I'm making a simple for loop with a few lines.  I just figured out how to Shift + Enter to go to a new line without yet executing.  How do I indent my code on the next line, like in every other programming language ever made?  The Tab key does nothing.
Suppose N numbered cars start a race with starting positions N < ... < 4 < 3 < 2 < 1, car number 1 starting in front. (the car's index is the position on the starting grid) The race covers a total of L laps.
If two successive cars are in the position i < j, the probability that i overtakes j within 1 lap is P(i,j). This probability is independent of the position on the track and is constant throughout the race. For instance, if the starting positions...
Hi:
I have justdiscovered that the following "simplify" command gives the wrong answer on Maple 11. Could someone please check to determine if Maple 14 does any better?
> S1:=Sum(1/GAMMA(j+1)/GAMMA(2-j)*GAMMA(1+a-c+j)*GAMMA(1+a-b+j)/GAMMA(a-
> 1+j)*GAMMA(-2+b+c-j+n-a),j = 0 .. 1);
> Ans1:=simplify(S1);
My array contains numbers like
[ 0.333333 0.211111]
I used the command
interface(displayprecision=3)
and it is displayed  [ 0.333  0.211]   (which is ok).
However, when I send the output to latex
latext(%)
I get again [ 0.333333  0.211111].
How  could I display  only 0.333   after using LATEX(%)?
I have to prove a trig identity with Maple for class. It's rather simple, but I can't figure out how to get the right-hand side into the form I want. What I have is:
tan(x)^2*sin(x)^2 = sin(x)^4/cos(x)^2
I simply want to convert sin(x)^4/cos(x)^2 into tan(x)^2*sin(x)^2.
The conversion is apparent to anyone looking at it but I simply cannot figure out how to put it in the right form, and I can't change the left-hand...
I have those functions
M:=n->piecewise(And(n::integer,(n/p)::odd),((4*Br)/(mu0*Pi*(n/p)))*sin((Pi/2)*(n/p)),0);
W:=(n,r)->piecewise(And(n::integer,(n/p)::odd),(M(n)*r)/(mu1*(1-n^2)),0);
u1:=(r,theta)->sum((r^n*AI[n]+r^(-n)*BI[n]+W(n,r)*sin(n*theta0))*sin(n*theta)+(r^n*CI[n]+r^(-n)*DI[n]+W(n,r)*cos(n*theta0))*cos(n*theta),n = 1 .. nn);
diff(u1(r,theta),r);
Error, (in type/polynom) too many levels of recursion
I need to find a specific temperature which I named T2 to cross the zeroline in a plot but maple doesn't plot or give a solution at all. I'm very confused and also new with this software.
My code is as follows:
R = 8.314472;
> A = 1.935;
> B = 36.915*E-3;
> C = -11.402*E-6;
> P2 = 10*10^5;
> P1 = 101300;
> T1=365;
> Tc=425.1;
> Tw=T2/T1;
> Pc = 37.96*10^5;
> Pr1=P1/Pc;
I have got a question. I have an Hamiltonianfunctionand want to differentiate this function to all variables. There is no problem with most of the variables, but one doesn't work. The error above occures, when I use the button "execute the entire worksheet". When I just press Enter, the errror does not occure and the right results are presented. But I am not abel to use the results.
Has anyone an idea how I can solve this problem?
I do not have any experience with maple and have a homework assignment due tomorrow. I have been staring at a screen blankly for an hour now trying to research how to do this but have had no luck. Here is my problem...
compute the projection of w onto v. call proj w onto v "p" and let q be vector perpendicular to p so that p+q=w. plot all four vectors together.
I have no idea where to even begin. I can do this by hand but it's the computer stuff...
Hello.
After using my command FOR --DO (see the commands below of the attached file) I would like that appears only the last graphic ( and not the previous "plot"s neither the matrix ww).
How could be done it?
Thanks in advance,
Jean-Jacques.
#POUR FAIRE LE "FOR FROM BY TO DO"
max1:=60:
q:=1/2:
for w1 from 1/27 by 7/27 to 1/2 do
ww:= [seq( [n, add(1/(n+1), k=ceil(  max(0,(q-w1...
Hello, I am using maple 7 and I want to find all the solutions to a set of 4 equations with 4 variables.  These equations are all trigonometric.  fsolve of course only gives a single solution and using the avoid unction doesn't work.
I have tried to write something like this:
Sol1:=({equations},{vars})
Sol2:=({equations},{vars},avoid=Sol1)
and this always gives the same solution.  Any ideas?  Thank you.
Hey folks I have a question regarding how to fill an Array.
Lets say I do this...
Array(1..10, [seq(i, i=0..9)]);
This produces [0 1 2 3 4 5 6 7 8 9] as output which is fine.
Now lets say I want a 2x10 array (2 rows, 10 columns), the top row being the digits 0-9 (as above) and the second row being something else (in this case it is counting the number of times each digit appears in Pi)
I would like to use Maple to visualize some data produced by a computational geometry application I am working on.  However, my coordinate system is different than a standard cartesian system.  In my case, the positive Y direction is downward.
Can I re-orient the Y axis on a point plot to go downwards instead of upwards?
Greetings,
I want to solve the non linear recurrency system:
x[1](k*T+T) = x[1](k*T)+2*u[1]*psi*cos(alpha); x[2](k*T+T) = x[2](k*T)+2*u[1]*psi*sin(alpha); theta[0](k*T+T) = theta[0](k*T)+T*u[2];
with:
psi := piecewise(u2 <> 0, sin((1/2)*T*u[2])/u[2], (1/2)*T); alpha := theta[0]+(1/2)*T*u[2];
and u1 and u2 some functions of x1(kT) and x2(kT).
I tried to use the rsolve command but didn't work.
Can you help me, please? Is there some way to solve this?...
First 1945 1946 1947 1948 1949 1950 1951 Last Page 1947 of 2471
