I want to increase the stack limit. but i can not raise it above the hard limit....
so i wonder whether there is a way to increase the hard limit, or at least tell me how much is it?
Why nothing changes?
I tried to use java to call maple command, but end up jvm crash. after some digging, i found the command i issued returned a rather huge string (around 40KB...).
Is this the reason why jvm crash? should i constrant the length of a command result when calling it from Java code?
I am writing here because of a problem with writing mathematical expressions in Maple T.A.. I have been using it since two years, and I have a lot if questions created in version 9.0 and 9.5. A few months ago my university installed T.A. 10. At the beginning there were problems with the connections between T.A. and the Maple server. After the administrators got over these, there were another problems.
There are a lot of questions where I use greek letters, for example Sigma. Earlier it was easy, I wrote
in the 'Algorithm' section, and I could write
in the Text of the question. The letter had a perfect italic and bold style, like as it would be created with Equation Editor.
Now I have to write
sig2=maple("MathML:-ExportPresentation($sig1)");
Could someone help me understand what is happening to this procedure. When I run it, I get the subject error. Thanks.
game := proc()
  local player1, player2, roll;
  roll := rand( 1..6 );
  player1 := roll():
  player2 := roll(2):
  if player1>player2 then "A wins"
  elif player1=player2 then "Tie"
  else "B wins"
Derive the orbit of the Moon around the Earth by doing a Verlet algorith of Molecular Dynamics simulation. Use one hour for your step τ. Place the stationary Earth at the origin of the Cartesian system. For initial conditions, use the position and the speed of the Moon when it is at its apogee (furthest from Earth). Plot the orbit.
Dear friends.
I need a simple approach for reading a specified line of a text file.
FileTools[Text] module allows to count the lines. By sequential reading of lines it's possible to reach any position in the file. But for large file this takes a lot of time.
FileTools[Position] allows to set/get position in the file, but the position is counted in bytes.
Are there any workarounds for the problem or the use of Database Package is more preferable?
Using with(Physics):
On an initial condition setting for using dsolve when I do D(theta)(0) it returns  0=0
I'll have to check tonight if it's a mistake on my part.  But perhaps that is supposed to happen.
please help check what's wrong with this code. I need the analytic solution and convert to Bessel but return error. Here is the worksheet ID_1.mw
Best regards.
this code not answer:
> whit*evalf; tx := evalf((t1+t2)*(1/2));
> t1 := 326*40; t2 := 327*40;
> y1, y2 := eval([y1, y2], Ns(t1), Ns(t2));
>while (t1 < tx) and (tx < t2) do:
yx := rhs(Ns(tx)[c2]):
if yx > 0 then
y2 := yx: t2 := tx:
y1 := yx: t1 := tx:
fi;
od;
>Tx = evalf(tx);
> Hx := floor((1/3600)*tx):
> Mx := floor((tx-3600*Hx)*(1/60)):
> Sx := tx-3600*Hx-60*Mx:
> Hx, Mx, Sx;
> XS := [seq(X[i], i = 0 .. 328)]: YS := [seq(Y[i], i = 0 .. 328)]:
> VxS := [seq(Vx[i], i = 0 .. 328)]: VyS := [seq(Vy[i], i = 0 .. 328)]:
> save(G,Mz,Xs,VxS,VyS, 'orbit.sav'):
 can you help me?
This might seem easy but i am a total beginner in Maple and i really need to know how to do this. If i have an expression like this:
X^2 + 3*y + 3*z + X^7
where (y) and (z) are constants of unknown values. I need to integrate the expression over an interval for example (from 1 to 10) so that the answer would still be in terms of (y) and (z).
Would anyone please help me and give me the right expression for writing this on Maple?
(a) Show that if {an} ∞ n=1 is Cauchy then {a 2 n} ∞ n=1 is also Cauchy. (b) Give an example of a Cauchy sequence {a 2 n} ∞ n=1 such that {an} ∞ n=1 is not Cauchy
Show that 2^3 + x ^2 − 3x + 2 is O(x ^3 ).
guys , i have a metric and i want to define a componenets of a tensor and then obtain its covariant derivative with respect to a metric, what is your idea ?
N_1=-A(r)^1/2 , A_2=A_3=A_4=0 , what is D_[nu] N_1 =?
 in general i want to define N[1]=-A(r)^(1/2) and N[2] = N[3]= N[3] = N[4] = 0 And define F[mu, nu] = 2*(D_[mu] N[nu]-D_[nu] N[mu]) And define Omega[mu, nu] = 2*(D_[mu] N[nu]+D_[nu] N[mu]) and compute expression F_[alpha, beta] F_[~alpha`, ~beta ] And N_[alpha] N_[~beta`] F_[ ~alpha, ~lambda ] Omega_[beta, lambda])
i have problem with this how to difine this tensorial terms and how to compute them.
Covariant.mw
thxxxx
Hi EveryOne!
In the the answer of the question "How to find k^th root of the given matrix over finite field (at URL: http://www.mapleprimes.com/questions/203997-How-To-Find-Kth-Root-Of-The-Given-Matrix#comment215683). Carl Love helped to find k^th root of the given matrix M over GF(2m)/f(x).
Now, I need to compute direct exponentiation of the given matrix M in finite field. (If M = [mi,j], we say Direct Exponent (element-wise exponent matrix), Mdk of M is a matrix whose each element is the result of exponentiation of corresponding elements of M. If k=2, then we say Md2 is a direct square matrix of M )
Please help me!!! Thank you very much.
First 1318 1319 1320 1321 1322 1323 1324 Last Page 1320 of 2471
