Is there a simple (i.e. without using of op( ), coeff( ), etc.)  way to force Maple to put a common constant out of brackets in the expression like 2*a+2*b -> 2(a+b)? The task seems as very simple. But I can't find a solution
I've tried alot, but nothing seems to work. The problem occurres whenever im trying to use multiple SI Units in caculations that require division. Example:
"`E__n`:=n->-6.63*10^(-34)⟦J⟧*⟦s⟧*3*10^(8)*⟦m⟧/(⟦s⟧)*1.097*10^(7)⟦m⟧^(-1)*1/(n^(2)):"
Error, null
Parse:-ConvertTo1D, "invalid input %1", 3
"eV:=x->x/(1.602*10^(-19)⟦J⟧/(⟦eV⟧))"
Error, null
Parse:-ConvertTo1D, "invalid input %1", 6
Download Maple_prob1.mw
I have a pretty simple problem and I feel pretty dumb just asking this.
If I have a 2x2 Matrix and I remove one column and one row, how do I get the result to be a scalar, not 0th vector?
R := RandomMatrix(2);
R1 := DeleteRow(R,-1);
R2 := DeleteColumn(R1,-1);
                         R := [ -82  41 ]
                                  [-70  91]
                        R1 := [-82  41]
                          R2 := [-82]
I am trying to find the positive integer numbers a, b, c, d, e, f so that the function y =  (a x^2 + b x + c)/(d x^2 + e x + f) is increasing function and the equation  (a x^2 + b x + c)/(d x^2 + e x + f) = x has three integer solutions. I tried
ListTools[Categorize];
L := [];
for a to 10 do
for b to 10 do
for c to 10 do
for d to 10 do
for e to 10 do
for f to 10 do
if a*e-b*d > 0 and a^2*f^2-a*b*e*f-2*a*c*d*f+a*c*e^2+b^2*d*f-b*c*d*e+c^2*d^2 < 0 and igcd(a, b, c) = 1 and igcd(d, e, f) = 1 and igcd(a, b, c, d, e, f) = 1 and x = (a*x^2+b*x+c)/(d*x^2+e*x+f) then L := [op(L), [a, b, c, d, e, f, x]]
L:=[op(L), [a, b, c, d,e,f,x]]; fi;
od: od: od: od:od:od:
nops(L);
I did not get the result.
With Mathematica, I got like this picture (a, b, c, d, e, f, x1, x2, x3)
How can I get the correct results?
Is it possible to save table settings (and set a new default), so I dont have to manually change the "indent" number in every table i make in a document?
Its not possible to save the settings in the table menu itself, and there is no "table" option under preferences.
Almost Happy maple user on macbook pro 18
Here I put two functions defined by piece-wise command and then using int(...,numeric) to take their integration but Maple computes only one while for the other one just gives the expression back. The integration domain is bounded, the function is bounded too so I don't think the reason is being divergent in the one that Maple is not computing it.
Is there any prepared command or package for Maple which computes the integrals like this or is better than just int(...,numeric)? Or I have to write an algorithm an force Maple to compute my integral using an algorithm given by myself?
The codes in plain text:
int(piecewise(0 < -k5*x1*x2+k1*x1 < 1, 1, -k5*x1*x2+k1*x1 <= 0 and 1 <= -k5*x1*x2+k1*x1, 0)*piecewise(0 < -k5*x1*x2+k2*x2 < 1, 1, -k5*x1*x2+k2*x2 <= 0 and 1 <= -k5*x1*x2+k2*x2, 0), k1 = 0 .. 1, k2 = 0 .. 1, k5 = 0 .. 1, x1 = 0 .. 1, x2 = 0 .. 1, numeric);
int(piecewise(0 < x+y < 1, 1, x+y <= 0 and 1 <= x+y, 0)*piecewise(0 < y*x^2 < 1, 1, y*x^2 <= 0 and 1 <= y*x^2, 0), x = 0 .. 1, y = 0 .. 1, numeric);
I have a file consisting of
a b
b a
I want to read it into Maple and convert to a 2x2 matrix.  This will be trivial to most of you, but it isn't to me!  Thanks for some help.  .........Edgar
I need your help, to find all possible leading behavior of the following curves as x ->infinity of the following curves  defined using the implicit equation:
implicitplot(x^2*y^2-2*x*y^3+y^4-y^3+x^2 = 1, x = 100 .. 1000, y = 0 .. 1000);
Maybe we must change the range of y or x to conclude and obtain all possibles behavior.
I hope have any idea to conclude.
many thanks
I need help for two exercise. In the first I have in the secondary circuit nothing, in the second exercise un inductor.thanksinduzione_fra_due_circuiti.msim
Hi :-(
Just type this little set of lines (presently in Maple 2018, not checked for older versions)
with(Statistics):
N := ... Some integer value >= 2;
X := RandomVariable(Binomial(N, 1/2));
plot(CDF(X, s), s=-1..N+1, gridlines=true, axis[1]=[gridlines=N+1]);
You will be horified by the results you obtain:
Whatever the value of n in [2, 5] the CDF is null for s < 0 (good), equal to 1 for s > N (good also) ... and equal to 1 in between
I didn't check with p = 0.5 instead of 1/2, neither for other values.
Surprinsingly the PDF is correct for any integer n
I want to solve system of nonlinear ordinary differential equations numerically using the variational finite
element method (FEM). is it possible to solve on Maple? If anybody have a idea please share with me. I attach the image of my problem which I am tryimng to solve.
There was a streamlines question that has dissappeared.  Where did it go?  Why was it deleted?
Below is a picture of my code and the errors that have arisen when I have tried to use a 2-level indice within a loop and dsolve. I will also paste in the code below.
with(PDEtools); umain := 1-exp(-y)+sum(A^i*u[i](y, z), i = 1 .. 4); vmain := -1+sum(A^i*v[i](y, z), i = 1 .. 4); wmain := sum(A^i*w[i](y, z), i = 1 .. 4); pde[main] := diff(vmain, y)+diff(wmain, z); pde[main[2]] := vmain*(diff(wmain, y))+wmain*(diff(wmain, z))-(diff(wmain, y$2));
for i to 1 do pde[i] := coeff(pde[main[2]], A^i) = 0; w[i](y, z) := sum(sol[i, k](y)*sin(k*z), k = 1 .. i); for j to i do sys__i__j := [-(diff(sol__i__j(y), y))-(diff(sol__i__j(y), y$2)) = coeff(pde[main[2]], sin(j*z)), sol__i__j(0) = 0, sol__i__j(infinity) = 0]*dsolve([-(diff(sol__i__j(y), y))-(diff(sol__i__j(y), y$2)) = coeff(pde[main[2]], sin(j*z)), sol__i__j(0) = 0, sol__i__j(infinity) = 0]); assign(op(0, sol__i__j*y)) = unapply(dsolve(sys__i__j), op(dsolve(sys__i__j))) end do end do
I have learned that the eigenvectors of an solid object's Inertial Tensor are its principal axes and are an orthonormal set, however two of the eigenvectors in the cube in the uploaded worksheet are not orthogonal.
Where is my error?
CubePrincipalAxes.mw
Let a in ] 0, 1[  and  x real
Let  f := sin(x) / ( ( sin(a*x) )^a * ( sin((1-a)*x) )^(1-a) );
How can I find the limit of f as x goes to 0 ?
(limit, series, taylor don't work, wether I set or not assumptions on "a" [assume/assuming])
PS 1:  the limit is found once a numeric value is given to alpha
PS 2:  By simple calculations:
           sin(x) ~x  ;  sin(a*x) ~ ax  ; sin((1-a)*x) ~(1-a)x and thus
          ==>  f(x->0) ~ x / ( -a*x)^a * ((1-a)*x)^(1-a) )
                              = x / ( -a^a * (1-a)^(1-a) * x^(a+1-a)
                              = 1 /  ( -a^a * (1-a)^(1-a)  )
First 812 813 814 815 816 817 818 Last Page 814 of 2464
