I have a more relavant form of a question regarding procedures. I need to write a procedure with parameter f(x) and result in the plot of the function f(x) along with the plot of the curvature of f on the same graph. Ideally, parameter f(x) could be requested to be any function, such as x^2 or cos(x). I am new to procedures and do now know where to begin, even at such a basic level.
Any assistance greatly appreciated.
I am using Maple 14 and struggling with writing procedures. Here is an example of what I need to be able to program. I require a procedure which will receive as a parameter a function f(x) and plot that function (say in red) along with the curvature function (say in blue) on the same graph. Sample parameters include the functions f(x)=x^2 or sin(x) or exp(-x^2).
I feel somewhat confident in my maple commands, but procedures are a whole new thing to me. If even a basic...
I have those questions:
1) set
When I write these inputs,
x:={1,3,2}; y:={b,a,d,c}; z:={a[1],a[1,1],b[0],d[0],c[0],a[0],2};
the results are x := {1, 2, 3}, y := {a, b, c, d}, z := {2, a[0], a[1], a[1,1], b[0], c[0], d[0]}
Is there a way to get what I input
2) This problem in ordering numbers and words is verry important and hard when solving a large system of equations with:
restart:with(SolveTools): eqns:=[a[0...
The following simple procedure:
SubsColumn: = proc (A, V, k)
local B, m;
with (LinearAlgebra);
m: = ColumnDimension (A);
B: = <A[..,1..m]|V>;
B: = ColumnOperation (B, [k, m +1]);
B: = DeleteColumn (B, m +1);
B;
solve the problem of...
Could you please tell me, how can I model a varying stiffness spring using MapleSim 4?
I think, this can realized using a varying "c" parameter of a standard spring from the MapleSim library, but I don't know, how I can change the "c"-stiffness value during the modeling process.
Dear friends,
My following commands (MAPLE 14), generate the matrix zz1 (see below).
How could I get a plot with "n" (first column) in the "X-coordinate" and second/third and fouth columns in "Y-coordinate"?,
Thanks for your attention,
Jean-Jacques
interface(rtablesize=50):
f1 :=  (w1, w2,n) -> add(add(
 `if` (1/2 <= w1+j*w2+((1/n)*(1-w1-w2))*k and
why the results of two BessLk function is wrong? The results I got is negative,but it shouldn't be less than zero。For the same  integration expression, I use the mathematica, can get the right results.But when use maple,with the variable value's increasing,the results ranges from positive to negative.In fact, the result I got is outage probability,it should be positive.
What can be said about this divergent series:
 sum((cos(m)+I*sin(m))*(cosh(w)+sinh(w)),n=1 ..infinity) where m=Pi*n and w = ln(n)/n?
Calculate
int(cos(100*(x^4-x)), x = -infinity .. infinity)
with the relative error less than  10 percentages.
I use 'SystemConnect' command to connect two transfer function, as the following codes illustrated.
with(DynamicSystems);
sys1 := TransferFunction(10/(s*(s+10)));
sys2 := TransferFunction(k*s^2/(s+20));
Warning, improper transfer-function, degree(num) > degree(den)
sys3 := SystemConnect(sys1, sys2, connection = negativefeedback, outputtype = tf);
Error, (in unknown) cannot convert improper transfer function to state-space model
does anybody have experience with solving heat conduction for multi-layer domain?
the following command gives unrealistic results:
pdsolve(PDE,IBC, numerics)
Mo
I'm currently implementing the Poker test to determine whether a binary sequence possesses some specific characteristics that a truly random sequence would be likely to exhibit.
Maple can't solve the inequation `assuming`([solve(floor(160/m)>=5*2^m,[m])],[m::posint]);
However, `assuming`([solve((160/m)>=5*2^m,[m])],[m::posint]); works.
Is there a way to rewrite...
Hi friends,
I have this piecewise function:
restart:assume(n,integer):h := piecewise(n::odd, n^2, n^3);
I can not get explicitly the derivative:
diff(h,n);
But, with
restart:h1 := piecewise(And(n::integer, n::odd), n^2, n^3);
I can get the derivative explicitly:
diff(h1,n);
Why ?
k := 1:
alpha := vector([x*cos(theta), x*sin(theta), k*x]);
e1 := map(diff, alpha, theta);
e2 := map(diff, alpha, x);
G := matrix([[simplify(e1[1]^2 + e1[2]^2 + e1[3]^2), 0],[0, simplify(e2[1]^2 + e2[2]^2 + e2[3]^2)]]);
inv_e1 := evalm(1/G[1,1]*e1);
inv_e2 := evalm(1/G[2,2]*e2);
e11 := map(diff, e1, theta);
e12 := map(diff, e1, x);
e22 := map(diff, e2, x);
gamma_1_11 := simplify(evalm(e11&*inv_e1));
gamma_1_12 := simplify(evalm(e12&*inv_e1));
How to interpolate in terms of any form of algebra in maple?
For example, to interpolate a time series in terms of exponential or mixed with cos and sin?
First 1948 1949 1950 1951 1952 1953 1954 Last Page 1950 of 2470
