Quite often, Maple freezes, and the file cannot be saved, and Maple cannot be closed.
Did you get the problem ?
Can someone give me an example for using
linear regressor function from deep learning package
By passing one dependent variable say Y
And a set of independent variables say X
As a matrix say
Can we be able to split data into train and test and use this linear regressor command on train and do validation
As I am not able to see some examples on the implementations using command kind help
I run the following command.
$ maple2022/bin/maple -q problem.mpl
where problem.mpl is the following:
with(Student[Calculus1]):
ShowSolution(Diff(ln(x),x));
I get the following output.
Differentiation Steps
    Diff(ln(x),x)
▫    1. Apply the natural logarithm rule
        ◦ Recall the definition of the natural logarithm rule
        Diff(ln(x),x) = x^(-1)
    This gives:
    x^(-1)
I want the solver to use 1/x instead of x^(-1) in the output. How can I achieve this?
P.S. I require the output to be parsable, so using output=print to show fractions in a multi-line fashion is not a solution for me.
I have this very simple intergral
((Int(sin(m*Pi*y/a), y = 0 .. b))
I want to solve it when m is even then when it is odd. Of course, a and b are real positive. Then I will do the same with the other side of the integral.
Int(sin(n*Pi*y/a)*sin(m*Pi*y/a), y = 0 .. b)
Thank you in advance.
Mario
document:Laplace_Problem.mw
I've been working on a file in Maple, and saved it yesterday - but now I am not able to open it, as it is corrupted. I have been able to find the back up file, HOWEVER I am not able to load half of the file as Maple comes up with a "there was a problem loading your file....". Is there anything I can do to repair the back up file?
Any help is greatly appreciated!
Back up file is here: C_Users_jonas_OneDrive_Skrivebord_Mat_B-A_Hjemmeopgavesæt_Opgavesæt_1115_MAS_-_Kopi.mw
Is it possible to graph multiple Niquist plots using DynamicSystems:-NiquistPlot() ? All my attemps have failed.
How I can ontain results without Rootof !!
help.mw
EQ1 := c[11]*exp(-n*Pi*a/b)+c[12]*exp(n*Pi*a/b) = 0
EQ2 := c[11]*n*Pi/b-c[12]*n*Pi/b+b^2*Q[0, 1]*sin(n*Pi*y[0, 1]/b)*(n*Pi*exp(-n*Pi*x[0, 1]/b)/b+n*Pi*exp(n*Pi*x[0, 1]/b)/b)/(n*Pi) = c[21]*n*Pi/b-c[22]*n*Pi/b
c[21] := -b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)/(n*Pi)
EQ3 := c[11]+c[12]+b^2*Q[0, 1]*sin(n*Pi*y[0, 1]/b)*(exp(-n*Pi*x[0, 1]/b)-exp(n*Pi*x[0, 1]/b))/(n*Pi) = lambda.(c[21]+c[22])
c[11]+c[12]+b^2*Q[0, 1]*sin(n*Pi*y[0, 1]/b)*(exp(-n*Pi*x[0, 1]/b)-exp(n*Pi*x[0, 1]/b))/(n*Pi) = lambda.(-b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)/(n*Pi)+c[22])
solve({EQ1, EQ2, EQ3}, {c[11], c[12], c[22]})
{c[11] = RootOf(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b)+(lambda.((exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+2*b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b))/(n*exp(n*Pi*a/b))))*n*exp(n*Pi*a/b)), c[12] = -RootOf(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b)+(lambda.((exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+2*b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b))/(n*exp(n*Pi*a/b))))*n*exp(n*Pi*a/b))*exp(-n*Pi*a/b)/exp(n*Pi*a/b), c[22] = -(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+RootOf(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b)+(lambda.((exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+2*b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b))/(n*exp(n*Pi*a/b))))*n*exp(n*Pi*a/b))*Pi*n*exp(-n*Pi*a/b)+RootOf(exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]-_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b)+(lambda.((exp(-n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+exp(n*Pi*x[0, 1]/b)*exp(n*Pi*a/b)*b^2*sin(n*Pi*y[0, 1]/b)*Q[0, 1]+2*b^2*Q[0, 2]*sin(n*Pi*y[0, 2]/b)*exp(-n*Pi*x[0, 2]/b)*exp(n*Pi*a/b)+_Z*n*Pi*exp(-n*Pi*a/b)+_Z*n*Pi*exp(n*Pi*a/b))/(n*exp(n*Pi*a/b))))*n*exp(n*Pi*a/b))*Pi*n*exp(n*Pi*a/b))/(Pi*n*exp(n*Pi*a/b))}
Download help.mw
Can i use Maple to do satellite image classification . by implement the satellite image so the software will do the math processing ?
I want to plot the Tsai Wu failure envelope for a given
composite. The Tsai Wu failure criterion (for a pure biaxial
state of stress) is given by:
F1*x+F2*y+F11*x^2+F22*y^2+F12*x*y=1
can someone help me?please.
Can Maple carry around an unevaluated/inert  Matrix-Vector product(A matrix product without executing the matrix multiplication)? See Maple sheet.
inert_matrix_products.mw
with(LinearAlgebra)
NULLNULL
Can Maple carry around an unevaluated/inert explicit Matrix-Vector product?
Define a matrix K and vector U as:
U := `<,>`(u1, u2)
Vector[column](%id = 36893490583464982996)
K := Matrix(2, 2, symbol = k)
Matrix(%id = 36893490583464975884)
I can take their product using MatrixVectorMultiply( ) I get,
MatrixVectorMultiply(K, U)
Vector[column](%id = 36893490583464964812)
however output I am really looking for is
(Matrix(2, 2, {(1, 1) = k[1, 1], (1, 2) = k[1, 2], (2, 1) = k[2, 1], (2, 2) = k[2, 2]})).(Vector(2, {(1) = u1, (2) = u2}))
In the later case, K.U is still a product however the actual matrix multiplication is not carried out. Sure, eventually I will want to evaluate the matrix-vector product but sometimes when setting up a problem I want to look at the explicit matrix equation before any explicit matrix multiplication is carried out.NULL
Here I show some ideas that don't work but may give a sense of what I am going for. I am essentially trying to mute the computation of the product while keeping the elements of the product together for further substitutions elsewhere. This there a standardized way to complish this? Or do I have to write my own procedure for something like this?
`&MatrixVectorMultiply`(K, U)
`&MatrixVectorMultiply`(Matrix(%id = 36893490583464975884), Vector[column](%id = 36893490583464982996))
%MatrixVectorMultiply(K, U)
%MatrixVectorMultiply(Matrix(%id = 36893490583464975884), Vector[column](%id = 36893490583464982996))
`&.`(K, U)
`&.`(Matrix(%id = 36893490583464975884), Vector[column](%id = 36893490583464982996))
K*%.U
`&.`(Matrix(%id = 36893490583464975884), Vector[column](%id = 36893490583464982996))*Matrix(%id = 36893490583464939756).Vector[column](%id = 36893490583464982996)
NULLNULL
Download inert_matrix_products.mw
I'm having trouble performing a direct operation, involving DotProduct, in the piecewise function. Attached is a document. I appreciate any contribution.
Oliveira
Example2.mw
I am new to Maple and I couldn't really find anything about this problem. Why doesn't Maple automatically simplify the last expression in the following? (see for example the first and last terms, as well as other terms)
total := (((((D^2/(alpha^2*mu^2) + D^2*exp(2*(-t + t1)*alpha*mu)/(alpha^2*mu^2)) + D^2*exp(2*(-t + t1)*alpha*mu)/(alpha^2*mu^2)) + D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) - (-alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) + exp(2*(-t + t1)*alpha*mu))*D*D1/(mu^2*alpha^2*(alpha^2*mu^2*tau0^2 - 1)) + (alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) - exp(2*(-t + t1)*alpha*mu))*D1*D/(alpha^2*mu^2*(alpha^2*mu^2*tau0^2 - 1))) - (-alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) + exp(2*(-t + t1)*alpha*mu))*D*D1/(mu^2*alpha^2*(alpha^2*mu^2*tau0^2 - 1))) + (alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) - exp(2*(-t + t1)*alpha*mu))*D1*D/(alpha^2*mu^2*(alpha^2*mu^2*tau0^2 - 1)) + D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) + D1^2/((alpha*mu*tau0 + 1)^2*alpha^2*mu^2) - (alpha*mu*tau0*exp(-(-t + t1)*(alpha*mu*tau0 - 1)/tau0) + alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 - 1)/tau0) - alpha^2*mu^2*tau0^2 - 1)*D1^2/(alpha^2*mu^2*(alpha^4*mu^4*tau0^4 - 2*alpha^2*mu^2*tau0^2 + 1))) - (alpha*mu*tau0*exp(-(-t + t1)*(alpha*mu*tau0 - 1)/tau0) + alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 - 1)/tau0) - alpha^2*mu^2*tau0^2 - 1)*D1^2/(alpha^2*mu^2*(alpha^4*mu^4*tau0^4 - 2*alpha^2*mu^2*tau0^2 + 1))
D1^2/((alpha*mu*tau0 + 1)^2*alpha^2*mu^2) + 2*D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) + D^2/(alpha^2*mu^2)
r2r2 := %;
total - r2r2;
((((((D^2/(alpha^2*mu^2) + D^2*exp(2*(-t + t1)*alpha*mu)/(alpha^2*mu^2)) + D^2*exp(2*(-t + t1)*alpha*mu)/(alpha^2*mu^2)) + D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) - (-alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) + exp(2*(-t + t1)*alpha*mu))*D*D1/(mu^2*alpha^2*(alpha^2*mu^2*tau0^2 - 1)) + (alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) - exp(2*(-t + t1)*alpha*mu))*D1*D/(alpha^2*mu^2*(alpha^2*mu^2*tau0^2 - 1))) - (-alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) + exp(2*(-t + t1)*alpha*mu))*D*D1/(mu^2*alpha^2*(alpha^2*mu^2*tau0^2 - 1))) + (alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 + 1)/tau0) - exp(2*(-t + t1)*alpha*mu))*D1*D/(alpha^2*mu^2*(alpha^2*mu^2*tau0^2 - 1)) + D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) + D1^2/((alpha*mu*tau0 + 1)^2*alpha^2*mu^2) - (alpha*mu*tau0*exp(-(-t + t1)*(alpha*mu*tau0 - 1)/tau0) + alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 - 1)/tau0) - alpha^2*mu^2*tau0^2 - 1)*D1^2/(alpha^2*mu^2*(alpha^4*mu^4*tau0^4 - 2*alpha^2*mu^2*tau0^2 + 1))) - (alpha*mu*tau0*exp(-(-t + t1)*(alpha*mu*tau0 - 1)/tau0) + alpha*mu*tau0*exp((-t + t1)*(alpha*mu*tau0 - 1)/tau0) - alpha^2*mu^2*tau0^2 - 1)*D1^2/(alpha^2*mu^2*(alpha^4*mu^4*tau0^4 - 2*alpha^2*mu^2*tau0^2 + 1))) - D1^2/((alpha*mu*tau0 + 1)^2*alpha^2*mu^2) - 2*D1*D/((alpha*mu*tau0 + 1)*alpha^2*mu^2) - D^2/(alpha^2*mu^2)
couldnt insert "r2r2" properly...
problemfilepdsolve.mw
eq1 := diff(p(x, t), x)-p(x, t)*(1/(p(x, t)^2*q(x, t)^(1/3)))
diff(p(x, t), x)-1/(p(x, t)*q(x, t)^(1/3))
eq2 := diff(q(x, t), x)-(-3*q(x, t))*(1/(p(x, t)^2*q(x, t)^(1/3)))
diff(q(x, t), x)+3*q(x, t)^(2/3)/p(x, t)^2
pdsolve({eq1, eq2})
Error, (in pdsolve/sys) found the element '_F2' repeated in the indication of blocks variables
eq3 := diff(p(x), x)-p(x)*(1/(p(x)^2*q(x)^(1/3)))
diff(p(x), x)-1/(p(x)*q(x)^(1/3))
eq4 := diff(q(x), x)-(-3*q(x))*(1/(p(x)^2*q(x)^(1/3)))
diff(q(x), x)+3*q(x)^(2/3)/p(x)^2
dsolve({eq3, eq4})
[{q(x) = -27/(_C1*x+_C2)^3}, {p(x) = (-3*(diff(q(x), x))*q(x)^(2/3))^(1/2)/(diff(q(x), x)), p(x) = -(-3*(diff(q(x), x))*q(x)^(2/3))^(1/2)/(diff(q(x), x))}]
eq5 := diff(p(x, t), x)-x = 0
pdsolve(eq5)
p(x, t) = (1/2)*x^2+_F1(t)
eq6 := diff(p(x), x)-x = 0
diff(p(x), x)-x = 0
dsolve(eq6)
p(x) = (1/2)*x^2+_C1
Help me in finding the solution of system eq1 and eq2.
Download problemfilepdsolve.mw
Hope the resolution of the images which come via Plot3d and plot commands are atleast 300 dpi
If not how to make them
First 257 258 259 260 261 262 263 Last Page 259 of 2457
