Maple 2022.2 on windows 10. I found another serious problem with timelimit. When changing the timelimit value, solve hangs.
i.e. timelimit do not timeout.  But that is not all. Unable to terminate the process running the worksheet. Clicking on the little ! circle at the top does nothing.  But that is not all. Killing the server.exe from the task manager, now I am not even able to close the worksheet. Maple hangs on closing the worksheet.
This code below on  my PC produces this. I used 60 seconds to make it hang. When using 10 seconds it does not hang. You might have to change these values depending on how fast/slow your PC is. If it does not hang for you using 60, you might to try 100 and so on.
Why does it hang so bad? This really makes using Maple for development not practical if one can't even put a timeout on an operation like this. What is a user to do?  Not use solve? reduce the timelimit to avoid maple lockin? To what value? If I reduce all timelimits to 5 seconds, this will cause problems as I could lose solutions that will show up with more time.
Anyone else can produce this? Make sure to save all your work before because you might not be able to close the worksheet after this.  I use worksheet mode only.
interface(warnlevel=4);
kernelopts('assertlevel'=2):
eq:=1/24*ln(9*u + 2) + 1/8*ln(u) - 1/24*ln(3*sqrt(4*u + 1) + 1) - 1/8*ln(sqrt(4*u + 1) - 1) + 1/24*ln(3*sqrt(4*u + 1) - 1) + 1/8*ln(sqrt(4*u + 1) + 1) - 1/2*ln(x) - c[1] = 0;
try
   the_sol := timelimit(60,[solve(eq,u)]);
   print("finished before timeout");
  catch:
    print("Timed out OK");
end try;
Download solve_hangs_different_timing_dec_23_2022.mw
To get optimum value (maximum) of 3 variable p, q and w. Where p and q are from the function E1(p,q) and w from the function M1(p,q). The algorithm to obtain the optimum value is described below:-
step 1: Initialize w = c = 20
step2: Evaluate E1(p,q) by substituting w in it.
step3: Find optimum value of p and q from function E1(p,q) using NLPsolve or any other optimiztion method.
step 4: Substitute q optimum value into function M1(p,q) and evaluate it.
step 5: find optimum value of w from optimizing function M1(p,q).
step 6: substitute optimum value of w to E1(p,q) and evaluate it.
step 7: do step 3
step 8: do step 5 and 6
step 9: stop the loop when (w final - w previous) <0.05
I have done this through NLPsolve but it is showing error "Error, (in int) integration range or variable must be specified in the second argument, got 5000 = -3500 .. 1500*p+q-100000"
I am attaching the worksheet below. Please see the numerical analysis part below in the sheet. maple_question.mw
Is there a command to generate a second-difference matrix of size n by n?
This matrix has 2s on its main diagonal and -1 above and below each main diagonal element.
I currently have a document in which controls and a plot are displayed "inline".  I need more controls and more control over where they appear.  Ideally I need my code to display a window in which the controls are laid out and in which the plot can be displayed.  Is this possible with Maple (I know it can be done with other products)?
This is really a question on getting index positions of a sub list from the main list.
Have a list of Vertices and a list of populations for each vertes.
Then from the Neighbours list I need the respective positions in the Vertex list to sum to corresponding values from the population list.
2nd Question  Can the population values be displayed near its vertex or in the vertes circle? e.g y=5
with(GraphTheory)
with(SpecialGraphs)
Vs := [x, y, z, w]
[x, y, z, w]
Popvs := [-2, 1, 6, 3]
[-2, 1, 6, 3]
newPopsvs := Popvs
[-2, 1, 6, 3]
X := Graph(Vs)
GRAPHLN(undirected, unweighted, [x, y, z, w], Array(1..4, {(1) = {}, (2) = {}, (3) = {}, (4) = {}}), `GRAPHLN/table/1`, 0)
AddEdge(X, {{w, y}, {w, z}, {x, y}, {y, z}})
GRAPHLN(undirected, unweighted, [x, y, z, w], Array(1..4, {(1) = {2}, (2) = {1, 3, 4}, (3) = {2, 4}, (4) = {2, 3}}), `GRAPHLN/table/1`, 0)
Nbs := [seq(Neighbors(X, Vs[i]), i = 1 .. nops(Vs))]
[[y], [x, z, w], [y, w], [y, z]]
vp := [[0, 0], [1, 0], [1.5, 1], [2, 0]]
SetVertexPositions(X, vp)
DrawGraph(X)
k := rand(1 .. 4)
for c to nops(Nbs) do Nbs[c]; select(proc (i) options operator, arrow; Vs[i] = Nbs[c, 1 .. -1] end proc, [`$`(1 .. nops(Vs))]) end do
Download Q_23-12-22_Test_Graph_indices_.mw
with(ImageTools);
U1 := Read("C:/Users/S/Desktop/StarPicture.jpg"):
ttt0 := textplot([0 + 0.5, (5 + 0) - 0.5, " Star ", color = "blue", font = ["times", "roman", "bold", 40]]):
display(ttt0, U1, axes = none, size = [400, 160]);
This is the error I get:
Error, (in plots:-display) cannot display array with other plots
I can see Maple doesn't allow adding images to plots. But is there a way around that?
I want to be able to virtually have a white box that I can add plots to such as curves, text, and images at certain locations etc? I want to do that with actual Maple code in the worksheet, without having to mouse-clicking Menu, insert, etc.
As we know, choosing different generators can all represent the same group. But how can I get the combination of these different generators by maple? For example, how do I get the following different combinations of generators of C6?
How do I characterize this equation set? I think it has 6 solutions, equal in pairs, or 3 distinct solutions.
eq1 := x = (((72*5^(3/2)+270)*a^2-1344*5^(3/2)*a)*w+(9*5^(5/2)-1485)*a^2-2016*5^(3/2)*a-12544*5^(5/2))/(((288*sqrt(5)+216)*a^2-5376*sqrt(5)*a)*w+(36*5^(3/2)-1188)*a^2-8064*sqrt(5)*a+6272*5^(3/2)):
eq2:= a^3 = -(128*5^(5/2)*w)/9+(1600*w)/3+(544*5^(3/2))/9+15200/27:
eq3:=1+w+w*w = 0:##   or w = (sqrt(3)*%i)/2-1/2;
for s1 in [solve(eq2,a)] do
    for s2 in [solve(eq3,w)] do
        subs(a=s1, eq1):
        subs(w=s2,%):
        lprint("sol",simplify(%));
The loop for HFS _data_2 and SFS_data_2 and the loop for HFS _data_3 and SFS_data_3 do not seem to be terminated. I do not know what it is the issue here. Anyone who can help this?
Negativity_(v12_beta_gamma_mu).mw
Thank you in advance,
simplify(sqrt((x^2 + y^2)/x)/sqrt(x^2 + y^2)) assuming x>0, y>0
is not sqrt(1/x), why?
If we have two univariate polynomials $f(x)$ and $g(x)$ such that
$gcd(f(x),g(x))=1$
then we know there exist two other polynomials $a(x)$ and $b(x)$ such that $a(x)f(x)+b(x)g(x)=1$. For example, if $f(x)=x^3−1$ and $g(x)=x^2+2$, then we can set
$a(x)=\frac{2x−1}{9}$, $b(x)=\frac{−2x^2+x+4}{9}$
Here the polynomials $a(x)$ and $b(x)$ are known as Bezout polynomials and they can be found using the extended Euclidean algorithm, which I know how to do using pen and paper, but not in Maple.
So my question is: in Maple, is there a way, given $f(x)$ and $g(x)$, to solve for $a(x)$ and $b(x)$?
Another training example (number 2 and last) for finding all solutions to a system of equations:
f1 := x3^2-0.1*x1^4-0.05*x2^4+1;
f2 := x1^3+x2^3+0.05*x3^3-1;
f3 := -2*cos(3*x1)+2*cos(3*x2)-2*cos(3*x3)+1;
In my version, there are 116 solutions.
Is it so?
What kind of solution is it (see (3))? Why is there no solution when I put the initial condition v(0)=C1? Secondly, eq. (2) can be reduced to a first-order differential equation?
interface(showassumed = 0)
declare(v(y))
q := v(y)*(diff(diff(diff(v(y), y), y), y))+(2*v(y)-(diff(v(y), y)))*(diff(diff(v(y), y), y))+(diff(v(y), y))*(v(y)^3+v(y)-(diff(v(y), y))) = 0
dsolve(q)
v(y) = ODESolStruc(_a, [{(diff(diff(_b(_a), _a), _a))*_b(_a)^2+_b(_a)*((diff(_b(_a), _a))^2*_a+_a^3-(diff(_b(_a), _a))*_b(_a)+2*(diff(_b(_a), _a))*_a-_b(_a)+_a)/_a = 0}, {_a = v(y), _b(_a) = diff(v(y), y)}, {y = Int(1/_b(_a), _a)+_C1, v(y) = _a}])
dsolve({q, v(0) = C1})
v(y) = C1
Download CD_ode.mw
First 247 248 249 250 251 252 253 Last Page 249 of 2427
