Hi, I would appreciate some help in solving the following system of partial differential equations. The particularity of the system is that only the individual variables (i.e. a, c, and l) depend on two arguments (t: current time period and v: date of birth). The other variables are either rates or aggregates. The aggregate variables (i.e. K, L, and Y) depend only on time, t, because they are the integrals of the individual variables over v. Thanks for your help.
restart; with(PDEtools)
alpha := .3306341; delta := solve(1+0.4877489e-1 = exp(delta_a)); T := 1
l0 := 42.375*(33.16667/(52*(24-9.95)*7)); L0 := l0*T
x0 := 0
IOR := .2093723865
KOR := IOR/delta
r0 := alpha/KOR-delta; rho := r0; fsolve({K0 = Y0*KOR, w0 = (1-alpha)*Y0/L0, alpha*exp(x0)*K0^(alpha-1)*L0^(1-alpha) = r0+delta}); assign(%)
0.2758153402e-1
{K0 = 2.510740299, Y0 = .5710794198, w0 = 1.390997088}
C0 := -K0*delta+Y0; c0 := C0/T
.4515111588
.4515111588
sigma := w0*(1-l0)/c0
2.234133040
eq1 := diff(c(t, v), t) = (r(t)-rho)*c(t, v)
eq2 := sigma*c(t, v) = w(t)*(1-l(t, v))
eq3 := r(t)*a(t, v)+w(t)*l(t, v) = c(t, v)+diff(a(t, v), t)
eq4 := Y(t) = exp(x(t))*K(t)^alpha*L(t)^(1-alpha)
eq5 := r(t)-delta = alpha*Y(t)/K(t)
eq6 := w(t) = (1-alpha)*Y(t)/L(t)
eq7 := K(t) = int(a(t, v), v = t-T .. t)
eq8 := L(t) = int(l(t, v), v = t-T .. t)
eq9 := x(t) = piecewise(t = 0, 0, t > 0, 0.1e-1)
eq := {eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9}
SV := {K(0) = K0, L(0) = L0, Y(0) = Y0, a(t, 0) = 0, c(0, 0) = c0, l(0, 0) = l0, r(0) = r0, w(0) = w0}
pdsolve(eq, SV, numeric, 'time' = t, 'range' = 0 .. T)
Error, (in pdsolve/numeric/process_PDEs) variable(s) {v} are in the PDE system but are not dependent or independent variables
sol := pdsolve(eq, SV, 'time' = t, 'range' = 0 .. T)
Download OLG.mw
This might sound like a simple question, but I have looked pretty hard in the documentation and can't find a solution.  I want to plot functions in spherical coordinates in such a way that they are actually spherical.  For example, r = 1 should be a sphere.  All I can do is get the "cube" with sides labelled as the traditional variables r, theta, and phi.  That's not really spherical coordinates, it's just relabelled Cartesian.
I didn't make a worksheet for this topic.
I have been bothered lately by the number format for axis labels in Maple. My problem existed before, but it apparently didn't bother me before. I have spent many hours trying to find an answer in the program help, in MaplePrimes, and in general online searches. I am not having any luck at all (good luck, that is).
I want to change the format of the axis numbering. Maple seems to default to 2 decimal places in my graph, and I really need more. Oddly, when I export the graph to PDF, I get another decimal place (even though I didn't explicitly ask for one).
How do I change the axis-label format? Any idea what I might get when I export the graph?
Thanks for your help,
Jno.
How can I change the order of variables in a polynomial as I want? For example, I want to assign a polynomial G of 3 variables a,b,c. Then I want to compute G(a,b,c) (exchange the variable a to b, exchange variable b to a)?
Hello everybody
I would like to check, with Spacetime Tensors computation , if  a transfomation is a Lorentz transformation , i.e that leavs Minkosky metric invariant
For esample a boost  or axis rotation transformation
Some could help me ? ( Maple 2016)
Thank's a lot
I've probably asked about this long time ago but I do not remember now. But it is still a problem any way in 2022.2
Compare these two results
code is
alias(seq(c[k] = _C||k, k = 0..10));
c[1]*h(x);
Int(c[1]*h(x),x);
c[1]*h(x);
Int(c[1]*h(x),x);
I tried with typesetting level as extended and standard and same result.
Is this a know issue? It is not a big deal as it only affects display but it will be nice to find why it happens when using alias.
This a more a math question than  a maple programming question. But interesting.
I have a point P=[x,y] on a line y= 2+3x. The point maps to Pn=[f(x, y), g(x, y)]. That represents a conic.
I want to find the equation of the conic. I did it by calculating 5 points and that works fine but only because I know I'm looking for a conic.
Can the problem by solved without having to get the five points?
I copied and pasted the equations for the lines because they were generated by commands in a pagkage I have.
P := [X, Y]
[X, Y]
Pn := [(5*X+12*Y)*(-384+48*X+55*Y)/(225*X^2+225*Y^2-1800*X-602*Y), (2*(12*X-5*Y))*(-384+48*X+55*Y)/(225*X^2+225*Y^2-1800*X-602*Y)]
[(5*X+12*Y)*(-384+48*X+55*Y)/(225*X^2+225*Y^2-1800*X-602*Y), 2*(12*X-5*Y)*(-384+48*X+55*Y)/(225*X^2+225*Y^2-1800*X-602*Y)]
Y := 2+3*Xn
2+3*X
for i to 5 do P || i := eval(Pn, X = i) end do
[181139/51416, -19775/25708]
l12 := 153621*x*(1/68840)+169429*y*(1/27536)-15067/17210
(153621/68840)*x+(169429/27536)*y-15067/17210
l34 := -5733*x*(1/473062)+258973*y*(1/946124)+244205/946124
-(5733/473062)*x+(258973/946124)*y+244205/946124
c1 := l12*l34
((153621/68840)*x+(169429/27536)*y-15067/17210)*(-(5733/473062)*x+(258973/946124)*y+244205/946124)
l13 := 5499*x*(1/2360)+6539*y*(1/944)-793/472
(5499/2360)*x+(6539/944)*y-793/472
l24 := 596115*x*(1/6899489)+7228091*y*(1/6899489)+195364/363131
(596115/6899489)*x+(7228091/6899489)*y+195364/363131
plots:-implicitplot([l12, l34, l13, l24])
c2 := l13*l24
((5499/2360)*x+(6539/944)*y-793/472)*((596115/6899489)*x+(7228091/6899489)*y+195364/363131)
c := simplify(c2*lambda+c1)
(655607277/3256558808)*(x+(2515/846)*y-305/423)*(x+(556007/45855)*y+285532/45855)*lambda-(880709193/32565588080)*(x-(19921/882)*y-18785/882)*(x+(65165/23634)*y-4636/11817)
lambda := solve(eval(c, [x = P5[1], y = P5[2]]), lambda)
-1/4
simplify(c)
-(5039454771/65131176160)*x^2+(1/130262352320)*(-29130506847*y+40315638168)*x-(423368829/3256558808)*y^2+(111619143207/130262352320)*y
plt1 := plot(Y, X = -10 .. 10)
plt2 := plots:-implicitplot([c])
plots:-display(plt1, plt2, colour = ["Red", "Green"])
for i in [-7, 13/3, 42*(1/7)] do x := eval(Pn[1], X = i); y := eval(Pn[2], X = i); simplify(c) end do
Download Q_23-03-04_how_to_find_conic_from_mapping.mw
Dears,
I have a problem whem try to solve a optimization probolem.
The equations are "complex" (G1 equation), and this error is showed "Error, (in Optimization:-NLPSolve) could not store 0.1749271137e-1*(588.000000000000+72.0000000000000*(-3.03333333+.333333333333333*MM)*(MM-17.80)+72.0000000000000*(.333333333333333*NN-3.5666666666667)*(17.00-1.*NN)+24.50000000*(2.90+4.666666667*tan(1.000000000*arctan(.166666666666667*MM-2.96666666666667)))*(18.00+5.627472876000*sin(-1.570796327+1.000000000*arctan(.166666666666667*MM-2.96666666666667))/sin(-1.745329252+1.000000000*arctan(.166666666666667*MM-2.96666666666667)))*cos(-.5235987756000+1.000000000*arctan(.166666666666667*MM-2.96666666666667))^2*sin(.3490658504000+1.000000000*arctan(.166666666666667*MM-2.9666 ... 756000+1.000000000*arctan(.166666666666667*MM-2.96666666666667))^2)-1. in a floating-point rtable".
Someone can help me?
ATS := proc(NN::float, MM::float)
L[7]*H[4] + L[4]*H[2] + L[1]*(H[1] - H[2]) + 1/2*(P[X1] - NN)*(H[1] - H[2]) + 1/2*(MM - P[XF])*(H[1] - H[2]);
bounds := 14.90 .. 16.90, 17.90 .. 19.90;
cstr8 := proc(NN::float, MM::float)
G1 - FS;
NLPSolve(ATS, {cstr8}, bounds, initialpoint = [15.90, 18.90], assume = nonnegative)
Hi MaplePrimes,
I am interested in obtaining some gravitational field equations from an action using the FunDiff command. I have been able to write what I think is a pretty short and quick worksheet(with an arbitrary metric) and I am easily able to obtain the Einstein Field Equations. However, when I introduce some new more complicated terms into the action and apply the Simplify command maple does not appear to be able to evaluate and I end up halting the computation. When I specify a metric Maple, for example Schwarzschild, Maple will easily be able to Simplify my expression but it will use metric components during the process. Where what I am interested in is just the Tensor expression with respective indices.
I was wondering if anyone had any thoughts on how I could resolve this.
I have attached the worksheet that I am working with. I look forward to your thoughts/comments.
ActionFieldEquations.mw
If we use, for example, pointplot3d with an mx3 matrix we get a 3d plot. I can click on the plot and choose the lighting. But how do we do that with code?
Maple continuously shows 'Evaluating' and there is no output. How to fix it?
with(LinearAlgebra)
assume(x::real); assume(t::real); assume(`α__1`::real); assume(`α__2`::real); assume(nu::real)
A2s := Matrix([[H__11*exp(I*v__11)/(`λ__1`-conjugate(`λ__1`))+H__13*exp(I*v__21)/(`λ__1`-conjugate(`λ__2`))+1, H__12*exp(-I*v__11)/(`λ__1`-conjugate(`λ__1`))+H__14*exp(-I*v__21)/(`λ__1`-conjugate(`λ__2`)), H__11*exp(I*v__12)/(`λ__2`-conjugate(`λ__1`))+H__13*exp(I*v__22)/(`λ__2`-conjugate(`λ__2`)), H__12*exp(-I*v__12)/(`λ__2`-conjugate(`λ__1`))+H__14*exp(-I*v__22)/(`λ__2`-conjugate(`λ__2`))], [H__12*exp(I*v__11)/(`λ__1`-conjugate(`λ__1`))+H__14*exp(I*v__21)/(`λ__1`-conjugate(`λ__2`)), 1+H__11*exp(-I*v__11)/(`λ__1`-conjugate(`λ__1`))+H__13*exp(-I*v__21)/(`λ__1`-conjugate(`λ__2`)), H__12*exp(I*v__12)/(`λ__2`-conjugate(`λ__1`))+H__14*exp(I*v__22)/(`λ__2`-conjugate(`λ__2`)), H__11*exp(-I*v__12)/(`λ__2`-conjugate(`λ__1`))+H__13*exp(-I*v__22)/(`λ__2`-conjugate(`λ__2`))], [H__13*exp(I*v__11)/(`λ__1`-conjugate(`λ__1`))+H__33*exp(I*v__21)/(`λ__1`-conjugate(`λ__2`)), H__14*exp(-I*v__11)/(`λ__1`-conjugate(`λ__1`))+H__34*exp(-I*v__21)/(`λ__1`-conjugate(`λ__2`)), 1+H__13*exp(I*v__12)/(`λ__2`-conjugate(`λ__1`))+H__33*exp(I*v__22)/(`λ__2`-conjugate(`λ__2`)), H__14*exp(-I*v__12)/(`λ__2`-conjugate(`λ__1`))+H__34*exp(-I*v__22)/(`λ__2`-conjugate(`λ__2`))], [H__14*exp(I*v__11)/(`λ__1`-conjugate(`λ__1`))+H__34*exp(I*v__21)/(`λ__1`-conjugate(`λ__2`)), H__13*exp(-I*v__11)/(`λ__1`-conjugate(`λ__1`))+H__33*exp(-I*v__21)/(`λ__1`-conjugate(`λ__2`)), H__14*exp(I*v__12)/(`λ__2`-conjugate(`λ__1`))+H__34*exp(I*v__22)/(`λ__2`-conjugate(`λ__2`)), H__13*exp(-I*v__12)/(`λ__2`-conjugate(`λ__1`))+H__33*exp(-I*v__22)/(`λ__2`-conjugate(`λ__2`))+1]])
Matrix(%id = 36893490803012390908)
vvalue := {v__11 = (conjugate(`λ__1`)-`#msub(mi("λ",fontstyle = "normal"),mn("1"))`)*x+(4*`α__1`*(conjugate(`λ__1`)^3-`λ__1`^3)+2*`α__2`*(conjugate(`λ__1`)^2-`λ__1`^2)-8*nu*(conjugate(`λ__1`)^4-`λ__1`^4))*t, v__12 = (conjugate(`λ__1`)-`#msub(mi("λ",fontstyle = "normal"),mn("2"))`)*x+(4*`α__1`*(conjugate(`λ__1`)^3-`λ__2`^3)+2*`α__2`*(conjugate(`λ__1`)^2-`λ__2`^2)-8*nu*(conjugate(`λ__1`)^4-`λ__2`^4))*t, v__21 = (conjugate(`λ__2`)-`#msub(mi("λ",fontstyle = "normal"),mn("1"))`)*x+(4*`α__1`*(conjugate(`λ__2`)^3-`λ__1`^3)+2*`α__2`*(conjugate(`λ__2`)^2-`λ__1`^2)-8*nu*(conjugate(`λ__2`)^4-`λ__1`^4))*t, v__22 = (conjugate(`λ__2`)-`#msub(mi("λ",fontstyle = "normal"),mn("2"))`)*x+(4*`α__1`*(conjugate(`λ__2`)^3-`λ__2`^3)+2*`α__2`*(conjugate(`λ__2`)^2-`λ__2`^2)-8*nu*(conjugate(`λ__2`)^4-`λ__2`^4))*t}
{v__11 = (conjugate(lambda__1)-`#msub(mi("λ",fontstyle = "normal"),mn("1"))`)*x+(4*alpha__1*(conjugate(lambda__1)^3-lambda__1^3)+2*alpha__2*(conjugate(lambda__1)^2-lambda__1^2)-8*nu*(conjugate(lambda__1)^4-lambda__1^4))*t, v__12 = (conjugate(lambda__1)-`#msub(mi("λ",fontstyle = "normal"),mn("2"))`)*x+(4*alpha__1*(conjugate(lambda__1)^3-lambda__2^3)+2*alpha__2*(conjugate(lambda__1)^2-lambda__2^2)-8*nu*(conjugate(lambda__1)^4-lambda__2^4))*t, v__21 = (conjugate(lambda__2)-`#msub(mi("λ",fontstyle = "normal"),mn("1"))`)*x+(4*alpha__1*(conjugate(lambda__2)^3-lambda__1^3)+2*alpha__2*(conjugate(lambda__2)^2-lambda__1^2)-8*nu*(conjugate(lambda__2)^4-lambda__1^4))*t, v__22 = (conjugate(lambda__2)-`#msub(mi("λ",fontstyle = "normal"),mn("2"))`)*x+(4*alpha__1*(conjugate(lambda__2)^3-lambda__2^3)+2*alpha__2*(conjugate(lambda__2)^2-lambda__2^2)-8*nu*(conjugate(lambda__2)^4-lambda__2^4))*t}
A2s2 := Determinant(A2s); dets22 := simplify(A2s2, size); length(%)
8949
dets22f := simplify(subs(vvalue, dets22))
Download sol1det.mw
Hello. I work with vector fields and 1-forms with the package DifferentialGeometry. I need to copy the output in a latex file, but when I use copy paste what I get is the internal representation of the 1-forms, for example, something like
_DG([[\"form\", M, 1], [[[1], x2/x4], [[2], -1]]])
But what I need is something like:
x2/x4 dx1-(`*`(dx2))
which is what I see at the screen. I have tried lot of commands but I don't get what I want.
Here is the basic code:
with(DifferentialGeometry);
with(JetCalculus);
DGsetup([x1, x2, x3], M);
w:=evalDG(x2/x4 dx1-dx2)
I'm using Maple 2022.  I'm using fsolve to solve for values of 3 variables and I've created a function that looks like
solution := (TtT, FtT) -> fsolve({eq1, eq2, eq3},{Y,P,PY},{Y=0..100,P=0..100,PY=0..100})
this works fine, giving answers like
solution(1, 0.5);
    {P = 0.1813175442, PY = 0.1593412279, Y = 0.4393982627}
I'd like to plot Y vs TtT at a fixed FtT of 0.5 so I defined a second function
YFtpt5 := TtT -> solution(TtT, 0.5)[3]
this also works fine, giving
YFtpt5(10);
                       Y = 0.02320766980
so I try to plot it with a range variable like this
with plots:
plot(YFtpt5,0.01..10)
but this gives the error
plot(YFtpt5, 0.01 .. 10);
It draws axis but no plot.  I've evaluated the function at 0.01,10, and a number of points in between and everything I've tried gives a numeric answer.  Is it because the answer is "Y=0.43"  or something else.
Help, have no idea what to do.
Obtain a finite topological space from a dynamical system specified as a system of ODEs, by writing Maple code for following steps (use Maple packages DynamicSytems and GraphTheory, preferablly):
  1. Visualize the phase space of the system by plotting solution curves for different initial conditions.
  2. Consider a finite region of the phase space.
  3. Define a finite grid of points in the region.
  4. Define a topology on the grid points based on their connectivity.
  5. Give some useful information regarding the dynamical system in terms of topological properties.
Article https://mapleprimes.com/posts/208409-Downloading-Historical-Stock-Quotes has worked well for the last few years.
Somewhere in the last 6 months Yahoo has changed the method. Crumbstore no longer exists within the page source.
Does anyone have a method that currently works.
Problem is also verified at: https://www.solveforum.com/forums/threads/solved-yahoo-finance-cookie-and-crumb-not-working.2316600/ ,however they do not have a solution.
First 265 266 267 268 269 270 271 Last Page 267 of 2457
