Hi, I'm new to Maple and I have to produce a recursive procedure with the nomenclature Puis:=proc(X,n::integer) which calculates X^n with:
for n<0   ->   1/(X^(-n))
for n=0  ->   1
for n being an even integer   ->   X^(n/2) * X^(n/2)
for n being an odd integer   ->   X*X^(n-1)
The procedure I produced is:
option remember;
if n<0 then Puis(X,-n);
elif n=0 then 1;
elif rem(n,2,x)=0 then Puis(X,n);
else X*Puis(X,n-1);
i don't have any eror up to this point, but when I try to evaluate, only Puis(4,0) works
Puis(4,-1);
Error, (in content) too many levels of recursion
Puis(4,0);
Puis(4,3);
Puis(4,4);
I was wondering what was wrong with my procedure, I changed the 1/(X^(-n)) with X^n and X^(n/2)*X^(n/2) for X^n because it is equivalent. I think I should put some sort of initial value to limit the recursion, but with that kind of function i really don't know how. I also tried with the X^(n/2)*X^(n/2) for the even numbers, but it says Puis expects its 2nd argument, n, to be of type integer, but received 1/2.
Hello everyone!
This is a procedure which I have writern. I know I write false, X=x because in maple, x is a table.although I did write x::Vector. Can you help me? Sorry, my English is not very good! :(
JACOBI.mw
I''m looking to complete the following, and then use the 2nd to find what n for which Fn is divisible by f(3),  not sure where to start..any help much appreciated..
proc(f::procedure,s::posint,r::posint,c::posint)
description
"Indicate divisibility of f(n) by s for n <= cr.",
"Write 'D' for divisible, else 'n'; r rows and c cols.";
local i, j, str, char;
for i from 0 to r-1 do
str := "";
for j from 1 to c do
if (f(c*i+j) mod s) = 0 then
str := cat(str,"D")
str := cat(str,"n")
end if
print(str)
end do
end proc; # s_div_f
proc(s::posint,r::posint,c::posint)
description
"Indicate divisibility of Fib(n) by m for n <= cr.",
---MORE STUFF HERE---
end proc; # s_div_fib
I am using the solve command and the independent variables are in the form x=x. How can I output the solution as a list [set of solutions,independent variables]? The command select(z->symbol=symbol,S), where S is my set of solutions, does not work.
Hello everybody,
I would like to know if there's a possibility to change the style of the errorbars in errorplot. I would espacially like to add short lines at both ends of each errorbar, orthogonal to those, similiar to the looks of errorbars in GNUplot.
I appreciate your help. Many thanks in advance!
Piecewise function in Maple are continuous function. Now, how I able to write the commands for following discontinuous piecewise function?
and when find out f(0) the result is undefined?
InputMatrix3aa := Matrix(3, 3, {(1, 1) = xx, (1, 2) = 283.6, (1, 3) = 285.4, (2, 1) = 283.6, (2, 2) = 285.4, (2, 3) = 0, (3, 1) = 285.4, (3, 2) = 0, (3, 3) = 0});
InputMatrix3 := Matrix(3, 3, {(1, 1) = 283.6, (1, 2) = 285.4, (1, 3) = 283.0, (2, 1) = 285.4, (2, 2) = 283.0, (2, 3) = 0, (3, 1) = 283.0, (3, 2) = 0, (3, 3) = 0});
InputMatrix3b := Matrix(3, 3, {(1, 1) = 285.4, (1, 2) = 283.0, (1, 3) = 287.6, (2, 1) = 283.0, (2, 2) = 287.6, (2, 3) = 0, (3, 1) = 287.6, (3, 2) = 0, (3, 3) = 0});
InputMatrix3c := Matrix(3, 3, {(1, 1) = 283.0, (1, 2) = 287.6, (1, 3) = 296.6, (2, 1) = 287.6, (2, 2) = 296.6, (2, 3) = 0, (3, 1) = 296.6, (3, 2) = 0, (3, 3) = 0});
InputMatrix3d := Matrix(3, 3, {(1, 1) = 287.6, (1, 2) = 296.6, (1, 3) = 286.2, (2, 1) = 296.6, (2, 2) = 286.2, (2, 3) = 0, (3, 1) = 286.2, (3, 2) = 0, (3, 3) = 0});
Old_Asso_eigenvector0 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3aa), InputMatrix3aa)):
Old_Asso_eigenvector1 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3)):
Old_Asso_eigenvector2 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3b), InputMatrix3b)):
Old_Asso_eigenvector3 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3c), InputMatrix3c)):
Old_Asso_eigenvector4 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3d), InputMatrix3d)):
#AA2 := MatrixMatrixMultiply(Old_Asso_eigenvector3[2], MatrixInverse(Old_Asso_eigenvector2[2]));
#AA3 := MatrixMatrixMultiply(Old_Asso_eigenvector4[2], MatrixInverse(Old_Asso_eigenvector3[2]));
AA2 := MatrixMatrixMultiply(Old_Asso_eigenvector2[2], MatrixInverse(Old_Asso_eigenvector1[2]));
AA3 := MatrixMatrixMultiply(Old_Asso_eigenvector3[2], MatrixInverse(Old_Asso_eigenvector2[2]));
sol11 := solve([Re(AA2[1][1]) = sin(m*2+phi), Re(AA3[1][1]) = sin(m*3+phi)], [m,phi]);
if nops(sol11) > 1 then
sol11 := sol11[1];
end if:
sin(rhs(sol11[1])+rhs(sol11[2]));
sol12 := solve([Re(AA2[1][2]) = sin(m*2+phi), Re(AA3[1][2]) = sin(m*3+phi)], [m,phi]);
if nops(sol12) > 1 then
sol12 := sol12[1];
end if:
sin(rhs(sol12[1])+rhs(sol12[2]));
sol13 := solve([Re(AA2[1][3]) = sin(m*2+phi), Re(AA3[1][3]) = sin(m*3+phi)], [m,phi]);
if nops(sol13) > 1 then
sol13 := sol13[1];
end if:
sin(rhs(sol13[1])+rhs(sol13[2]));
sol21 := solve([Re(AA2[2][1]) = sin(m*2+phi), Re(AA3[2][1]) = sin(m*3+phi)], [m,phi]);
if nops(sol21) > 1 then
sol21 := sol21[1];
end if:
sin(rhs(sol21[1])+rhs(sol21[2]));
sol22 := solve([Re(AA2[2][2]) = sin(m*2+phi), Re(AA3[2][2]) = sin(m*3+phi)], [m,phi]);
if nops(sol22) > 1 then
sol22 := sol22[1];
end if:
sin(rhs(sol22[1])+rhs(sol22[2]));
sol23 := solve([Re(AA2[2][3]) = sin(m*2+phi), Re(AA3[2][3]) = sin(m*3+phi)], [m,phi]);
if nops(sol23) > 1 then
sol23 := sol23[1];
end if:
sin(rhs(sol23[1])+rhs(sol23[2]));
sol31 := solve([Re(AA2[3][1]) = sin(m*2+phi), Re(AA3[3][1]) = sin(m*3+phi)], [m,phi]);
if nops(sol31) > 1 then
sol31 := sol31[1];
end if:
sin(rhs(sol31[1])+rhs(sol31[2]));
sol32 := solve([Re(AA2[3][2]) = sin(m*2+phi), Re(AA3[3][2]) = sin(m*3+phi)], [m,phi]);
if nops(sol32) > 1 then
sol32 := sol32[1];
end if:
sin(rhs(sol32[1])+rhs(sol32[2]));
sol33 := solve([Re(AA2[3][3]) = sin(m*2+phi), Re(AA3[3][3]) = sin(m*3+phi)], [m,phi]);
if nops(sol33) > 1 then
sol33 := sol33[1];
end if:
sin(rhs(sol33[1])+rhs(sol33[2]));
AAA1 := Matrix([[sin(rhs(sol11[1])+rhs(sol11[2])),sin(rhs(sol12[1])+rhs(sol12[2])),sin(rhs(sol13[1])+rhs(sol13[2]))],[sin(rhs(sol21[1])+rhs(sol21[2])),sin(rhs(sol22[1])+rhs(sol22[2])),sin(rhs(sol23[1])+rhs(sol23[2]))],[sin(rhs(sol31[1])+rhs(sol31[2])),sin(rhs(sol32[1])+rhs(sol32[2])),sin(rhs(sol33[1])+rhs(sol33[2]))]]);
MA := MatrixMatrixMultiply(Transpose(InputMatrix3aa), InputMatrix3aa) - lambda*IdentityMatrix(3):
eignvalues1 := evalf(solve(Determinant(MA), lambda)):
MA1 := MatrixMatrixMultiply(Transpose(InputMatrix3aa), InputMatrix3aa) - eignvalues1[1]*IdentityMatrix(3):
MA2 := MatrixMatrixMultiply(Transpose(InputMatrix3aa), InputMatrix3aa) - eignvalues1[2]*IdentityMatrix(3):
MA3 := MatrixMatrixMultiply(Transpose(InputMatrix3aa), InputMatrix3aa) - eignvalues1[3]*IdentityMatrix(3):
eigenvector1 := LinearSolve(MA1,<x,y,z>):
eigenvector2 := LinearSolve(MA2,<x,y,z>):
eigenvector3 := LinearSolve(MA3,<x,y,z>):
MR := MatrixMatrixMultiply(AAA1, Matrix([[Re(eigenvector1[1]),Re(eigenvector2[1]),Re(eigenvector3[1])],[Re(eigenvector1[2]),Re(eigenvector2[2]),Re(eigenvector3[2])],[Re(eigenvector1[3]),Re(eigenvector2[3]),Re(eigenvector3[3])]]));
ML := Re(Old_Asso_eigenvector1[2]);
solve(ML[1][1] = MR[1][1], xx);
with(Optimization):
Minimize(ML[1][1] - MR[1][1], {0 <= xx}, assume = nonnegative);
Error, (in Optimization:-NLPSolve) abs is not differentiable at non-real arguments;
when one of element in matrix s variable below code is very slow
MA := MatrixMatrixMultiply(InputMatrix3aa - lambda*IdentityMatrix(3);
eignvalues1 := evalf(solve(Determinant(MA), lambda));
MA1 := MatrixMatrixMultiply(InputMatrix3aa - eignvalues1[1]*IdentityMatrix(3);
MA2 := MatrixMatrixMultiply(InputMatrix3aa - eignvalues1[2]*IdentityMatrix(3);
MA3 := MatrixMatrixMultiply(InputMatrix3aa - eignvalues1[3]*IdentityMatrix(3);
eignvector1 := LinearSolve(MA1,<x,y,z>);
eignvector2 := LinearSolve(MA2,<x,y,z>);
eignvector3 := LinearSolve(MA3,<x,y,z>);
Need to create a fibonacci defintiion using this form..Any help appreciated..thanks in advance
The Fibonacci numbers Fn are defined for all positive integers n as follows:
Fn = ( 1,                 n =1, 2 , )
      (Fn−1 + Fn−2 , otherwise.)
 Complete the definition of fib so that fib(n) returns Fn for all positive integers n. You must compute Fn using the below definition! A recursive proc is most natural.
fib:=
proc(n::posint)
description "Calculate fib(n), the n'th Fibonacci number.";
option remember; # important for efficiency!
end proc; # fib
I need to complete the definition of P km using a for loop so that km(n,m) returns n k=1 k m whenever n, m ∈ Z, n > 0, and m ≥ 0.( You must use a for loop in the variable k, with k ranging from 1 to n, to do this question in the manner requested.)
km is defined as
km:=
proc(n::TYPE1,m::TYPE2)
description "km(n,m) returns the sum of k^m as k ranges from 1 to n.";
end proc; # km
Not sure where tostart..Any help appreciated...thank you
Tried different ways to apply unapply but failed:
a := .1994;
modfit3 := a*x^1.5;
f := unapply(rhs(modfit3), x);
Error, invalid input: rhs received .1994*x^1.5, which is not valid for its 1st argument, expr
What's wrong here?
S
Exercise: Find all the elements of order 2 in D30 .
I set the D30 group , but I do not know how to calculate and list elements of order 2 . I thought of calculating the order of all the elements ( With PermOrder () command , perhaps) , and then use the select command to select those with order of 2. But the big problem is to calculate the order of elements.
I know only calculate the order of the group. Could anyone help me ?
I'm trying to create a routine to perform the test of rational roots , but I'm having some problems. Below is the routine I created :
But the program is only printing " aux = -24 " . I don't know what it can be .
I need to modify my code , but I don't know where. Can someone help me? Thank you!
Hi Everyone,
I want to draw a 3D cylindrical object with follwoing constraint:
(1) For z=0 to 5, it should be a cylinder with radius 2 units
(2) For z = 10 to 20, it should be a cylinder with radius 8 units
(3) Connecting piece between z=5 to 10 is a type of cylinder such that its radius increses from 2 to 8 as z moves from 5 to 10.
I know how to draw (1) and (2) individually, but can't make a connecting object.
Can anyone help me drawing that object?
How can I integrate the value of different k values in the plot function, instead of assigning values to k before giving the plot comman? Can't see anything about this in the help file.
staffan
First 1238 1239 1240 1241 1242 1243 1244 Last Page 1240 of 2471
