprised that Maple can't solve this first order ode which is exact ode.
I solved by hand and Maple says my solution is correct.
Any one can find why Maple failed to solve this and if older versions can solve it? Also tried implicit option, but that did not help.
SupportTools:-Version();
ode:=diff(y(x),x) = (2*sin(2*x)-tan(y(x)))/x/sec(y(x))^2;
diff(y(x), x) = (2*sin(2*x)-tan(y(x)))/(x*sec(y(x))^2)
sol:=dsolve(ode);
mysol:=cos(2*x)+x*tan(y(x))=c__1;
cos(2*x)+x*tan(y(x)) = c__1
odetest(mysol,ode);
Download maple_solving_exact_ode_august_25_2025.mw
In the attached file, the trigonometric term (2, term) is transformed into a term (3, term1) consisting of radicals. Is there a Maple procedure that can be used to reverse this process? Given an algebraic term (e.g., consisting of radicals, powers, etc.), under what conditions can it be transformed into a trigonometric form (not a Fourier series) in the sense of (3) according to (2)?test.mw
`Standard Worksheet Interface, Maple 2024.2, Windows 11, October 29 2024 Build ID 1872373`
term := 2*cos(5*arcsin((1/2)*x))
term1 := expand(term)
-3*(-x^2+4)^(1/2)*x^2+(-x^2+4)^(1/2)+(-x^2+4)^(1/2)*x^4
convert(term1, trig)
simplify(term1, trig)
(-x^2+4)^(1/2)*(x^4-3*x^2+1)
solve(term1 = sqrt(2), x)
(1/2)*(8-2*(10+2*5^(1/2))^(1/2))^(1/2), (1/2)*(8+2*(10-2*5^(1/2))^(1/2))^(1/2), (1/2)*(8+2*(10+2*5^(1/2))^(1/2))^(1/2), -(1/2)*(8-2*(10+2*5^(1/2))^(1/2))^(1/2), -(1/2)*(8+2*(10-2*5^(1/2))^(1/2))^(1/2), -(1/2)*(8+2*(10+2*5^(1/2))^(1/2))^(1/2)
evalf(solve(term1 = sqrt(2), x))
.3128689302, 1.782013048, 1.975376681, -.3128689302, -1.782013048, -1.975376681
plot(term, x = -2.5 .. 2.5)
plot(term1, x = -2.5 .. 2.5)
Download test.mw
As we can see, RealDomain:-solve gives an incorrect solution to the following system:
sys := `~`[diff](sqrt(2*a^2-8*a+10)+sqrt(b^2-6*b+10)+sqrt(2*a^2-2*a*b+b^2), [a, b]):
RealDomain:-solve(`~`[`=`](sys, 0), {a, b})
{a = 5/3, b = 5/2}, {a = a, b = 2*a/(a-1)}
plot(eval(sys, {max(2*5^(1/2), (2*a^2-8*a+10)^(1/2)+2^(1/2)*((a^2-4*a+5)/(a-1)^2)^(1/2)+2^(1/2)*(a^2*(a^2-4*a+5)/(a-1)^2)^(1/2)), min(2*5^(1/2), (2*a^2-8*a+10)^(1/2)+2^(1/2)*((a^2-4*a+5)/(a-1)^2)^(1/2)+2^(1/2)*(a^2*(a^2-4*a+5)/(a-1)^2)^(1/2))}[-1]), a = -infinity .. infinity)
extrema(sqrt(2*a^2-8*a+10)+sqrt(b^2-6*b+10)+sqrt(2*a^2-2*a*b+b^2), {}, {a, b})
Download solve_returns_an_unsatisfiable_real_solution.mw
This appears to be a bug; is it possible to fix it?
Text:
sys := diff~(sqrt(2*a^2 - 8*a + 10) + sqrt(b^2 - 6*b + 10) + sqrt(2*a^2 - 2*a*b + b^2), [a, b]):
RealDomain:-solve(sys =~ 0, {a, b});
THis is problem from textbook. Maple do not give solution.
But when asked for implicit solution, it gives one.  Should it not have done this automatically?
ode:=y(x)*diff(y(x),x) = a;
ic:=y(0) = b;
sol:=dsolve([ode,ic]);
y(x)*(diff(y(x), x)) = a
y(0) = b
sol:=dsolve([ode,ic],'implicit')
-2*a*x+y(x)^2-b^2 = 0
Download why_no_solution_maple_2025_1.mw
We see now there are two solutions for y(x), since quadratic.
So why dsolve do not solve this and at least give implicit solution automatically? Should this be reported as defect?
is been a while i work on a test still i am study and there is a lot paper remain and is so important in PDEs, a lot paper explain in 2003 untill know and there is other way to find it too but i choose a easy one but is 2025 paper  which is explanation is so beeter than other paper, also some people write a package for take out this test with a second but maybe is not work for all i  search for that  but i didn't find it i will ask the question how we can find thus as shown in graph i did my train but need a little help while i am collect more information and style of solving
Download p1.mw
I hope this message finds you well. I am trying to plot a function f(x, y) and overlay its contour on a quarter ellipse using Maple 2015. However, I’ve encountered some difficulties and have not been successful so far. I would greatly appreciate any assistance in resolving this issue. Thank you!
Plotting in 2D
restart:with(plots):  aa := 4: bb := 2:
f := -((x^(2))/(aa^(2))+(y^(2))/(bb^(2))-1)*((aa^(2)*bb^(2))/(aa^(2)+bb^(2))):
plot3d(f,x = 0 .. aa/(2),y = 0 .. bb/(2),region = (x, y) -> ((2 x)/(aa))^(2) + ((2 y)/(bb))^(2)<= 1,axes = boxed,style = patchcontour, grid = [50, 50],orientation = [-120, 45],shading = zhue,title = "f(x,y) over quarter ellipse domain");
Contour plotting
xrange := 0 .. aa/(2): yrange := 0 .. bb/(2):
nx := 100:   ny := 100:
dx := (rhs(xrange) - lhs(xrange))/(nx-1):dy := (rhs(yrange) - lhs(yrange))/(ny-1):
Z := Matrix(nx, ny, (i, j) -> local x, y, inside;x := lhs(xrange) + (i-1)*dx;y := lhs(yrange) + (j-1)*dy;inside := (((2 x)/aa)^2 + ((2 y)/bb)^2 <= 1);if inside then f(x, y) else NULL end if):
contourplot(Z, xrange, yrange,contours = 15, filled = true, coloring = [blue, green, yellow, red], axes = boxed, title = "Contour plot over quarter ellipse", grid = [nx, ny]);
I would like to solve a system of 2 PDE with this code, but it does not work.
lin_eqs := {diff(h(x, t), t) + H*diff(u(x, t), x) = 0, diff(u(x, t), t) + g*diff(h(x, t), x) = 0};
sol := pdsolve(lin_eqs);
print('sol', sol);
Can you help me?Thanks
Best regards
Any idea why Maple simplifies 1+sin(x)^2 to 2-cos(x)^2?  Leaf count is larger also.
e1:=1+sin(x)^2;
1+sin(x)^2
e2:=simplify(e1)
-cos(x)^2+2
MmaTranslator:-Mma:-LeafCount(e1)
6
MmaTranslator:-Mma:-LeafCount(e2)
8
Download strange_simplification_august_20_2025.mw
Attached worksheet
`The "Physics Updates" version in the MapleCloud is 1877 and is the same as the version installed in this computer, created 2025, July 11, 19:24 hours Pacific Time.`
integrand:=1/2/x^(9/2)*2^(1/2)*Pi^(1/2)/(1/x)^(1/2)*cos(1/x);
(1/2)*2^(1/2)*Pi^(1/2)*cos(1/x)/(x^(9/2)*(1/x)^(1/2))
int(integrand,x)
Error, (in tools/eval_foo/do) too many levels of recursion
Download internal_error_on_int_august_20_2025_maple_2025_1.mw
Update
fyi, Here is yet another int() error Error, (in type/trig) too many levels of recursion in Maple 2025.1. (also reported to Maplesoft).
integrand:=(a+a*sin(f*x+e))^(3/2)*(A+B*sin(f*x+e))*(c-c*sin(f*x+e))^(5/2);
int(integrand,x)
int(integrand,x)
(1/6)*(-c*(-1+sin(f*x+e)))^(1/2)*((3/4)*B*sin(f*x+e)*tan(f*x+e)*cos(2*f*x+2*e)+A*sin(2*f*x+2*e)-(3/8)*tan(f*x+e)*(((4/5)*B*sin(f*x+e)+A)*sin(3*f*x+3*e)+(44/15)*B*sin(f*x+e)^2+(5*A-6*B)*sin(f*x+e)-(32/3)*A))*a*c^2*(a*(1+sin(f*x+e)))^(1/2)/f
int(integrand,x)
Download another_int_error_too_many_levels_maple_2025_1.mw
Greetings
I trust that everyone is well here. I have an inquiry regarding the partitioning of a matrix BA, defined on both regular and irregular domains, into three matrices: Ad, Ab, and Ae, such that NewBA = Ad + Ab + Ae. Here, Ad comprises the entries of BA that reside within the domain, Ab includes the elements of BA located on the boundary, and Ae is derived as BA - Ad - Ab for any values of Mx and My. The specifics of matrix BA are contained in the attached document where NewBA constructed manually for different values of Mx and My for better understanding.
Splitting_a_matrix.mw
The attached file contains the matrix BA constructed in a square format. How may the BA matrix be adapted to create an irregular shape, such as a quarter circle?
The red dots indicate the mesh within the domain Ad, while the meshing along the blue line should occur in Ab.
I await your kind reply. Kindly ensure your well-being
I’m getting an error while solving the equations derived from the KKT conditions.
What syntax modifications should I make?
The decision variables are p1 and pr, with two constraints.
sheet: Q1_solve_equation.mw
I can't seem to find the "Stop Execution" symbol with the new Maple 2025.1 GUI.  Does anyone know where it went?
I was wondering why there is no longer a separate section for Maple Flow under the tab "Products". As syntax is not always the same between Maple and Maple Flow it would be nice to ask specific questions. Also why is there no suggestion tag for maple flow?
Thank you for any information
I installed a free trial of Maple 2025, but I can't seem to get the (simple) sample test.java script to run using OpenMaple. It compiles fine, but when I try to run it I get a Segmentation Fault error. I've ensured that the environmental variables, as described in the installation documentation, are given properly. The documentation/example in the installation refers to an old version of Maple, so I wondered if perhaps the free trial version does not have all of the updated components? I was hoping to test my project compatibility with OpenMaple before purchasing Maple.
My OS is Ubuntu 24.04, and I'm using Java 21. It would be nice to get everything running in IntelliJ eventually, but for now even trying to run in the terminal is problematic.
In thus manuscript i got some reviewer comment which is asked to simplify this expresion and there is a lot of them maybe if i do by hand i  made a mistake becuase a lot of variable so how i can fix this issue and make thus square root are very simple as they demand
B[2] := 0
K := sqrt(-(1/2)*sqrt(2)*sqrt(lambda*a[5]/a[4])+sqrt(-a[5]/(2*a[4]))*(B[1]*sqrt(-lambda)*sinh(xi*sqrt(-lambda))+B[2]*sqrt(-lambda)*cosh(xi*sqrt(-lambda)))/(B[1]*cosh(xi*sqrt(-lambda))+B[2]*sinh(xi*sqrt(-lambda))+mu/lambda)+sqrt(-(lambda^2*B[1]^2*a[5]-lambda^2*B[2]^2*a[5]-mu^2*a[5])/(2*lambda*a[4]))/(B[1]*cosh(xi*sqrt(-lambda))+B[2]*sinh(xi*sqrt(-lambda))+mu/lambda))*exp(I*(k*(xi+v*tau^alpha/alpha)+w*tau^alpha/alpha+gamma))
(1/2)*(-2*2^(1/2)*(lambda*a[5]/a[4])^(1/2)+2*(-2*a[5]/a[4])^(1/2)*B[1]*(-lambda)^(1/2)*sinh(xi*(-lambda)^(1/2))/(B[1]*cosh(xi*(-lambda)^(1/2))+mu/lambda)+2*(-2*(lambda^2*B[1]^2*a[5]-mu^2*a[5])/(lambda*a[4]))^(1/2)/(B[1]*cosh(xi*(-lambda)^(1/2))+mu/lambda))^(1/2)*exp(I*(k*(xi+v*tau^alpha/alpha)+w*tau^alpha/alpha+gamma))
simplify(K)
(1/2)*exp(I*((k*v+w)*tau^alpha+alpha*(k*xi+gamma))/alpha)*2^(3/4)*((lambda*(a[5]*(-lambda^2*B[1]^2+mu^2)/(lambda*a[4]))^(1/2)+(-B[1]*cosh(xi*(-lambda)^(1/2))*lambda-mu)*(lambda*a[5]/a[4])^(1/2)+sinh(xi*(-lambda)^(1/2))*lambda*(-a[5]/a[4])^(1/2)*(-lambda)^(1/2)*B[1])/(B[1]*cosh(xi*(-lambda)^(1/2))*lambda+mu))^(1/2)
subsindets(K, `&*`(rational, anything^(1/2)), proc (u) options operator, arrow; (u^2)^(1/2) end proc)
latex(%)
\frac{\sqrt{-2 \sqrt{2}\, \sqrt{\frac{\lambda  a_{5}}{a_{4}}}+\frac{2 \sqrt{-\frac{2 a_{5}}{a_{4}}}\, B_{1} \sqrt{-\lambda}\, \sinh \left(\xi  \sqrt{-\lambda}\right)}{B_{1} \cosh \left(\xi  \sqrt{-\lambda}\right)+\frac{\mu}{\lambda}}+\frac{2 \sqrt{-\frac{2 \left(\lambda^{2} B_{1}^{2} a_{5}-\mu^{2} a_{5}\right)}{\lambda  a_{4}}}}{B_{1} \cosh \left(\xi  \sqrt{-\lambda}\right)+\frac{\mu}{\lambda}}}\, {\mathrm e}^{\mathrm{I} \left(k \left(\xi +\frac{v \,\tau^{\alpha}}{\alpha}\right)+\frac{w \,\tau^{\alpha}}{\alpha}+\gamma \right)}}{2}
KK := sqrt(-(1/2)*sqrt(2)*sqrt(lambda*a[5]/a[4])+sqrt(-a[5]/(2*a[4]))*(B[1]*sqrt(-lambda)*sinh(xi*sqrt(-lambda))+B[2]*sqrt(-lambda)*cosh(xi*sqrt(-lambda)))/(B[1]*cosh(xi*sqrt(-lambda))+B[2]*sinh(xi*sqrt(-lambda))+mu/lambda)+sqrt(-(lambda^2*B[1]^2*a[5]-lambda^2*B[2]^2*a[5]-mu^2*a[5])/(2*lambda*a[4]))/(B[1]*cosh(xi*sqrt(-lambda))+B[2]*sinh(xi*sqrt(-lambda))+mu/lambda))*exp(I*(k*(xi+v*tau^alpha/alpha)+w*tau^alpha/alpha+gamma))
(1/2)*(-2*2^(1/2)*(lambda*a[5]/a[4])^(1/2)+2*(-2*a[5]/a[4])^(1/2)*B[1]*(-lambda)^(1/2)*sinh(xi*(-lambda)^(1/2))/(B[1]*cosh(xi*(-lambda)^(1/2))+mu/lambda)+2*(-2*(lambda^2*B[1]^2*a[5]-mu^2*a[5])/(lambda*a[4]))^(1/2)/(B[1]*cosh(xi*(-lambda)^(1/2))+mu/lambda))^(1/2)*exp((k*(xi+v*tau^alpha/alpha)+w*tau^alpha/alpha+gamma)*I)
latex(KK)
Download simplify.mw
5 6 7 8 9 10 11 Last Page 7 of 2433
