  I have a complicated task. Suppose there is a file, its content is
A    3
0.8 0.2
0.6 0.3
0.5 0.4
A   3
0.8 0.2
0.6 0.3
0.5 0.4
  I want to read the file for each line, and store the content in each variable, e.g. "S" and 3 for two different variables, respectively.
By using
Nn:=readline("file");
Nn2:=readline("file");
Nn3:=readline("file");
parse(Nn);
parse(Nn2);
For N2, it does not work "Error, incorrect syntax in parse: unexpected number (near 6-th character of parsed string)"
How to read such a file properly including varies of content? Thanks a lot!
Int(piecewise(t < T1, exp((1/2)*t*(1+2*I-I*sqrt(3))), t < T2, -1000*exp((1/2)*t*(1+2*I-I*sqrt(3)))*(-1/1000+T1-t), T2 <= t, -1000*exp((1/2)*t*(1+2*I-I*sqrt(3)))*(-1/1000-T2+T1)), t)
The help of maple software is not so clear , and I cant understand the exact way which leads to exporting a matrix from maple to matlab. more precisely how I can link between maple and matlab .
would you please with an example show me the rule.
I just wanted to ask whether one can get out of the expansion
(D-f(x))@@2(g)(x)=(D@@2)(g)(x)-(D((f(x))(g)))(x)-((f(x))(D(g)-(f(x))(g)))(x)
the intended result
(D@@2)(g)(x)-D(f*g)(x)-f(x)*D(g)(x)+f(x)^2*g(x)
Here is a simple example to explain my problem:
I would like to have a break after the first graph and with return
the loop shoul continue to the next and so on.
Thank you for your help!
Test:=proc()
    plot(x^j,x=-2..2):
for j from 1 to 3 do
   Test()
Hi Edgardo/Others,
I'm not sure if any more development work is being done on the physics package or not. But I've gotten back to playing around with the great tetrad package you've developed.
Specfically, I'm calculating spin connections for various metrics. I've run into a few troubles, and have written a simple example showing some calculations that don't match my expectations.
This is by no means urgent, and if you are no longer developing the package, you can ignore this post.
Hopefully you can follow the code, I've commented on the issues I have, summary:
1. Checking the tetrads match the minkowski metric when contracted with the curved metric.
2. I build a tensor Gamma_mu (represents spin connection for a covariant derivative) which contains non-commuting gamma matricies (ideally dirac gamma's). I then try and contract this tensor with another non commutating tensor (dirac gamma matrix) using SumOverRepeatedIndices(). Unless I'm mistaken, this function doesn't preserve the anticommuting nature of the tensor components.
Cheers.
Correcting_-_Tetrads.mw
Can we rotate 3d text in Maple like this shown here?
http://mathematica.stackexchange.com/questions/25065/rotating-3d-text
Let us consider the definite integral
J:=int(abs(x-(-x^5+1)^(1/5)), x = 0 .. 1);
Maple fails with it, Mathematica 10.1 finds it in terms of  special functions. Let us look at the integrand:
plot(x-(-x^5+1)^(1/5), x = 0 .. 1);
We see the expression under the modulus changes its sign at the unique point of RealRange(0,1). Therefore
solve(x-(-x^5+1)^(1/5));
Then
J:= int(-x+(-x^5+1)^(1/5), x = 0 .. (1/2)*2^(4/5))+int(x-(-x^5+1)^(1/5), x = (1/2)*2^(4/5) .. 1);
which outputs a complicated expression
(1/8)*2^(4/5)*(4*hypergeom([-1/5, 1/5], [6/5], 1/2)-2^(4/5))+(1/2)*2^(4/5)*((1/2)*2^(1/5)-(1/4)*2^(4/5))-(1/25)*Pi*csc((1/5)*Pi)*(-(25/2)*sin((1/5)*Pi)*GAMMA(4/5)*2^(4/5)*hypergeom([-1/5, 1/5], [6/5], 1/2)/Pi+(5/4)*sec((3/10)*Pi)*cos((1/10)*Pi)*2^(3/5)*Pi^(1/2)*csc((3/10)*Pi)/GAMMA(7/10))/GAMMA(4/5).
At the same time we have
int(abs(x-(-x^5+1)^(1/5)), x = 0 .. 1, numeric);
                          0.5000000000
How to obtain 1/2 symbolically?
I am trying to integrate product of exp(t+s) and a piecewise polynomial but the result can not be read and not usefull. also I used numerical integration function "Quadrature" but the result did not change.
error.mwerror.mw
guys ,
in a differential equation i want to expand its variable, but i  have some problem with it for exponential term :jadid.mw
thanks guys
 Let M be a matrix with polynomial array f_i's such that any array is in K[a_1,..,a_m][x_1,..,x_n] where a=a_1,,,a_m are sequence of parameters and x=x_1,..,x_n are sequense of variables. Now, I want to extract the coefficients of  f_i that are in K[a_1,a_2,..,a_m]. For example if M=Matrix([[ax-bxy],[cx^2-dy]]) how can I extract the matrix coefficint C=Matrix([[a,-b],[c,-d]])?
Please note that a,b,c,d are parameters and x,y are variables.
Hi, I'm having a problem regarding this equation:
                                                           sum(v(i), i = 1 .. 28)
where, v is a Data Table created under the Components Tab with 28 Rows, and 1 Column.
I keep on getting an error of:
                                                     Error, unsupported type of index, i
I didn't use or declare 'i' in any part of the program.
Let's say I have something like
p1:=((a+b+c)*t + (a^2 + b^2)*t^3)*(c^3a^b + a*b)*t^2 + (1/(b^2 + a^3)) + b + 1/c^7)*t^7 = 0;
or something complicated like that.
Would it be possible to print the polynomail up to say order 3?
I want to be able to print
collect(expand(p1),t) up to order 3 and see the resulting coefficients
In the following worksheet, I can evaluate S(32), but not S(31). As a result, I can't use any value that depends on S(31) (or any i<31), for example, the graph is incomplete. How can I get Maple to evaluate S(31)?
sigma := 167:
t := proc (i) options operator, arrow; exp(-(1/2)*i^2/sigma^2) end proc:
S := proc (l) options operator, arrow; 1+2*(sum(t(i), i = l .. infinity)) end proc:
evalf(S(32))
356.9784188
evalf(S(31))
1.+2.*(sum(exp(-(1/55778)*i^2), i = 31 .. infinity))
Expected result of evalf(S(31)):
evalf(S(32)+2*t(31))
358.9442559
plot(S(y), y = 20 .. 50)
All told, S(i) fails for i in [0..31], i = 115,116, and 221. S(i) succeeds for all other i < 3500.
Download test.mw
First 1310 1311 1312 1313 1314 1315 1316 Last Page 1312 of 2471
