I am curious, can simplify/siderels be executed in mod p by some equivalent Maple function call?
Hi, I have the equations (below) with different parameters. I'd like to find out if is it possitble to:
(1) Create a loop that solves for values of on of the parameters, T, in the interval -0.3<T<0.3 and obtain the solutions allowing for a grid of 0.01.
That is, if one can first solve for T= -0.3 and then use the loop with increments that raise T by 0.01 each time until T=0.3. Other parameters are held constant at their assigned values.
(2) Generates the corresponding vectors for T and all the endogenous variables.
eq1 := PI_T = alpha*M*(kappa/(1+kappa-sigma)-1):
eq2 := l = alpha*((sigma-1)*kappa/(1+kappa-sigma)+1):
eq3 := M = phi_c^(-kappa)*F:
eq4 := e*F = PI_T*v+T:
eq5 := M*l+L_A = L_s:
eq6 := F*e+A = A_s:
eq7 := A = (1-beta)*(L_s+(1-v)*PI_T-T):
eq8 := A_s = L_A:
eq9 := p = sigma/((sigma-1)*phi):
eq10 := P_Y = M^(lambda/(1-sigma))*p:
eq11 := L_s = N*(theta*P_Y^beta)^(-1/delta):
eq12 := phi = (kappa/(1+kappa-sigma))^(1/(sigma-1))*phi_c:
eq13 := U = delta*theta*L_s/((1+delta)*P_Y^beta)+((1-v)*PI_T-T)/P_Y^beta:
Params:= [ T=0, N = 1, v = 1, beta = .75, lambda = 1, sigma = 5, kappa = 4.8, delta = 2, theta = 2.591350635, alpha = 0.3998699153e-1, e = 0.8333333332e-1]:
Init_Values:= {A_s = .2500000000, l = .9996747882, PI_T = 0.8333333332e-1, L_A = .2500000000, phi = 1.878101496, M = .4168022157, A = .1666666667, p = .6655657336, P_Y = .8283396488, L_s = 2/3, phi_c = 1.2, F = 1, U = 1.326439132 }:
SOL:= fsolve(eval({eq||(1..13)}, Params), Init_Values);
Many thanks!!
Hello there,
Suppose I have a parametric experssion like   P(ε)=1+ε+ε2+ε3 where ε is very small. How can I get P(ε)≈1+ε or P(ε)≈1+ε+ε2?
I would like to remove from a table, the index that verifies some constraint.
For example :
a := table([1=c, 2=g, 3=y]);
for k in [indices(a, `nolist`)] do
  if is(k, even) then
    a[k] := 'a[k]':
  end if:
# This does not work as expected
eval(a);
I have found this workaround
b := map(u -> if `not`(is(u, even)) then u=a[u] end if, [indices(a, `nolist`)]);
eval(b);
But is there a way to force Maple to evaluate k to 2 before it "unevaluate"  'a[k]' ?
I would like to know , what is the command that i able to carry out (simple one) such that I able to shaded the region between y=x^2 and y-axis from y= 0 to y=4.
Hi all
If I have an expression:
B := int(A(x), x = -infinity .. infinity)
How can I use a statement to extract A(x) when A(x) is quite complecated during calculation. thanks
" there were problems during the loading process. your worksheet may be incomplete"
I have seen some other people having this problem, I have tried to erase the bad characters myself but I can't seem to do it right. Can someone pleeeease help me? :(
https://drive.google.com/file/d/0B5FKHYOiyQ0jMk9XNzBYU3FDbzQ/view?usp=sharing
Hello.
int(floor(x^2), x = 0 .. 2) = 6 , but it should be 1.85374.
Bug_in_integrate(floor_and_ceil).mw
Mariusz Iwaniuk
With the following equation
eqn:=y=1/2+(1/2)*erf((1/2)*sqrt(2)*(x-mu)/sigma)-exp(-lambda*(x-mu)+(1/2)*lambda^2*sigma^2+ln(1/2-(1/2)*erf((1/2)*sqrt(2)*(lambda^2*sigma^2-lambda*(x-mu))/(lambda*sigma))));
and with
x:=solve(eqn,x) assuming sigma > 0, lambda > 0;
I got the following solution
x := -(1/2)*(-lambda^2*sigma^2-2*lambda*mu+2*RootOf(-exp(_Z)*erf((1/4)*sqrt(2)*(lambda^2*sigma^2+2*_Z)/(lambda*sigma))+exp(_Z)+erf((1/4)*sqrt(2)*(-lambda^2*sigma^2+2*_Z)/(lambda*sigma))+2*y-1))/lambda;
In order to get rid of RootOf I gave the command:
allvalues(%);
However, RootOf did not disappear. How should I proceed?
hi
if possible to convert matlab file in to maple fie program??convert_to_maple_program.txt
hi...how i can gain result for solve three equations,in which term '' Root of'' dont appear?
root.mw
restart; Q1 := aa*(y-x)
aa*(y-x)
Q2 := -ll*x*z+bb*x
-ll*x*z+bb*x
-ll*x*z+bb*x
Q3 := -cc*z+hh*x*x+kk*y*y
hh*x^2+kk*y^2-cc*z
SOLL := solve({Q1, Q2, Q3}, {x, y, z})
{x = 0, y = 0, z = 0}, {x = RootOf((hh*ll+kk*ll)*_Z^2-bb*cc), y = RootOf((hh*ll+kk*ll)*_Z^2-bb*cc), z = bb/ll}
Download root.mw
Hi all
How can I realize the following code in maple:
 EquCon := K[4]*(diff(W(x), x, x, x, x))-omega^2*W(x)
EquConFour := subs((1/2)*(int(W(kappa)*exp^(-J*kappa*x), kappa = -infinity .. infinity))/Pi, EquControl)
Thanks~
if you want a random interger between 0 and 100
what will be the command?
For implicitplot of say (cos(\theta))^2, I had to use 'factor' in the options for the plot so that it considers cos(theta) also while plotting. But I couldn't do the same in implicitplot3d. How can I achieve this plotting of all factors of a function for implicitplot3d?
First 1161 1162 1163 1164 1165 1166 1167 Last Page 1163 of 2470
