In 1D-Math an inert division can be entered as an infix operator using "%/"
The same sequence of chracters does not work the same way in 2D-Math
In 2D-Math I have to use
Is there an infix division operator in 2D-Math?
Is there a helppage describing %arithop and the like?
I was reading a book on complex analysis, and I tried to answer some questions like "Find and plot the sixth roots of unity on Maple."  I tried the following code, which works. Is there any other way to solve and plot the same question?
with(plots); interface(imaginaryunit = 'I'); s := [seq(exp(2*I*Pi*k*(1/6)), k = 0 .. 5)]; X := [seq(Re(s[k]), k = 1 .. 6)]; Y := [seq(Im(s[k]), k = 1 .. 6)]
[1, 1/2+((1/2)*I)*3^(1/2), -1/2+((1/2)*I)*3^(1/2), -1, -1/2-((1/2)*I)*3^(1/2), 1/2-((1/2)*I)*3^(1/2)]
[1, 1/2, -1/2, -1, -1/2, 1/2]
[0, (1/2)*3^(1/2), (1/2)*3^(1/2), 0, -(1/2)*3^(1/2), -(1/2)*3^(1/2)]
UnitCircle := plot([cos(t), sin(t), t = 0 .. 2*Pi], color = gray, linestyle = dash); RootsPlot := pointplot([X, Y], symbol = solidcircle, color = blue, symbolsize = 10); display(UnitCircle, RootsPlot, scaling = constrained, title = "6th Roots of Unity")
Download 6th_roots_of_unity.mw
I want to plot some 2D polygon shapes in one plot. Every shape should have their own color.
for example: from the Plasma colorschem "Plasma 212"
Can somebody give me an example code ?
Best regards Jannis
I have several sets of nonlinear equations that need to be solved for certain unknowns. In many cases, the equations admit more than one solution, and Maple is sometimes able to find different solutions by changing the order of the unknowns.
However, in one particular case, I haven't been able to get Maple to find a known solution that was obtained elsewhere.
Below are the equations, the list of unknowns, the solution returned by Maple, and the alternative solution I'm trying to obtain.
Is there a way to guide Maple to find this other solution?
eqjerkAB:=[-alpha[9, 1, 1] - alpha[9, 2, 2] - alpha[9, 3, 3] = -alpha[14, 1, 1] - alpha[14, 2, 2] - alpha[14, 3, 3], alpha[9, 1, 1] + alpha[9, 2, 2] = alpha[14, 1, 1] + alpha[14, 2, 2], -alpha[9, 2, 6]*alpha[9, 3, 5] = -alpha[14, 2, 6]*alpha[14, 3, 5], alpha[9, 1, 1]*alpha[9, 3, 3] + alpha[9, 2, 2]*alpha[9, 3, 3] = alpha[14, 1, 1]*alpha[14, 3, 3] + alpha[14, 2, 2]*alpha[14, 3, 3], alpha[9, 1, 1]*alpha[9, 2, 6]*alpha[9, 3, 5] - alpha[9, 1, 2]*alpha[9, 2, 6]*alpha[9, 3, 4] = alpha[14, 1, 1]*alpha[14, 2, 6]*alpha[14, 3, 5], -alpha[9, 1, 1]*alpha[9, 2, 2]*alpha[9, 3, 3] - alpha[9, 1, 2]*alpha[9, 2, 6]*alpha[9, 3, 0] = -alpha[14, 1, 1]*alpha[14, 2, 2]*alpha[14, 3, 3] + alpha[14, 1, 2]*alpha[14, 2, 1]*alpha[14, 3, 3]]:
incA:={alpha[9, 1, 1], alpha[9, 1, 2], alpha[9, 2, 2], alpha[9, 2, 6], alpha[9, 3, 0], alpha[9, 3, 3], alpha[9, 3, 4], alpha[9, 3, 5]}:
solM:=[alpha[9, 1, 1] = (alpha[9, 1, 2]*alpha[9, 2, 6]*alpha[9, 3, 4] + alpha[14, 1, 1]*alpha[14, 2, 6]*alpha[14, 3, 5])/(alpha[14, 2, 6]*alpha[14, 3, 5]), alpha[9, 1, 2] = alpha[9, 1, 2], alpha[9, 2, 2] = (-alpha[9, 1, 2]*alpha[9, 2, 6]*alpha[9, 3, 4] + alpha[14, 2, 2]*alpha[14, 2, 6]*alpha[14, 3, 5])/(alpha[14, 2, 6]*alpha[14, 3, 5]), alpha[9, 2, 6] = alpha[9, 2, 6], alpha[9, 3, 0] = alpha[14, 3, 3]*(-alpha[14, 1, 2]*alpha[14, 2, 1]*alpha[14, 2, 6]^2*alpha[14, 3, 5]^2 + alpha[9, 1, 2]*alpha[14, 3, 5]*alpha[9, 2, 6]*alpha[9, 3, 4]*(alpha[14, 1, 1] - alpha[14, 2, 2])*alpha[14, 2, 6] + alpha[9, 1, 2]^2*alpha[9, 2, 6]^2*alpha[9, 3, 4]^2)/(alpha[9, 1, 2]*alpha[9, 2, 6]*alpha[14, 3, 5]^2*alpha[14, 2, 6]^2), alpha[9, 3, 3] = alpha[14, 3, 3], alpha[9, 3, 4] = alpha[9, 3, 4], alpha[9, 3, 5] = alpha[14, 2, 6]*alpha[14, 3, 5]/alpha[9, 2, 6]]:
solother:={alpha[9,2,2]=-alpha[9,1,1] + alpha[14,1,1] + alpha[14,2,2],
alpha[9,3,0] = (((alpha[9,1,1] - alpha[14,1,1])*(alpha[9,1,1] - alpha[14,2,2]) - alpha[14,1,2]*alpha[14,2,1])*alpha[14,3,3])/(alpha[9,1,2]*alpha[9,2,6]),
alpha[9,3,3] = alpha[14,3,3],
alpha[9,3,4] = (alpha[9,1,1] - alpha[14,1,1])*alpha[14,2,6]*alpha[14,3,5]/(alpha[9,1,2]*alpha[9,2,6]),
alpha[9,3,5] = alpha[14,2,6]*alpha[14,3,5]/alpha[9,2,6]}:
Many thanks.
Ed
I want to run Maple Linux builds under Windows. I know that this can be done with a virtual machine but that's it.
Are there other options to do that?
I would go for an easy installation with the possibilty to save and load files from the Windows file system and ideally to copy/paste screen content from and to Windows applications.
Any recommendations and/or references?
i did this question before but i didn't get any answer before, but the shape of question is different, the function is different this time i try 3 term like they mention in that paper so there  must be a way for finding R[2],R[1], and R[0]
Download Find-U-in-PDE.mw
why i get error in end and how i can fix this error?
with(PDEtools)
undeclare(prime, quiet); declare(u(x, y, t), quiet); declare(f(x, y, t), quiet)
theta := i -> t*w[i]+y*l[i]+x:
eqf := f(x, y, t) = theta(1)*theta(2)+Bij(1, 2):
eqfcomplex := eval(eqf, l[2] = conjugate(l[1])):
eq17 := u(x, y, t) =2*diff(f(x, y, t), x)/f(x, y, t):
equ := eval(eq17, eqfcomplex):
sys := map(normal, {diff(rhs(equ), x), diff(rhs(equ), y)}):
nsys  := map(numer, sys):
nroot := solve(nsys, {x, y}, explicit):
dsys  := map(denom, sys):
droot := solve(dsys, {x, y}, explicit):
{nroot} intersect {droot}
compact_ans1 := nroot[1]:
__w := seq(w[i] = (-beta*l[i]^2 - b*l[i] - a), i=1..2):
__Bij := (i,j) -> 12*alpha/(beta*(l[i] - l[j])^2):
eval(eval(compact_ans1, {__w, Bij(1, 2) = __Bij(1, 2)}), l[1]=lambda[1]+I*lambda[2])
assuming lambda[1]::real, lambda[2]::real:
ans1 := map(simplify, %, size): # it's up to you to use another simplification strategy
eqp1 := eval(eval(ans1, l[2] = conjugate(l[1])), l[1] = lambda[1]+I*lambda[2])
# Do the same for the other nroot solutions
eqp := {x = xp+((1/2)*beta*lambda[2]^3+I*(-beta*lambda[1]-b)*lambda[2]^2*(1/2)-((1/2)*beta*conjugate(lambda[1]+I*lambda[2])^2-(1/2)*beta*lambda[1]^2+(1/2)*b*conjugate(lambda[1]+I*lambda[2])+a)*lambda[2]+I*lambda[1]*(conjugate(lambda[1]+I*lambda[2])-lambda[1])*(beta*conjugate(lambda[1]+I*lambda[2])+beta*lambda[1]+b)*(1/2))*t/lambda[2], y = yp-(I*beta*lambda[2]^2+(2*beta*lambda[1]+b)*lambda[2]+I*((conjugate(lambda[1]+I*lambda[2])+lambda[1])*beta+b)*(conjugate(lambda[1]+I*lambda[2])-lambda[1]))*t/(2*lambda[2])}
vx, vy := diff(eval(x, eqp), t), diff(eval(y, eqp), t); dydx := simplify(vy/vx)
eqfp := dchange(eqp, eqfcomplex, [xp, yp], params = [a, b, alpha, beta, `λ__1`, `λ__2`], simplify); eq17p := dchange(eqp, eq17, [xp, yp], params = [a, b, alpha, beta, `λ__1`, `λ__2`], simplify); eqt := simplify(eval(eq17p, eqfp))
eqt1 := eval(subs({xp = x, yp = y}, eqt), l[1] = lambda[1]+I*lambda[2])
with(plots); lambda[1] := .14; lambda[2] := .68; alpha := -.46; beta := 1.83; a := 1.56; b := -.19; eq := y = (-beta*conjugate(lambda[1]+I*lambda[2])^2-b*conjugate(lambda[1]+I*lambda[2])-beta*lambda[2]^2+I*(2*beta*lambda[1]+b)*lambda[2]+lambda[1]*(beta*lambda[1]+b))*(x+(2*I)*sqrt(3)*lambda[1]*sqrt(alpha/(beta*(lambda[1]+I*lambda[2]-conjugate(lambda[1]+I*lambda[2]))^2))/lambda[2])/((lambda[1]+I*lambda[2])*beta*conjugate(lambda[1]+I*lambda[2])^2+(lambda[1]+I*lambda[2])*b*conjugate(lambda[1]+I*lambda[2])-I*beta*lambda[2]^3+(-beta*lambda[1]-b)*lambda[2]^2+I*(-beta*lambda[1]^2+2*a)*lambda[2]-beta*lambda[1]^3-b*lambda[1]^2); U := proc (x, y, a, b, alpha, beta, `λ__1`, `λ__2`) options operator, arrow; rhs(eqt1) end proc; contour1 := contourplot(eval(U(x, y, a, b, alpha, beta, `λ__1`, `λ__2`), t = -50), x = -200 .. 200, y = -100 .. 100, contours = 30, color = red, grid = [100, 100], transparency = .1); contour2 := contourplot(eval(U(x, y, a, b, alpha, beta, `λ__1`, `λ__2`), t = 0), x = -200 .. 200, y = -100 .. 100, contours = 30, color = green, grid = [100, 100], transparency = .1); contour3 := contourplot(eval(U(x, y, a, b, alpha, beta, `λ__1`, `λ__2`), t = 50), x = -200 .. 200, y = -100 .. 100, contours = 30, color = blue, grid = [100, 100], transparency = .1); trajectory_plot := implicitplot(eq, x = -200 .. 200, y = -200 .. 200, color = black, thickness = 1); T := textplot([[100, 45, "t=50", color = blue], [45, -10, "t=0", color = green], [-100, -45, "t=-50", color = red]], font = [Times, Roman, 16]); display(contour1, contour2, contour3, trajectory_plot, T, labels = ["x", "y"], scaling = constrained, size = [1200, 800])
.14
.68
-.46
1.83
1.56
-.19
y = (.4755583090+0.*I)*(x+(-0.+.1517971372*I)*3^(1/2))
proc (x, y, a, b, alpha, beta, lambda__1, lambda__2) options operator, arrow; rhs(eqt1) end proc
Error, (in plot/iplot2d) invalid input: Plot:-ColorBar expects its 2nd argument, ymin, to be of type numeric, but received infinity
Error, (in plots:-display) expecting plot structure but received: contour1
8
Download line-plot.mw
( squircle is the humoristic name for the 2D open ball of center 0 and radius 1 in Ln norm ).
The equation of the squircle in Ln norm writes  |x|n+|y|n = 1
The attached file gives the exact values of the areas of squircles in norms L2L4L100L1
Unless for n=2 the results are dramatically poor (evalf/Int gives the same wrong results).
The function a(n) gives the exact expression of the squircle area in  Ln norm.
squircle.mw
How do I change the legend position so it doesn't cover the plot label?
Before entertaining non-standard solutions to this problem such as building my own from scratch, is the a standard method for changing the position of the default legend generated along with a standard plot? I couldn't find anything about custom legend positions in the help sheets.
I can't help but wonder why this observed behaviour occurs by default? In what kind of plot would I prefer the plot labels to be obscured by the plot legend?
legend_covers_plot_labels.mw
I coppied the Maple.ini file follwing ?worksheet,reference,preferencesfile.
My favorite palette however was not coppied.
How to do this?
I will look for sensitivity analysis for parameters in the epidemic model using the normalization formula, the result should be between -1 to 1 but there are 2 parameters whose values ​​are more than 1, how do I set the limit so that the sensitivity value is between -1 to 1?
with(VectorCalculus):
with(linalg):
_local(I):
I
Warning, The imaginary unit, I, has been renamed _I
dS := VectorCalculus:-`+`(VectorCalculus:-`+`(Lambda, VectorCalculus:-`-`(VectorCalculus:-`*`(VectorCalculus:-`*`(alpha, S), P))), VectorCalculus:-`-`(VectorCalculus:-`*`(mu, S)));
-P*S*alpha-S*mu+Lambda
alpha*S*P-(-T*eta+1)*beta*E-theta*E-mu*E
(-T*eta+1)*beta*E-delta*I-gamma*I-mu*I
E*theta+I*gamma-R*mu
-P*T*sigma+I*xi-P*tau
r*T*(1-T/K)-phi*T
Ro := VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(Lambda, alpha), beta), r), xi), VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`-`(VectorCalculus:-`*`(VectorCalculus:-`*`(K, eta), phi)), VectorCalculus:-`*`(VectorCalculus:-`*`(K, eta), r)), VectorCalculus:-`-`(r))), 1/VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(mu, VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(K, phi), sigma), VectorCalculus:-`-`(VectorCalculus:-`*`(VectorCalculus:-`*`(K, r), sigma))), VectorCalculus:-`-`(VectorCalculus:-`*`(r, tau)))), VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(K, beta), eta), phi), VectorCalculus:-`-`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(K, beta), eta), r))), VectorCalculus:-`*`(beta, r)), VectorCalculus:-`*`(mu, r)), VectorCalculus:-`*`(r, theta))), VectorCalculus:-`+`(VectorCalculus:-`+`(delta, gamma), mu)));
Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))
`as1_Λ` := VectorCalculus:-`*`(diff(Ro, Lambda), VectorCalculus:-`*`(Lambda, 1/Ro));
`as1_μ` := VectorCalculus:-`*`(diff(Ro, mu), VectorCalculus:-`*`(mu, 1/Ro));
(-Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r)/(mu^2*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))-Lambda*alpha*beta*r^2*xi*(-K*eta*phi+K*eta*r-r)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)^2*(delta+gamma+mu))-Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu)^2))*mu^2*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu)/(Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r))
`as1_η` := VectorCalculus:-`*`(diff(Ro, eta), VectorCalculus:-`*`(eta, 1/Ro));
(Lambda*alpha*beta*r*xi*(-K*phi+K*r)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))-Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r)*(K*beta*phi-K*beta*r)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)^2*(delta+gamma+mu)))*eta*mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu)/(Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r))
`as1_β` := VectorCalculus:-`*`(diff(Ro, beta), VectorCalculus:-`*`(beta, 1/Ro));
(Lambda*alpha*r*xi*(-K*eta*phi+K*eta*r-r)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))-Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r)*(K*eta*phi-K*eta*r+r)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)^2*(delta+gamma+mu)))*mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu)/(Lambda*alpha*r*xi*(-K*eta*phi+K*eta*r-r))
`as1_θ` := VectorCalculus:-`*`(diff(Ro, theta), VectorCalculus:-`*`(theta, 1/Ro));
-r*theta/(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)
`as1_τ` := VectorCalculus:-`*`(diff(Ro, tau), VectorCalculus:-`*`(tau, 1/Ro));
r*tau/(K*phi*sigma-K*r*sigma-r*tau)
as1_r := VectorCalculus:-`*`(diff(Ro, r), VectorCalculus:-`*`(r, 1/Ro));
(Lambda*alpha*beta*xi*(-K*eta*phi+K*eta*r-r)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))+Lambda*alpha*beta*r*xi*(K*eta-1)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))-Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r)*(-K*sigma-tau)/(mu*(K*phi*sigma-K*r*sigma-r*tau)^2*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))-Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r)*(-K*beta*eta+beta+mu+theta)/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)^2*(delta+gamma+mu)))*mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu)/(Lambda*alpha*beta*xi*(-K*eta*phi+K*eta*r-r))
`as1_φ` := VectorCalculus:-`*`(diff(Ro, phi), VectorCalculus:-`*`(phi, 1/Ro));
(-Lambda*alpha*beta*r*xi*K*eta/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))-Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r)*K*sigma/(mu*(K*phi*sigma-K*r*sigma-r*tau)^2*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu))-Lambda*alpha*beta^2*r*xi*(-K*eta*phi+K*eta*r-r)*K*eta/(mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)^2*(delta+gamma+mu)))*phi*mu*(K*phi*sigma-K*r*sigma-r*tau)*(K*beta*eta*phi-K*beta*eta*r+beta*r+mu*r+r*theta)*(delta+gamma+mu)/(Lambda*alpha*beta*r*xi*(-K*eta*phi+K*eta*r-r))
param := Lambda = 0.133e-1, alpha = 0.7954551e-1, delta = .9, K = 300, r = 0.76e-1, tau = 0.900982e-1, gamma = 0.917e-2, mu = 0.56e-3, phi = 0.9e-1, eta = 0.9e-2, sigma = 0.456e-3, beta = .567, theta = 0.9e-2, xi = 0.487e-1:
subs(param, `svΛ` = `as1_Λ`);
`svΛ` = 1
`svμ` = -1.001267817
`svη` = 0.3698561176e-2
`svβ` = 0.1113482136e-1
`svθ` = -0.1048257226e-1
`svτ` = -1.388300446
svr = -2.519993617
`svφ` = 2.519993621
Download sensitivity.mw
How does one create a new section using UI in Maple 2025?
I've done this many times in Maple 2024. To make section there, I simply do
   Insert -> Section
But I am not able to find this using the UI in Maple 2025, under insert
Ofcourse, I know I can add section using
                    CTRL .
which works. But I was wondering, where is insert section is in the GUI? Hard to find. I do not see anything called section in the menu there., I tried few of the other items, but so far, can't find section.
Is it possible to reduce icon shaps in the top bar in Maple 2025 UI? It takes too much vertical space
Here is how Maple 2024 UI look in worksheet mode:
Compare to same thing in Maple 2025, worksheet mode
Comparing just the top bars, we see 2025 is much large and takes too much space.
We see Maple 2025 takes about twice as much vertical space as Maple 2024 from top of window to the first > in the worksheet.
Is it possible to have top bar in Maple 2025 with small icons or minimized somehow?
I also find the blank gray line annoying above the |> in Maple 2025 and I have no idea what it is there.
Over all, I like Maple 2024 UI much more. Easier to look at on the eye for me. The dark gray background is annoying for me to look at.
Can I open Maple 2025 files in Maple 2024? Further, what if the files don't use Maple 2025 features/packages? Does that change the outcome?
Using inttrans package fourier (Dirac(t-T),t,w) gives the correct answer
exp(-I*T*w).
Taking immediatel the inverse transform I get only
invfourier(exp(-I*T*w), w, t),
but the the expression remains unevaluated and cannot be brought to evaluate by any means that I know. Funny thing: Taking just plain Fourier Transform and Inverse in the usual integral form "int" it works flawlessly. Apparently Maple knows how to deal with distributions in this context. What am I doing wrong?
First 25 26 27 28 29 30 31 Last Page 27 of 2429
