> restart:with(plots):blt:=7:
> lambda:=2:m:=3:s:=1:
> Eq1:=(diff(f(eta),eta,eta,eta))+(f(eta)*(diff(f(eta),eta,eta)))-((diff(f(eta),eta))^2)+lambda*(((f(eta)*(diff(f(eta),eta,eta,eta))))-2*(diff(f(eta),eta))*(diff(f(eta),eta,eta,eta))^2)-(M/(1+m^2))*((diff(f(eta),eta)+ms))=0;
> Eq2:=(diff(h(eta),eta,eta))+(f(eta)*(diff(h(eta),eta)))-((diff(f(eta),eta))*(h(eta)))+lambda*(((f(eta)*(diff(h(eta),eta,eta,eta))))+(h(eta)*(diff(f(eta),eta,eta,eta)))+(diff(f(eta),eta,eta))*(diff(h(eta),eta))-2*(diff(f(eta),eta))*(diff(h(eta),eta,eta))+(M/(1+m^2)))*(m*(diff(f(eta),eta)-h))=0;
> Eq3:=((f(eta))*(diff(theta(eta),eta)))+Pr*((diff(theta(eta),eta,eta)))=0;
> bcs1 := f(0) = 0, (D(f))(0) = 1, (h)(0) = 0, (theta)(0) = 1, (D(f))(blt) = 0,  h(blt) = 0, theta(blt) = 0, D(D(f))(blt) = 0, (D(h))(blt)=0;
> L := [1,2,3];
> for k to 3 do R := dsolve(eval({Eq1, Eq2, Eq3, bcs1}, M = L[k]), [f(eta),h(eta),theta(eta)], numeric, maxmesh=10000, output = listprocedure);;Y || k := rhs(R[3]); YA || k := rhs(R[6]);YB || k := rhs(R[5]);YC || k := rhs(R[4]);YD || k := rhs(R[7]);end do:
for example is there an existing package for reducing groups of matrices like the one below to only its unique elements, or do i basically need to use  linear algebra matrix operations ie finding the basis of the set via echeleon reduction blah blah
{Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = -673/2880}), Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = -5/96}), Matrix(2, 2, {(1, 1) = 0, (1, 2) = -(2521/17920)*Zeta(5), (2, 1) = 0, (2, 2) = -(2521/17920)*Zeta(3)-2087/1920}), Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0}), Matrix(2, 2, {(1, 1) = 0, (1, 2) = -(7/320)*Zeta(5), (2, 1) = 0, (2, 2) = -(7/320)*Zeta(3)-499/840})}
i want a scheme of fractional differential equation so that i solve my questions and make a code of it.
please provide me the scheme
I was learning about Maple, but I do not understand this code below. This does not look correct.
http://www.maplesoft.com/support/help/Maple/view.aspx?path=Task/ConvertExpressionToFunction
When I type it on my worksheet, I get these errors
Sometimes I wonder if any one at Maplesoft actually looks at their own help web pages and try to use them, or is just the poor users who do that.
I noticed Maple gives different order of term (but still correct) when variable y or z is used, vs. other letters in this computation.
In this example below, integral results are given, using one letter of the alphabet at a time in the integrand.
Only when the variable is y or z, Maple shows expression in different form from all the others (negative sign pulled out). The result are correct ofcourse, but was wondering why this hapens only for these two variables? I would have expected that variable name (letter used) should not make any difference to the final form.
interface(rtablesize=infinity):
chars:=[seq(parse(StringTools:-Char(i)),i=97..122)]: #generate a..z variables, may be there is better way?
Matrix([seq([chars[i0],simplify(int((c0^2 - c1^2)/(chars[i0] - x0+I*c3), x0))],i0=1..nops(chars))]);
Gives (this below. Notice the very last 2 entries below)
Is this something common in Maple? Does it depend on the computation being performed? Can a user do something to tell Maple not to change order/form of expression depending on what variable letter is used?
hi
please help me for dsolve differential equations...after much time dont answer!!!
thanks..
dsolve.mw
Digits := 15; SYS := [.16783*h1(theta)-0.96238e-3*(diff(h1(theta), theta, theta))+0.61603e-1*(diff(h2(theta), theta))+0.14870e-4*(diff(h2(theta), theta, theta, theta))-.23703*h3(theta)-0.84431e-3*(diff(h3(theta), theta, theta))+3.4919*10^(-7)*(diff(h1(theta), theta, theta, theta, theta)) = 0, 2.3940*h2(theta)-.35329*(diff(h2(theta), theta, theta))-0.68260e-1*(diff(h1(theta), theta))-0.16526e-4*(diff(h1(theta), theta, theta, theta))+3.0808*(diff(h3(theta), theta))-0.17833e-2*(diff(h3(theta), theta, theta, theta)) = 0, 9.4813*10^(-7)/((1.+1.5802*10^(-8)*h3(theta))*ln(10.+1.5802*10^(-7)*h3(theta))^2)-3.1867/((1.-0.26556e-1*h3(theta))*ln(10.-.26556*h3(theta))^2)-7.6530/((1.-0.31888e-1*h3(theta))*ln(10.-.31888*h3(theta))^2)-4.2551/((1.-0.35459e-1*h3(theta))*ln(10.-.35459*h3(theta))^2)-9.0315/((1.-0.37632e-1*h3(theta))*ln(10.-.37632*h3(theta))^2)-4.6587/((1.-0.38822e-1*h3(theta))*ln(10.-.38822*h3(theta))^2)-9.4520/((1.-0.39384e-1*h3(theta))*ln(10.-.39384*h3(theta))^2)+0.74999e-1/((1.+0.12500e-2*h3(theta))*ln(10.+0.12500e-1*h3(theta))^2)-.69143/((1.-0.28810e-2*h3(theta))*ln(10.-0.28810e-1*h3(theta))^2)-.12945/(1.-0.38836e-1*h3(theta))^4-0.38260e-1/(1.-0.11478e-1*h3(theta))^4-0.24826e-1/(1.-0.37240e-2*h3(theta))^4+0.74712e-3*(diff(h3(theta), theta, theta, theta, theta))+2.6337*10^(-8)/(1.+1.5802*10^(-8)*h3(theta))^4-0.27242e-1*(diff(h3(theta), theta, theta))-3.0707*(diff(h2(theta), theta))+0.17833e-2*(diff(h2(theta), theta, theta, theta))-.23618*h1(theta)-0.84126e-3*(diff(h1(theta), theta, theta))-0.89222e-1/(1.-0.26767e-1*h3(theta))^4-.21340/(1.-0.32010e-1*h3(theta))^4-.13154/(1.-0.19732e-1*h3(theta))^4-0.88519e-1/(1.-0.26556e-1*h3(theta))^4-4.7454/((1.-0.39545e-1*h3(theta))*ln(10.-.39545*h3(theta))^2)-0.36390e-1/(1.-0.10917e-1*h3(theta))^4-1.3100/((1.-0.10917e-1*h3(theta))*ln(10.-.10917*h3(theta))^2)-.89374/((1.-0.37240e-2*h3(theta))*ln(10.-0.37240e-1*h3(theta))^2)-1.3773/((1.-0.11478e-1*h3(theta))*ln(10.-.11478*h3(theta))^2)-.11820/(1.-0.35459e-1*h3(theta))^4-.26259/(1.-0.39388e-1*h3(theta))^4-4.7356/((1.-0.19732e-1*h3(theta))*ln(10.-.19732*h3(theta))^2)+28.586*h3(theta)-.21258/(1.-0.31888e-1*h3(theta))^4-9.4531/((1.-0.39388e-1*h3(theta))*ln(10.-.39388*h3(theta))^2)-4.6603/((1.-0.38836e-1*h3(theta))*ln(10.-.38836*h3(theta))^2)-9.0393/((1.-0.37664e-1*h3(theta))*ln(10.-.37664*h3(theta))^2)-4.2631/((1.-0.35526e-1*h3(theta))*ln(10.-.35526*h3(theta))^2)-7.6824/((1.-0.32010e-1*h3(theta))*ln(10.-.32010*h3(theta))^2)-.25088/(1.-0.37632e-1*h3(theta))^4-.12919/(1.-0.19378e-1*h3(theta))^4-.11842/(1.-0.35526e-1*h3(theta))^4-.12941/(1.-0.38822e-1*h3(theta))^4+0.20833e-2/(1.+0.12500e-2*h3(theta))^4-0.19206e-1/(1.-0.28810e-2*h3(theta))^4-4.6507/((1.-0.19378e-1*h3(theta))*ln(10.-.19378*h3(theta))^2)-.26255/(1.-0.39384e-1*h3(theta))^4-.13182/(1.-0.39545e-1*h3(theta))^4-.25109/(1.-0.37664e-1*h3(theta))^4-3.2120/((1.-0.26767e-1*h3(theta))*ln(10.-.26767*h3(theta))^2) = 0]
ode2 := diff(SYS[2], theta); SYS2 := {ode2, SYS[1], SYS[3]}; bcs2 := {h1(0) = 0, h1(1) = 0, h2(0) = 0, h2(1) = 0, h3(0) = 0, h3(1) = 0, ((D@@1)(h1))(0) = 0, ((D@@1)(h1))(1) = 0, ((D@@1)(h3))(0) = 0, ((D@@1)(h3))(1) = 0}; bcs22 := eval[recurse](convert(SYS[2], D), `union`({theta = 1}, bcs2)); res2 := dsolve(`union`(`union`(SYS2, bcs2), {bcs22}), 'maxmesh' = 2024, numeric, method = bvp[middefer], range = 0 .. 1, abserr = 0.1e-3, output = listprocedure)
Download dsolve.mw
Can you tell me the signification of the number 5 in output below.
Input: maximize(x^2+3,x=-1..2,location)
Output: 7,{[{x=2},5]}
how can solve using assume option ?
F(z):=m*z^4-4*m*z^3+(3*m+3)*z^2-6*u;
solve(F(z),z assuming -0.5<m<0.5, 0<u<0.5)
Error, `<` unexpected
Download assume.mw
This sequence has a special name does anyone know what it is? i mean id look it up on oeis but unfortunately the asthetics of their presentation dont meet my strict standards, so yes i did work out an expression for it but if anyone knows the easiest in a singular expression.. very helpful right now.
1, 1, 2, 2, 3, 3, 4, 4, 5, 5
Let q be  a real  different to one and for a fixed positive integer  n  given also
Let x and y satisfies the condition
x*y -q*y*x=1
I will assume that the product is not commutative in all my computation
We would like to write the following function using only y
f(x,y)= x*y^n-q^n*y^n*x
all computation done I get f(x,y)=(q^n-1)/(q-1)*y^(n-1)
But how can I get the same result using Maple
Thank you very much for any help
Im trying to copy my collegues work, he uses mathcad and I use maple. I have a problem when trying to solve a system of 7 equations and 7 unknows. For some reason he dosent seem to get the same problem of "Error, recursive assignment".
You can see a screen shot of his solution here:
http://i.imgur.com/U7nE7sU.png
And you can see my solution here:
http://i.imgur.com/vrBTLIY.jpg
As you can see the code dosent work, is there anyone that could help me understand why eactly this happens and how to fix this?
Best Regards
Ivan N
Could someone please explain to me why the procedure GraphTheory:-CycleBasis requires that the vertices of a graph be integers for it to work correctly ?
(while the definition of a graph supports other types of vertex names)
with(GraphTheory):
#------------------------------------------------------- test 1
g1 := Graph({{"a", 1}, {1, 3}, {"a", 3}});
DrawGraph(g1);
CycleBasis(g1);
Error, (in GraphTheory:-CycleBasis) cannot determine if this expression is true or false: "a" < 1
#------------------------------------------------------- test 2
g2 := Graph({{a, 1}, {1, 3}, {a, 3}});
CycleBasis(g2);
Error, (in GraphTheory:-CycleBasis) cannot determine if this expression is true or false: a < 1
#------------------------------------------------------- test 3
g3 := Graph({{4, 1}, {1, 3}, {4, 3}});
CycleBasis(g3);
[[1, 3, 4]]
Knowing this limitation I usually rename to integers the vertices of the graphs, next do some operations, and next go back to the original names.
Thanks for any explanation.
Hy Prof.
Please help me or guide me to get idea to solve Nonlinear coupled PDEwith MAPLE.Dr.Sam Dao could please help me as I saw your YOUTUBE lecturer which very helpful to me and please give some idea about my topic.
pde[1] := diff(u(x, t), t)-D(diff(u(x, t), x, x)) = alpha*u(x, t)*(1-v(x, t))
pde[2] := diff(v(x, t), t)-E(diff(v(x, t), x, x)) = beta*v(x, t)*(1-u(x, t))
Thanks in advance and answer is highly appricaited
I have to draw a couple of graphs in Maple 2016. Certain subgraphs must be highlighted and the commands
HighlightEdges() and HighlightSubgraph() are very useful. It seems to me however, that while I can choose the color
of any given edge, it is not possible to change the style or the thickness of the edge. All the edges in my graphs are straight l
ine segments but I do not know if it is possible to have a different style than solid, and/or a different thickness for that matter.
Ideally, I would like to be able to draw certain edges as dot, or dash, or any other options that are available for regular
plotting.
Does anybody know if this can be done, and if it is possible, how should I do it.
Dan
First 1120 1121 1122 1123 1124 1125 1126 Last Page 1122 of 2463
