I have a complex equation EQ, it gives me 4 answers - two complex, one negative and one positive. Which assumptions do i need to use to automatically get one answer - real and positive one?
I tried similary to what I did with real equations:
simplify(solve(EQ)) assuming real, positive
But that didn't work
How do i make output (that blue part i get after pressing Enter) go in one line? Sometimes it's easier to look at one line of answer (even if it is longer than all other parts of the documents) than to look through row after row of equations.
And also - is there a way to hide output? There are many not important equations and i want to see only a few plots and a result. How do i hide outputs - because when i just delete them - maple deletes associated variables.
objectiveproc := proc(mmm)
return Trace(abs(M));
with(Optimization):
i := 0:
t := 1:
Minimize(objectiveproc(x)-abs(Trace(abs(MA))));
Error, (in objectiveproc) invalid subscript selector
I have still some difficulties to conduct some specific trigonometric simplications but which are very common in mechanism study.
The equations are in the form :
sin(gamma0(t))*cos(beta0(t)) = -(sin(psi[1](t))*cos(theta[1](t))*cos(gamma[1](t))+sin(psi[1](t))*sin(theta[1](t))*sin(gamma[1](t))-cos(theta[1](t))*cos(psi[1](t))*sin(gamma[1](t))+cos(psi[1](t))*sin(theta[1](t))*cos(gamma[1](t)))*cos(beta[1](t))
I would like to obtain this equation after simplifications :
sin(gamma0(t))*cos(beta0(t)) = cos(beta[1](t))*sin(gamma[1](t)-theta[1](t)-psi[1](t))
I try to make a procedure to automatize the simplification of this kind of trigonometric equation.
Strangely, I noticed that the simplification is done only if there is a minus before the combine function. The simplification works but the result is wrong because i didn't obtain the good sign.
For you information, I try to make these simplifications with MMA and the FullSimplify function of MMA gives directly the expected result that is to say :
I'm sure that it shoud exist a good way to conduct this kind of simplications in Maple.
Can you help me to correct my procedure so to obtain the good result and be enough general, adaptative ?
Code here and attached in this post :
Initialisation
with(Student[MultivariateCalculus]):
with(MathML):
with(ListTools):
constants:= ({constants} minus {gamma})[]:
`evalf/gamma`:= proc() end proc:
`evalf/constant/gamma`:= proc() end proc:
unprotect(gamma);
Angular Constraint equations
eq_liaison:=sin(gamma0(t))*cos(beta0(t)) = -(sin(gamma[1](t))*sin(psi[1](t))*sin(theta[1](t))-sin(gamma[1](t))*cos(theta[1](t))*cos(psi[1](t))+cos(gamma[1](t))*sin(psi[1](t))*cos(theta[1](t))+cos(gamma[1](t))*cos(psi[1](t))*sin(theta[1](t)))*cos(beta[1](t));
Traitement
TrigoTransform2:= proc(Eq)
local S,S1,tt,pp,Eq2,ListVariables,ListVariablesMod,Subs,size,rhsEq2,lhsEq2;
#Construit une liste à plat#
ListVariables:=indets(Eq, function(identical(t)));
ListVariables:=[op(ListVariables)];
ListVariablesMod:=map(f->cat(op(0,f),_),ListVariables);
Subs:=ListVariables=~ListVariablesMod;
#Variables Changement#
Eq2:=Eq:
print("Equation traitée=",Eq2):
Eq2:=subs(Subs, Eq2);
print("Equation après subs=",Eq2):
#Trigonometric transformations#
lhsEq2:=applyrule([
cos(u::anything)*cos(v::anything)-sin(u::anything)*sin(v::anything)=cos(u+v),
cos(u::anything)*sin (v::anything)+sin(u::anything)*cos(v::anything)=sin(u+v),
sin(u::anything)*sin(v::anything)-cos(u::anything)*cos(v::anything)=-cos(u+v),
-sin(v::anything)*cos(u::anything)-sin(u::anything)*cos(v::anything)=-sin(u+v)], simplify(lhs(Eq2), size));
print("Equation lhsEq2 première analyse=",lhsEq2):
rhsEq2:=applyrule([
-sin(v::anything)*cos(u::anything)-sin(u::anything)*cos(v::anything)=-sin(u+v)], simplify(rhs(Eq2), size));
print("Equation rhsEq2 première analyse=",rhsEq2):
try
lhsEq2:=(trigsubs(2*combine(lhsEq2))[])/2;
print("Equation lhsEq2=",lhsEq2):
catch:
lhsEq2:=lhs(Eq2);
end try;
try
rhsEq2:=(trigsubs(-2*combine(rhsEq2))[])/2;
print("Equation rhsEq2=",rhsEq2):
catch:
rhsEq2:=rhs(Eq2);
end try;
Eq2:= lhsEq2=rhsEq2;
Eq2:=subs(map(t->rhs(t)=lhs(t),Subs),Eq2)
TrigoTransform2(eq_liaison);
TrigoTransformEqAng2_anglais.mws
Thanks a lot for your help.
A small question : what does [] mean at the end of a function or a list ?
Thank you for your help
Please help to plot radial solution "U" in n-sphere of radius "R"   such that
R in [0,1] and "t" is a parameter varying in [-1,0[. I started with
restart; n:=3: Sn:=2*Pi^2:
R0:=(n+2)*sqrt(8*Pi/2*Sn); p:=-2*n/(n+2):
U := unapply(piecewise(R<R0, (-t)^p*(R0^2-R^2)/(n+2), 0), R);
For the iterators package on Maple 2016 the graphic below was used.  Because it was used, it had to have been created with Maple, right?
Was that done with Maple?  If so, how?
I have recentry constructed Fourier amplitude and Fouier Power graphs which are plotted against the frequency of the oscillations, like the picture below.
I would like to change the frequency scale along the x axis into a period scale in order to Fourier analyse future ODE systems in  terms of period rather than frequency.
But I unsure how to manipulate my code to do so.
Any help would be much apreciated, and the Maple file that I am using is attached.
Thanks in advance!
Fourier_with_Period.mw
Hi, I'm having trouble with print doing strange things:
a:=1235
                1235
b:=751
                751
p:=1601
                1601
print(The solution `to` a^x = b (`mod ` p) is x = 1323)
                              1601 The solution to (1235^x) = 751 mod is x = 1323
Why has the 1601 gone to the beginning, and how do I make it go to the correct place?
Also is it possible to remove the brackets from around 1235^x?
And is it possible to make the brackets (that I have put in) go around the `mod` p?
EDIT:
If I do: print(The solution `to` a^x = b (`mod ` ,p) is x = 1323)
I get:  The solution to (1235^x) = 751 (mod, 1601) is x = 1323
So is there a way to just remove the comma on the output?
In my code, I need to use 2 packages :
- with(LinearAlgebra)
- with(ListTools)
Problem :
It seems that the package with(ListTools) creates some troubles/ conflicts when I use some functions of the LinearAlgebra package such as DotProduct.
Here a small example to illustrate my issue
with(MathML):
DotProduct(<0,0,l>, <0,0,l>, conjugate = false);
--> This code works
with(MathML):
with(ListTools):
--> This code doesn't work
I try to replace the line with the DotProduct by the following line but it still doesn't work
with(LinearAlgebra):-DotProduct(<0,0,l>, <0,0,l>, conjugate = false));
How can I do to use in my code both packages (LinearAlgebra and ListTools) ?
Hello :-),
How can I differentiate the follwing function:
Cq = Cao*k1*t / [(1+k1*t)*(1+k2*t)]
If want to find the maximum:
dCq/dt = 0
I can solve if of course by hand. The solution is t=1/sqrt(k1*k2)
I tried it with maple, but I got a strange result (see picture). How can I use maple to get the right result?
Thank you very much!
Consider the following lines:
eqs := {x - a*y,y - a*x};
sol := solve(eqs,y);
In general, sol will be NULL, but if a2=1 then the equations can be solved. How can such side relations be implemented in connection with solving?
PS: The above example is of course a grossly simplified one.
Note added: Perhaps it would be prudent to mention that the variable 'a' above is intended to be a symbolic place holder for some operator acting on some functions x,y, and having square equal to the identity map; it is not simply some algebraic number. The equations should thus be solved for x,y using a2=1, without having assigned anything to 'a' itself. For the simple example above, this can be done using the function eliminate, as suggested by Axel Vogt, but for more complicated cases, its success seems quite unlikely: for one thing, how can one determine, by looking at the set of equations, which variables can or should be eliminated?
I am using maple 13 to get the result of the einstein field equations,
with(tensor)
Estn := Einstein(metric, RICCI, RS);
displayGR(Einstein, Estn);
How can I put the result on an array element, so I can use it later on?
The following integral appears in the recent SEEMOUS 2016 competition:
Int( arctan(x) * ln(1+1/x^2), x = 0..infinity );
Maple 2015 can compute it, but with a little help.
What about Maple 2016?
How can I get maple to express the end result more compact/dense. Like for example in the picture, why can the program not just sum up all the fractions and everything in one number?
First 1195 1196 1197 1198 1199 1200 1201 Last Page 1197 of 2471
