Hi everybody;
In the following attached file, I am trying to solve a system of nonlinear equations with one equality constraint. I have 9 equations and 9 unknowns. Attached file has composed of 3 main parts, first is input data, second is the 9 nonlinear equations from E_1 to E_9 and finally third part is constraint equation called C_1. My unknowns are "phi, theta, p, q, r, T, L, M and N". My question is that: Can Maple solve this problem?? Is there any solution to this problem or I have to change input data?? If Maple can solve this problem, how can I do that??
I appreciate your help in advance.
NL.mw
with(DEtools):
phaseportrait([secret], [a(t), b(t), c(t)], t = -2 .. 2, [[a(0) = 1, b(0) = 0, c(0) = 2]], stepsize = 0.5e-1, scene = [c(t), a(t)], linecolour = sin((1/2)*t*Pi), method = classical[foreuler]);
Error, (in DEtools/phaseportrait) the ODE system does not contain derivatives of the unknown function a
Hello guys, i have some problems.
i have system
\dot{x} = Ax + Bu
s=b*u =
now, we have X' = (A+S)X,  i need numeric/analytical solution and found Vector(X)
I have some problems with syntax maple.
Sorry for my bad english.
ricatti.mw
I am a student of an engineering career
The math teacher is going to ask us to solve some exercises Matlab
The teacher is very hard and explains nothing of Matlab in class
We must learn to use the program on our own viewing internet watching tutorials
I was wondering if somebody could help solve some exercises.
Are only three exercises which are imposible to me
I would appreciate it greatly.
My e-mail :
alessagosti1@gmail.com
I will try to be as specific as possible.
On my Ti nspire it is possible for me to calculate polar equations like on the buttom picture with the settings on the upper picture. But when I try this in Maple It is not possible. I have worked my way try for two days now and it does not work for me.
Does any body know how to get this solved?
Heide
I have two polynomials f(x,y,z) and g(x,y,z) and ask MAPLE to find conditions on the coefficients of f and g such that the Jacobian determinant in x and y is purely a polynomial in z. MAPLE finds 4 solutions, one of which is g=0, but does not find the solution f=0. I attach the relevant MAPLE worksheet.
How can I do to suppress all the complex components of a vector ? Is there a simple code to do this?
For example, I would like to replace the complex components with zero.
If the considered vector is a:= [2+I,2,5], i would like to obtain after modifications amod:= [0,2,5] ou amod  [Nothing,2,5]
VectorWithComplexComponents.mw
Nota :
The origin of my issue is to be able to plot points with the following syntax :
pointplot([tp,xp,symbol = solidcircle,color=black,symbolsize = 10): where xp is a vector with, sometimes, some complex components.
I would like to plot the points only for the real components of xp
Thanks a lot for your help
This question is related to the recent post
http://www.mapleprimes.com/questions/211460-Series-Of-Bessel-Functions
1. Consider the following fast convergent series:
f:=n->(-1)^(n+1)*1/(n+exp(n));
S1:=Sum(f(n),n=1..infinity);
evalf(S1);
S2:=Sum(f(2*n-1)+f(2*n),n=1..infinity);
evalf(S2);
As expected, the sum of the series is obtained very fast (with any precision), same results for S1 and S2.
2. Now change the series to a very slowly convergent one:
f:=n->(-1)^(n+1)/sqrt(n+sqrt(n));
evalf(S1) is computed also extremely fast, because the acceleration algorithm works here perfectly.
But evalf(S2) demonstrates a bug:
Error, (in evalf/Sum1) invalid input: `evalf/Sum/infinite` expects its 2nd argument, ix, to be of type name, but received ...
3. Let us take another series:
f:=n->(-1)^(n+1)/sqrt(n+sqrt(n)*sin(n));
Now evalf(S1) does not evaluate numerically and evalf(S2) ==> same error.
Note that I do not know whether this series is convergent or not, but the same thing happens for the obviously convergent series
f:=n->(-1)^(n+1)/sqrt(n^(11/5)+n^2*sin(n));
(because it converges slowly (but absolutely) and the acceleration fails).
I would be interested to know a method to approximate (in Maple) the sum of such series.
Edit. Now I know that the mentioned series
converges (but note that Leibniz' test cannot be used).
I am trying to have the output of DETOOLS as 3dpolarplot. As in the following example:
EF := {2*(diff(w[2](t), t)) = 10, diff(w[1](t), t) = sqrt(2/w[1](t)), diff(w[3](t), t) = 0}; with(DEtools); DEplot3d(EF, {w[1](t), w[2](t), w[3](t)}, t = 0 .. 100, [[w[1](0) = 1, w[2](0) = 0, w[3](0) = 0]], scene = [w[1](t), w[2](t), w[3](t)], stepsize = .1, orientation = [139, -106])
how can I get the output as a polarplot in 3d where, w[2] and w[3] have range 0..2*pi.
Please help in this respect asap.
I would like to obtain the display of several outputs from a procedure.
Sorry for this question which should be quiet simple but I didn't manage to solve my issue. By the past, I always wanted to obtain only one output from a procedure.
I put attached a example of procedure which calculates x^2 and x^3 for a given value of x.
With my procedure, I didn't obtain the display of the output calculating the square value.
How can I display all the outputs of a procedure ?
Thank you for your help
ExampleOfprocedure.mw
As a college project we have to implement the caesar cipher on maple but as beginners we haven't got a clue.
Any advice even on how to begin please?
I am using maple 13 to found Eingenvalues of an hermitian matrix :
M1:=Matrix([
> [lambda3+lambda4,0,0,0,0,0,lambda4/sqrt(2),0,0,I*lambda4/sqrt(2)],
> [0,lambda3/4,0,0,0,0,0,0,0,0],
> [0,0,lambda3/4,0,0,0,0,0,0,0],
> [0,0,0,lambda3/4,0,0,0,0,0,0],
> [0,0,0,0,lambda3/4,0,0,0,0,0],
> [0,0,0,0,0,lambda3,0,0,0,0],
> [lambda4/sqrt(2),0,0,0,0,0,lambda3/2,0,0,0],
> [0,0,0,0,0,0,0,lambda2,0,0],
> [0,0,0,0,0,0,0,0,lambda2,0],
> [-I*lambda4/sqrt(2),0,0,0,0,0,0,0,0,lambda4/2]
>Eigenvalues(M1);
my surprise is that maple gives me 8 correct solutions an 2 complex eigenvalues which are not acceptable (we now that the eigenvalues for an hermitian matrix are all real) .
To understand the output of maple, first,  I suspect that the complex part of the roots was null but without success I haven't found how to do it zero...
is it a bug? Thanks a lot to cooperation
I have .mla. package and I would like to create the source code associated to this package.
In the past, you have also help me to obtain the source code of procedure of the module.
Here the post where Carl Love has helped me :
http://www.mapleprimes.com/questions/203676-Open-A-Maple-Package
How can I do to create the complete source code of package directly ?
Is there a direct way enabling to not have to read one procedure by one procedure but to obtain the code source for all the package ?
Environment: Maple2015, MATLAB_R2014b(MacOSX10.8.5), 2015b(MacOSX10.11.4)
MapleToolbox2015.1MacInstaller.app was successfully completed (log tells us), but when MATLAB were booted, following error messages appeared and symbolic operations of maple failed.
This would be closely related to maple installation on MATLAB as such errors never occur for clean install of MATLABs and looks independent on OSX versions. Now javaforosx.dmg in use by instruction of Maplesoft.  Something wrong is in Maple2015. Note maple-MATLAB link works normally.
Please provide us with direction of how to fix it hopefully by Maplesoft professionals.
(Quote of MATLAB command window display)
Exception in thread "Startup Class Loader" java.lang.UnsatisfiedLinkError: jogamp.common.os.MachineDescriptionRuntime.getPointerSizeInBytesImpl()I
at jogamp.common.os.MachineDescriptionRuntime.getPointerSizeInBytesImpl(Native Method)
at jogamp.common.os.MachineDescriptionRuntime.getRuntimeImpl(MachineDescriptionRuntime.java:138)
at jogamp.common.os.MachineDescriptionRuntime.getRuntime(MachineDescriptionRuntime.java:124)
at com.jogamp.common.os.Platform.<clinit>(Platform.java:228)
at javax.media.opengl.GLProfile.<clinit>(GLProfile.java:83)
at com.mathworks.hg.peer.JavaSceneServerPeer.initializeJOGL(JavaSceneServerPeer.java:114)
at com.mathworks.hg.peer.JavaSceneServerPeer.<clinit>(JavaSceneServerPeer.java:100)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:190)
at com.mathworks.mde.desk.StartupClassLoader.loadClass(StartupClassLoader.java:258)
at com.mathworks.mde.desk.StartupClassLoader.access$900(StartupClassLoader.java:25)
at com.mathworks.mde.desk.StartupClassLoader$2.run(StartupClassLoader.java:244)
at java.lang.Thread.run(Thread.java:745)
>> maple();
error: maple (line 178)
Invalid MEX-file '/Applications/MATLAB_R2014b.app/toolbox/maple/maplemex.mexmaci64':
dlopen(/Applications/MATLAB_R2014b.app/toolbox/maple/maplemex.mexmaci64, 6): Symbol not found: ___sincos_stret
  Referenced from: /Library/Frameworks/Maple.framework/Versions/2015/bin.APPLE_UNIVERSAL_OSX/libhf.dylib
  Expected in: /usr/lib/libSystem.B.dylib
 in /Library/Frameworks/Maple.framework/Versions/2015/bin.APPLE_UNIVERSAL_OSX/libhf.dylib
>> syms x  y
error: sym (line 186)
 error: sym (line 56)
           assignin('caller',varargin{i},sym(varargin{i}));
(Unquote)
How i need to write
>teksbiasa:=`Hello! Bob`;
in button Action When Clicked at simple graphical interface instead of
Do(teksbiasa=%txtTeksBiasa);
because when i enter Hello! Bob in %txtTeksBiasa, system pop up ERROR
Error
Error in Component button with caption "Botton":
(in unknown) incorrect syntax in parse: missing operator or
`;`(near 7th character of parsed string)
Thank you~=]]
First 1168 1169 1170 1171 1172 1173 1174 Last Page 1170 of 2463
