How can I find the exact solution? > a20:=cos(Pi/17) = sqrt(sqrt(38*sqrt(17) + 170) + 3*sqrt(17) + 17)/8 + sqrt(34 - 2*sqrt(17))/16 - sqrt(17)/16 + 1/16: > evalf(a20); 0.9829730997 = 0.9829730994 I found cos(Pi/5) and cos(Pi/15). a1:=cos(Pi - 2*Pi/5) = cos(3*Pi/5): > a2:=cos(Pi - 2*x) = cos(3*x); a2 := -cos(2 x) = cos(3 x) > a3:=expand(a2); 2 3 a3 := -2 cos(x) + 1 = 4 cos(x) - 3 cos(x) > a4:=subs(cos(x)=y,a3); 2 3 a4 := -2 y + 1 = 4 y - 3 y > a5:=[solve(a4,y)]; 1/2 1/2 5 5 a5 := [-1, ---- + 1/4, 1/4 - ----] 4 4 > a6:=cos(Pi/5)=a5[2]; a6 := cos(1/5*Pi) = 1/4*5^(1/2)+1/4 > evalf(a6); 0.8090169943 = 0.8090169942 > a7:=cos(Pi/3-2*Pi/5)=cos(Pi/15): > a8:=cos(Pi/3-2*x)=cos(Pi/15): > a9:=expand(a8); a9 := cos(x)^2-1/2+3^(1/2)*sin(x)*cos(x) = cos(1/15*Pi) > a10:=subs(sin(x)=sqrt(1-cos(x)^2),a9); a10 := cos(x)^2-1/2+3^(1/2)*(1-cos(x)^2)^(1/2)*cos(x) = cos(1/15*Pi) > a11:=subs(cos(x)=a5[2],a10): > a12:=simplify(expand(a11)); a12 := -1/8+1/8*5^(1/2)+1/16*3^(1/2)*(10-2*5^(1/2))^(1/2)*5^(1/2)+1/16*3^(1/2)*(10-2*5^(1/2))^(1/2) = cos(1/15*Pi) > evalf(a12); 0.9781476005 = 0.9781476007 I have a simplier version. > a13:=sqrt(6*sqrt(5) + 30)/8 + sqrt(5)/8 - 1/8 = cos(Pi/15): > evalf(a13); 0.9781476010 = 0.9781476007
I am new to maple. At present, i am do some study on FEM. so i want to ask if there is some command in maple about the fomulation of Green and Gauss theorem. for i want to change to the body integral to the boundary integral. Thanks for your reply!
Seems that Maple outputs ".." instead of ":" for Matlab code. Note that I'm using Matlab 6.5, so not sure if version has anything to do with it. Is this a bug? Any help would be greatly appreciated. Thanks. >Matlab Code generated from Maple follows
I have a bit of programming experience but am completely new to Maple (using Maple V release 5, by the way). How would a person go about writing a short program that opens a plain text file, and builds a family of sets based on the content. some of these families will be quite large, so we would like to enter the data into the text files not as sets formatted {a,b,c...} but with an uninterupted sequence of characters (interuption can be comma, space or line break) representing the members of the sets, ie. a text file containing abc,def,ghi jkl would create a set equal to { {a,b,c}, {d,e,f}, {g,h,i}, {j,k,l} }.
I am in document mode where I have plots that I generated using the right click on the expression. Then I edit the range and style and drag in two other expressions that plot. everything looks wonderfull until I save and reload the document. and all the edits and dragged in plots are gone. When I try to use plotbuilder to get around this when I reload the document the plotbuilder screens come up when the document executes waiting for all the plot info to be input again. I Think that if I use a worksheet plot command directly with all the parameters and expressions included that it would do what I want. But I would think that when you hit save in document mode it should save what you see.
How do I change the size of a plot programmatically from the default size? I can do it by clicking the plot and pulling the borders with the mouse, but not programmatically. When using an embedded plot, one can easily define the the size of the plot component in the x- and y-direction (pixelheight, pixelwidth) using SetProperty from the DocumentTools package. I would like to do the same thing for a regular Maple plot, but have been unable to find the right command. Is it possible to do that? Thank you for the help. Peter
1. I have a third order PDE with boundary conditions. I try and solve numerically but Maple 9 returns the above error ... Error, (in pdsolve/numeric) unable to handle elliptic PDEs. Would anyone be able to help? 2. If I transform this PDE into an ODE, it returns that there is a "removable singularity at x=0". How do I solve knowing this? Many thanks for any help. Sandra
Of those of you who use calculators in your daily lives, how many use algebraic and how many use RPN? Do you care which you use, i.e., do you choose algebraic over RPN or vice versa, or is it simply a case of what you grew up with or what an employer expects/requires? Are you in industry or education? Do you imagine that there would be a value to having Maple run on a hendheld device, one with a decent interface and good graphical display? Rich
I tried Maple to find a closed-form expression of the following infinite
series:
F:=sum(r^j/(1-a*z^j),j=1..infinity)
where r and a are probabilities and |z|<1.
It did not work
Then I tried to get a series expansion of F around z=0, i.e:
G:=series(F,z=0);
Got the following error message:
Error, (in series/exp) unable to compute series
However when the upper limit of the summation is changed from infinity to any pre-defined number;
ex: F:=sum(r^j/(1-a*z^j),j=1..100)
Maple was able to derive the series expansion around z=0.
Is there any way to get the series expansion at z=0, when the upper limit of the summation is infinity ?
I'm trying to fit an equation to some experimental data but I'm not sure how to do it. Could someone here please offer their help? I would really appreciate it. I have three fitting parameters: kT, kU, and A. I will post my worksheet below and I will also attach the part where I begin to try to fit the data in case it doesnt read well when I post it here. > restart > ptotal := 0.0000022 ptotal := 0.0000022 > Ci0 := 1 Ci0 := 1 > d 2 2
Hey All, I'm new here, but I'm getting a math degree in 20 days if I can finish this project, so hopefully when finals are over I'll be able to stick around. I'm also new to Maple. I have two ODEs which I can plot. I simplified them to be, well, very simple. The ones I want to use are more complicated by a wee bit. de:={diff(x(t),t)=x(t)+y(t),diff(y(t),t)=x(t)+y(t)}; ic:=[[x(0)=1,y(0)=1]]; ic := [[x(0) = 1, y(0) = 1]] Now I want to see how x(t) varies with (t), but all I can find to do is DEplot(de,{x(t),y(t)}, t=0..10, ic);
Hi everyone, I'm new here and I need some serious help. This may seems stupid to you but here it goes. A friend of mine has Maple 10 and I've done my homework with him. But At my school, they've got Maple 6 or something like that and my teacher is unable to see the worksheet that I've done.... Can you help me???
i want to label something in a PLOT structure with TEXT. the problems are that the POLYGON i want to label is (usually) dark. One might solve this by guesstimating the size of the label and putting a white polygon behind it. The problem with this is that text doesn't scale in the same way that polygons do, so when you enlarge or reduce the graph the "text box" no longer holds the text. is there an option for TEXT that will write the label on white? or some other way of doing this? also the text is of variable length (edge weights for a graph, actually). thank you for your help
Hi, I need to find how many solutions were found by solve or fsolve. I have solutions := fsolve(eqution,t) and I need to operate solutions in the loop, I have tried to make condition solution[i] <> NULL. It seems to work, but it print an error message(when i is higher then no of solutions). Is there any possibility, how to get no of solutions to bypass that, or any better solution? Thanks for your answer
Hi, this is a really simple question but I just can't seem to find a solution, how do I plot a vertical line in maple such as x=10, everytime I try something it always plots the line y=10 and gives me a horizontal line. Thanks.
First 2390 2391 2392 2393 2394 2395 2396 Last Page 2392 of 2426
