whats the difference between A.B and A&*B given that both A and B are matrices.
I would like to create a model of a sinngle pendulum with Maple 13
I began but I cannot manage to animate it
Here is what i have already written:
pendulum:=proc(l,initialAngle,initialSpeed)
local eq,sol,angledata,x,y,plotseq
eq:=diff(θ(t),t,t) + 9.81/l sin(θ(t)) = 0;
sol:=dsolve({eq,θ(0)=initialAngle,D(θ)(0)=initialSpeed},θ(t),numeric);
I am trying to get the equation of a line. I have a buch of points and need the equation of a line going through those points. I am making computer program that can finde the y value of any point on the line with the equation I'm trying to get and an X value.
So, I have some points,..
I can get the graph,..but not the equation for that graph...
Is this posable,...?? I can't seem to find out how...
(I put in the points Im using just as are ference)
I don't find an easy way to do what follows.
I've a list of names, with assumptions on them, eg:
assume(a,real);
assume(b,real):
parameters:=[a,b]
then I try do to something like
i:=0;
for what in parameters do
temp:=i;
assign(cat('crlb_', what), temp);
i:=i+1;
end do
because I want to create variables which keep a trace of the parameters they describe in the last part of their name.
ifplease how can i factorise in powers of (x-xn), the expression  y(t):=(1/3h2)[(-x+xn+h)(-x+xn+3h)]yn+(1/3h2)[(-xn+x)(-x+xn+4h)]yn+1 -(1/3h)[(-xn+x)(-x+xn+3h)]fn+2?
i was trying to familiarize with maple 13 but encountered this. pls how may i go out from here?
> with(Student[NumericalAnalysis]);
> DE1 := d*y(t)/dt = y(t)-t^2+1;
                           d y(t)           2
I need to differentiate a postion vector with respect to time and extract the theta dots in the following http://img543.imageshack.us/img543/3079/positionvector.jpg
Many Thanks
How I can, with the help of maple, perform the following demonstration using rsolve?
From Equation : Y(t)=1 +A t + B t2 + D t3
recursively determine t, by equation:
How can I plot this piecewise function:
for j from n-1 by -1 to 0 do
... does some processing that's not really relevant to the question:
s[j] := evalf(a[j]+b[j]*(t-x[j])+c[j]*(t-x[j])^2+d[j]*(t-x[j])^3)
S := t-> piecewise(
x[0] <= t and t <= x[1], s[0],
x[1] <= t and t <= x[2], s[1],
x[2] <= t and t <= x[3], s[2]);
My friends all...
Hi I would like to know how to traverse all terms in a polynomial. I've constructed formal polynomials out of abstract objects. They are all linear, without any cross terms. So I could have something like this:
f = 2a + 3b - c +8z
Ultimately I want to construct a table with the frequency of each element showing up in a random set of polynomials.
I Have a proc that creates some very long lists.
I would like to be able to store each of these lists with the same name in different indexed files.
What I would like to do looks something like...
fd:=["file1.m", "file2.m", ..., "filen.m"]
for i from 1 to n
do
proc(user defined variables)
save variable1,vaiable2, ...,variablem, fd[i]
This however doesn't work.
I would then like to be able then to run proceedures on these variables from each file.
hi everybody!
I have a question. Why my first loop works but the second one doesn't work?
first:
for m from 1 by 1 to 4 do
alpha := m+n:
od;
second:
for n from 1 by 1 to 4 do
alpha := m+n
od;
od;
what is my mistake?
I'm writting a simple program to obtain chi-squared for my model. I've written it for a costant value of "n" and it correctly works and results chi-squared, but when I want to write a loop for "n" then the program doesn't work at all.
I don't recieve any error message. can you help me?
I am trying to solve the the differential equation. for this I have written the following program. But it is showing the error.
with(plots)
eq := diff(x(t), `$`(t, 2))+326.1*(diff(x(t), `$`(t, 1)))+3190*(diff(x(t), `$`(t, 1)))^2-37500*sqrt(x(t)*(0.165e-2-x(t)))+2.825
BCs := [x(0), x(0.2e-1)-0.15e-2]
sol := dsolve({BCs, eq}, {x(t)}, type = numeric)
Maple is saying:
Error, (in dsolve/numeric/process_input) system...
I'm sure there is a simple solution to my problem, but because I'm fairly new to using Maple, I can't figure out why my graph won't work. All I'm trying to do is graph a function along with its first and second derivatives within the same graph. The original function is f(x)= (2+sinx)^x2/(x2+1).
I defined the function as f and then found the first derivative by using df:=D(f...
First 1977 1978 1979 1980 1981 1982 1983 Last Page 1979 of 2470
