LettR_curvefitting.mws
Am in the process of trying to addsome animation to a 2D letter R, namely to make the 'stalk' move.  I lost the output and managed to retrieve it by adding  verboseproc=0, and printlevel:=5.  However printlevel:=5 gives an excessive amount of output and anything less than 5 doesn't give enough output.  The code is messy asI've been experimenting with general curve fitting.
   Any help gratefully received.
I have a problem with writing this equation in maple.
the equation is:
I want to write this equation in maple, so I write it in this way:
for k from 1 to 7 do tau[k] := add*(d(k, j)*(diff(theta[j](t), t, t)), j = 1 .. 7)+add(add(c[i, j, k]*(diff(theta[i](t), t))*(diff(theta[j](t), t)), j = 1 .. 7), i = 1 .. 7)+phi[k] end do:
but I see this error: Error, index out of bounds
I appriciate if you help me find the problem.
Why is assume(...) do_something();  gives an error when I run the code one more time, but do_something() assuming ...; do not give an error when everything else is the same?
Is there semantic difference between the two forms? I thought they should work the same way. Here is an example
#in separate cell
#in separate cell
interface(showassumed=0):
pde := diff(u(x, t), t)=k*diff(u(x, t), x$2):
ic:=u(x,0)=0: bc:=u(0,t)=t:
assume(x>0);assume(t>0);assume(k>0):
sol:= pdsolve({pde,ic,bc},u(x,t)):
#in separate cell. Now this gives error
#error message now
Here is screen shot
Now will do the same, but use assuming. Now there is no error
#in one cell
#in one cell
sol:= pdsolve({pde,ic,bc},u(x,t)) assuming x>0,t>0,k>0:
#in one cell, no error
Here is screen shot
Why does one give an error, but the second one does not?
I thought they work the same way. Which method is recommended to use?
assume(...); do_something();
or
Maple 2018 on windows.
equ.pdf The equation is in the following form:
     I'm attempting to use unevaluation quotes on a keyword argument within a procedure. For instance, if I have two procedures with the same keyword arguments, I need to unevaluate one to call the other:
foo1 := proc( {param:={}}, $)
  foo2('param'=param):
foo2 := proc( {param:={}}, $)
foo1('param'=1);
The above code throws the error,
Error, (in foo1) invalid input: too many and/or wrong type of arguments passed to foo2; first unused argument is 1 = 1
which I take to mean that 'param' in foo1 isn't being unevaluated in the call to foo2. What is the correct way to accomplish this?
Is it possible to get the following integral involving vectors done in Maple 2018, but handle the singularity when p1=p3?
Note that the output of p3 and p1 are slightly different, probably because the earlier version of the worksheet was in Maple 2017?
(Note: Earlier version - was due to help received from Dr. Edgardo Cheb-Terrab, using Maple 2017).
with(Physics[Vectors]);
r_ := _i*x+_j*y+_k*z;
                    r_ := _i x + _j y + _k z
p__1_ := _i*`p__1x `+_j*`p__1y `+_k*`p__1z `;
           p__1_ := _i p__1x  + _j p__1y  + _k p__1z
p__3_ := _i*`p__3x `+_j*`p__3y `+_k*`p__3z `;
           p__3_ := _i p__3x  + _j p__3y  + _k p__3z
Expression to integrate wrt p3
'exp(i*(p__1_ . r_))/((p__3_ - p__1_)^2)'
             exp(I Physics:-Vectors:-.(p__1_, r_))
              Physics:-Vectors:-+(p__3_, -p__1_)
Delaying the evaluation above, if evaluation is allowed, the integrand is
exp(I*(p__1_ . r_))/(p__3_-p__1_)^2;
(exp(I (p__1x  x + p__1y  y + p__1z  z)))/((_i (-p__1x  + p__3x )
   + _j (-p__1y  + p__3y ) + _k (-p__1z  + p__3z ))^2)
T i is the imaginary unit
interface(imaginaryunit = I);
                               I
Because (4), has the value of i before being the imaginary unit, input the integrand again
Now on the integration
Int(exp(I*(p__1_ . r_))/(p__3_-p__1_)^2, [`p__3x ` = -infinity .. infinity, `p__3y ` = -infinity .. infinity, `p__3y ` = -infinity .. infinity]);
  /infinity   /infinity   /infinity
/-infinity  /-infinity  / -infinity
   + p__1z  z)))/((_i (-p__1x  + p__3x ) + _j (-p__1y  + p__3y )
   + _k (-p__1z  + p__3z ))^2) dp__3x  dp__3y  dp__3y
value(Int(exp(I*(`p__1x `*x+`p__1y `*y+`p__1z `*z))/(_i*(-`p__1x `+`p__3x `)+_j*(-`p__1y `+`p__3y `)+_k*(-`p__1z `+`p__3z `))^2, [`p__3x ` = -infinity .. infinity, `p__3y ` = -infinity .. infinity, `p__3y ` = -infinity .. infinity]));
 exp(I (p__1x  x + p__1y  y + p__1z  z)) |PIECEWISE|[infinity,
   Im(_i p__1x  + _j p__1y  + _k p__1z  - _k p__3z )    ]
   ------------------------------------------------- = 0],
                          _i                            ]
   [0, otherwise]|| infinity
In the above, there is the product of three Dirac delta functions, that can be represented as a single 3D Dirac delta
combine(exp(I*(`p__1x `*x+`p__1y `*y+`p__1z `*z))*piecewise(Im(_i*`p__1x `+_j*`p__1y `+_k*`p__1z `-_k*`p__3z `)/_i = 0, infinity, 0)*infinity);
                          _i                            ]
Hello. Tell me please how to fix it and build a graph? Thank you in advance.
p := PolyhedralSets([-x >= 0, -y >= 0, -z >= 0, -(1/2)*x >= 0, (-x-y)*(1/2) >= 0, (-x-z)*(1/2) >= 0], {y = -20}, [x, y, z]);
plot(p);
Error, (in plot) cannot determine plotting variable
I wonder why trigonometric functions in the Trig Identities context menu in this new release are now suddenly printed italic like cos(x). It's not only inconsistent with the display of functions everywhere else within Maple, also every LaTeX user with very little knowledge of mathematical typesetting rules will frown at the sight of this.
I know it's not a big thing but Maple always stresses to produce pretty-print textbook style output. Powers of trigonometric functions like tan(theta)^2 as shown in the attached screenshot would however be printed like tan^2(theta) in textbooks just as when written by hand.
There are quite some examples where Maple uses significantly strange typesetting like total derivatives dx dy dz in the Physics package that are typeset as partial derivatives. I wonder why Maple introduced a partial-d but not also a total-d operator - doesn't that kind of hurt the eye even if the functionality is beyond critique? That's actually the only case that comes to my mind right now where even Mathematica's typesetting resembles mathematics in textbooks more closely and displays mathematical content more pleasantly than Maple does.
Good day. Please can someone kindly help to reduce the result of this code. Thank you and kind regards
s:=(sum(a[j]*x^j,j=0..3)+sum(a[j]*exp(-(j-3)*x),j=4..7)):
F:=diff(s,x):
p1:=simplify(eval(s,x=q))=y[n]:
p2:=simplify(eval(F,x=q))=f[n]:
p3:=simplify(eval(F,x=q+h/3))=f[n+1/3]:
p4:=simplify(eval(F,x=q+h))=f[n+1]:
p5:=simplify(eval(F,x=q+5*h/3))=f[n+5/3]:
p6:=simplify(eval(F,x=q+2*h))=f[n+2]:
p7:=simplify(eval(F,x=q+7*h/3))=f[n+7/3]:
p8:=simplify(eval(F,x=q+3*h))=f[n+3]:
vars:= seq(a[i],i=0..7):
Cc:=eval(<vars>, solve({p||(1..8)}, {vars})):
for i from 1 to 8 do
	a[i-1]:=Cc[i]:
Cf:=s:
L:=collect(simplify(simplify(expand(eval(Cf,x=q+3*h)),size)), [y[n],f[n],f[n+1/3],f[n+1],f[n+5/3],f[n+2],f[n+7/3],f[n+3]], factor):
length(L);
H := ee -> collect(numer(ee),[exp],h->simplify(simplify(h),size))/collect(denom(ee),[exp],h->simplify(simplify(h),size)):
M:=y[n+3]=(H@expand)(L);
length(M);
CurveFitting.mws
Splines and BSplines etc for curve fitting.
The attached short program uses with(CurveFitting) and BS:=BSpline(2,x);  outputs four expressions, the third being
2-x, x<2.  I'd like to be able to access this, and plot it. but plots[display](BS[3], x=1..2); comes up with an error message.
How do you can write equation with Maple 2015
into
please help me!
hi, i am trying to get a list of equations using the coeff function. I have the following equation:
Lambda:=-(1/8)*(D[4](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), x))-(1/8)*(D[6](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), y, x))-(1/8)*(D[7](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), x, t))-(1/8)*(D[5](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), x, x))-(1/8)*(D[12](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), x, t, t))-(1/8)*(D[10](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), x, x, t))-(1/8)*(D[11](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), y, x, t))-(1/8)*(D[9](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), y, x, x))+(1/8*(-3*(D[8](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))-4))*(diff(u(x, y, t), x, x, x))-(1/8)*(D[1](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))+(1/4)*(D[8](a))(x, y, t, u(x, y, t), diff(u(x, y, t), x), diff(u(x, y, t), y), diff(u(x, y, t), t), diff(u(x, y, t), x, x), diff(u(x, y, t), y, x), diff(u(x, y, t), x, t), diff(u(x, y, t), y, t), diff(u(x, y, t), t, t))*(diff(u(x, y, t), x, x, x));
Now I am trying to get the coefficients of the derivatives of u(x,y,t). So by hand I have done the calculation of taking the coeffient of diff(u(x,y,t),x,x,x) and setting this equal to zero, and then the coefficient of diff(u(x,y,t),x,x,t) and so on. However when I use the coeff function, it will only allow me to compute the coeff of diff(u(x,y,t),x,x,x) and others of third order. However it will not let me use the deriviateves of u of second and first order.
coeff(Lambda,diff(u(x,y,t),x));
this will not work but
coeff(Lambda,diff(u(x,y,t),x,x,x));
will work.
Any help would be great thanks.
If I have a fourier series as a function of x and t and summation goes from n=1 to eternity how can I get a new function, say F, with unapply so that F=F(x,t,n)?
So instead of plotting F from n=1 to eternity I want to plot e.g from n=1 to n=10
if known solution [a,b,c,d]
solve([eq2, eq3, eq4, ....], [a,b,c,d])
but not equal to known solution a,b,c,d even if number of equations more than number of variables.
then guess that there are some necessary and sufficient conditions unknown.
how to find the necessary and sufficient conditions from solutions?
is there options to set for this?
or can eliminate function help to find necessary and sufficient conditions and how to do?
I'm perplexed by the fact that this bug is not fixed in Maple 2018:
seq(alias(a[i] = RootOf(_Z1^6-3*_Z1^2-2*_Z1+11, index = i)), i = 1 .. 6);
ee := a[1]*a[5]+a[2]*a[6]+a[3]*a[4];
evala(ee); # wrong
     -320/449*a[1]-(16/449*(a[2]^2))*a[1]^4*a[3]-(16/449*(a[2]^3))*a[3]*a[1]^2-
     (56/449*(a[2]^2))*a[1]^3*a[3]-(16/449*(a[2]^2))*a[1]^5*a[3]+(32/449*a[2])*
     a[3]*a[1]^5-(60/449*(a[2]^2))*a[1]^2*a[3]-(256/449*a[2])*a[1]*a[3]+(64/449*
     a[2])*a[3]*a[1]^2+(128/449*(a[2]^2))*a[3]*a[1]-(32/449*(a[2]^3))*a[3]*a[1]^3-
     (16/449*(a[2]^3))*a[3]*a[1]^4-(24/449*a[2])*a[3]*a[1]^4+(256/449*a[1])*a[2]+
     (88/449*(a[1]^4))*a[2]-220/449*a[3]-680/449*a[2]-128/449*(a[1]^4)-(48/449*
     (a[2]^2))*a[1]^4-(32/449*(a[1]^5))*a[2]-(48/449*(a[2]^2))*a[1]^3+(128/449*
     a[2])*a[1]^3-(48/449*(a[2]^3))*a[1]^3+(256/449*(a[2]^3))*a[1]-(32/449*
     (a[2]^3))*a[1]^5-(88/449*(a[2]^3))*a[1]^2-(232/449*a[3])*a[2]+(66/449*
     (a[2]^2))*a[3]+(130/449*(a[1]^2))*a[3]+(24/449*(a[1]^5))*a[3]+(64/449*
     (a[1]^4))*a[3]+(228/449*(a[2]^3))*a[3]+(164/449*a[3])*a[1]^3-(192/449*
     a[3])*a[1]-(256/449*(a[2]^2))*a[1]-196/449*(a[1]^3)+40/449*(a[1]^5)+110/449*
     (a[2]^2)-324/449*(a[2]^3)-18/449*(a[1]^2)+1780/449+(40/449*(a[2]^2))*a[1]^2+
     (32/449*(a[2]^2))*a[1]^5
(along with quite a few bugs that are less critical but seem trivial to fix, like INTERVAL(1..2, 3..4) being displayed as INTERVAL(1..2)).
Are the issues reported on MaplePrimes not being looked into by anyone?
EDIT: And now the original post (the first link above) is gone, for which I don't have any reasonable explanation. Here is the post: i.imgur.com/9kIhPz5.jpg. Here is what I'm seeing now: i.imgur.com/yC4cqE3.jpg.
First 880 881 882 883 884 885 886 Last Page 882 of 2459
