I would like to split the expression 1 / (x²+i)² into partial fractions, but Maple (2020) doesn't seem to know:
convert(1/(z^2+I)^2, parfrac, z);
How do i fix this?
I wanna shade/fill different areas in a single graph and provide a legend for the graph. Areas are defined as follows where 0<=x<=1 and 0<=z<=1.
(label = c1) \quad if 0<x<1/13*(5-2sqrt(3)),0<z<1/2(2x+x^2)+1/2sqrt(4x^3+x^4)
(label = c2) \quad if 0<x<1/13*(5-2sqrt(3)),1/2(2x+x^2)+1/2sqrt(4x^3+x^4)<z<2x
I am trying solve on the outout of odetest, in order to determine range of which x makes this output zero.
It works sometimes and  does not work another times. I mean, it gives correct domain something, and other times, it overlooks some domain.
Here is an example
ode:=x*diff(y(x),x)*y(x) = (y(x)^2-9)^(1/2):
ic:=y(exp(4)) = 5:
sol:=dsolve([ode,ic],y(x)):
res:=odetest(sol,ode);
solve(simplify(res),x,allsolutions = true) assuming real;
It is true than when x=1, then is zero.  But so all values x>1 as well.
How to get solve to find those values as well and not just x=1?
I tried PDEtools:-Solve as well. It did not better
PDEtools:-Solve(simplify(res),x,allsolutions = true) assuming real;
Compare to Mathematica
Are there other commands in Maple which could obtain all the solutions like in the above?
Maple 2020.2 on windows 10
My problem is a hickup in the Maple 2020 version as compared to earlier versions :
In the Maple 2020 listtorec from package gfun asks for unknown value u(0) in recognition of series.
Example from the Maple help page:
with(gfun);
l := [1, 1, 2, 5, 14, 42, 132, 429, 1430, 4862, 16796, 58786];
rec := listtorec(l, u(n));
Error, (in gfun:-listtorec) invalid unknown function, u(0)
This error also happens with the second example in the Maple help page:
rec2 := seriestorec(series(add(l[i]*x^(i - 1)*(i - 1)!, i = 1 .. nops(l)), x, 12), u(n), ['egf']);
Error, (in gfun:-seriestorec) invalid unknown function, u(0)
How to feed this unknown value in the  call?
I have the following piece of code:
beta := 16250.25391;
tlow := 11.92817468;
y0 := t -> 1/4*4^(7/8)/(beta*(tlow - t))^(1/8);
r0 := 1;
r2 := 1.194444444;
r3 := -2.071877530;
dyr := t -> M*(-2*r0*diff(y0(t), t)/y0(t)^3 + 2*r2*y0(t)*diff(y0(t), t) + 4*r3*y0(t)^3*diff(y0(t), t));
plot(dyr(t))
Everything seems to work out fine until this point and I obtain a good plot. The problem occurs when I try calling the value of dyr at a specific point t. Here is an example:
dyr(5)
Error, (in dyr) invalid input: diff received 5, which is not valid for its 2nd argument
I understand there is something wrong with the diff part. I tried writing the following simple code and I have the same problem.
y := t -> t^2
z := t -> diff(y(t), t)
z(1);
Error, (in z) invalid input: diff received 1, which is not valid for its 2nd argument
I start with a function that has only one argument and it seems like introducing the diff requires that I use two arguments. y0 is a function of t solely and I would like dyr to have the same argument, so that I can call dyr(t) at any point t I want. Please take a look at this. Thanks in advance.
I can't figure exactly why adding export on module wide variable when using option package makes the variable not writable from a function inside the module
dsolver :=module()
option package;
export X::boolean := true;
export foo:=proc()
   dsolver:-X :=false;
end module;
dsolver:-foo();
Error, (in foo) attempting to assign to `X` which is protected.  Try declaring `local X`; see ?protect for details.
But this works
dsolver :=module()
export foo:=proc()
   dsolver:X :=false;
end module;
dsolver:-foo();
    false;
I wanted to make the variable export, so it can be set from anywhere (by other modules for example, directly). if I make it local, then other modules can no longer access it?
I know I can change the export to local as the error says. But why is this needed? Only thing I found so far, is this
"Not all modules are packages. Package semantics differ from module semantics in two ways. First, (module-based) package exports are automatically protected. Second, packages can be used as the first argument to"
So the above says function inside module, can't change module wide variable, if this variable is exprted, when using option package? Why?
In general, I am still not sure when to use option package or not.
Are there any general rules as to when one needs to add option package vs. Not using this option? i.e. just use module() without this option? or the question is: When must one use option package?
I put everything (all modules) eventually in an .mla file and both cases work the same in this respect, so not sure when to use this option now.
Hello everyone;
There is itterative scheme and i have written a code. I want to know time and bytes used in each itteration. I have used the command "Usage" and code is showning results which are not right i thin becasue momery used should increase with itterations i.e., computaion is increasing so. CPU time is alos a issue here in my code.
Note: Code is also uploaded.
The code
S:=sum(1/x__i,i=1..5)
will give us the following ouput
Why not
S:=add(1/x__i,i=1..5)
 also give same result. why?How to do?
I also note that:
S:=add(1/x||i,i=1..5)
S:=sum(1/x||i,i=1..5)
Hey everyone,
f_1 and f_2  are satisfying the set of non-linear integral equations I have attached to this message.
I know that I need to solve them numerically by iterations. Probably, the first guest of the function f_1 and f_2  is the driving term. a is just a parameter which can be fixed (I guess smaller than \pi/4). * is the convolution product and k is the momentum space parameter. I learnt that in order to solve them I should solve them in the Fourier space. I know also that I need to discretize these function in the “real ” space between {-L,+L} before applying the FFT or one of its relatives. Thank you for any suggestions or leads.
Hi to all community. I am trying to integrate a lengthy-expression but could not get the result after waiting of 1 and 2 hours even. is there any way to control such integration
Integration_Help.mw
This is the context
A mathematical expression f has been coded by a two stage process of the form
(u and s are character strings)
I do not know what f is, but I know what P1, P2 are and I know s too.
I would like to recover f.
Here is the particular couple of coding processes that I consider
f := sqrt(x);    # assumed to be unknown
u  := sprintf("%Zm", f);                     # "process" P1
s  := StringTools:-Encode(u,':-base64');     # "process" P2
# The "inverse" of P2 is
v := StringTools:-Decode( s, 'encoding' = ':-base64' );
# Does it exist an operation to recover f from v?
Hey there, I´m new to maple and running into some syntax issues when calculating the Euler-Lagrange equation.
The Euler Lagrange equation in general looks like this:
I´ve got  the Lagrangian for my task figured out:
Here´s the code for this line, be aware that the function definition part of this is not working.
L:=((x),(varphi),t)->(J)/(2)*(((x))/(R))^(2)+(`m__R`)/(2)(*(x))^(2)+(`m__p`)/(2)(((x)+l*(varphi)*cos(varphi))^(2)+(l*(varphi)*sin(varphi))^(2))+`m__p`*g*l*cos(varphi)
phi is obviously a function of t, I´m not sure if I should have written phi(t)
In the first step to solve the Euler-Lagrange, I have to partially differentiate L w.r.t xdot. preferably with a command something like the following:
How do I do that, how do I set L up to be able to do that? The way I defined the function above is not correct because xdot and phidot cant be used an argument apparently.
If all is working perfectly I´d be able to partially differentiate L w.r.t xdot, phidot, x, phi and subsequently be able to differentiate the first two w.r.t t again.
I´ll spare you the detail but I´ve tried for hours now with redefining xdot as xdot:= diff(x(t),t) and all sorts of other ways but nothing seems to really work.
Thanks for your help.
I have three equations in terms of the following variables:
X,Y,X1, X2
How do I get an equation in terms of (X1,X2)  with Maple from Equations 1-3?
E.mw
A very simple question (by example):
Consider two polynomials g and h:
with(PolynomialTools):
g:=FromCoefficientList([1,2,3],x);
h:=FromCoefficientList([4,5,6,7],x);
What is the syntax for computing the composition of g with h? (As a polynomial.)
For instance, I would like to use CoefficientList on the result.
I know the @ operator and the subs command and have tried using them in various ways, but with no success.
(Of course, my question is general; the above is just an example.)
Edit: Additional question (which is my real question):
I'm writing a procedure that takes two polynomials g and h, and in which I define an unknown polynomial f. I want to compute its coefficients so that
f "composition" g = h
I write:
fCoeff:=seq(a[i],i=0..t) (to define the unknown coefficients. I can compute t.)
f := FromCoefficientList([fCoeff],x);
Then I would like to do something like:
comCoeff:=CoefficientList(f "composition" g,x)
If I have this, then I know how to solve for the unkown coefficients in f.
Hello. Tell me, please, is it possible to somehow remove the labels on the axes in Maple when plotting graphs? I mean labels 1, 2, 3 and so on. Thank you for your help.
First 488 489 490 491 492 493 494 Last Page 490 of 2458
