Given:
x'=-(1+0.1sin(10t))*x+1
https://www.wolframalpha.com/input/?i=x%27%3D-%281%2B0.1sin%2810t%29%29*x%2B1
I need to linearize this non-autonomous differential equation at the equilibrium point (which, according to numerical simulations, is present).
I am familiar with the usual approaches through the Jacobi matrix, but how to use this tool in the case of non-autonomous equations is not clear.
Dear Maple specialists, I ask for help. I would be grateful for your advice and support.
Reviewing the help Physics Examples worksheet Section 1, subsection 5 a transformation between cartesion and spherical coordinates is defined using the command ChangeCoordinates from the Physics[Vectors] package. This command is described briefly as follows in the Updates, Maple 2015, Physics page:
"New command: ChangeCoordinates, to rewrite an algebraic expression, using Cartesian, cylindrical, and spherical coordinates, an expression that involves these coordinates, either a scalar expression, or vectorial one but then not changing the orthonormal basis."
However, when I use the link to the ChangeCoordinates help page, the link simply loops back to the Updates, Maple 2015, Physics page.  Is there a specific help page for the ChangeCoordinates command?
The file is attached.
Download err.mw
The command 'coeff' doesn't work.
I am trying to combine the plot in cobweb-diagram.mw (sorry for the messed up axes, you can adjust it in the 'axes properties') with the plot in modèle_graphes.mw. I've tried these two things : test1.mw and test2.mw, but I can't make it work.
Can someone please help me combine these graphics ? Thank you very much for your time.
How do I make my Maple use delta instead of d for differential equations?
example:
The Document Tools, Tabulate command says this:
Calls to the Tabulate command cannot be nested within each other unless used with the option output=XML and other DocumentTools commands to construct your own content.
Is there an example of nesting Tabulate commands using output=XML ?
I have a polynomial in c & d.  I wish to extract the coefficients of lets say 3rd order i.e c^3+c^2d+c d^2+d^3.
The polynomials can be of 2,3,4.. variables.
coeffs(14*c^4 + 84*c^3*d + 180*c^2*d^2 + 165*c*d^3 + 55*d^4 + 5*c^3 + 21*c^2*d + 28*c*d^2 + 12*d^3 + 2*c^2 + 5*c*d + 3*d^2 + c + d + 1, [c, d], 'l');
     14, 84, 180, 165, 55, 5, 21, 28, 12, 2, 5, 3, 1, 1, 1
l[1];
                                4
                               c
l[2];
                              c  d
l;
 4   3     2  2     3   4   3     2     2   3   2        2
c , c  d, c  d , c d , d , c , d c , c d , d , c , d c, d , c, d,
hello everyone, i have an idea how to implement adomain decomposition method manually but want to transform the whole method on maple for any kind of non-linear ode.
Respected administration I already posted the same question for the other method, pls do not delete my question
help_adomian_decomposition_method.mw
I'm trying to use "Matlab()" command to convert Maple expression into Matlab's expression.
but for some reason it doesn't work.
it works for simple expressions but not this one. It is just a long expression with only some symbols, and the most basic math operations. I don't see why it fails.
It says: "Error, (in Translate) options... not recognized"
I'm attaching the maple code so you can see the error.
The reason I'm using it is because Matlab could not solve the equation in the file (even numerically). So I wrote the same equation symbolically in Maple so I can copy the symbolic solutions to matlab and use them instead of matlab's 'solve' command.
Hope anyone can help with it.
Here's the code attached:
calc_theta.mw
Rootfinding,Isolate seems to work on more that univariate expressions.
See https://www.mapleprimes.com/posts/215233-Another-Example-Of-A-Real-Manipulator-Model for example with a list of multivariate expressions.
Is there documentation/examples on that?
Hello, I don't succeed finding what is wrong. The file is a worksheet in 2D math
I always get 'error, invalid loop'. The text in bold is my simple program, the other text was added while copy-paste
som := 0
for i from 1 by 1 to 10 do
Error, invalid loop
 Typesetting:-mambiguous(Typesetting:-mambiguous(
   for i from 1 to 10 do, Typesetting:-merror("invalid loop")))
som := som + i;
od;
Error, unable to parse
      Typesetting:-mambiguous(Typesetting:-mambiguous(od,
        Typesetting:-merror("unable to parse")))
NULL;
NULL;
how to delete account from this site?
solve({-mu*a[1]+2*c[2]*a[1]*a[2]^2-a[1]*k^2*c[1]+2*c[2]*a[1]*a[0]^2+5*c[4]*a[0]^4*a[1]+5*c[4]*a[1]*a[2]^4+3*c[3]*a[1]*a[2]^2+3*c[3]*a[0]^2*a[1]+a[1]*c[1]+30*c[4]*a[0]^2*a[1]*a[2]^2-20*c[4]*a[1]*a[2]*a[0]^3-4*c[2]*a[1]*a[0]*a[2]-8*c[2]*a[1]^3*A*B+24*c[1]*a[1]*A*B-6*c[3]*a[0]*a[1]*a[2]-20*c[4]*a[0]*a[1]*a[2]^3+48*c[2]*a[1]*a[0]^2*A*B+176*c[2]*a[1]*a[2]^2*A*B-224*c[2]*a[1]*A*B*a[0]*a[2] = 0, -16*c[2]*a[1]^3-6*mu*a[1]+156*c[2]*a[1]*a[2]^2-6*a[1]*k^2*c[1]-20*c[2]*a[1]*a[0]^2+30*c[4]*a[0]^4*a[1]-20*c[4]*a[1]^3*a[2]^2+30*c[4]*a[1]*a[2]^4-6*c[3]*a[1]*a[2]^2+18*c[3]*a[0]^2*a[1]+20*c[4]*a[0]^2*a[1]^3+c[4]*a[1]^5+2*a[1]^3*c[3]-10*a[1]*c[1]-60*c[4]*a[0]^2*a[1]*a[2]^2-24*c[2]*a[1]^3*A*B+8*c[1]*a[1]*A*B+16*c[2]*a[1]*a[0]^2*A*B+336*c[2]*a[1]*a[2]^2*A*B+352*c[2]*a[1]*A*B*a[0]*a[2] = 0, -32*c[2]*a[2]*a[0]^2*A*B-8*c[2]*a[1]^2*a[0]*A*B+64*c[2]*a[2]^2*a[0]*A*B+8*c[2]*a[1]^2*a[2]*A*B-5*c[4]*a[0]^4*a[2]+10*c[4]*a[0]^3*a[2]^2-10*c[4]*a[0]^2*a[2]^3+5*c[4]*a[0]*a[2]^4-a[0]*k^2*c[1]+a[2]*k^2*c[1]-3*c[3]*a[0]^2*a[2]+3*c[3]*a[0]*a[2]^2-32*c[2]*a[2]^3*A*B-16*c[1]*a[2]*A*B+c[4]*a[0]^5-c[4]*a[2]^5+c[3]*a[0]^3-c[3]*a[2]^3-a[0]*mu+a[2]*mu = 0, 4*c[2]*a[1]^3-4*mu*a[1]-64*c[2]*a[1]*a[2]^2-4*a[1]*k^2*c[1]-8*c[2]*a[1]*a[0]^2+20*c[4]*a[0]^4*a[1]+10*c[4]*a[1]^3*a[2]^2-20*c[4]*a[1]*a[2]^4+12*c[3]*a[0]^2*a[1]+10*c[4]*a[0]^2*a[1]^3+a[1]^3*c[3]-4*a[1]*c[1]+40*c[4]*a[1]*a[2]*a[0]^3-72*c[2]*a[1]*a[0]*a[2]-8*c[1]*a[1]*A*B+12*c[3]*a[0]*a[1]*a[2]+20*c[4]*a[0]*a[1]^3*a[2]-40*c[4]*a[0]*a[1]*a[2]^3-16*c[2]*a[1]*a[0]^2*A*B-16*c[2]*a[1]*a[2]^2*A*B-32*c[2]*a[1]*A*B*a[0]*a[2] = 0, 4*c[2]*a[1]^3-4*mu*a[1]-64*c[2]*a[1]*a[2]^2-4*a[1]*k^2*c[1]-8*c[2]*a[1]*a[0]^2+20*c[4]*a[0]^4*a[1]+10*c[4]*a[1]^3*a[2]^2-20*c[4]*a[1]*a[2]^4+12*c[3]*a[0]^2*a[1]+10*c[4]*a[0]^2*a[1]^3+a[1]^3*c[3]-4*a[1]*c[1]-40*c[4]*a[1]*a[2]*a[0]^3+72*c[2]*a[1]*a[0]*a[2]+64*c[2]*a[1]^3*A*B+40*c[1]*a[1]*A*B-12*c[3]*a[0]*a[1]*a[2]-20*c[4]*a[0]*a[1]^3*a[2]+40*c[4]*a[0]*a[1]*a[2]^3+80*c[2]*a[1]*a[0]^2*A*B-624*c[2]*a[1]*a[2]^2*A*B+160*c[2]*a[1]*A*B*a[0]*a[2] = 0, 3*c[3]*a[0]*a[2]^2+6*c[2]*a[1]^2*a[0]-32*c[2]*a[2]^2*a[0]-5*a[0]*k^2*c[1]+10*c[4]*a[0]^3*a[2]^2-6*c[2]*a[1]^2*a[2]-15*c[4]*a[0]^4*a[2]-15*c[4]*a[0]*a[2]^4+10*c[4]*a[0]^2*a[2]^3+3*a[2]*k^2*c[1]-9*c[3]*a[0]^2*a[2]+16*c[2]*a[2]*a[0]^2-5*a[0]*mu+3*a[2]*mu-30*c[4]*a[0]^2*a[1]^2*a[2]+30*c[4]*a[0]*a[1]^2*a[2]^2+288*c[2]*a[2]^3*A*B+16*c[1]*a[2]*A*B+32*c[2]*a[2]*a[0]^2*A*B+104*c[2]*a[1]^2*a[0]*A*B-320*c[2]*a[2]^2*a[0]*A*B-216*c[2]*a[1]^2*a[2]*A*B+5*c[4]*a[0]^5+5*c[4]*a[2]^5+5*c[3]*a[0]^3+c[3]*a[2]^3-3*c[3]*a[1]^2*a[2]-10*c[4]*a[1]^2*a[2]^3+3*c[3]*a[0]*a[1]^2+10*c[4]*a[0]^3*a[1]^2+16*c[2]*a[2]^3+8*c[1]*a[2] = 0, -6*c[3]*a[0]*a[2]^2-22*c[2]*a[1]^2*a[0]+64*c[2]*a[2]^2*a[0]-10*a[0]*k^2*c[1]-20*c[4]*a[0]^3*a[2]^2-66*c[2]*a[1]^2*a[2]+10*c[4]*a[0]^4*a[2]+10*c[4]*a[0]*a[2]^4-20*c[4]*a[0]^2*a[2]^3-2*a[2]*k^2*c[1]+6*c[3]*a[0]^2*a[2]-16*c[2]*a[2]*a[0]^2-10*a[0]*mu-2*a[2]*mu+30*c[4]*a[0]^2*a[1]^2*a[2]-30*c[4]*a[0]*a[1]^2*a[2]^2+96*c[2]*a[2]^3*A*B+48*c[1]*a[2]*A*B+5*c[4]*a[1]^4*a[2]+5*c[4]*a[0]*a[1]^4+96*c[2]*a[2]*a[0]^2*A*B-40*c[2]*a[1]^2*a[0]*A*B+192*c[2]*a[2]^2*a[0]*A*B-40*c[2]*a[1]^2*a[2]*A*B+10*c[4]*a[0]^5+10*c[4]*a[2]^5+10*c[3]*a[0]^3-2*c[3]*a[2]^3+3*c[3]*a[1]^2*a[2]-30*c[4]*a[1]^2*a[2]^3+9*c[3]*a[0]*a[1]^2+30*c[4]*a[0]^3*a[1]^2+80*c[2]*a[2]^3-8*c[1]*a[2] = 0, -6*c[3]*a[0]*a[2]^2-22*c[2]*a[1]^2*a[0]+64*c[2]*a[2]^2*a[0]-10*a[0]*k^2*c[1]-20*c[4]*a[0]^3*a[2]^2+66*c[2]*a[1]^2*a[2]-10*c[4]*a[0]^4*a[2]+10*c[4]*a[0]*a[2]^4+20*c[4]*a[0]^2*a[2]^3+2*a[2]*k^2*c[1]-6*c[3]*a[0]^2*a[2]+16*c[2]*a[2]*a[0]^2-10*a[0]*mu+2*a[2]*mu-30*c[4]*a[0]^2*a[1]^2*a[2]-30*c[4]*a[0]*a[1]^2*a[2]^2-352*c[2]*a[2]^3*A*B+80*c[1]*a[2]*A*B-5*c[4]*a[1]^4*a[2]+5*c[4]*a[0]*a[1]^4+160*c[2]*a[2]*a[0]^2*A*B+72*c[2]*a[1]^2*a[0]*A*B-192*c[2]*a[2]^2*a[0]*A*B+312*c[2]*a[1]^2*a[2]*A*B+10*c[4]*a[0]^5-10*c[4]*a[2]^5+10*c[3]*a[0]^3+2*c[3]*a[2]^3-3*c[3]*a[1]^2*a[2]+30*c[4]*a[1]^2*a[2]^3+9*c[3]*a[0]*a[1]^2+30*c[4]*a[0]^3*a[1]^2-80*c[2]*a[2]^3+8*c[1]*a[2] = 0, a[0]^5*c[4]+5*a[0]^4*a[2]*c[4]+10*a[0]^3*a[2]^2*c[4]+10*a[0]^2*a[2]^3*c[4]+5*a[0]*a[2]^4*c[4]+a[2]^5*c[4]-k^2*a[0]*c[1]-k^2*a[2]*c[1]+a[0]^3*c[3]+3*a[0]^2*a[2]*c[3]+3*a[0]*a[2]^2*c[3]+a[2]^3*c[3]-mu*a[0]-mu*a[2] = 0, 5*a[0]^4*a[1]*c[4]+20*a[0]^3*a[1]*a[2]*c[4]+30*a[0]^2*a[1]*a[2]^2*c[4]+20*a[0]*a[1]*a[2]^3*c[4]+5*a[1]*a[2]^4*c[4]-k^2*a[1]*c[1]+2*a[0]^2*a[1]*c[2]+3*a[0]^2*a[1]*c[3]+4*a[0]*a[1]*a[2]*c[2]+6*a[0]*a[1]*a[2]*c[3]+2*a[1]*a[2]^2*c[2]+3*a[1]*a[2]^2*c[3]-mu*a[1]+a[1]*c[1] = 0, 5*a[0]^5*c[4]+15*a[0]^4*a[2]*c[4]+10*a[0]^3*a[1]^2*c[4]+10*a[0]^3*a[2]^2*c[4]+30*a[0]^2*a[1]^2*a[2]*c[4]-10*a[0]^2*a[2]^3*c[4]+30*a[0]*a[1]^2*a[2]^2*c[4]-15*a[0]*a[2]^4*c[4]+10*a[1]^2*a[2]^3*c[4]-5*a[2]^5*c[4]-5*k^2*a[0]*c[1]-3*k^2*a[2]*c[1]+5*a[0]^3*c[3]-16*a[0]^2*a[2]*c[2]+9*a[0]^2*a[2]*c[3]+6*a[0]*a[1]^2*c[2]+3*a[0]*a[1]^2*c[3]-32*a[0]*a[2]^2*c[2]+3*a[0]*a[2]^2*c[3]+6*a[1]^2*a[2]*c[2]+3*a[1]^2*a[2]*c[3]-16*a[2]^3*c[2]-a[2]^3*c[3]-5*mu*a[0]-3*mu*a[2]-8*a[2]*c[1] = 0}, {B, mu, a[0], a[1], a[2]})
A user asks what they're doing wrong in r/maplesoft with the attached screenshot:
How are constructed binary operators in Maple?
Is it possible to create a binary operator A that we can use this way z := x A y ?
TIA
First 416 417 418 419 420 421 422 Last Page 418 of 2458
