mpl files for sure are good for committing to a repository, especially if you are collaborating with someone in writing the code in those files. They can be opened in an editor and worked on just like in the normal course of working in other programming languages and collaborating.
Worksheets and Workbooks I would imagine are alright as well, right? In this case, they are meant to be opened in Maple of course, not in a code editor.
Now, what about mla files? I imagine that if someone obtained an .mla file I created (containing a package, say), and saved it in a path contained in their libname then they would have access to that package. Is this the standard way of sharing packages with others?
If I wrote a package and wanted to share it (via a Github repo, for instance, or simply by emailling) would it consist of a single .mla file?
I have a folder called Packages, and I added its path to libname. I have an .mla file in there that I have been experimenting with to learn about writing packages in Maple.
The workflow I have currently developed is as follows.
Imagine I am working on a library that does something specific. Just to give a simple example, let's say I want to write a package that has functions sum, add, multiply.
I create an mpl file and I edit it in VSCode which has a plugin with syntax highlighting. In this file I write my package, procedures, etc. At the end of the file I add a line that tells LibraryTools to save the package to an mla file that I am keeping in the same directory as the mpl file (for organizational purposes, not for any technicality).
So at this point both these files are in the Packages directory.
Now let's say I want to create another package for doing animations. I would do the same thing: an mpl file and an mla file.
At this point all four files are together in the Packages directory, because that is where Maple knows to search for mla files.
However, this isn't very convenient if I want to use version control for each package individually.
To do this I would need to have the two files of each package in their own directory (like a subdirectory of Packages)
i can do this of course, by adding each of the two resulting directories (each with two files) to libname.
But is it possible to tell Maple to simply search all subdirectories of the directory Packages?
In other words, in this workflow, must I update libname every time I make a new package (which consists of a directory, an mpl file, an mla file, and a git file)?
Note: It seems in the course of writing this question I found the answer, but I am still interested in any tips on the best workflow to update a library. Here is the original post (annotated ex post in bold):
I have successully created my own package in Maple. I basically used LibraryTools:-Create to create an .mla file and then I used LibraryTools:-Save, passing in the name of my package and the path to the .mla file. I did this in a worksheet.
I can import it with the command with(MyPackage).
I'd like to add code to the package.
I have a package defined in as
module MyPackage()
  option package;
  export MyModule;
  module MyModule()
  end;
 end;
I would like to add a procedure to be exported inside the package.
I tried to add the procedure, save the file, and then use LibraryTools:-Save again, but the error I get is
Error (in MyPackage) attempting to assign to 'MyPackage' which is protected. Try declaring local 'MyPackage'; see ?protect for details.
I tried to unprotect the name 'MyPackage' but this gives another error
Error, on line %1, unexpected end of input. Error while reading '%1' (this turned out to be a missing semicolon on the Save command, which was the last command in the mpl file. The error messags are quite unhelpful)
Note: As I mentioned before, I did the initial saving of the package from a worksheet (the package code was in a code editing region in the worksheet). In the current attempt to add the new procedure, I copied the code to an .mpl file so I could edit it in a code editor (VSCode). At the end of this file I added the commands to LibraryTools:-Save the package again to the same .mla file as before.
My attempt to unprotect the name "MyPackage" involved simply adding unprotect('MyPackage') as the first line in this .mpl file.
I then used the command read to execute the mpl file from within a worksheet.
What am I doing wrong, and what is the recommended workflow to be able to work on a package?
If I try to update a simple variable in the .mla file it seems to work.
EDIT: The problem seems to be the use of the named module initially, ie module MyPackage().
If I try the whole process again (write a simple package and save it to the mla file) but this time I use the syntax
MyTestPackage = module()
then I can update it no problem (at least for a simple package that I just wrote; for the actual package with my real code I still get even though Maple is able to read the mpl file without a problem, apparently there is still some issue while trying to save.
Error, on line %1, unexpected end of input. Error while reading '%1'   (turns out it was the missing semicolon)
In summary: don't used named module syntax.
Hello guys.
I want to solve Laplace's equation for a triangle plate, subject to the following boundary conditions:
For the contour y = x, u(x,y) =20
For the contour y = -x+2, u(x,y) =100
diff(u(x,y),x,x)+diff(u(x,y),y,y)=0
Oliveira
Why is the Maple giving this error. See attched file. Further, how can we eq. of the form "A+B`*sqrt(C) = 0" by eliminating the common denominator.
CM_TW.mw
Hi, I have an rational polynomial:
r:=-36*u^3*v*(-1 + u + v)*(3*u^2 + u*v - 5*u - 2*v + 2)/(-1 + u)^2;
int(r, u=0..1-v, v=0..1);
Then I got:
I'm confused, why can't maple do this?
Any ideas about how to do this exact integration?
Hello!!
So I am brand new here and am here as somewhat of a last resort, I was in the hospital for a large portion of my semester (Junior Yr Computer Engineering/Electrical Engineering double major) and I am trying to get through the makeup work for my calculus class. The assignments are on maple, and I have been able to do all the actual solving parts with no issue but several of the problems require you to generate a graph as well and I have been working on it for literally 11  hours to no avail. I'm hoping maybe someone here can help me with what the input should be if I list what the graphs of the ones I am stuck on are (somehow managed to get 2 of them to work, but not the rest). No worries if not/if this is the wrong forum for this I am sorry, but I have cycled through every tutoring website I could find and the error I'm getting keeps linking to a page that says there is not a help page available for the error. So heres the problem I am stuck on (as I said I was able to do the solving for each section myself, I just cant get the graphs to work to save my soul):
2. Graph the following with maple:
a) the cardioid r = 8+8sin(theta) and find its area
b) the first octant portion of the surface z=25-x^2, 1<=y<=8 and find the volume of the solid over the xy plane under the surface
c) the solid common to the cylinders x^2+z^2=16 and y^2+x^2=16 and find the volume of the common region
d) the cylinder x^2+y^2=36 and the sphere x^2+y^2+z^2=100 together, then find the volume outside the cylinder and inside the  sphere
e) the region inside the one sheeted hyperboloid x62+y^2-z^2=36 between z=-8 and z=8 and find the volume of the region
f) the "ice cream cone" formed by the  upper half of the sphere x^2+y^2+z^2=400 and the cons z=sqrt(3x^2=3y^2), then find the z-coordinate of its center of mass written as a rounded decimal number with 3 places, assuming density is constant.
Yeah, that is one of 11 problems on the project I know its a ton. Anyway like I said I am kind of posting this as a hail mary but if anyone can help me with what the input is supposed to be on any of these at all I would be eternally grateful, as I have 2 more of these projects to make up from while I was in the hospital and I have been on this one question all night. I will literally take ANYTHING. Thanks so much for reading and for anyone who takes the time to help out.
hi. i want to improve my integration calculation speed, it takes me hours to calculate the results for even N=8. but i want for much more N's such as 20 30. can calculation speed improve? thanks in advance
Download M.mw
Problema with textplot
restart:with(plots):
  with(geometry):
  _EnvHorizontalName := 'x':
  _EnvVerticalName := 'y':
  a := 7:
  b := 3:
  ellipse(p, x^2/a^2 + y^2/b^2 - 1, [x, y]):
  Fig := proc(t)
              local M, l1,L1,L2,  q, m, c , tex;
              global a, b, p;
              point(M, a*cos(t), b*sin(t));
              if   VerticalCoord(M)=0
              then line(l1, x=HorizontalCoord(M));
              else m:=eval[recurse]( rhs
                                     ( isolate
                                       ( diff
                                         ( eval
                                           ( Equation(p),
                                             y=y(x)
                                           x
                                         diff(y(x),x)
                                     [ y(x)=y,
                                       x=HorizontalCoord(M),
                                       y=VerticalCoord(M)
                   c:=VerticalCoord(M)-m*HorizontalCoord(M);
                   line(l1, y=m*x+c);
              fi;
              reflection(q, p, l1);
              line(L1, [point(P1, evalf~(coordinates(foci(q)[1]))),
                            point(P2, evalf~(coordinates(foci(q)[2])))]):
              line(L2, [point(P3, evalf~(coordinates(foci(p)[1]))),
                            point(P4, evalf~(coordinates(foci(p)[2])))]):
              segment(P1P3,[P1,P3]): circle(cir1,[P3,2*a]):
              segment(P2P4,[P2,P4]):
              circle(cir1,[P3,2*a]): circle(cir2,[P4,2*a]):
              textplot([[P2[], "F1"], [P4[], "F2"]], font = [times, 10], align = {below, left}):
              draw( [ p(color = blue),P1P3(color=magenta,linestyle=3),
                      q(color = blue),P2P4(color=magenta,linestyle=3),
                      l1(color = black),L1(color = black),cir1(color=magenta,linestyle=3),
                      cir2(color=magenta,linestyle=3),
                      M(color = blue, symbol = solidcircle, symbolsize = 16),
                      P1(color = red, symbol = solidcircle, symbolsize = 16),
                      P2(color = red, symbol = solidcircle, symbolsize = 16),
                      P3(color = red, symbol = solidcircle, symbolsize = 16),
                      P4(color = red, symbol = solidcircle, symbolsize = 16)
                    axes = none,
                    scaling = constrained);
# Change nFig to type float
   nFig := 180.0:
# Make sure loop index is a float, and change end point
# on loop to nFig-1.0
   Figs := seq(Fig(2*Pi*i/nFig), i = 0.0 .. nFig-1.0):
   plots:-display(Figs, insequence = true);
Error, (in plots:-textplot) improper op or subscript selector
Error, (in plots:-display) expecting plot structure but received: Figs
Hi maple users
I am working with the PDE solver.
i am receiving a following error
"unable to compute solution for t>HFloat(0.0):"
Kindly do the needful how to rectify this error.
dumm.mw
Consider the sequence of numbers 1, 2, 3, 4, ...
Can we plot these points on the real line?
That is, just a line with dots on the numbers 1, 2, 3, 4, ...
Hi Everyone,
I want to do some fourier analysis on a numeric ODE solution but first I wanted to understand all the commands and make sure it worked with a simple example. I created a Array of data which I attempted to take the DFT of but I got an error and I cannot seem to figure out why, I looked through the help pages and it looks like inputs use an Array of data but for some reason mine wont work.
Worksheet attached, any help greatly appreciated.
DFT_Test.mw
Dears
Can you give me advice on how to improve the calculation time for Binomial-Beta mcmc Metropolis-Hastings algorithm?
The calculation time for 50 000 samples for my laptop (Dell XPS 9710) takes approx 22 sec.
At the same time, in MathCAD Prime 8.0, the same amount of samples is calculated (using the same procedure) in approx 0.3 s.
I will be appreciated any help
wzelik
HHow do i correct "error, illegal use of an object as a name"
Given a planar graph G
i) How to find the degrees of the regions of G
ii) The edges in each region as sets
iii) edges in the intersection of regions
First 296 297 298 299 300 301 302 Last Page 298 of 2463
