Let us denote the cardinality of the subsets of {1,..,n} without two consequent numbers
(e.g. {..,4,5,..} is not allowed) by A[n]. What is the asymptotics of A[n] as n approaches infinity?
The same question for the case of three consequent numbers.
Here is my math experiment.
restart; L := combinat:-powerset({seq(i, i = 1 .. 11)}):#n = 11
nops(%);
2048
M := selectremove(c-> min([seq(c[k+1]-c[k], k = 1 .. nops(c)-1)]) = 1, L)[2]:
nops(M);
233
The other results are [11, 233], [15, 1597], [20, 17711], [21, 28657], [22, 46368].
These points are very close to some straight line in logarithmic scale as
plot([[11, 233], [15, 1597], [20, 17711], [21, 28657], [22, 46368]], axis[2] = [mode = log]);
shows. However, the ones do not exactly belong to a straight line:
evalf(ln(46368)-ln(28657), 15);
0.4812118247230
evalf(ln(28657)-ln(17711), 15);
0.48121182594077
eval(exp(.4812118247230*n), n = 15);
1364.000725  .
These results suggest that A[n] is asymptotically equal to exp(c*n) with c about 0.481.
I have not succeeded to find out the nature of the constant c.
question_on_asymptotics.mw
I need to solve an ode of the type ay''+by'+cy=f(x) using cubic b spline.
can any one help me with the code or algorithm. Thanks
N := 4;
4
y := sum(A[2*n].cos(2.*n.x), n = 0 .. N);
eq1 := diff(y, `$`(x, 2))+(a+2*q*cos(2*x))*y
eq2 := map(combine, eq1, trig)
for i from 0 to 4 do eq4[i] := coeff(eq2, cos(2*n*x)) end do
From these I want to extract the co-ffficients of cos(0x),cos(2x),cos(4x)..
and form a simultaneous linear equation containg A0,A2,A4
The solution is
aA0+qA2=0
2q*A0+(a-4)*A2+q*A4=0
Can anybody tell me how to do it
so I'm trying this:
sigma := 0.143e-18;
l_0 := 1.87;
l0 := 1.87;
roll := rand(0 .. 25.0);
f_gauss := proc (x) options operator, arrow; exp(-(1/2)*x^2/`σ_x`^2)/sqrt(2*Pi*`σ_x`^2) end proc;
f_norm := proc (dx) options operator, arrow; int(f_gauss(x), x = -(1/2)*dx .. (1/2)*dx) end proc;
sol_gauss := proc (mix) options operator, arrow; evalf(eval(-ln((int(f_gauss(x)*exp(-2*sigma*N2O*sqrt((1/4)*l_0^2-x^2)), x = -(1/2)*dx .. (1/2)*dx))/f_norm(dx))/(sigma*N2O), [N2O = 0.25e20*mix/100])) end proc;
for ii to 10 do
a := roll();
eval(sol_gauss(a), [dx = l_0, `σ_x` = l0])
end do
Hello people in mapleprimes,
I want to ask you about how to make a function of function which makes a logarithmic derivative of a function.
For example, x^3 is mapped as h(x^3)=3h(x), h(x+y)=(x/(x+y))*h(x)+(y/(x+y))*h(y),
h(g(x)*k(x))=h(g(x))+h(k(x)).
I hope someone give me a hing to create h.
Best wishes.
taro
environment
- Windows 10 LTSB 64-bit
- Intel Haswell/Skylake
sequence:
1. install Windows unattended
2. install scheduletask for software installation (runs with systemaccount on windows starts and available network)
3. task runs a cmdfile(1) that map a networkshare and runs another cmdfile(2) on the networkshare
4. cmdfile(2) runs softwareinstallation one by one, every install is a seperate cmdfile
5. cmfile(maple.cmd) starts maple installation with the following cmdline
START "Maple 2016" /WAIT "N:\Math\Maple\Maple2016Windowsx86Installer.exe" --mode unattended --desktopshortcut 0 --shortcutname "Maple 2016" --configureMatlab 0 --matlabpath "" --licenseType network --serverName "licserver.company.domain" --portnumber 27000
Note: licenseserver and port are configured correctly, tested with manual installation of Maple
effects:
- installer starts and install some files (found unter C:\ProgramFiles\Maple 2016)
- installer persists in memory
- no startmenuentry for maple found
- no installler logfile in maple directory found
- install not finished
- try it with --optionfile ... -> hangs
- try copying all files to local harddisk and run it from there -> hangs
- try it running with a local administrator (using psexec) -> hangs
- if im logged in and run the installer cmdline manually with adminconsole or with systemaccount (psexec -i -s -d cmd) the installation runs perfect, but this is not what i need to install hundreds of machines
Dear Community,
I have a complicated function with two independent variables, namely QD( tD,  rD ). I would like to explore its behavior in a semilog plot in the range of tD = 1.0 .. 1000.0 with changing rDs, where I would like to change the values of rD with a slider of the Explore command. I've developed the attached code, yet it gives me an error message, "unexpected option... " Could you pls. have a look at it what do I do wrong?
Tx for the kind help in advance
best regards
Andras
 Explore_VEHQD.mw
Can anyone tell me how to combine several graphs into one? Fo instance I have one graph with x going from 0-1,another with x going from 1-20 and yet another with x going from 20-21. I can plot them individually but how do I put all three together?
I'm sorry I'm not doing a very good job explaining, but I hope it is understandable.
Thanks to the help of several list members I managed to translate and update some old procedures.  These procedures were part of a packcage and they all had help files.   Here is an example
# E. Mendes - 25/04/94
`help/text/sampling`:=TEXT(``,
`FUNCTION: sampling - finds the discretized model`,
`CALLING SEQUENCE:`,
` sampling(f)`,
` sampling(f,k)`,
` sampling(f,k,vars)`,
`PARAMETERS:`,
` f - state space`,
` k - order of approximation`,
` vars - variables`,
`SYNOPSIS:`,
`- sampling(f,k) returns a discrete approximation for a continuous`,
` system`,``,
` dx(t)/dt=f(x(t),u(t)) `,
`EXAMPLE: `,``,
`> with(linalg):`,
`> f:=vector([x2,x3,-x1+x2^2+2*x3]):`,
`> sampling(f,1)`,
` 2`,
` [- x1, x2 + x1 ]`,``,
`SEE ALSO: fixpoind, fixpoinc`):
I have browsed the help documentation but I must confess I don't feel comfortable to modify the help database.  Do I have to wrap all the functions up as a package and then write the help files?   I am lost here.  Any help will be most welcome.
Many thanks
Ed
I would like to silmplify a trigonometric equation with some squares. I'm sure this equation can be reduced but i didn't manage to simplify it with Maple.
Here is the equation (named condition in the maple file) that I would like to simplify:
simplification_condition_de_compatibilité.mw
May you help me to simplify this trigonometric equation?
I would like simplification if time the pattern cos()^2+sin()^2 appears.
Thanks a lot for your help
Pick any point P and let Q = (1, 1, 1). [Your choice for P can be anything other than the origin or
Find an equation for the line l1 that passes through P and the origin. Plot the line segment formed by P and the origin in Maple
How would I plot this?
Please, I need assistance with this problem.
Here is the problem I am trying to solve:
with(PDEtools):
with(Student):
myPDE1 := D11*diff(w(x,y), x$4) + 2*(D12+2*D66)*diff(w(x,y), y$4) + D22*diff(w(x,y), x$2, y$2) - G*diff(w(x,y), x,y)= 0;
pdsolve(myPDE1);
pdsolve(myPDE1, build);
"Boundary conditions";
"(Note:the domain for the problem is a rectangle)";
bc1 := w(0,y) = 0; # @ x=0 edge;
bc2 := w(a,y) = 0;  # @ x=a edge;
bc3 := w(x,0) = 0; # @ y=0 edge;
bc4 := w(x,b) = 0; # @ y=b edge;
bcx1 := -D11*D[2](w)(0,y) - D12*D[2](w)(0,y) = 0; # @ x=0 edge;
bcx2 := -D11*D[2](w)(a,y) - D12*D[2](w)(a,y) = 0; # @ x=a edge;
bcy1 := -D12*D[2](w)(x,0) - D22*D[2](w)(x,0) = 0; # @ y=0 edge;
bcy2 := -D12*D[2](w)(x,b) - D22*D[2](w)(x,b) = 0; # @ y=b edge;
sol := [myPDE1, bc1, bc2, bc3, bc4, bcx1, bcx2, bcy1, bcy2];
pdsolve(sol);
"Note:
and D11, D12, D22, D66 and G are constant.
The intention is to find the critical value for G"
I need help with how I can handle the boundary conditions for the problem. Thanks a million.
I want to join two animations, but displayed subsequently, not simultaniously, As far as I got, I have:
plot2 := plots[animate](plot, [tau[1], z = -(1/2)*J .. (1/2)*J, color = red, legend = shear*stress], h = 1 .. 1+1/sqrt(3));
plot3 := plots[animate](plot, [tau[2], z = -(1/2)*h .. (1/2)*h, color = red, legend = shear*stress], h = 0 .. 1);
display([plot2, plot3], insequence = true);
my functions are difined as
tau[1] := h-1+(4/3)*(1/sqrt(3)-h+1)*sqrt(3)*(sqrt(3)*((1/4)*J^2-z^2)/(J^2*b))
tau[2] := (4/3)*sqrt(3)*((1/4)*h^2-z^2)/(h^2*b)
Both plots work individually, however, they have successive ranges. I wondered if I could make 1 plot, with an if statement wether to plot tau[1] or tau[2] depending on where the animation is in the range h. Does anyone know about a solution?
I need  some examples s.t. the computation of their lexicographic Groebner basis is heavy?
Thank you so much.
First 1107 1108 1109 1110 1111 1112 1113 Last Page 1109 of 2463
