I solve numerically a DAE system whose independent variable is named t and the dependent variables are d[1](t), ..., d[n](t).
I would like to to 2D or 3D plots of the solutions and color the resulting curve using a function f(...) of the remaining dependent variables.
Here is a simple example.
sys := {
   diff(x(t), t) = v(t)
  ,diff(v(t), t) = cos(t)
  ,x(0) = -1
  ,v(0) = 0
  ,px(t) = piecewise(x(t) >=0, 1, -1)
  ,pv(t) = piecewise(v(t) >=0, 1, -1)
sol := dsolve(sys, numeric):
odeplot(sol, [t, x(t), v(t)], t=0..4*Pi)
# I would like to color this space curve depending on the signs of x(t) and y(t)
# for instance, f being a "color function"
f := proc(s)
  local a, b:
  if s::numeric then
    a := round(eval(px(t), sol(s))):
    b := round(eval(pv(t), sol(s))):
    return piecewise(a+b = 2, "Green", a = 1, "Red", b = 1, "Blue", "Gold")
  end if:
SOL := proc(s)
  if s::numeric then
    eval([t, x(t), v(t)], sol(s))
  end if:
# I would like to make something like this to work
plot3d(SOL(s), s=0..4*Pi, colorfunc=f(s)):  #... which generates a void plot
# In some sense a continuous version of this
opts := symbol=solidbox, symbolsize=20:
display( seq(pointplot3d({SOL(s)}, opts, color=f(s)), s in [seq](0..6, 0.1)) );
Download coloring.mw
How can I fix (if possible) the syntax in the command
Has someone tried to connect Grasshopper with Maple yet?
Grasshopper is a visual programming environment on Rhino.
https://en.wikipedia.org/wiki/Grasshopper_3D
Try to calculate the values for the Zeta(z) on the critical line in symbolic form and also as a plot
Both i did not yet succeed in
f:=z->Zeta(z);
complexplot3d(f,-1-1*I..1+1*I);
solve(f = 1/2 , z )
Hello;
I am facing "Error, too many levels of recursion" in loops. kindly guide me. Thanks
1D1P.mw
restart; printlevel := 3
restart; with(LinearAlgebra); with(linalg); with(CodeGeneration); with(plots); Digits := 30; `ε` := 0.1e-1; k := .5; m := 1; c := 1; q := 1
L[time] := 1:
.200000000000000000000000000000
ICff := 1.0*exp(-p^2/(2.0))*(1.0+epsilon*cos(1.0*k*x))/sqrt(2.0*Pi):
for i from 0 while i <= N[x] do for j from 0 while j <= N[p] do f[0, i, j] := eval(ICff, [x = i*`&Delta;x`, p = j*`&Delta;p`]) end do end do:
for n from 0 while n <= T do for j from 0 while j <= N[p] do f[n, 0, j] := 0; f[n, N[x], j] := 0 end do end do:
for n from 0 while n <= T do for i from 0 while i <= N[x] do f[n, i, 0] := 0; f[n, i, N[p]] := 0 end do end do:
for n1 from 0 while n1 <= T-1 do for i1 while i1 <= N[x] do for j1 while j1 <= N[p] do f[n1+1, i1, j1] := f[n1, i1, j1]-`&Delta;t`*j1*`&Delta;p`*(f[n1+1, i1+1, j1]-f[n1+1, i1-1, j1]+f[n1, i1+1, j1]-f[n1, i1-1, j1])/((4*`&Delta;x`)*(1.0)) end do end do end do
Dear esteem Colleagues,
Please how do I modify the following two files (though similar) to get consistent errors? I am not sure where I made the mistake.
Any modifications would be appreciated.
Thank you all for your time and mentorship. Best regard
Biratu_Mapleprimes.mw
DDE_2_Mapleprime.mw
I would like to emphasize a particular region of my plot by shading the whole strip between x=0 and x=1. I learned of the command shadebetween, but the functions it takes as arguments for the boundaries of the region to shade must be functions of x.
Does someone know how to shade between two vertical lines?
I am a new user to Maple, but have used PTC's Mathcad and Prime.
I have several matrices that I need to combine both vertically and horizontally.  The command augment will combine the matrices horizontally.  I was unable to find a command to combine the matrices vertically.  I tried the stack command (Prime command).  The Maple stack command appears to have a different functionality.  Could you suggest which command would do the job?  The matrices are large and I would like to limit the number of rows and columns shown in the document.
The next step will be sorting the data. I am researching this at this time.
Thank you for the support,
David Tietje
Alternating serie
sum((-1)^(n+1)/(2*n-1), n = 1 .. infinity)
(1/4)*Pi
sum((-1)^(n + 1)/(2*n - 1), n = 1 .. infinity):
sum((-1)^(n+1)/(2*n-1), n = 1 .. 4)
76/105
expand(sum((-1)^(n + 1)/(2*n - 1), n = 1 .. 4),symbolic);
76/105
?expand
series(sum((-1)^(n + 1)/(2*n - 1), n = 1 .. infinity),n=0,5);
series((1/4)*Pi,n)
Info series
How to get for n= 4  "for (&sum;)(((-1)^(n+1))/(2 n-1))  =   symbolic term 1+ symbolic term 2+... "
Download onderzoek_reeks_-hoe_krijg_ik_een_partieke_symbolische_som.mw
Input:
 a := x^2;
 whattype(x);
 b := x[1]^2;
 whattype(x[1]);
 CodeGeneration[C](a);
 CodeGeneration[C](b);
Output:
Do you know why cg0 =/= x[0]*x[0]?
Hello people in MaplePrimes,
I can't understand a code with PLOT3D using GRID in it.
I hope you will give me explanation about it.
k:=[[1,2,10],[1,1,8],[0,1,5],[0,0,6]];
PLOT3D(GRID(1..2,1..3,k),
       AXESLABELS(x,y,z));
I cannot understand the correspondence between points in the graph and lists in the code such as [1,2,10], [1,1,8].
 As two ranges in GRID augments in the code are 1..2 and 1..3, x takes value from 1 to 2, and
y from 1 to 3 in the picture.
And, as k is k:=[[1,2,10],[1,1,8],[0,1,5],[0,0,6]], which means this list of lists are 4 X 3, so in the picture
as for x the interval of 1 to 2 is divided to three sections with the points of value of 0, 1/3, 2/3 and 3/3, which total number is 4.
And, as for y the interval of 1 to 3 is devided to two sections with the points of value of 1, 2 and 3, which total number is 3.
And, I cannot understand why from the grid of [1,1,8] in the code, which I think is the coodinate of (1, 1) on x-y plane, does not mean that the value of z on that point on the graph is not 8, but 1.
graph.mw
sys:={-diff(v(x,t),t)+0.5*p*diff(u(x,t),x,x)+q*u(x,t)*(u(x,t)^2+v(x,t)^2)=0,diff(u(x,t),t)+0.5*p*diff(v(x,t),x,x)+q*v(x,t)*(u(x,t)^2+v(x,t)^2)=0};
        /                      /  2         \
        |/ d         \         | d          |
sys := < |--- u(x, t)| + 0.5 p |---- v(x, t)|
        |\ dt        /         |   2        |
        \                      \ dx         /
               /       2          2\       / d         \
   + q v(x, t) \u(x, t)  + v(x, t) / = 0, -|--- v(x, t)|
                                           \ dt        /
           /  2         \                                      \
           | d          |             /       2          2\    |
   + 0.5 p |---- u(x, t)| + q u(x, t) \u(x, t)  + v(x, t) / = 0 >
           |   2        |                                      |
           \ dx         /                                      /
eq1 := diff(u(x,t),t) = u__t(x,t):
eq2 := diff(v(x,t),t) = v__t(x,t):
sys_tmp := subs(eq1, eq2, sys):
sys_new := sys_tmp union {eq1, eq2}:
Boundary conditions:
bc :=
    u(0,t) = 2,
    v(0,t) = 0;
                 bc := u(0, t) = 2, v(0, t) = 0
Initial conditions:
ic :=
    u(x,0) = tanh(2*Pi),
    v(x,0) = tanh(2*Pi),
    u__t(x,0) = 0,
    v__t(x,0) = 0;
ic := u(x, 0) = tanh(2 Pi), v(x, 0) = tanh(2 Pi), u__t(x, 0) = 0,
  v__t(x, 0) = 0
Solve the system:
pdsol := pdsolve(subs(p=1, q=0.5, sys_new), {ic, bc}, numeric);
I want to change my variables. The coding below shows the influence of the Nb and Nt on the local Nusselt number (-theta') against the convection Bi.
But now I want it to be  the influence of the Bi on the local Nusselt number (-theta') against the Nb and Nt.
Can anyone help me?
with(plots)
DE1 := diff(f(eta), `$`(eta, 3))+f(eta)*(diff(f(eta), `$`(eta, 2)))-(diff(f(eta), eta))^2 = 0
diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))-(diff(f(eta), eta))^2 = 0
DE2 := diff(theta(eta), `$`(eta, 2))+Pr*f(eta)*(diff(theta(eta), eta))+Pr*Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Pr*Nt*(diff(theta(eta), eta))^2 = 0
diff(diff(theta(eta), eta), eta)+Pr*f(eta)*(diff(theta(eta), eta))+Pr*Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Pr*Nt*(diff(theta(eta), eta))^2 = 0
DE3 := diff(phi(eta), `$`(eta, 2))+Le*(diff(phi(eta), eta))+Nt*(diff(theta(eta), `$`(eta, 2)))/Nb
diff(diff(phi(eta), eta), eta)+Le*(diff(phi(eta), eta))+Nt*(diff(diff(theta(eta), eta), eta))/Nb
BC1 := f(0) = 0, (D(f))(0) = 1, (D(f))(10) = 0
BC2 := theta(10) = 0, (D(theta))(0) = -Bi*(1-theta(0))
BC3 := phi(0) = 1, phi(10) = 0
  getRes:= proc(a, x);
                local sol;
                if   type(x, numeric)
                then sol:= dsolve
                           ( eval
                             ( {BC1, BC2, BC3, DE1, DE2, DE3},
                               [Nt = a, Nb = a, Pr = 2, Le = 5, Bi = x]
                             numeric,
                             output = listprocedure,
                             abserr = 0.0001,
                             maxmesh = 1024,
                             initmesh = 512
                else return 'procname(a,x)';
                fi;
                return -eval(diff(theta(eta), eta), sol)(0)
  cl:=[red, green, blue, yellow, black]:
  L:=[0.2, 0.4, 0.6,0.8,1.0]:
  display
  ( [ seq
      ( plot
        ( getRes( L[k], x),
          x=0..5,color = colorList[k], legend = ["Nb=Nt" = L[k]], legendstyle = [location = top],
          color=cl[k]
        k=1..5
Download odeProb2.mw
Contour integration notation
" (&int;)[+infinity]^(+infinity)((-x)^(z))/((e)^(x)-1). (&DifferentialD;x)/(x)"
The limits of integration are intented to indicate a path of integration which begins at + ∞, moves to th e left down the positive real axis, circles the orign once in positive ( counterclockwise) direction, and returns up to the positive real axis to  +∞
-How does this contour look like  in a  graph ?
- the "(&DifferentialD;x)/(x)" notation  ?
- calculating this complexe contour integral?
Seems that the concept of the contour integration is similar wit a line integral in real calculus ?
Some more information needed about singularities ( first en second order ..more?)
Nieuwe pagina 1 (hhofstede.nl)
Download contourintegraal_vraag1.mw
I have just come across this curious but really boring problem.
In the code snippet below, expr1 and expr2 are identical.
data := [a=1, b=2]:
convert(
  piecewise(And(x(t) > a, x(t) < b), 1, 0),
  Heaviside
expr1 := eval(eval(%, data),  x(t)=z):
plot(expr1, z=0..3);
convert(
  piecewise(And(z > a, z< b), 1, 0),
  Heaviside
expr2 := eval(%, data),:
plot(expr2, z=0..3);
But if I change the parameterization of the problem, expr2 is still correct but expr1 is not
data := [d=1.5, a=0.5]:
convert(
  piecewise(And(x(t) > d-a, x(t) < d+a), 1, 0),
  Heaviside
convert(
  piecewise(And(z > d-a, z< d+a), 1, 0),
  Heaviside
Where does this come from?
PS: I'm sorry not to be able loading the mw file
First 345 346 347 348 349 350 351 Last Page 347 of 2427
