For the life of me I can not get maple to plot this equation.  I have poured over various resources and it simply isn't working.  I have gone so far as to use SIMPLIFY and even  Re(circuitSix) and Im(circuitSix) yet still get only errors.  Any insight would be appreciated.
I want to make a nested loop and store the data(with complex numbers) in matrix in order to make 3D plot.
The function hypergeom([2/3,2/3,2/3],[-1/3,4/3],z) has radius of convergence 1 and real coefficients.
But Maple tells me evalf(hypergeom([2/3, 2/3, 2/3], [-1/3, 4/3], 99/100),50);
is -138.999 + 0.0012 I
It should be more like −138.9962313171333091754979138344422738025
(Maple 18, version 991181)
G A Edgar
Hi everyone,
I would like to create an eBook with the pakage "eBookTools", but I have got several errors if in my mw document there is a table. The same error came out if I try to compile a book with the sample documents ("GettingStartedWithMaple.mw"). Anyone knows a solution?
Thank you for your time
Giorgio
a1 := Matrix(3, [1, 2, 3, 7, 8, 9, 13, 14, 15]);
a2 := Matrix(3, 2, [5, 6, 11, 12, 17, 18]);
a3 := Matrix(2, [19, 20, 25, 26]);
i want to combine above matrices in big matrix like
A := Matrix(2, 2, [a1, a2, a3, a4]);
best regards
I am using Maple-9 to simplify the expression and the expression is not having numerical coefficients. Example expression is given below.
a2:=(18*d^2*R^2*r-4*d1^3*r+5*R^6-z1*r^3*p-14*r1^3*r*rc+k1*d^2*R^2*r);
The question here is: I want to collect all "positive terms" and "negative terms" and assign to new variable.
Please suggest steps for the above problem
Thank you in advance.
hello
when i weite this expression
diff(1/(6*t+1)+x(12*t+1)/(6*t+1)^2, t)
then it give an ans
-6/(6*t+1)^2+12*(D(x))(12*t+1)/(6*t+1)^2-12*x(12*t+1)/(6*t+1)^3
i want to solve it completly,but it give another darivative D(x) which is inside of the the equation.
how can i solve this D(x)
I am trying to define iso surfaces mathematically. From teh output of a numerical simulation, I have a 3d field of a parameter called MF. So, MF = MF (x,y,z).
So, when I have MF = constant, I will hypothetically have the equation for a surface called x = f(y,z). As I said it's the output of a simulation so I don't have a defined function for MF. Now, I wanted to calculate the surface area on a constant value of MF. I know that the way to calculate a surface is: integral of(1=Fx^2 +Fy^2)^0.5. on the other hand I know that MF = 11, everywhere on the surface. I am trying to come up with an expression for surface area, based on special derivatives of MF. I started by assuming a potential field for MF, but I didn't get to a conclusion and got a little confused. I would greatly appreciate any comments or helps.
Haley
Occasionally I am at a computer where I can't install or use the free Maple player.  I would like to be able to simply view a worksheet, something like a worksheet viewer would be nice.  Online Maple player would be nice too but the worksheet viewer should be easier to implement, wouldn't it?
I want to work (cross products, differentiating and simplificating) of three dimensional vector functions.
But I'd like to work with them as vector, not as components. Is it available in Maple?
Bubble := proc (X::list)
local n, i, j, t;
n := nops(X);
if n = 0 then ERROR("empty list") end if;
for i to n-1 do
   for j to n-i do
      if X[j+1] < X[j] then
          t := X[j];
          X[j] := X[j+1];
          X[j+1] := t;
print(X);
end proc
I make bubble sort algorithm. but i can't find 'illegal use of a formal parameter'.
The following integral
f := u-> int(-1/(x*sqrt(-1+u^2*(x+1)^2*x^2)), x = (1/2)*(-u-sqrt(u^2-4*u))/u .. (1/2)*(-u+sqrt(u^2-4*u))/u);
arised in an applied research. I was asked about its properties:
plot on RealRange(4,infinity), limit(f(u),u=4,right), limit(f(u),u=infinity).
Unfortunately, I lost a file. As far as I remember it, I have had a problem with
the last-named one only:
limit(f(u), u = infinity);
MultiSeries:-limit(f(u), u = infinity);
asympt(f(u), u, 2);
Error, (in asympt) unable to compute series
Hope my colleagues will make progress with it. The assumed value is Pi/2.
Of course, with Maple. This object is described in Wiki.
Its plot looks like
Also the 2d Gaussian free field is of great interest. As far as I understand it, a one-dimensional Gaussian random field is formed by the
Finance[GaussMarkovProcess] command of Maple.
PS. The googling brings, in particular, http://mathematica.stackexchange.com/questions/4829/efficiently-generating-n-d-gaussian-random-fields.
I'm trying to use the stats graph feature in Maple 17, but I do not know how to change the x-axis in a bar graph. The values that are default are 1, 2, 3,... but I would like to have words instead. Any idea how to do this?
First 1262 1263 1264 1265 1266 1267 1268 Last Page 1264 of 2464
