Considered a list of this type
L:=[["O",3.85090000,0.45160000,0.00120000],
["O",−2.59990000,1.40410000,−0.00180000],
["N",−1.57050000,−0.71710000,0.00010000],
["C",−0.20660000,−0.42310000,−0.00020000],
["C",0.22050000,0.90470000,0.00040000],
["C",0.72980000,−1.45700000,−0.00070000],
["C",1.58410000,1.19860000,0.00020000],
["C",2.09330000,−1.16290000,−0.00070000],
["C",2.52040000,0.16480000,−0.00030000],
["C",−2.64850000,0.17820000,0.00090000],
["C",−3.97350000,−0.54200000,0.00100000],
["H",−0.44360000,1.75770000,0.00120000],
["H",0.41130000,−2.49630000,−0.00100000],
["H",−1.80100000,−1.70860000,0.00010000],
["H",1.90530000,2.23700000,0.00090000],
["H",2.81800000,−1.97260000,−0.00080000],
["H",−4.06550000,−1.14630000,−0.90580000],
["H",−4.79040000,0.18440000,0.02880000],
["H",−4.04450000,−1.18860000,0.88020000],
["H",3.96500000,1.41760000,0.00170000]];
Find out the indexs of the list within the list where "H" is their and to store is set S.
Here we can say 12th list have "H"
Similarly 13th list has "H" and so on
So it will output a set
{11,12,13,...}
A function which takes a list like above as input and outputs the set which give index positions of lists containing "H"
Is their anyway in by which given a molecule I can code to get the hydrogen depleted form of the molecule using Maplesoft quantum chemistry toolbox
After hydrogen depleted get the BondDistances table of that depleted molecule structure
I have a third order equations, I would like to know the sign of its roots, not necessary to find the roots since the equations contains some parameters. All parameters used are positives.
roots.mw
thank you
Here is the full code with output and errors.
restart; with(plots): with(plottools):
w:=-Ps/2*(Hk*cos(theta)^2+2*H*cos(theta-psi));
             1    /             2                        \
      w := - - Ps \Hk cos(theta)  + 2 H cos(-theta + psi)/
dw:=diff(w,theta);
dw := - - Ps (-2 Hk cos(theta) sin(theta) + 2 H sin(-theta + psi))
equ:=dw=0;
           equ := - - Ps (-2 Hk cos(theta) sin(theta)
              + 2 H sin(-theta + psi)) = 0
Hg:=(sin(psi)^(2/3)+cos(psi)^(2/3))^(-3/2);
           Hg := ------------------------------------
                                                (3/2)
                 /        (2/3)           (2/3)\
                 \sin(psi)      + cos(psi)     /
psi:=35.0*Pi/180;H:=0.1;Ps:=1.0;Hk:=1.0;
                      psi := 0.6108652383
                            H := 0.1
                           Ps := 1.0
                           Hk := 1.0
Hc:=evalf(Hk*Hg); theta:='theta';
                       Hc := 0.5103773339
                         theta := theta
theta_s:=evalf(Pi-arctan(tan(psi)^1/3));
                     theta_s := 2.912295114
H:='H';np:=100;H_max:=1.0;
                             H := H
                           np := 100
                          H_max := 1.0
h_p:=array(1..np):
h_n:=array(1..np):
m_p:=array(1..np):
m_n:=array(1..np):
h_p[1]:=0.0;m_p[1]:=cos(psi);
                          h_p[1] := 0.
                     m_p[1] := 0.8191520442
for i from 2 to np do
   h_p[i]:=(i-1)*H_max/(np-1):
   H:=h_p[i]:
   theta_plus:=fsolve(equ,theta,0..Pi/2):
   m_p[i]:=evalf(cos(theta_plus-psi)):
h_n[1]:=0.0; m_n[1]:=evalf(cos(Pi-psi));
                          h_n[1] := 0.
                    m_n[1] := -0.8191520446
for i from 2 to np-1 do
   h_n[i]:=(i-1)*Hc/(np-1):
   H:=h_n[i]:
   theta_minus:=fsolve(equ,theta,theta_s..Pi);
   m_n[i]:=evalf(cos(theta_minus-psi)):
h_n[np]:=Hc; m_n[np]:=evalf(cos(theta_minus-psi));
                    h_n[100] := 0.5103773339
    m_n[100] := cos(fsolve(1.000000000 cos(theta) sin(theta)
       + 0.5052220075 sin(theta - 0.6108652383) = 0, theta,
      2.912295114 .. Pi) - 0.6108652383)
pl_pp:=array(1..np):
pl_pn:=array(1..np):
pl_np:=array(1..np):
pl_nn:=array(1..np):
i:='i';
                             i := i
NULL;
NULL;
NULL;
NULL;
for i from 1 to np do
   pl_pp[i]:=point([h_p[i],m_p[i]],color=red):
   pl_np[i]:=point([h_n[i],m_n[i]],color=blue):
   pl_pn[i]:=point([-h_n[i],-m_n[i]],color=red):
   pl_nn[i]:=point([-h_p[i],-m_p[i]],color=blue):
Error, (in plottools:-point) incorrect arguments for creating points structure, try providing the dimension option
display([seq(pl_pp[i],i=1..np),seq(pl_np[i],i=1..np),seq(pl_pn[i],i=1..np),seq(pl_nn[i],i=1..np)]);
Error, (in plots:-display) expecting plot structures but received: [pl_pp[60], pl_pp[61], pl_pp[62], pl_pp[63], pl_pp[64], pl_pp[65], pl_pp[66], pl_pp[67], pl_pp[68], pl_pp[69], pl_pp[70], pl_pp[71], pl_pp[72], pl_pp[73], pl_pp[74], pl_pp[75], pl_pp[76], pl_pp[77], pl_pp[78], pl_pp[79], pl_pp[80], pl_pp[81], pl_pp[82], pl_pp[83], pl_pp[84], pl_pp[85], pl_pp[86], pl_pp[87], pl_pp[88], pl_pp[89], pl_pp[90], pl_pp[91], pl_pp[92], pl_pp[93], pl_pp[94], pl_pp[95], pl_pp[96], pl_pp[97], pl_pp[98], pl_pp[99], pl_pp[100], pl_np[59], pl_np[60], pl_np[61], pl_np[62], pl_np[63], pl_np[64], pl_np[65], pl_np[66], pl_np[67], pl_np[68], pl_np[69], pl_np[70], pl_np[71], pl_np[72], pl_np[73], pl_np[74], pl_np[75], pl_np[76], pl_np[77], pl_np[78], pl_np[79], pl_np[80], pl_np[81], pl_np[82], pl_np[83], pl_np[84], pl_np[85], pl_np[86], pl_np[87], pl_np[88], pl_np[89], pl_np[90], pl_np[91], pl_np[92], pl_np[93], pl_np[94], pl_np[95], pl_np[96], pl_np[97], pl_np[98], pl_np[99], pl_np[100], pl_pn[59], pl_pn[60], pl_pn[61], pl_pn[62], pl_pn[63], pl_pn[64], pl_pn[65], pl_pn[66], pl_pn[67], pl_pn[68], pl_pn[69], pl_pn[70], pl_pn[71], pl_pn[72], pl_pn[73], pl_pn[74], pl_pn[75], pl_pn[76], pl_pn[77], pl_pn[78], pl_pn[79], pl_pn[80], pl_pn[81], pl_pn[82], pl_pn[83], pl_pn[84], pl_pn[85], pl_pn[86], pl_pn[87], pl_pn[88], pl_pn[89], pl_pn[90], pl_pn[91], pl_pn[92], pl_pn[93], pl_pn[94], pl_pn[95], pl_pn[96], pl_pn[97], pl_pn[98], pl_pn[99], pl_pn[100], pl_nn[59], pl_nn[60], pl_nn[61], pl_nn[62], pl_nn[63], pl_nn[64], pl_nn[65], pl_nn[66], pl_nn[67], pl_nn[68], pl_nn[69], pl_nn[70], pl_nn[71], pl_nn[72], pl_nn[73], pl_nn[74], pl_nn[75], pl_nn[76], pl_nn[77], pl_nn[78], pl_nn[79], pl_nn[80], pl_nn[81], pl_nn[82], pl_nn[83], pl_nn[84], pl_nn[85], pl_nn[86], pl_nn[87], pl_nn[88], pl_nn[89], pl_nn[90], pl_nn[91], pl_nn[92], pl_nn[93], pl_nn[94], pl_nn[95], pl_nn[96], pl_nn[97], pl_nn[98], pl_nn[99], pl_nn[100]]
NULL;
NULL;
@David Mazziotti
I just purchased the quantum chemistry package
The plotmolecule is not giving the correct structure of the attached xyz file can you please confirm and help
I am attaching
A.xyz    as     A.txt
Please rename it .xyz as maple is not allowing to attach a xyz file.
XYZ  file :       A.txt     Rename as xyz
Image file of the molecule which is expected:
Image coming from maple code:
It can be observed that the bond between yellow (Sulfur ) and carbon missing
Code given below I typed
with(QuantumChemistry);
molecule := ReadXYZ("A.xyz");
print(PlotMolecule(molecule));
The help page solve/details claims that solve(x^2-1,{x}, useassumptions) assuming x>0; is equivalent to solve({x^2-1, x>0},{x});. But the following example perplexes me again.
Considering a multi-variable polynomial:
expr := 36*a^3*b^3+8*a^2*b^2*(9*(a+b+1)^2+4*(a*b+a+b))*(a+b+1)+((a-b)^2-2*(a+b)+1)^2*(a+b+1)^5+a*b*((a-b)^2-2*(a+b)+1)*(17*(a+b+1)^2+4*(a*b+a+b))*(a+b+1)^2: # assuming nonnegative
I intend to find the nonnegative real roots of it.
solve({expr = 0, (a, b) >= ~ 0}, [a, b], allsolutions);
solve(expr = 0., [a, b], useassumptions, allsolutions) assuming (a, b) >= ~ 0;
solve({expr = 0., (a, b) >= ~ 0}, [a, b], allsolutions);
all return six solutions, but curiously,
solve(expr = 0, [a, b], useassumptions, allsolutions) assuming (a, b) >= ~ 0;
only returns four solutions. Why???
In addition, as you can see, the first output (i.e., sol1) is thoroughly less meaningful. Can't it be more readable??
sol1 := solve({`~`[`>=`](a, b, ` $`, 0), expr = 0}, [a, b], allsolutions) =
[[a = 0, b = 1], [a = 3^(1/2)-1, b = RootOf((-741235976922591048947725497133370413109846163676281959390560108171291511786260537194814187602376638467882392432305864*3^(1/2)+1283858372427879519277780718816094877088966867890478064541174875107114975191197490158346515516574907111238006510832897)*_Z^8+(542622395505288470330055221682724463979120704214196105150614766935823463404936952963532327914198268643355614078527033*3^(1/2)-939849558339893627565395772584016362240571623138367813630505449406759560167584121426096047290555008292409170786084695)*_Z^7+(27663303262730616171732317130828357033086591952430419833222950914496979987637185645479748907213281840470027913754446250*3^(1/2)-47914246756235321853987379290323009935074722268098020072540300747281044857411765919011355938402797296261231903185833860)*_Z^6+(-36848925451143075385294452437991667121840085487125852139251120381482252862356891660819456375517484560073220737684055360*3^(1/2)+63824211085697719773601999676355867125229886950052051470652732444578522019946850568834704346278726602905590979989005206)*_Z^5+(-361541600067355242269699717707379679953498397064818094940691654358197984962782803819129269994590941790029033835785321091*3^(1/2)+626208420366406708672813369852190896907780666621957659007533759258885959287096424079349105562785060297582745252447270847)*_Z^4+(469917886838763314544262854134623783463102170709338866937842556434901449696233730989733509809486602395675273592523379039*3^(1/2)-813921655390140293483357785790922432834508040979560342164969934794994487106266639300148834412459020073129881509269947685)*_Z^3+(2419091701164731099042357448446421888413075728672522494523180828886450053865285232431099171783692236478370266582727759022*3^(1/2)-4189989734585541679787610388006771626857619186946433018568920261866881451820006582050966407487366628715776067639375659568)*_Z^2+(-276526595929812923186277260098945143564039808175960075417091066631428638512893788855336862569832144723039829695578843580*3^(1/2)+478958113794505090444730274771005660986137994458744274847200001817421835204311147220572248669252963586284164359082018778)*_Z-2241557156236496486338463519192106892320755475146925672942972549523504139162741341146795559700763371271548957041603585449*3^(1/2)+3882490882671219790342097523842232566093205006918585285230133334462570311857306952032638288791685675699575851624588398080, index = real[4])], [a = 1, b = 0], [a = 1, b = 3^(1/2)-1], [a = 1, b = 1], [a = 1/2+(1/2)*3^(1/2), b = RootOf((3265859930834838622581170032695923790177759993209560990735389424723672715638564736*3^(1/2)+5656635330609319983539361351500545583607599001912359529744925502462343818424446992)*_Z^8+(12188355192278997228701701416892393163963118988331481511215704351909689249701576464*3^(1/2)+21110850453723155834822232801088862537748477983453402031696019279095705783764588192)*_Z^7+(-16329299654174193112905850163479618950888799966047804953676947123618363578192823680*3^(1/2)-28283176653046599917696806757502727918037995009561797648724627512311719092122234960)*_Z^6+(-47558033069228748234327710008167261759137556448974526775358049368769421447413364728*3^(1/2)-82372929583945025397186856831061837257531071444955446405553455730528485970812729160)*_Z^5+(71016746435016238932635448066739883738739336153617153345258159361269798232579788444*3^(1/2)+123004613013684064253013423478212462789515684702771043974383244940692061281906669908)*_Z^4+(-539074301591972734261861623983834399153978765971327430710378028630584341753429268*3^(1/2)-933704079412004867600664919608623045951401970711134655767859337789085046795723776)*_Z^3+(-8660811640968922793242100644402781523021841461481655906743406226105766029465794376*3^(1/2)-15000965796942156111966381948246207258139974790596863072851606476670777826354805396)*_Z^2+(-30769734905669303241874027457081560634086527346916553595415452889491557012102176442*3^(1/2)-53294744192044789072581100596045559567736905080848045509547703544202848750472876382)*_Z-3181857373467742490740890760219056890779274438575702235481520595135068397863751433*3^(1/2)-5511138633283790175605724430174371395924969988541134171865969654221197707640077992, index = real[4])]]
sol2 := `assuming`([solve(expr = 0., [a, b], useassumptions, allsolutions)], [`~`[`>=`](a, b, ` $`, 0)]) =
[[a = 0., b = 1.], [a = .7320508076, b = 1.000000000], [a = 1., b = 0.], [a = 1., b = .7320508076], [a = 1., b = 1.], [a = 1.366025404, b = 1.366025404]]
sol3 := solve({`~`[`>=`](a, b, ` $`, 0), expr = 0.}, [a, b], allsolutions) =
sol4 := `assuming`([solve(expr = 0, [a, b], useassumptions, allsolutions)], [`~`[`>=`](a, b, ` $`, 0)]) = [[a = 0, b = 1], [a = 1, b = 0], [a = 1, b = 3^(1/2)-1], [a = 1, b = 1]]NULL
_SolutionsMayBeLost;
_SolutionsMayBeLost
numelems(sol1), numelems(sol2), numelems(sol3), numelems(sol4) = 6, 6, 6, 4NULL
sol5 := [[a = 0, b = 1], [a = sqrt(3)-1, b = 1], [a = 1, b = 0], [a = 1, b = sqrt(3)-1], [a = 1, b = 1], [a = (sqrt(3)+1)*(1/2), b = (sqrt(3)+1)*(1/2)]]
Why did't solve({`~`[`>=`](a, b, ` $`, 0), expr = 0}, [a, b]) return sol5?
map2(evala@eval, expr, sol5);
[0, 0, 0, 0, 0, 0]
Error, (in type/algext) too many levels of recursion
Download solve_details.mw
 Can you tell me how I can create the variation tab of a function with Maple 2022?
Thanking you,
,DAVID CRESPIL
I have only seen big O show up in series solutions, as in
series(sin(x),x)
I've never seen it before show up in result of solve
eq:=x=p*(a*ln(p+sqrt(p^2-2))+2*_C1)/(2*sqrt(p^2-2));
sol:=solve(eq,p);
What does it actually mean when the solution has  O(RootOf(....))?
Should not result of solve be exact? isn't having big O means an approximation?
Maple 2022.2 on windows 10
Q1: Is it possible to find out where a warning was generated (i.e. which procedure issued the warning)?
Q2: Is a command specific warning suppression possible? Something like that for example: infolevel[int] := 0
Q3: Can warnings be removed form a document before printing it?
Typical warnings I want to suppress are attached
Download warnings_to_suppress.mw
Update: for the attached warnings Typesetting:-Settings(parserwarnings = false) is effective, which does not work for warnings discussed bellow.
So for my project, I need to be able to do this integral for different values of "l". Here is the integral I need to evaluate:
Where "R", "Xi", and "l" are all constant. When I try to do it, it gives back an imaginary number. The absolute value of this imaginary number seems to be correct but I'm not sure why it's imaginary. This is a plot of what it should give for various values of "l":
Here is my maple code copy-pasted from the application (I'm new to Maple and this forum and cannot figure out how to attach the file version of my code sorry):
Digits := 30;
E := 3.83*10^14;
                                            14
                  E := 3.8300000000000000 10
R := 0.1*E;
                                            13
                  R := 3.8300000000000000 10
l := 0.01*R;
                                            11
                  l := 3.8300000000000000 10
A := int((-4*E^2 + r^2)^(1/2)*(R^2 - l^2 + r^2)/((R^2 - (l - r)^2)^(1/2)*((l + r)^2 - R^2)^(1/2)), r = abs(l - R) .. l + R)/(Pi*R^2);
             A := 19.9744824651978825998722703010 I
Max := (1 + 4*(E/R)^2)^(1/2);
             Max := 20.0249843945007857276972121483
NULL;
Here is the code when I exported as maple input:
NULL;
Digits := 30;
E := 3.83*10^14;
R := 0.1*E;
l := 0.01*R;
NULL;
Thank you in advance!
Having  Matrix say A of dimensions n×m
Writing a function that
Will choose k  columns of the matrix at
At random where one of the column that is column m is the last column of output matrix that is after choosing k columns from the first m-1 column
We append the column m as last column to the new random matrix and the function returns the new matrix M
Kind help
k can be any big number less than m-1
When exporting a maple file containing
pH = 1/2*(pKa - log[10](c)),
I could see that the minus was transformed into a K
Any idea for solving this problem ?
Cheers for Maple anyway
There are two issues I am having with images in Maple Flow 2022.
1. When I need to move an image up or down in the document it instantly flies to the top or off in to the vast corner of the document with the tiniest motion of the mouse. It's utterly ridiculous. Is there a setting to change this behaviour in Maple Flow? I have changed settings on my desktop with no change, so I believe it is Maple Flow's behavior.
2. When I do put an image somewhere and save the document and open it some time later, the images are moved in position on top of text. No amount of moving them and saving them ever changes this and I can't export a document that I need to submit for calculations on a report because of this.
Could you suggest a more elegent way to remove any entry in piecewise which has undefined in it?
expr:=(s+exp(-Pi*s)-exp(-2*Pi*s))/(s*(s^2+2*s+2));
inttrans:-invlaplace(expr,s,t);
Y:=convert(%,piecewise);
#remove all entries in piecwise which has undefined
To obtain this
I can;t just apply select on piecewise. So currently I convert piecwise to list of lists, each sublist has the 2 entries you see above in each row.
Next apply select. Then use piecewise again on the result. This works, but wondering if there is a better way.
Attached worksheet.
expr := (s+exp(-Pi*s)-exp(-2*Pi*s))/(s*(s^2+2*s+2))
exp(-t)*sin(t)+(1/2)*(-1+exp(-t+2*Pi)*(cos(t)+sin(t)))*Heaviside(t-2*Pi)+(1/2)*(1+exp(-t+Pi)*(cos(t)+sin(t)))*Heaviside(t-Pi)
piecewise(t < Pi, exp(-t)*sin(t), t = Pi, undefined, t < 2*Pi, exp(-t)*sin(t)+1/2+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)), t = 2*Pi, undefined+(1/2)*exp(-Pi), 2*Pi < t, exp(-t)*sin(t)+(1/2)*exp(-t+2*Pi)*(cos(t)+sin(t))+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)))
Y:=[op(Y)]:
Y:=seq([Y[n],Y[n+1]],n=1..nops(Y)-1,2):
ListTools:-Flatten(select(not has,[Y],'undefined')):
piecewise(op(%))
piecewise(t < Pi, exp(-t)*sin(t), t < 2*Pi, exp(-t)*sin(t)+1/2+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)), 2*Pi < t, exp(-t)*sin(t)+(1/2)*exp(-t+2*Pi)*(cos(t)+sin(t))+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)))
Download remove_undefined.mw
Another very strange result from simplify.  Consider
simplify(a*f(x) + b*f(x) + a*g(x))
Which is what is expected. Now
expr := a*f(x) + b*f(x) + a*g(x) + 1/(a*f(x) + b*f(x) + a*g(x));
simplify(expr)
gives
why?  I expected (a+b)*f(x) also in the first expression. Compare for reference the same thing in Mathematica where it does them both the same way:
You see it simplified it to (a+b)*f(x)+a*g(x) in both places as expected.
I tried using size option for simplify, but it had no effect.
How can one obtain same result shown above using Maple? And why it does not automatically produce this result?
Maple 2022.2
First 260 261 262 263 264 265 266 Last Page 262 of 2457
