Good day!
I wish to represent the flow across a network from a set of sources to a number of destinations or sinks.
In the simple example attached, there are 4 sources and 10 possible sinks. The flow from source to sink is given by the matrix, A, and each element is a binary entry; 1 for active and 0, otherwise. I would like to assign labels to each source (A,B,C,D) and sink (1,2,3,..., 9,10) and this feature will be most convenient for large matrices.The idea is to have these labels shown on the directed graph so that it is easy to see the flow configurations at a glance.
Does anyone know how this can be done?
MaplePrimes_network_labels.mw
I have to build a simple model in MapleSim that allows to simulate a mass that goes down along an inclined plane with a certain friction.
Is there a component that simulates the inclined plane? I tried to use a prismatic joint but it has some predifined translational directions so I can't impose the movement along the plane.
Help required to get the derire output  for the differential equation . I am attacing the codes and the sample output.
with(DETools):
a1:=m^2*((1-N)/(2-N))*(r/2)*Dp:
a2:=((1-N)*m^2/(2-N))*(((Nb-Nt)/64)*(r^5/6-h^2*r/2)-(B[r]/4)*(r^3/4-h^2*r/2)*(Nt/Nb)):
a3:=a1-a2:
a4:=r^2*a3:
DE1:=r^2*diff(v(r),r,r)+r*diff(v(r),r)-(m^2*r^2+1)*v(r)=a4:
b1:=dsolve(DE1,v(r)):
Could you please help me to solve the following problem
I want to catch the optimized values for df, tf, hw, and tw using considered constraint.
Thank you very much.
with(plots); R := 5; alpha := (1/9)*Pi; beta := (1/3)*Pi; n := 100; dt := 2*Pi/n; C1 := plot([R*cos(t), R*sin(t), t = 0 .. 2*Pi], color = blue); O := [0, 0]; M := [R*cos(beta), R*sin(beta)]; A := [R*cos(alpha), R*sin(alpha)]; B := [R*cos(alpha+Pi), R*sin(alpha+Pi)]; AB := plot([A, B]); OM := plot([O, M]); P := [R*cos(t0*dt), R*sin(t0*dt)]; Q := [R*cos(dt*t0+Pi), R*sin(dt*t0+Pi)]; diamob := seq(plot([P, Q], color = green), t0 = 0 .. n); MP := plot([M, P]); MQ := plot([M, Q]); tp := textplot([[A[1]+.3, A[2], "A"], [B[1]-.3, B[2], "B"], [M[1]+.3, M[2]+.3, "M"]]); display({AB, C1, OM, tp, display(diamob, MP, MQ, insequence = true)}, scaling = constrained):
I wish animate MPand MQ.
Is there a way to take the laplacian of 1/r and get the "physics" answer of -4*pi*delta(\vec{r})?
Dear Community,
I'm trying to import a simple Excel (xlsx) file into my Maple worksheet.
1st problem: Maple reads it only, if I put it into my root directory. As soon as I try to read it from the directory I'm working in, and provide full file name (Path + file name)  it fails. Why?
2nd problem: The real surprise comes, when I manage to import it. Its a 150 x 2 matrix, but as soon as I try to retrieve a value, I get an error message "Error, bad index into Matrix". Why is this? Should be very simple. Files attached.
Tx in advance
best regards
Andras
ImportTest.mw,
RC_Rate_Schedule.xlsx
For a statistical course I will give next year, I would like to demonstrate the calculation of tetrachoric and polychoric correlations. Furthermore, it would be nice to show the students how the expectation-maximization algorithm works.
Has anyone already programmed this in Maple?
best regards,
Harry
I´a currently making a school assigment, but i can´t get maple plots to combine the graphs i plot, when i plot multiple plots. (see picture) (the code is in the bottom of the question)
as you can see the green and yellow grafh won´t combine. I have tried google but couldn´t find any anserws that worked.
Hope someone can help me!
with(plots); with(Plot);
a := plot(4, x = 0 .. .25, color = red, view = [0 .. .25, 0 .. 5]);
b := plot(1/x, x = .25 .. 1.101, color = blue, view = [.25 .. 1.101, 0 .. 5]);
c := plot(-(1/12)*x+1, x = 1.01 .. 6, color = yellow, view = [1.101 .. 6, 0 .. 5]);
d := plot(.5+sqrt(x-5), x = 6 .. 20, color = green, view = [6 .. 20, 0 .. 5]);
e := plot(1.15*sqrt(x-7), x = 7 .. 20, color = pink, view = [7 .. 20, 0 .. 5]);
display(a, b, c, d, e);
I want to plot all three "roots" of the polynom I called 'H[i]' for different values of 'V', in the interval k=0.0..1.0, all in the same plot.
How can I do it, both for real and imaginary parts of H[i]?
Thanks for your help.
file1.mw
with(plots):R := 5; alpha := (1/9)*Pi;
A := [R*cos(alpha), R*sin(alpha)]; B := [R*cos(alpha+Pi), R*sin(alpha+Pi)]; AB := plot([A, B], scaling = constrained);
display({AB, C1}, scaling = constrained);# bad drawing
I’m working on a weighted statistical series.. and I notice a difference in results with the DataSummary command. Any suggestions? Thank you
QuestionDataWeights.mw
this is my code:
g(x,y):=min((3+((x-y)^(2))/(10)+(|x+y|)/(sqrt(2))),(-|x-y|+(7)/(sqrt(2))));
q:=0; h(x,y):=Heaviside(g(x,y)-q);
(x, y) -> Heaviside(g(x, y))
p := int(int(h(x, y)*exp((-x^2-y^2)*(1/2))/(2*Pi), y = -infinity .. infinity), x = -infinity .. infinity);
Error, (in unknown) too many levels of recursion
I keep having this error message, is this integral impossible to process or is there someting wrong with the code?
https://aws.amazon.com/getting-started/projects/deploy-elastic-hpc-cluster/
is it possible to use maple on high performance clusters?
i can only think to use c program to call cmaple with MPI in linux to use high performance clusters.
is there any other official method to do this?
if i upload my maple 2015 version to amazon for this computing, will it used up all license in this first chance of installation leading to that i can not install maple 2015 linux version to other machine?
https://docs.aws.amazon.com/AWSEC2/latest/WindowsGuide/ConfigWindowsHPC.html#ComputeNode
which virtual machine should i install the maple 12? on one virtual machine or all compute nodes?
how many compute nodes are need to compute dsolve 100,000 systems which may or may not have solution in maple 12?
Hello Maple experts;
I am not able to understand why Maple 2019 can solve Laplace PDE in 2D Catersian on semi-infinite domain, when the infinity is along the Y direction, but not along the X direction, since the solution method is exactly the same.
Here is the code
#right one, Maple can not solve
pde := diff(u(x, y), x$2)+diff(u(x, y), y$2) = 0:
bc_left_edge := u(0, y) = 0:
bc_bottom_edge:= u(x, 0) = 0:
bc_top_edge:= u(x, 1) = A:
bc:=bc_left_edge ,bc_top_edge,bc_bottom_edge:
sol:=pdsolve([pde, bc],HINT = boundedseries(x = infinity)) assuming x>0,y>0;
#left one, Maple can solve
bc_right_edge:= u(1, y) = A:
bc:=bc_left_edge ,bc_right_edge,bc_bottom_edge:
sol:=pdsolve([pde, bc],HINT = boundedseries(y = infinity)) assuming x>0,y>0;
Here is screen shot.
Maple can solve both cases if I remove the HINT. But the solution it gives is not as simple as using the HINT and contains unknown constants (_C5) that is why I use the HINT.
But the main question is, since both problems are exactly the same, why Maple can solve one and not the other when using the HINT? Is there something I am doing wrong?
Maple 2019 on windows 10 and Physics cloud version 333.
First 752 753 754 755 756 757 758 Last Page 754 of 2470
