Hi everyone! I'd really appreciate if I could get pointed in the right direction as I am a brand new maple user.
So im trying to solve this constrainted optimization problem (See picture) using Maple symbollically. I believe I should have a closed form solution given I can substitute the one constraint into the objective function. Specifically closed form solutions for the three phi variables.
Can someone point me in the right direction as to how I should go about this? I've already taken first order conditions and tried to using the solve() function to no avail, realizing my sytem of equations weren't linear );.
I have problems with tasks.
If you have some usefull commands, you select them all, right-click and select 'create task'. You now get a button in the 'task'-pane in Maple you can use whenever you need to insert these commands- - - brilliant!!
But now I want to modify these tasks and delete the ones I don't use anymore or the ones I made by mistake.
Right-click on the task does nothing.
Selecting 'tools' from the menu and then 'tasks' allows me to see the tasks I have made, but not to modify them or delete them
How do I modify or delete a task??
/Rasmus Post
how we can merge multiple plots in single graph in maple ???
Hi! do you know any effective method to count area under this function given by dataset points? (I counted this by approximation by trapezes)
Edit: PolyFit is ok the best what I have done
Edit2: triangulation is the best (just add all triangles)
How to rectify this error
k := 0;
for k[1] from 0 to k do Y[k[1]+3] := solve(sum(sum(factorial(k[1]+3)*(-1)^((k-k[1]-1)*(1/2))*Y(k[1]+3)/(factorial(k[1])*factorial(k-k[1])), k[1] = 0 .. k), k = 0 .. infinity)-(sum(1/4*((-1)^((1/2)*k)/factorial(k)-(3^k)(-1)^((1/2)*k)/factorial(k)), k = 0 .. infinity))-(sum(factorial(k[1]+2)*(-1)^((k-k[1])*(1/2))*Y(k[1]+2)/(factorial(k[1])*factorial(k-k[factorial(1)])), k[1] = 0 .. k)), Y[k[1]+3]) end do;
Error, (in sum) summation variable previously assigned, second argument evaluates to 0 = 0 .. k
Hi! Do you know how to divide this array from .txt data to take separately these numbers? (I have over one thousands of these so I don't want to rewrite)
PS this is 1x1 I want to make 1x8
["0,00244140625;8,07751097960625;-3,555908203125E-05;0,002166748046875;1;1;0,0056941700604248;-0,0101856454842773;100 µA"]
Maple apparently has managed to destroy the last working piece of code in the Units package in the 2022 release.
This code is working in Maple 2021, but not in 2022 anymore.
with(Units[Simple])
[`*`, `+`, `-`, `/`, `<`, `<=`, `<>`, `=`, Im, Re, `^`, abs, add, arccos, arccosh, arccot, arccoth, arccsc, arccsch, arcsec, arcsech, arcsin, arcsinh, arctan, arctanh, argument, ceil, collect, combine, conjugate, cos, cosh, cot, coth, csc, csch, csgn, diff, eval, evalc, evalr, exp, expand, factor, floor, frac, frem, ln, log, log10, log2, max, min, mul, normal, piecewise, polar, root, round, sec, sech, seq, shake, signum, simplify, sin, sinh, sqrt, surd, tan, tanh, trunc, type, verify]
alpha := 45*Unit('degree')
45*Units:-Unit(arcdeg)
if alpha = 0 then
Error, cannot determine if this expression is true or false: 0 < 1/4*Pi
evalf(sin(alpha))
.7071067810
Download UnitsSimple_alpha.mw
I tried to use the command Secant to solve a nonlinear system of equations, In the following, example of two simple equations, how can I use Secant to solve the problem
secant_for_system.mw
Hy
How I solved it accurately,and remove "'rootoff
eq1 := alpha + beta*r[c] - d*n[c] - Upsilon*n[c]*(n[r] + r[c]) - n[r]*(alpha - d*n[c] - b*(n[r] + r[c]));
q2 := `e&Upsi;`*n[c]*(n[r] + r[c]) - mu*n[r] + d*n[c]*n[r] + b*n[c]*n[r] - alpha*n[r];
eq3 := b*n[c]*n[r] + d*n[c]*n[r] - alpha*n[r] - beta*r[c] + mu*n[r];
 eq1 := alpha + beta r[c] - d n[c] - Upsilon n[c] (n[r] + r[c])
    - n[r] (alpha - d n[c] - b (n[r] + r[c]))
   eq2 := Upsilon n[c] (n[r] + r[c]) - mu n[r] + d n[c] n[r]
      + b n[c] n[r] - alpha n[r]
   eq3 := b n[c] n[r] + d n[c] n[r] - alpha n[r] - beta r[c]
      + mu n[r]
solve({eq1, eq2, eq3}, {n[c], n[r], r[c]});
 /       alpha                    \    /             /
{ n[c] = -----, n[r] = 0, r[c] = 0 }, { n[c] = RootOf\(Upsilon b
 \         d                      /    \
   + Upsilon d) _Z  + (-Upsilon alpha + Upsilon beta + Upsilon mu
   + b beta + beta d) _Z - alpha beta - mu beta/, n[r] = RootOf\\
   2           2                         \   2   /
  b  beta + 2 b  mu + b beta d + 2 b d mu/ _Z  + \
       /                          2
-RootOf\(Upsilon b + Upsilon d) _Z  + (-Upsilon alpha
   + Upsilon beta + Upsilon mu + b beta + beta d) _Z - alpha beta
   - mu beta/ Upsilon alpha b - 2 RootOf\(Upsilon b + Upsilon d)
  _Z  + (-Upsilon alpha + Upsilon beta + Upsilon mu + b beta
   + beta d) _Z - alpha beta - mu beta/ Upsilon b beta - 2 RootOf\
  (Upsilon b + Upsilon d) _Z  + (-Upsilon alpha + Upsilon beta
   + Upsilon mu + b beta + beta d) _Z - alpha beta - mu beta/
                         /                          2
  Upsilon b mu - 3 RootOf\(Upsilon b + Upsilon d) _Z  + (
-Upsilon alpha + Upsilon beta + Upsilon mu + b beta + beta d) _Z
   - alpha beta - mu beta/ Upsilon beta d - 3 RootOf\(Upsilon b
   + b beta + beta d) _Z - alpha beta - mu beta/ Upsilon d mu
   - alpha b beta + 2 b beta mu + 3 beta d mu/ _Z + RootOf\
                          /                          2
  Upsilon alpha b + RootOf\(Upsilon b + Upsilon d) _Z  + (
   - alpha beta - mu beta/ Upsilon beta d + RootOf\(Upsilon b
                             \          1   /      // 2
   + alpha b beta - beta d mu/, r[c] = ---- \RootOf\\b  beta
                                       beta
        2                         \   2   /
       /                          2
                         /                          2
                          /                          2
   + alpha b beta - beta d mu/ \RootOf\(Upsilon b + Upsilon d)
   + beta d) _Z - alpha beta - mu beta/ b + RootOf\(Upsilon b
   + b beta + beta d) _Z - alpha beta - mu beta/ d - alpha + mu//
I have  a funciton f(x,y)
I compute the critical point, maple gives me three different points, denoted in the code tmin
from these points how can I fix one  one of them that  give me the min( f(x))
code.mw
thank you for any help
H all expert
first this Expression
ni := diff(Q(x, t), t)+a*Q*(x, t)*(diff(Q(x, t), x))+b*(diff(Q(x, t), t$3))+d*(diff(Q(x, t), t$5)) = 0
then I want to solve  diff(Q(x, t), t$5)
diff(Q(x, t), t$5) = solve(ni, diff(Q(x, t), t$5))#eq2
p (x, t) :=H1(t)*Q(x*H2(t), H3(t)) #assumption
k := diff(p(x, t), t)+a*p(x, t)*(diff(p(x, t), x))+diff(p(x, t), t$3)+d*(diff(p(x, t), t$5))+c*p(x, t) #eq3
r := subs(diff(Q(x, t), t$5), k) #subs eq2 in eq3
i recived error
SUBS1.mw
I need some calculations in a noncommutative ring - specifically, I need to rewrite/simplify some algebraic expressions in those variables.  My variables need to be indexed by integers - for example, I need variables A[n], B[n], and C[n], where n is an arbitrary integer.  These variables should not commute.  My approach to doing this so far has been to use quantumoperators:
with(Physics);
Setup(quantumoperators = {A, B, C});
                 [quantumoperators = {A, B, C}]
There are some commutator relations that need to be imposed.  For example, suppose we have
Commutator(A[m], B[n]) = C[m+n].
I can impose these commutator relations using
Setup(algebrarules = {%Commutator(A[m], B[n]) = C[m+n]});
That part is ok.   But I would also like to subsitute certain algebraic expressions in these variables.  For example, suppose I would like to substitute A[2]*B[3] = 5. It seems I should be able to do so using subs or algsubs. This works on very simple expressions: for example, I get
algsubs(A[1]*B[2] = 5, A[1]*B[2] + C[3]);
                            5 + C3
 as I would expect.  But the following does not work:
algsubs(A[1]*B[2] = 5, A[1]*B[2]*C[4] + C[3]);
             A1B2C4 + C3
But I should get output 5C4+ C3.  This problem also persists if I use subs in stead of  algsubs.  It does not appear if I use 'standard' commuting variables.
I want to apply rk-2 for the following system of odes. I want to know what is process of rk-2 method maple used? Is it possible that we can see the complete process maple used?
Download Question.mw
Very often it happens that using solve alone, gives huge expressions that can't be used. The simplest thing to do is to wrap it inside an evalf. But then sometimes, even your system only has real solutions, you may get some complex numbers. When this evalf(solve()) being used inside an algorithm, then disastrous consequences may arise! If the system consists of a single equation of a single variable, then you may have some more tools. But if you have a system of several equations in several variables, you have less options. I am mostly interested in polynomials, I know several approaches to use and code to solve and get only the real solutions, but my codes might be not very optimized. In Maple 2022, one predefined command which is nice is RootFinding:-Isolate but it has one issue and it is that this command only likes numeric coefficients which means integers, fraction of integers and float numbers, so no square root or other real numbers of this shape in the coefficients. I thought it might be a good idea to have a list of all solving commands in Maple that only return the real solutions or have the options to restrict to only real solutions. fsolve is not very ideal, because it only returns one solution.
How to plot this equation with explore or animation
E[1]:=Sum((GAMMA(((beta+1)n-gamma(nu-1))+k))/(GAMMA(((beta+1)n-gamma(nu-1)))*GAMMA(rho*k + (nu(1-mu)+mu(2 n+1))))*((omega*t^(p))^(k))/(k!),k=0..5);  E[2] :=Sum((GAMMA((gamma(n+1)-beta *n)+k))/(GAMMA((gamma(n+1)-beta *n))*GAMMA(rho*k + (mu(2 n+1))))*((omega*t^(p))^(k))/(k!),k=0..5);    y(p):=Sum(c*gamma^(n)*t^(nu*(1-mu)+mu+2*mu*n-1)*E[1]+gamma^(n)t^(mu(2 n+1)-1)*E[2]*g, n=0..5);
with the conditions
mu, nu \in (0, 1); omega \in R; rho > 0; gamma, beta > or = 0; c & g are constant
First 356 357 358 359 360 361 362 Last Page 358 of 2463
