This is another bizzar behaviour of objects. I created a basic object of type person.  Noticed that after issuing the call copy(object,deep) and not doing anything at all with the result. Just made the call only, then I am not longer able to create new objects of this class. I had to restart the session to be able to create new objects again.
Why?  This seems like something went messy with memory layout. I put a print message in the constructor, and see that this message no longer show up  after the call copy(object,deep) even though this call was not used for any purpose as you see, but to only to see its effect on the session.
Any explanation why one can no longer create new objects after doing this?  Here is the workseet
interface(version)
person:=module()
    option object;
    export name::string:="";
    export ModuleCopy::static:=proc(_self,proto, name::string, $)
      print("Enter constructor of person");
      _self:-name := name;
end module;
_m2370471750336
p1:=Object(person,"me");
p1:-name;
do_not_care := copy(p1,deep);
_m2370557462816
"me"
_m2370557440576
p2:=Object(person,"me");  #WHy constructor no long called?
p2:-name;   #this no longer work.
_m2370556941056
p3:=Object(person,"me");  #WHy constructor no long called?
p3:-name;   #this no longer work.
_m2370556932032
restart;  #had to call restart to fix things.
person:=module()
    option object;
end module;
_m2370471750336
p4:=Object(person,"me");  #now it works again
p4:-name;
_m2370557462816
"me"
Download deep_call_problem.mw
I  generated some graphs via maple and would like to put them in my paper. So I am going to convert the following worksheet to pdf.
with(GraphTheory):
Graphs:=[NonIsomorphicGraphs(6,8,output=graphs,outputform = graph)]:
num_g:=nops(Graphs):
num:=ceil((num_g)/5.):
M1:=Matrix (num,5,(i,j)->`if`((i-1)*5+j<=num_g, DrawGraph(Graphs[(i-1)*5+j],size=[250,250] ,overrideoptions ,showlabels=false,style=planar, stylesheet =  [
 vertexcolor     = orange
,vertexfontcolor = black
,vertexborder    = false
,edgethickness   = 0.6
,edgecolor       = MidnightBlue
,vertexshape     =  "circle"
,vertexfont      = [Arial, 4],
vertexthickness=5], caption = cat(H__,5*(i-1)+j),captionfont=["ROMAN",7]),plot(x = 0 .. 1, axes = none))):
DocumentTools:-Tabulate (M1[1..5,.. ],widthmode=percentage ,width=80 , exterior =all) :
But there was a problem with the exported pdf. There was some mosaic stuff at the vertices of all those graphs. It was strange. (I want to reduce the size of vertices of the graphs in order not to look crowded.)
Only when I insert the option vertexpadding and set a large enough size  of vertex (for this example, we set vertexpadding=7),  it won't go wrong. However, in fact, we often need make vertice‘s size smaller , especially when there are more vertices.
Using a pdf viewer, it seems that after exporting, there is a box above each vertex.
As I was trying things with Maple OOP, I noticed strange behavior which I do not understand. I'll explain the problem in words first then given an example.
I have Person class. Then made one instance of it. In this class, there is one method which is defined to take in an object of same type as the class itself.
I found when I pass the object itself to its own method, it gives an error that the method expects a second argument of type person which is missing. But it is not missing.
Then when creating a second object of same type, and passing the second object, it worked!
Why?  Here is MWE. Attached worksheet.  I would have expected same behavior in both cases. EIther both work, or both do not work. As as long as the object being passed is the correct type (person).
It seems in the first case, Maple noticed the object being passed to the method happened to be same object where this method is, and it did not pass it. Hence the missing second argument.  Is this a documented behaviour somewhere? (I made sure to make all method static though, so same code is used by all instances of the class. This is strange error message).
interface(version)
person:=module()
    option object;
    #--- constructor---
    export process::static:=proc(_self, the_input::person ,$)
       print("in person::process. name = ", the_input:-name);
end module;
_m2370471750496
p:=Object(person,"me");
_m2370557462912
p:-process(p);  #why this fail
Error, invalid input: process uses a 2nd argument, the_input (of type person), which is missing
o:=Object(person,"new_name"); #make new object and try again
_m2370557450944
p:-process(o); #why this OK?
"in person::process. name = ", "new_name"
Download why_first_call_fail.mw
Update
Ok, I am all set. I found a good way to do this. i.e. pass the object to one of its method. One has to make a copy of the object first and pass the copy. Can't use the same object. This is how I do it now.
person:=module()
    option object;
     export ModuleCopy::static:= overload(
         proc(_self,proto, $)option overload;
            print("Enter 2 args constructor of person");
            #do nothing
         end proc,
         proc(_self,proto, name::string, $) option overload;
             print("Enter 3 args constructor of person");
        end proc
    export process::static:=proc(_self, the_input::person,$)
       print("the_input:-name = ",the_input:-name);
end module;
#p:-process(p);  #instead of this do the following
o:=Object(p);
p:-process(o)
Which works and gives
                  p := Object<<2370600065568>>
                  o := Object<<2370600048288>>
                   "the_input:-name = ", "me"
So I am now able to pass the object (or rather copy of it) as explicit argument to other methods and other modules.  I am not sure why it does not work when using the object itself and had to make a copy.
How to integrate the below function from 0 to eta.
A := P(eta)+S(H-2*`cos&theta;`(eta+1)*F)+`cos&theta;`*(2*F(eta)-2*H*F) = S(eta+1)*`sin&theta;`*F(theta)-`sin&theta;`(F*H(theta)-H*F(theta)+F(theta, eta))
How does one undo an overload?
:RLC circuit I want to solve.
with(DynamicSystems); with(inttrans)
E := 1; J := 3; R := 3; L := 1; C := 1/2
(1/s-6/s^2)/(s+3+2/s)
i__RL := proc (t) options operator, arrow; invlaplace((1/s-6/s^2)/(s+3+2/s), s, t) end proc
-4*exp(-2*t)-3+7*exp(-t)
e__C := proc (t) options operator, arrow; E-i__RL(t)*R-L*(diff(i__RL(t), t)) end proc
10+4*exp(-2*t)-14*exp(-t)
plot([-4*exp(-2*t)-3+7*exp(-t), 10+4*exp(-2*t)-14*exp(-t)], t = 0 .. 10, color = [red, blue], thickness = 3, labels = ["t", "i(t)_red and vc(t)_blue"])
[diff(x1(t), t) = x2(t), diff(x2(t), t) = -(1/3)*x3(t), diff(x3(t), t) = 6*x2(t)-3*x3(t)-3*u1(t), y1(t) = -6*x1(t)+x2(t)]
How to solve this by Maple? The answer I want to solve is the plot shown above.
Download DynamicSystem-How_to_ODE.mw
Hi experts, I know built in command to solve definite integral by using simpson and trapezoidal rule but i need to show step which is given in the example to satisfy his students of grade 12. Please help me to solve this example
I have an animation in Maple that only works if I use the option frames=120, or anything >120. Anything less and it gives the error "Error, (in plots/animate) points cannot be converted to floating-point values". I don't understand why this restriction is happening, any advice is appreciated.
transparent_background_in_plots.mw
Is there a better way to impletment a transparent background when genereating plots?
Here I generate a plot with a yellow background.
plot(sin(x), x = 0 .. 4*Pi, background = yellow);
I want the background to be completely transparent instead of yellow.
plot(sin(x), x = 0 .. 4*Pi, background = none);
Error, (in plot) Unable to find image file, none
none is not an accepted color, so an error is returned. Is there such a color as "clear" that is fully transparent? Is there a better way to impletment a transparent background when genereating plots?
As we know, when every Gi is normal in G, then the series is called a normal series:
cs := CompositionSeries(DihedralGroup(8))
We can draw it:
DrawSubgroupLattice(DihedralGroup(8), labels = ids, highlight = cs)
And all Gi is normal in G:
IsNormal~(cs, DihedralGroup(8))
[true, true, true, true, true]
But why type(cs, 'NormalSeries') will get false.. It is a bug or do I have a misunderstanding?
I am still struggling understanding Maple Object  inheritance due to lack of good examples and sparse documenation.
This is what I am trying to do. I have base class Person, and then make Employee class which extends Person class and adds new field.
The constructor to the Employee class then needs to call the constructor to the Person class (its base class) in order to initialize it. The base class constuctor takes care of initialization the fields in the base class.
I do not know how to do this. Actually it is not clear to me how the proto argument gets into play in all of this. I could not find one example that explains how to use proto with inheritance.
I am trying to implement this python example. I will show the code for the Python, and my Maple translation. The part I do not know how to do, it how to call the constructor for the base class from the sub class.  If I do not do this, then the fields of the base class will remain unitilized.
Python example is from https://www.geeksforgeeks.org/python-access-parent-class-attribute/
# parent class
class Person( object ):
        # __init__ is known as the constructor
        def __init__(self, name, idnumber):
                self.name = name
                self.idnumber = idnumber
        def display(self):
                print(self.name)
                print(self.idnumber)
# child class
class Employee( Person ):
        def __init__(self, name, idnumber, salary):
                self.salary = salary
                # invoking the constructor of the parent class
                #----->>>>> HOW TO DO THIS IN MAPLE?
                Person.__init__(self, name, idnumber)
        def show(self):
            print(self.salary)
# creation of an object
# variable or an instance
a = Employee('Rahul', 886012, 30000000)
# calling a function of the
# class Person using Employee's
# class instance
a.display()
a.show()
Here is the Maple code
person:=module()
    option object;
    #I made these exported instead of local for ease of printing from outside while
    #debugging , that is all.. These should otherwise be local
    export idnumber::integer:=0;
    export ModuleCopy::static:= proc( _self, proto, name::string, idnumber::integer, $)
        _self:-idnumber := idnumber;
end module;
#---- extend the above class
employee:=module()
    option object(person);
    export salary::integer:=0;
    ModuleCopy::static:= proc( _self, proto, name::string, idnumber::integer, salary::integer , $)
        _self:-salary := salary;
        # How to do that in Maple?
        #I could always manually do this. But I do not want to duplicate the code
        #done by the base class constructor.
        #_self:-name := name;
        #_self:-idnumber := idnumber;
end module;
How does one do the Python example in Maple?
Someone should write a book on programming using OOP in Maple. I'll buy a copy in advance.
Maple 2022.1
How does one compute the location of the minimum algebraically (rather than numerically) of the following expression:
F:=((z^2+(z^2+2*z+2)^(1/2)*(z^2+1)^(1/2)+z+1)^(1/2)*(-z^2+(z^2-2*z+2)^(1/2)*(z^2+1)^(1/2)+z-1)^(1/2)-(z^2+(z^2-2*z+2)^(1/2)*(z^2+1)^(1/2)-z+1)^(1/2)*(-z^2+(z^2+2*z+2)^(1/2)*(z^2+1)^(1/2)-z-1)^(1/2)+2*z)/(2*z^2+2);
Write a Maple procedures called “biggest4” and “smallest4” to find
a) the biggest
b) the smallest
of the given numbers  a = -1/3, b = 0, c = 7/3, d = -2
i guess i need to use end proc for programing but i dont understand:
I have set of graphs say with names
Graph1,Graph2,..., Graph50.
1) I want to print all these using a single for.
2) I want to check the Isomorphic property of which two are all Isomorphic pairwise using a for loop say
Or if any other methods kind help with suitable advice.
i need to use two different methods to solve the initial value problem. I tried but didnt find the answer
y" + 4y' + 4y = sin(x), y(0) = 1 , y'(0) = 0
y" + 4*diff(y(x), x) + 4*y(x) = sin(x)
dsys1 := {diff(y(x), x, x) + diff(y(x), x) + 4*y(x) = sin(x), y(0) = 1, D(y)(0) = 0};
dsol1 := dsolve(dsys1, numeric, method = gear);
dsol1(0);
First 303 304 305 306 307 308 309 Last Page 305 of 2428
