I calculate the limit
Let me know if there are any errors in my calculations?
assume(a > 0)
limit(int(sin(x)/x, x = n .. n+a), n = infinity)
-Si(n)+Si(n+a)
plot3d(-Si(n)+Si(n+a), a = -5 .. 5, n = -5 .. 5)
limit(-Si(n)+Si(n+a), n = infinity)
limit(-Si(n), n = infinity)
-(1/2)*Pi
limit(Si(n+a), n = infinity)
(1/2)*Pi
Thank you in advance.
Download limit_int.mw
I have a polyhedron with A(1,1,0), B(-1,1,0), C(-1,-1,0), H(-1/2,0,1), K(1/2,-1/2,0). How can I calculate volume of polyhedron ABCHK?
How can a horizontal axis be curved in a plot? like this
plot(F*r*sin(theta) - m, theta = 0 .. Pi)
When I am setting up the coordinates in the physics package, I use the following command. And it sets it to (r,theta,phi,t).
Setup(dimension = 4, mathematicalnotation = true, coordinates = spherical)
Is there a way to change it to (t,r,theta,phi)?
It gets a bit more confusing when we are looking at rank 2 objects.
Hi, I am working on an activity about conic sections, but I have a small issue with the display of the ellipse and the circle. My outlines are not complete. Any ideas on how to identify my error? Thanks  SectionsConiquesTest.mw
Hi to every one. I have attached a maple for eigenvalues. Please see and tell be solution of problem.
Thanks for time.
Eigen_Values.mw
Hi, here is my question.
test:=v^3;
plot3d(test,u=0..1-v, v=0..1);
How can I  transform this plot in the right triangle into an equilateral triangle?
So that the three edges of the plot are the same length.
I wanna, squish it, or shear?
any tools i can use? Or can I do it using some tricks to change the function?
why the output wont appear eventhough I think the working is right?
y'' + 1/x * u' + u = 6 - 9x + x^2 - x^3
with baundary condition :
u(0) = 0 , and u(1) = 0
 I run the attached code, but after waiting for a few minutes, there is no response, does anyone know the reason?
 It only shows Evaluating!!!!
 sy01.mw
eq1:=( d)/(dt)u+(d^(2))/(dy^(2))u + s*( d)/(dy)u + delta * theta = 0;
eq2:=( d)/(dt)theta + (d^(2))/(dy^(2))theta + s*Pr*( d)/(dy)theta +lambda* exp(theta/(1 +(epsilon*theta))) = 0;
initial and boundary conditons
t <=0; u = theta = 0, for 0 <= y  <= 1
t> 0;  u =0, theta = 0   at  y = 0;
t> 0;  u =1, theta = 0   at   y = 1  ;
where, s, epsilon, Pr, lambda, delta are arbitrary parameters
Assuming I have an expression
you can know that the derivative with respect to y will vanish when y is a constant y0.
How can we use the mathematical software Maple to simplify this expression?
There appears to be a bug in Maple 2023 where constants beginning with a Greek letter cannot be saved.  Assigning a constant to a Greek letter works in the Maple interface but does not work when reading an MPL file encoded as UTF-8.  Example:
read "D:/Nikki/docs/Maple/constants.mpl" :
MPL file contents:
alias(asec=arcsec) : # arcsecant
ζX1 := asec(1) : # first airmass zenith angle
ζX2 := asec(2) : # second airmass zenith angle
The constant "ζX1" can be assigned/saved in Maple but shows as unassigned when imported from an MPL file encoded as UTF-8.
Any assistance in how to use Greek letters in MPL files is much appreciated.
Hello everybody,
So, i managed to use the examples of https://www.mapleprimes.com/questions/233343-Drawing-Of-Complex-Numbers-On-A-Complex-grid- to get to a figure that works for me. If there is a better way, i would love to hear about it.
I believe the question does not need translation because it is very clear due to the other examples that have been done before example 3.
The real question is: how to combine these parameters to form the right figure? The parameters are in the red box in the 3rd picture.
#Toegepaste Wiskunde Deel 2
#Hoofdstuk 6
#Paragraaf 1
#Voorbeeld 1
plots:-inequal([2 <= x and x <= 7, 1 <= y and y <= 4], x = 0 .. 7, y = 0 .. 7)
plots:-inequal([1 <= y and y <= 4, 2 <= x and x <= 7], x = 0 .. 7, y = 0 .. 7)
#Voorbeeld 2
plots:-inequal([0 <= x and x <= 4, 0 <= y and y <= sqrt(x)], x = 0 .. 5, y = 0 .. 5)
plots:-inequal([0 <= y and y <= 2, y^2 <= x and x <= 4], x = 0 .. 5, y = 0 .. 5)
#Voorbeeld 3
plots:-inequal([0 <= x and x <= 2, (1/2)*x <= y and y <= 3*x*(1/2)], x = 0 .. 4, y = 0 .. 4)
plots:-inequal([0 <= y and y <= 1, 2*y*(1/3) <= x and x <= 2*y], x = 0 .. 5, y = 0 .. 5)
Download Toegepaste_Wiskunde_Deel_2_Hoofdstuk_6.mw
First 228 229 230 231 232 233 234 Last Page 230 of 2457
