sols[11][1] = [1,1];
sols[11][2] = [1,2];
sols[11][3] = [5,10];
...etc
animate(plot, sols[11][A], A=1..20, frames = 20);
Error bad index into Vector
animate(plot, [sols[11]], A=1..20, frames = 20);
this writing can be ploted, but when i play animation, can not see it draw step by step
plot([[1,1],[10,20],[30,23],[12,30]]);
all lines are in the same color, but would like to specify the final line [30,23],[12,30] another color how to do?
plot3d([[1,3,5],[10,30,55],[50,70,25]]);
there is no lines in plot3d
plot can do this, plot3d seems different
plot([[1,1],[10,20],[5,7],[2,3]]);
Let L = {a1, a2, ..., an} (or L = [a1, a2, ..., an]) with is homogeneous polynomial. How to create function createDegree() return elements of degree <= n from L.
Expamle. L = {a-2b, b^2, (a+c)^2}.
createDegree(L,1) return {a - 2b}.
createDegree(L,2) return {b^2, (a - 2b)^2, (a+c)^2, a - 2b}.
createDegree(L,3) return {b^2, (a - 2b)^2, (a - 2b)^3, (a+c)^2, (a - 2b)b^2, (a - 2b)(a+c)^2, a - 2b}.
Thanks you very much.
Hello everyone!
Could somebody help me with reading data from Huge txt-file? My file contains matrix with 10 columns and 10^6 rows. Datatype is float[8].
I use "ImportMatrix" comand to obtain data from file, but it is rather slow ~ 33 sec.
is there an efficient way to read file directly using Maple? Or I should use C-dll to read file faster?
I want to calculate the ratio of the length of day and night for every latitude on earth ?
but i confused on using Maple in a wise way for finding the formula !
this is my demonstration :
shekofte000.mw
Equations
the grat circle that divides the earth's surface into two dark and bright sides
[sin(t)*cos(tilt), cos(t), sin(t)*sin(tilt)]
(1.1)
circle of revolving of a point on earth in 24 hours
[sin(t)*cos(Latitude), cos(t)*cos(Latitude), sin(Latitude)]
(1.2)
Visualization of dark and bright side the of earth
Explore(plots[display](plots[spacecurve]({[sin(t)*cos(tilt), cos(t), sin(t)*sin(tilt), color = red], [sin(t)*cos(Latitude), cos(t)*cos(Latitude), sin(Latitude), color = blue]}, t = 0 .. 2*Pi, scaling = constrained, thickness = 4, labels = [x, y, Latitudez], labeldirections = [horizontal, horizontal, vertical], axes = frame), plottools[rotate](plottools[hemisphere]([0, 0, 0], 1, capped = false, color = green, grid = [10, 10], style = surface), 0, tilt, 0), plottools[rotate](plottools[hemisphere]([0, 0, 0], 1, capped = false, color = black, grid = [10, 10], style = surface), 0, Pi+tilt, 0)), parameters = [tilt = 0 .. Pi, Latitude = -(1/2)*Pi .. (1/2)*Pi], initialvalues = [tilt = (1/2)*Pi+.409, Latitude = 1.16])
Download shekofte000.mw
As you see above, when I want to evaluate the definite integral, Maple can not provide the desired result. Why does this happen? How can I do so that Maple can calculate this integral?
Tryed to work this application, but problems encountered.
http://www.maplesoft.com/applications/view.aspx?SID=89020
http://www.mapleprimes.com/maplesoftblog/89021-The-Traveling-Salesmans-US-Roadtrip
I installed PostgreSQL, (i believe version 8.4 from 2010) which I found at "oldapps" (the current version is 9.6).
I'm running Win 7, 64 bit. Anyways, I have to change the paths below "Query the database":
driver := LoadDriver(classpath = "C://Program Files (x86)//PostgreSQL//pgJDBC//postgresql-8.4-701.jdbc4.jar");
conn := driver:-OpenConnection("jdbc:postgresql://localhost:5432/zip_codes", "postgres", "password");
I fail to see pgJDBC folder and a search for .jar files in the directory yields only 3 jar files, non resembling the above. tried example.jar
same error. heres a screenshot of my directory
Please i need help to plot the graph of f'' against episoln using the below BVP
HELP.mw
I want to plot the following equation
((1/2)*x*tan(log((1/5)*(2*(x^2+y^2)))) = y
I tried:
with(plots, implicitplot)
implicitplot((1/2)*x*tan(log((1/5)*(2*(x^2+y^2)))) = y, x = -5 .. 5, y =-5..5, numpoints = 1000, gridrefine = 6, color = red)
but result is strange...
How to change the numer of hatchings in a 3d plot?
Hello, I have a function defined as
                                                   g :=  (x, y)->diff(u1(x, y), x, x)+diff(u2(x, y), x, y).
I want to define another function as follows
                                                           f :=  (y) ->subs(x = 0, g(x, y)) ,
Now, when I want to calculate numerical values for the new function f(0), f(0.1), f(0.2),..... and so on. The following massage appear
Error, (in f) invalid input: diff received 0, which is not valid for its 2nd argument.
What is the problem here.
Amr
I'm curious to know if anyone has written a procedure to optimize the VRP with time windows / constraints.
I have a system of ode's
restart:with(plots):
eq1:=((diff(f(x),x$3)))+f(x)*diff(f(x),x$2)-a*diff(f(x),x$1)^2=0;
eq2:=(diff(g(x),x$2))+b*f(x)*diff(g(x),x$1)=0;
bc1:=f(0)=0,D(f)(0)=1,D(f)(5)=0,g(0)=0.5,g(5)=0;
dsolve can solve it easily.
sol:=dsolve(subs(a=0.5,b=0.5,{bc1,eq1,eq2}), numeric):
Now I was to use the numerical data from the sol in the following expression
Expr:=a*f(x)+b*g'(x)+c*f'(x)*g(x) # at x=1:
to make a table of this form a  b  c  Expr, where a, b, c vary simultaneously between 0 and 1 by 0.2 producing data for Expr.
Any suggestions?
Hi everyone!
I have a question: what is the simpliest way to generate colorbar for spectrogram?
Now I use "valuesplit" to assign dependece "z"-value from color.
My programm. My test file: "Signal.txt".
filtered_spectrogram.mw
Signal.txt
P.S. I use Maple 2016.
First 1063 1064 1065 1066 1067 1068 1069 Last Page 1065 of 2463
