Idea for trigonometric animation like this? Thanks
Please I need help with my proc.
> RK2skritt:=proc(FR::procedure,xo,yo,vxo,vyo,h) local x, y, vx, vy, r, kx1, kx2, kx3, kx4, ky1, ky2, ky3, ky4, l x1, l x2, l x3, l x4, ly1, ly2, ly3, ly4, tmp; r:=sqrt(xo*xo+yo*yo); tmp:=-(h*FR(r))/(r); lx1:=h*vxo; ly1:=h*vyo; kx1:=tmp*xo; ky1:=tmp*yo; lx2:=h*(vxo+0.5*kx1); ly2:=h*(vyo+0.5 ky1); r:=sqrt((xo+0.5*lx1)^(2)+(yo+0.5*ly1)^(2)); tmp:=-(h*FR(r))/(r); kx2:=tmp*(xo+0.5*lx1); ky2:=tmp*(yo+0.5*ly1); lx3:=h*(vxo+0.5*kx2); ly3:=h*(vyo+0.5*ky2); r:=sqrt((xo+0.5*lx2)^(2)+(yo+0.5*ly2)^(2)); tmp:=-(h*FR(r))/(r); kx3:=tmp*(xo+0.5*lx2); ky3:=tmp*(yo+0.5*ly2); lx4:=h*(vxo+kx3); ly4:=h*(vyo+ky3); r:=sqrt((xo+lx3)^(2)+(yo+ly3)^(2)); tmp:=-(h*FR(r))/(r); kx4:=tmp*(xo+lx3); ky4:=tmp(yo+ly3); x:=xo+(lx1+2*lx2+2*lx3+lx4)/(6); y:=yo+(ly1+2*ly2+2*ly3+ly4)/(6); vx:=vxo+(kx1+2*kx2+2*kx3+kx4)/(6); vy:=vyo+(ky1+2*ky2+2*ky3+ky4)/(6); [x,y,vx,vy]; end proc: Error, invalid local declaration Please someone help me!!!!!!!!
in maple after fitting an equation (A + B.x) in the experimental data, how to assign to parameters A and B the adjusted values will be assigned in the equation?
I have a surface described by the equation.
f := (x, y) -> 3*(1 - x)^2*exp(-x^2 - (y + 1)^2) - (2*x - 10*x^3 - 10*y^5)*exp(-x^2 - y^2) - 1/3*exp(-(x + 1)^2 - y^2)
plot3d(f(x,y),x=-3..3,y=-3..3,orientation=[-40,60,0])
If a drop of water were put at point f(0.2,1.4), how would we draw a line to follow it's path?  (is that the gradient curve?)
I expect the output for the following code to be a Matrix containing 720 and a Matrix containing 21. What I get is a Matrix containing x^6 and one containing 21, which shows an unexpected difference between the parameter evaluation rule for Matrix products and that for Matrix sums. Is there a good reason for this, or is it a bug? Do any other binary operators between rtables also show this weirdness?
proc(n::nonnegint)
local x, q, v:= <<x>>, s:= <<0>>, p:= <<1>>;
   for x to n do p:= p.v; s:= s+v od;
   p, s
end proc(6);
Why does the following code return a vector containing x rather than containing 1 and how can I correct it?
proc() local x, v:= <x>; x:= 1; rtable_eval(v) end proc();
My actual goal is to have a Matrix with a parameter inside a procedure and to create different instantiations of the Matrix in a loop by changing the parameter.
What is the problem with the initialconsiditions that caused this error?
"Error, (in dsolve/numeric/DAE/initial) missing initial conditions for the following: {Integer}"
I use Maple 2016.
The following command calculates semicircle perimeter, but it returns infinity.
`assuming`([int(sqrt(1+(diff(sqrt(R^2-(x-R)^2), x))^2), x = 0 .. 2*R)], [R > 0])
I am running a for loop which for some loop index may give error message but it is fine for me to go with next loop indexes. but maple stop after the error message. How can I make maple to run even after the error message. Thank you
Can I do something like it?
I am trying to solve 1 equation with goniometric functions so I know the range (0..2*Pi), but it just doesnt solve it (though it solved similar ones before).
fsolve(3.*10^6 = sqrt((-4.2*10^14*(-1.*10^7*u*cos(u) + 3.84*10^8)/((-1.*10^7*u*cos(u) + 3.84*10^8)^2 + 1.*10^14*u^2*sin(u)^2)^(3/2) + 4.2*10^21*u*cos(u)/((-1.*10^7*u*cos(u) + 3.84*10^8)^2 + 1.*10^14*u^2*sin(u)^2)^(3/2))^2 + 7.056*10^43*u^2*sin(u)^2/((-1.*10^7*u*cos(u) + 3.84*10^8)^2 + 1.*10^14*u^2*sin(u)^2)^3), u, u = 0 .. 2*Pi)
Is there some way to get the solution?
Thank you in advance
I have a problem in solving a differential equation in maple. I got an error which is "unexpected occurence of the variables..." .  I have uploaded my full problem as a pdf and maple worksheet (mw) files.
Untitled_(4).pdf
Prob.mw
What is the derivative of the composed Bessel function BesselJ(alpha, sqrt(u^2+v^2-2*uv*cos(phi))) with respect to u?
BesselJ(alpha, sqrt(u^2+v^2-2*uv*cos(phi))) is a composed function of the form f(g(u)) with f=BesselJ(u) and g=sqrt(u^2+v^2-2*uv*cos(phi)).
Best regards
I can't figure out the source of the problem.  Any ideas?
with(Physics[Vectors]):
"/usr/local/opt/maple2019/lib/update.mla", `2019, May 21, 20:18 hours, version in the MapleCloud: 445, version installed in this computer: the "Physics Updates" is not installed.`
3.0*_i + 4.0*_j;
3.0*_i+4.0*_j
3.0*_i + 0.0*_j;
Error, (in Physics:-Vectors:-+) wrong sum of a vector with the scalar 0.
How do we handle this when it happens within a computation burried inside a proc?
Download mw.mw
How could one simplify the following expression, preferably over z in large parts of the complex plane, and with few calls under different assumptions, and preferably gracefully.
expr := 2*Pi*(-z)^(1/2)-z^(1/2)*(2*ln(-z^(1/2))-ln(z));
First 668 669 670 671 672 673 674 Last Page 670 of 2464
