Below is the parametric identity, which i have found empirically: sqrt[pi] =(1/(2^j) ((k*gamma[5 + 2 j] gamma[ 1 + l] hypergeometricpfq[{1, 5/2 + j, 3 + j}, {3 + j + l/2, 7/2 + j + l/2}, -1])/ gamma[6 + 2 j + l] + ((k + m) gamma[7 + 2 j] gamma[ 1 + l] hypergeometricpfq[{1, 7/2 + j, 4 + j}, {4 + j + l/2, 9/2 + j + l/2}, -1])/gamma[8 + 2 j + l]))/(2^(-5 - 3 j - l) gamma[ 5 + 2 j] gamma[ 1 + l] (k hypergeometricpfqregularized[{1, 5/2 + j, 3 + j}, {3 + j + l/2, 7/2 + j + l/2}, -1] + 1/2 (3 + j) (5 + 2 j) (k + m) hypergeometricpfqregularized[{1, 7/2 + j, 4 + j}, {4 + j + l/2, 9/2 + j + l/2}, -1]
It seems to be true for arbitrary j,k,l,m parameters where j, k, l and m are signed integer
For all tried specific sets of {j,k,l,m} above identity was confirmed by both mathematica based wolframalpha and maple.
Could this identity be simplified?
How this identity could be proven either by using mathematica and/or analyticall
Best regards,
Alexander R. Povolotsky
Is there any reason why the intersectplot can't plot the following curve?
plots:-intersectplot( x^2 + b*x + c , b^2 - 4*c , b = -4..4, c = -4..4, x = -4..4, color = red );
But it can plot the next one!
plots:-intersectplot( x , b^2 - 4*c , b = -4..4, c = -4..4, x = -4..4, color = red );
The output in the two cases respectively are shown below.
I am a bit confused that why the color option in the following plot3d does not work.
plot3d( [ b, ( b^2 ) / 4, -b / 2 ], b = -4 .. 4, c = -4 .. 4, thickness = 5, color = red  );
The output is the following.
I remember that once there was an option to provide to maple a given function and it produced a suitable DE that this function solves.
Can you remind me how to do it?
I remember there was such an option in the previous versions of maple.
Thanks in advance!
Dear people,
I have resolved the primitives of the equation of the odometric model.
I have plotted them to the Maple interface and I was thinking that it can have been done by the solver.
Nevertheless it has not been possible to do it.
Can you tell me if a package of Maple can resolve it ?
Best regards,
Edern Ollivier.
This is part of a package I put together in VScode. Testing it using CMaple.exe worked fine from the code editor. Then I imported it into Maple and saved it as a package, After ra restart  using using with(....) to load it, the special types defined in the package are not recognised. Procedures that don't check for the special types work ok. I have included one of each in the worksheet.
If I just read in the .mpl file things do work.
What is the cause of this problem?
A secondary question. If I use the same special types in another package. Would that cause a conflict if both are loaded together?
RationalTrigonometry:=module()
    option package;
    export
        AcuteObstuseQ,
        AcuteObstuseS,
        AltitudeQ,
        CircleParm,
        CircumCirQ,
        CfstoLeqn,
        CrossLaw,
        LinePrll,
        LinePrpnd,
        LinePts,
        LPproj,
        MedianQ,
        #QPrj,
        Quadrance,
        Quadrea,
        QQF,
        SolidSpread,
        SpreadLawQuadrea,
        SpreadLaw,
        SpreadPoly,
        Spread,
        Spreads123,
        TQF,
        TSF,
        UHG;
local MyModule,RelDPxyz,ppp,xpsn,ypsn,zpsn;
MyModule:= module()
uses TT= TypeTools;
global _T1, _T2L, _T2V, _T2VR, _T3L, _T3V, _T3VC, _T3VR, _T4L, _MyType,GeomClr,Prntmsg, prjpsn;
          GeomClr:="Blue";
          Prntmsg:="y";
          prjpsn:=3;
local
     MyTypes:= {_T1, _T2L, _T2V, _T2VR, _T3L, _T3V, _T3VC, _T3VR, _T4L},
     AllMyTypes:= MyTypes union {_MyType},
     ModuleLoad,
      ModuleUnload:= proc()
     local T;
          for T in AllMyTypes do if TT:-Exists(T) then TT:-RemoveType(T) end if; end do;
          return
     ModuleLoad:= proc()
     local
          g, #iterator over module globals
          e
          ModuleUnload();
          #op([2,6], ...) of a module is its globals.
          for g in op([2,6], thismodule) do
               e:= eval(g);
               #print("e",e);
               if g <> e and e in AllMyTypes then
                    error "The name %1 must be globally available.", g
               end if
          TT:-AddType(_T1, algebraic);
          TT:-AddType(_T2V, 'Vector(2, algebraic)');
          TT:-AddType(_T2VR, 'Vector[row](2, algebraic)');
          TT:-AddType(_T2L, [algebraic $ 2]);
          TT:-AddType(_T3V, 'Vector(3, algebraic)');
          TT:-AddType(_T3VC, 'Vector[column](3, algebraic)');
          TT:-AddType(_T3VR, 'Vector[row](3, algebraic)');
          TT:-AddType(_T3L, [algebraic $ 3]);
          TT:-AddType(_T4L, [algebraic $ 4]);
          TT:-AddType(_MyType, MyTypes);
          return
export
     WhichMyType:= proc(X)
     local S:= select(T-> X::T, MyTypes), n:= nops(S);
         printf("%a is ", X);
         if n=0 then printf("not any of the special types.\n")
         else printf("type %a.\n", `if`(n=1, S[], Amd(S[])))
         fi
export
     Dsp:= proc(msg:=" empty",prnt:=Prntmsg )
          if prnt = "y" then print(msg); end if;
     ModuleLoad()
     end module;
ppp:=proc(prjpsn)
     description " the position x,y,z or z,x,y in a Vector";
     if prjpsn=1 then
        xpsn:=2;
        ypsn:=3;
        zpsn:=1;
        xpsn:=1;
        ypsn:=2;
        zpsn:=3;
    return xpsn, ypsn, zpsn
#$include "Rational_Trigonometry\Quadruple Quad Formula.mpl"
#$include "Rational_Trigonometry\Quadrances_Overload_procs.mpl"
Quadrance :=overload([
   # 1 Quadrances p0 [x,y]
        proc(p0::{_T2L,_T2V}, clr := GeomClr,$)
                option overload;
                description "Calculates Quadrance of a [x,y] point";
                uses LinearAlgebra;
                if clr = "b" or clr = "B" or clr = "blue" or clr = "Blue" then
                                MyModule:-Dsp(" Blue");
                                        BilinearForm(p0, p0, conjugate = false) ;
                        elif clr = "r" or clr = "R" or clr = "red" or clr = "Red" then
                                MyModule:-Dsp(" Red");
                                        p0[1]^2 - p0[2]^2 ;
                        elif clr = "g" or clr = "G" or clr = "green" or clr = "Green" then
                                MyModule:-Dsp(" Green");
                                        2*p0[1]*p0[2];
        end proc,
# 7 Quadrances Point to Plane and intersection point 3D
        proc(p0::{_T3L,_T3V},pl::{_T4L,`+`,procedure},var::_T3L:=[x,y,z],$)
        option overload;
                local i, dlambda,nlambda,lambda,Q   ,intrP,  Vpn  ,f1  ;
                if pl::_T4L then
                        Vpn:=convert(pl,Vector[row]);
                 elif pl::{`+`,procedure} then
                        f1 := `if`(pl::procedure, pl(vars[]), pl);
                        Vpn:=<coeff(f1,var[1]),coeff(f1,var[2]),coeff(f1,var[3]),coeff(coeff(coeff(f1,var[3],0),var[2],0),var[1],0)>;
                end  if;
                nlambda:=(Vpn[1]*p0[1]+Vpn[2]*p0[2]+Vpn[3]*p0[3]+Vpn[4]);
                dlambda:=Vpn[1]^2+Vpn[2]^2+Vpn[3]^2;
                lambda:=nlambda/dlambda;
                intrP:=`<|>`(seq(p0[i]+lambda*Vpn[i],i=1..3));
                Q:=nlambda^2/dlambda;
                MyModule:-WhichMyType(pl);
                MyModule:-Dsp("Quadrance Point to Plane & intersect Point");
                return Q,intrP
                end proc,
        # 2 Quadrances p0 [x,y,z]
        proc(p0::{_T3L,_T3V}, clr := GeomClr,$)
                option overload;
                description "Calculates Quadrance of a [x,y,z] point Blue only";
                uses LinearAlgebra;
                         MyModule:-Dsp("Quadrance 3D Point Blue");
                                BilinearForm(p0, p0, conjugate = false);
                        else print("3D Not yet implimented for Red or Green Geometry" );
        end proc,
        # 3 Quadrances P0-P1 [x,y]
         proc(p0::{_T2L,_T2V},p1::{_T2L,_T2V}, clr := GeomClr,$)
                option overload;
                description "Quadrance between two [x,y] points";
                uses LinearAlgebra;
                                MyModule:-Dsp( "Quadrance between two 2D Points Blue") ;
                                 BilinearForm(p0 - p1, p0 - p1, conjugate = false);
                                        MyModule:-Dsp( "Quadrance between two 2D Points Red") ;
                                         (p0[1] - p1[1])^2 - (p0[2] - p1[2])^2;
                                        MyModule:-Dsp( "Quadrance between two 2D Points Green") ;
                                         (2*p1[1] - 2*p0[1])*(p1[2] - p0[2]);
        end proc,
        # 4 Quadrances p0-p1 [x,y,z]
        proc(p0::{_T3L,_T3V},p1::{_T3L,_T3V}, clr::string := GeomClr,$)
                option overload;
                description "Calculates Quadrance of between two points/vectors [x,y,z] Blue only";
                uses LinearAlgebra;
                                        MyModule:-Dsp( "Quadrance between two 3D Points Blue") ;
                        else print("Not at this point  implimented for Red or Green Geometry" );
        end proc,
        # 5 Quadrances Point to Line and intersection point 2D
        proc(p0::_T2L, l1::{_T3L,`+`,procedure}, vars::_T2L:=[x,y],clr:=GeomClr)
                option overload;
                local f1,P0:=p0,P1;
                if l1::_T3L then
                        P1:=l1;
                        f1 := `if`(l1::procedure, l1(vars[]), l1);
                        P1:=[coeff(f1,vars[1]),coeff(f1,vars[2]),coeff(coeff(f1,vars[1],0),vars[2],0)];
                        MyModule:-Dsp( "Quadrance 2D Point to Line & intersect Point Blue") ;
                        return (P0[1]*P1[1] + P0[2]*P1[2] + P1[3])^2/(P1[1]^2 + P1[2]^2),
                        [((-P0[2]*P1[2] - P1[3])*P1[1] + P0[1]*P1[2]^2)/(P1[1]^2 + P1[2]^2),
                        ((-P0[1]*P1[1] - P1[3])*P1[2] + P0[2]*P1[1]^2)/(P1[1]^2 + P1[2]^2)];
                        if P1[1]^2 - P1[2]^2 <> 0 then
                                MyModule:-Dsp( "Quadrance 2D Point to Line & intersect Point Red") ;
                                return (P0[1]*P1[1] + P0[2]*P1[2] + P1[3])^2/(P1[1]^2 - P1[2]^2),
                                [((-P0[2]*P1[2] - P1[3])*P1[1] - P0[1]*P1[2]^2)/(P1[1]^2 - P1[2]^2),
                                ((P0[1]*P1[1] + P1[3])*P1[2] + P0[2]*P1[1]^2)/(P1[1]^2 - P1[2]^2)];
                                "Null Red"
                        #"Input ERROR "Red"";
                        if P1[1]*P1[2] = 0 then
                                "Null Green";
                                 MyModule:-Dsp( "Quadrance 2D Point to Line & intersect Point Green") ;
                                return 1/2*(P0[1]*P1[1] + P0[2]*P1[2] + P1[3])^2/(P1[1]*P1[2]),
                                [1/2*(P0[1]*P1[1] - P0[2]*P1[2] - P1[3])/P1[1],
                                1/2*(-P0[1]*P1[1] + P0[2]*P1[2] - P1[3])/P1[2]];
                        "Input ERROR Green";
        end proc,
        # 6 Quadrances Point to Line and intersection point 3D
        proc(p0::{_T3L,_T3V},lP::{_T3L,_T3V},lV::{_T3V},$)
                option overload;
                local lambda , Q ,intrP ;
                lambda:=((p0[1]-lP[1])*lV[1]+(p0[2]-lP[2])*lV[2]+(p0[3]-lP[3])*lV[3])/(lV[1]^2+lV[2]^2+lV[3]^2);
                print(lambda);
                Q:=((p0[1]-lP[1]-lambda*lV[1])^2+(p0[2]-lP[2]-lambda*lV[2])^2+(p0[3]-lP[3]-lambda*lV[3])^2);
                intrP:=lP+lambda*lV;
                MyModule:-Dsp("Quadrance Point to 3D Line and Intersect Point");
                return Q,intrP
        end proc
QQF := proc(Q1, Q2, Q3, Q4)
 ((Q1 + Q2 + Q3 + Q4)^2 - 2*Q1^2 - 2*Q2^2 - 2*Q3^2 - 2*Q4^2)^2 = 64*Q2*Q1*Q3*Q4;
end module:
RationalTrigonometry:-Quadrance([0,2,3],<3,1,-1>,<2,1,2>);
1/3
25, Vector[column](%id = 36893489965928498348)
RationalTrigonometry:-Quadrance([4,-4,3],2*x-2*y+5*z+8,[x,y,z]);
2*x-2*y+5*z+8 is type _T1.
507/11, Vector[row](%id = 36893489965928500148)
RationalTrigonometry:-Quadrance([4,-4,3],[2,-2,5,8]);
[2, -2, 5, 8] is type _T4L.
507/11, Vector[row](%id = 36893489965928493652)
Qb:=RationalTrigonometry:-Quadrance([a,b],[c,d],"b");
(-c+a)^2+(-d+b)^2
RationalTrigonometry:-QQF(a,b,c,d)
((a+b+c+d)^2-2*a^2-2*b^2-2*c^2-2*d^2)^2 = 64*b*a*c*d
RationalTrigonometry:-QQF(10^2,5^2,2^2,3^2)
5760000 = 5760000
with(RationalTrigonometry)
[AcuteObstuseQ, AcuteObstuseS, AltitudeQ, CfstoLeqn, CircleParm, CircumCirQ, CrossLaw, LPproj, LinePrll, LinePrpnd, LinePts, MedianQ, QQF, Quadrance, Quadrea, SolidSpread, Spread, SpreadLaw, SpreadLawQuadrea, SpreadPoly, Spreads123, TQF, TSF, UHG]
Error, type `_T3L` does not exist
                       5760000 = 5760000
Download Q_2023-01-14_Package_not_Recognising_Types.mw
please help, thank you!
with(LinearAlgebra)
alias(u = u(x, t), ub = ub(x, t))
u, ub
z1 := (2*I)*u*(2*gamma*lambda^2+alpha*lambda-1/4)*(diff(ub, x))+(2*I)*ub*(-2*gamma*lambda^2+alpha*lambda-1/4)*(diff(u, x))+I*ub*gamma*(diff(u, x, x, x))+Typesetting[delayDotProduct](4*u*gamma, lambda*ub.u.ub, true)+Typesetting[delayDotProduct](4*ub*gamma, lambda*u.ub.u, true)+Typesetting[delayDotProduct]((3*I)*gamma, ub.u.ub.(diff(u, x)), true)+Typesetting[delayDotProduct]((3*I)*gamma, ub.u.(diff(ub, x)).u, true)+Typesetting[delayDotProduct]((3*I)*gamma, ub.(diff(u, x)).ub.u, true)+Typesetting[delayDotProduct]((3*I)*gamma, (diff(ub, x)).u.ub.u, true)+Typesetting[delayDotProduct](I*gamma, (diff(u, x)).(diff(ub, x, x)), true)-Typesetting[delayDotProduct](I*gamma, (diff(ub, x, x)).(diff(u, x)), true)+Typesetting[delayDotProduct](I*gamma, u.(diff(ub, x, x, x)), true)+Typesetting[delayDotProduct](I*gamma, ub.(diff(u, x, x, x)), true)-Typesetting[delayDotProduct]((2*I)*u*gamma, ub.(3*u.(diff(ub, x))-(4*I)*lambda^3), true)+Typesetting[delayDotProduct]((2*I)*ub*gamma, u.(3*ub.(diff(u, x))-(4*I)*lambda^3), true)+(1/2)*Typesetting[delayDotProduct](-4*gamma*lambda-2*alpha, u.(diff(ub, x, x)), true)+(1/2)*Typesetting[delayDotProduct](4*gamma*lambda+2*alpha, ub.(diff(u, x, x)), true)+(1/2)*Typesetting[delayDotProduct](-4*gamma*lambda-2*alpha, (diff(u, x)).(diff(ub, x)), true)+(1/2)*Typesetting[delayDotProduct](4*gamma*lambda+2*alpha, (diff(ub, x)).(diff(u, x)), true)+(1/2)*Typesetting[delayDotProduct](-(8*I)*gamma*lambda^2-(4*I)*alpha*lambda+I, (diff(ub, x)).u, true)+(1/2)*Typesetting[delayDotProduct](-(8*I)*gamma*lambda^2-(4*I)*alpha*lambda+I, ub.(diff(u, x)), true)-ub*(-2*gamma*lambda+alpha)*(diff(u, x, x))+u*(2*gamma*lambda+alpha)*(diff(ub, x, x))+Typesetting[delayDotProduct](2*u, u.ub.u, true)*alpha-Typesetting[delayDotProduct](2*ub, ub.u.ub, true)*alpha-I*u*gamma*(diff(ub, x, x, x)) = 0
(1/2)*(4*gamma*lambda+2*alpha)*((diff(ub, x)).(diff(u, x)))-ub*(-2*gamma*lambda+alpha)*(diff(diff(u, x), x))+u*(2*gamma*lambda+alpha)*(diff(diff(ub, x), x))+(3*I)*gamma*(`.`(ub, diff(u, x), ub, u))+(3*I)*gamma*(`.`(diff(ub, x), u, ub, u))+I*gamma*((diff(u, x)).(diff(diff(ub, x), x)))+I*gamma*(u.(diff(diff(diff(ub, x), x), x)))+(3*I)*gamma*(`.`(ub, u, ub, diff(u, x)))+(3*I)*gamma*(`.`(ub, u, diff(ub, x), u))+4*ub*gamma*(`.`(lambda*u, ub, u))+4*u*gamma*(`.`(lambda*ub, u, ub))+I*gamma*(ub.(diff(diff(diff(u, x), x), x)))+2*u*(`.`(u, ub, u))*alpha-2*ub*(`.`(ub, u, ub))*alpha-I*gamma*((diff(diff(ub, x), x)).(diff(u, x)))+(1/2)*(-4*gamma*lambda-2*alpha)*((diff(u, x)).(diff(ub, x)))+(1/2)*(4*gamma*lambda+2*alpha)*(ub.(diff(diff(u, x), x)))+(1/2)*(-4*gamma*lambda-2*alpha)*(u.(diff(diff(ub, x), x)))+(1/2)*(-(8*I)*gamma*lambda^2-(4*I)*alpha*lambda+I)*(ub.(diff(u, x)))+(2*I)*u*(2*gamma*lambda^2+alpha*lambda-1/4)*(diff(ub, x))+(2*I)*ub*(-2*gamma*lambda^2+alpha*lambda-1/4)*(diff(u, x))-I*u*gamma*(diff(diff(diff(ub, x), x), x))+(2*I)*ub*gamma*(u.(3*(ub.(diff(u, x)))-(4*I)*lambda^3))+I*ub*gamma*(diff(diff(diff(u, x), x), x))-(2*I)*u*gamma*(ub.(3*(u.(diff(ub, x)))-(4*I)*lambda^3))+(1/2)*(-(8*I)*gamma*lambda^2-(4*I)*alpha*lambda+I)*((diff(ub, x)).u) = 0
Parse:-ConvertTo1D, "first argument to _Inert_ASSIGN must be assignable"
Error, illegal use of an object as a name
"for m from 0 to 5 do  lambda^m:=coeff(lhs(z1),lambda,m)=0;  od;"
Download compare.mw
May  I please get a Maple code to solve the below Perturbation Iteration Solutions for Volterra Integral Equations?
I shall be very much grateful if I can get the Maple Code.
And possible plotting
Any comment, idea or innovation to calculate this parametric integral?
Note M, II, JJ are arbitrary positive integers (0<M, II, JJ<11).
F must be a function of Pm at the final!
M := 3:
JJ := 5
II := 5
with(ArrayTools):
W := RandomArray(II, JJ, M):
V := ArrayTools:-RandomArray(II, JJ, M):
w := add(add(add(W[i, j, m]*LegendreP(i-1, x)*LegendreP(j-1, y)*p[m], i = 1 .. II), j = 1 .. JJ), m = 1 .. M):
v := add(add(add(V[i, j, m]*LegendreP(i-1, x)*LegendreP(j-1, y)*p[m], i = 1 .. II), j = 1 .. JJ), m = 1 .. M):
L := add(add((LegendreP(i-1, x)*LegendreP(j-1, y))^2, i = 1 .. II), j = 1 .. JJ):
H := 1+tanh(w-v)
F := int(H*L, [y = -1 .. 1, x = -1 .. 1])
Download integralproblem.mw
What does the following message imply?
"Error, (in Engine:-Dispatch) invalid boolean expression: 0"
For a vector of floats like this:
v := < 4,3,2>;
How do I get the 24 (=4*3*2)?
Now, there are two unknows, and i cant seem to get it right.
Its "the method of the least squares", and it has gone wrong. How terrible, now ive made many books, but this book always sets me up, you may have guessed it: the Dutch Math book strikes again...
Ive tried to use a value, it looks like i used the rights steps, but the wrong input, the solution does not give me anything that looks like it is doing the rigth thing. Checking the new formula does not give the solution it is suppose to give. Now i know they mentioned that x=1/I but that does not give the right answer either.
Okey the question states: "A battery delivers a current I to a circuit with an external(not inside the battery) resistance Ry. The battery has an internal resistance Ri and delivers a source tension (voltage) U. These are the formulas U=(Ry+Ri)*I, of which follows: Ry+Ri=U/I. We state that x= 1/I and then we get Ry+Ri=U*x, of which follows: Ry=U*x-Ri.
That last formula gives a linear conjunction between x and Ry. There are a couple of measurements done, of which different values of the resistance Ry and the current I is measured (look at table 5.4). The value of x is determined by the smallest squares method."
While i did not use x instead of I, it made no difference. I was no where close to the results. I think i am misschien something.
`<,>`(`<|>`(1, 1.5, 2, 2.5, 3), `<|>`(1.31, 1.01, .81, .67, .56))
Matrix(%id = 18446745647253576510)
"f(t):=t/(2);seq(f(t),t=2..6);Sum(f(t),t=2..6)=sum(f(t),t=2..6)"
proc (t) options operator, arrow, function_assign; (1/2)*t end proc
1, 3/2, 2, 5/2, 3
Sum((1/2)*t, t = 2 .. 6) = 10
10*(1/5)
convert(`<,>`(1.31, 1.01, .81, .67, .56), `+`)
4.36
4.36*(1/5)
.8720000000
`<,>`(1, 1.5, 2, 2.5, 3).`<,>`(1.31, 1.01, .81, .67, .56)
7.80000000000000071
"f(t):=(t/(2))^(2);seq(f(t),t=2..6);Sum(f(t),t=2..6)=sum(f(t),t=2..6)"
proc (t) options operator, arrow, function_assign; (1/4)*t^2 end proc
1, 9/4, 4, 25/4, 9
Sum((1/4)*t^2, t = 2 .. 6) = 45/2
solve([(45/2)*a+10*b = 7.80000000000000071, 2*a+b = 4.36], [a, b])
[[a = -14.32000000, b = 33.00000000]]
"f(t):=-14.32 t+33"
proc (t) options operator, arrow, function_assign; -14.32*t+33 end proc
plot(proc (t) options operator, arrow, function_assign; -14.32*t+33 end proc)
f(1)
18.68
Maybe someone knows an answer to this.
Greetings,
The Function
Download Mapleprimes_Question_Book_2_Paragraph_5.12_Question_3.mw
The result is wrong and I want to know the reason. the dot is the  Matrix multiplication.
I cannot find documentation on Typesetting commands that can explain the following
From the help page of apply:
lprint(Typesetting[Typeset](sqrt(x)));
Typesetting:-msqrt(Typesetting:-mi("x"))
The first argument to Typeset has type uneval , signifying that it is not evaluated before being passed to Typesetting[Typeset].
Questions:
Where can I see  in the lprint output that the first argument is of type uneval?
Is sqrt(x) the first argument?
What does mi do?
Download help_page_apply.mw
I was introduced to DataFrame by some kind people here the other day and I thought I understood.  Then I tried this
M := DataFrame(<0,0,0;0,1,a;0,a,1>,rows=[0,1,a],columns=[0,1,a])
Now M[1, a] returns 0.  What's going on here?
First 283 284 285 286 287 288 289 Last Page 285 of 2469
