I have a square matrix of data points. Each point is between 0 to 0.2. I wish to plot it and set the axes to values from 0 to 1. I want the 3D plot to be plotted with a constrained scaling. The two options I have are plots:-matrixplot and plots:-surfdata.
* matrixplot can constrain the data, but it isn't obvious how to change the axes so that it shows from 0 to 1 in both directions.
* In surfaceplot, it is easy to adjust the axes values, but scaling=constrained does nothing.
(I assume someone else might also appreciate the answer. So, instead of me continuing to struggle, I post here and hope someone can answer without the use of many brain cells.)
Example attached.
restart; N := 20; M := LinearAlgebra:-RandomMatrix(N, generator = rand(0 .. .2))
Scaling can be easily controlled, but labels are bad
plots:-matrixplot(N*M, labels = ["x", "y", "V"], scaling = constrained, axis = [tickmarks = [seq(0 .. 1, numelems = 10)]], size = [600, 600])
Axes are shown nicely, but scaling cannot be constrained.
plots:-surfdata(M, 0 .. 1, 0 .. 1, labels = ["x", "y", "V"], scaling = constrained, size = [600, 600])
Download Scaled_matrix_plot_with_axes.mw
If I understand right, in the following calling an exception should be raised since the return value of the matching coercion procedure is of course not of type “set”:
foo := (x::coerce(set, (y::rtable) -> convert(y, list))) -> x:
foo(<0>);
                              [0]
Did I miss something?
So just like the title illustrates, I found a paper authored by Gary Nicklason in 2022: Autonomous Planar Systems of Riccati Type and in the last section it mentioned about a class of Abel ODE, which belongs to AIA(Abel Inverse Abel) class. It is of First kind and the inverse of it(by swapping variables) is of second kind.
While the first kind is solvable in terms of Airy function, the inverse of it along with its equivalence class is not solvable by the existing dsolve.
I have tested it in my worksheet Nicklason_equation.mw. So is it possible to add this class into the dictionary for solvable Abel ODE, or, maybe there are some bugs within the internal procedure of dsolve, which results in failure for catching the solvable candidates?
I want to remove the Lambert function (LambertW) from my equation, but I don't know how. I tried using the explicit option, but it didn't work. How can I express the equation without LambertW?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
declare(u(x, y, z, t))
declare(f(x, y, z, t))
pde := diff(diff(u(x, y, z, t), t)+6*u(x, y, z, t)*(diff(u(x, y, z, t), x))+diff(u(x, y, z, t), `$`(x, 3)), x)-lambda*(diff(u(x, y, z, t), `$`(y, 2)))+diff(alpha*(diff(u(x, y, z, t), x))+beta*(diff(u(x, y, z, t), y))+gamma*(diff(u(x, y, z, t), z)), x)
diff(diff(u(x, y, z, t), t), x)+6*(diff(u(x, y, z, t), x))^2+6*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x))+diff(diff(diff(diff(u(x, y, z, t), x), x), x), x)-lambda*(diff(diff(u(x, y, z, t), y), y))+alpha*(diff(diff(u(x, y, z, t), x), x))+beta*(diff(diff(u(x, y, z, t), x), y))+gamma*(diff(diff(u(x, y, z, t), x), z))
pde_nonlinear, pde_linear := selectremove(proc (term) options operator, arrow; not has((eval(term, u(x, y, t) = a*u(x, y, t)))/a, a) end proc, expand(pde))
0, diff(diff(u(x, y, z, t), t), x)+6*(diff(u(x, y, z, t), x))^2+6*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x))+diff(diff(diff(diff(u(x, y, z, t), x), x), x), x)-lambda*(diff(diff(u(x, y, z, t), y), y))+alpha*(diff(diff(u(x, y, z, t), x), x))+beta*(diff(diff(u(x, y, z, t), x), y))+gamma*(diff(diff(u(x, y, z, t), x), z))
thetai := t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i]; eval(pde_linear, u(x, y, z, t) = exp(thetai)); eq15 := isolate(%, w[i])
w[i]*k[i]*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])+12*k[i]^2*(exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i]))^2+k[i]^4*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])-lambda*l[i]^2*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])+alpha*k[i]^2*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])+beta*k[i]*l[i]*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])+gamma*k[i]*r[i]*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])
w[i] = -(t*k[i]^4+gamma*t*k[i]*r[i]+alpha*t*k[i]^2+beta*t*k[i]*l[i]-lambda*t*l[i]^2+LambertW(12*t*k[i]*exp(-(t*k[i]^4+alpha*t*k[i]^2+beta*t*k[i]*l[i]+gamma*t*k[i]*r[i]-lambda*t*l[i]^2-x*k[i]^2-y*k[i]*l[i]-z*k[i]*r[i]-eta[i]*k[i])/k[i]))*k[i])/(t*k[i])
sol := solve(eq15, w[i], explicit)
Download remove.mw
I have a system of polynomial equations where the unknowns are real numbers. The set of solutions is infinite (positive-dimensional). How can I compute the real dimension of the solution set (i.e. of a real algebraic variety)?
As it as mentioned in arXiv:2105.10255, this can be done using the RealTriangularize function from the RegularChains package. What is best way of getting the real dimension from the regular_semi_algebraic_system object, which is returned by this function?
I got email to register to "see" Maple 2025 :
for a special advanced look at Maple 2025
But I do not understand what does registering here means. Do I then get a link to some Maple internal URL to watch Video at that time? It says
Date/Time: Tuesday, March 18, 2025 at 11:00 AM
Language: English
Duration: 1 hour
If I register, then what happens?  do I get a link that opens at the time time to watch it? If so, why does one have to register to watch a Maple video? Why is the link not made public for any one to watch? Does one have to be at the browser at that exact time for the link to open?
I just do not know what a Maple webinar means.  Is it like a youtube video?
Would someone please help me with how to achieve this cool animation shown here.
3d plot
How i can add lebel inside graph  like this picture for some graph , in somecoding i have but i can't how it work i want add to  my code but i can't do the same as paper did
label.mw
I am trying to find the most compact form of the symbolic matrix exponential of the specific 4x4 input matrix with the following form:
where all variables are non-negative real constants, with the additional problem specific conditions:
1. omega__1 + omega__2 = 1
2. f__p + f__d1 + f__d2 = 1
There are many mathematically identical subterms at the matrix exponential, so I would like to use a few proper substitute subexpressions, but Maple does not apply it, without any error or warning message.
Moreover, I have no idea how to incorporate above-mentioned additional conditions into the simplification process.
expFT_compact.mw
I will be very happy for any help with this problem.
Michal
I am very interested in problems of integration and limit determination. In order to be able to continue other work with the help of Maple, I would like some advice on solving the following problem. The solution I know of using pen and paper is very tiring, perhaps Maple can make it easier:
To calculate Int(from 0 to 1)[ln(x)*ln(1-x)]dx
or, for obvious reasons, formulated differently:
Let eps, delta>0. Calculate
lim(eps, delta-->0)Int(0+eps to 1-delta)[ln(x)*ln(1-x)]dx
Is there a good way to include subscript(s) to a letter within a 'text' command?  Currently I do this by specifying the coordinates, letter, and font for the letter, then specify the coordinates, number and font for the subscript.  However, with this method the letter and subscript can be compressed if the viewing interval is compressed or expanded.
Is there another way to include letters with a subscript in a text command?
Hi! A basic issue.
Why view=[-2 ..1, -2 ..5]  is not useful here? According to the output, only the green line meets the view settings. I want to extend the left side of these three lines appropriately (show the intersection)
with(plots)
l := 2*x+y+1 = 0; l1 := 4*x+2*y+2 = 0; l2 := 4*x+2*y-2 = 0; l3 := 4*x-2*y+6 = 0
2*x+y+1 = 0
4*x+2*y+2 = 0
4*x+2*y-2 = 0
4*x-2*y+6 = 0
display({implicitplot(l, color = black, legend = l, thickness = 5, view = [-2 .. 1, -2 .. 5])}, {implicitplot(l1, color = red, legend = l1, view = [-2 .. 1, -2 .. 5])}, {implicitplot(l2, color = blue, legend = l2, view = [-2 .. 1, -2 .. 5])}, {implicitplot(l3, color = green, legend = l3, view = [-2 .. 1, -2 .. 5])})
Download The_intersection_parallelism_and_coincidence_of_two_straight_lines.mw
I have an epidemic model and the endemik equilibrium point contains rootOf _Z, here's one of the example
i still don't understand about the _Z and find the "remove_RootOf" command. Does it affect the result or is it an explicit result of Z?
I'm trying to use the Explore command to examine the effect of two parameters (mu and sigma) on the density function curve. The visualization isn't very optimal, especially with the mu parameter, and it's difficult to add options (range, color, gridlines, etc.). Any suggestions to optimize this idea? Thanks for your insights!
Q_Explore.mw
when we have ode equation we say what is type of equation then  i want solve by this method say the name of method and if possible i want to solve this equation by the method step by step too, maple can do that? also can we plot the solution or any geometricall presentation , also i have error in writing exact form of equation
"with(Student[ODEs]): "
with(DETools)
ode1 := diff(y(x), x)+2*x*y(x) = x
Type(ode1)
{linear, separable}
W := dsolve(ode1)
y(x) = 1/2+exp(-x^2)*c__1
odetest(W, ode1)
ODESteps(ode1)
"[[,,"Let's solve"],[,,(&DifferentialD;)/(&DifferentialD;x) y(x)+2 x y(x)=x],["&bullet;",,"Highest derivative means the order of the ODE is" 1],[,,(&DifferentialD;)/(&DifferentialD;x) y(x)],["&bullet;",,"Separate variables"],[,,((&DifferentialD;)/(&DifferentialD;x) y(x))/(2 y(x)-1)=-x],["&bullet;",,"Integrate both sides with respect to" x],[,,&int;((&DifferentialD;)/(&DifferentialD;x) y(x))/(2 y(x)-1) &DifferentialD;x=&int;-x &DifferentialD;x+`c__1`],["&bullet;",,"Evaluate integral"],[,,(ln(2 y(x)-1))/2=-(x^2)/2+`c__1`],["&bullet;",,"Solve for" y(x)],[,,y(x)=((e)^(-x^2+2 `c__1`))/2+1/2]]"
ode2 := (sin(x)*tan(x)+1)*dx-cos(x)*sec(y(x))^2*dy = 0
Type(ode2)
Error, (in Student:-ODEs:-Type) could not determine the solving variable. Please specify it as an extra argument in the form: y(x)
Download ode-example.mw
First 66 67 68 69 70 71 72 Last Page 68 of 2462
