How to linearize this equation by Taylor function?
sin(phi2)*sin(psi1(t))*lk*m1*(diff(psi1(t), t, t))+sin(phi2)*(diff(psi1(t), t))^2*cos(psi1(t))*lk*m1
or otherwise written:
Some one can help me?
If i do something like this:
my_points := [[1, 2], [2, .9]];
plot(my_points, style = point)
It works ok. But then i try to take units in place:
my_scaled_points := [[1*Unit('kg'), 2*Unit('hour')], [21*Unit('kg'), 7*Unit('hour')]];
plot(my_scaled_points, style = point, useunits = [Unit('kg'), Unit('hour')])
..i got empty graph. How it can be fixed?
Is it possible to construct in Maple the following sequence of ascending fifths?:
3/2, 3^2/2^3, 3^3/2^4, 3^4/2^6, 3^5/2^7, 3^6/2^9, 3^7/2^11, 3^8/2^12 and so on. The result always more than 1 and less than 2.
I'm quite new to Maple and as practise, I want to calculate some z-Transformations via the definition (sum).
sum(z^(-k),k=0..infinity) assuming abs(z)>1; this one works fine (after I added the convergence condition abs(z)>1.
sum(exp(a*k*Ta)*z^(-k),k=0..infinity) assuming abs(exp(a*Ta)*z^(-1))>1; doesn't work. But I if I change the convergence condition to a*Ta<ln(z), it is calculated correctly. Why does the first attempt not work? What is the correct way to tell maple the convergence condition?
Hi all
I would like to display 'Hello' or 'try again' to see the condition introduced is satisfied or not.
if f(a) <0 then print( a, f(a));
display ('  Hello);
display( ' Tru again')
But this code does not work.
Thanks for any help.
I solve an optimization problem ( minimization or maximization) using lagrangeMultiplier theorem
The objective function is f:=(x,y,z) =x*y+y*z;
The constraints are: x*y=1  and y^2+z^2=1;
Using a numerical method I get the follwing point
x = 1.41421356249703, y = .707106781124551, z = .707106781248575
How can I confirm that this point is a minumum or maximum
Maybe I must use Hessian matrix or something else.
Which condition must be introduced to know the type ( maximum or minumum) this point.
Many thanks for your help
I have a system of equation as
Hi all
I have a system of equation:
sys := [x+y, 2*x+y^2];
How can I convert the previous system to this function using maple
F:=(x,y)->(x+y,2*x^2+y^2);
then how can I compute the gradient of F.
Many thanks.
Hi there,
I have an ode that I want to plot, I am trying to plot 2 different graphs on one graph and have tried using display but cannot seem to add a legend to it. Someone suggested adding a legend to each individual graph before combining them but I cannot find out how to add a legend to a DEplot. My code is as follows:
ode:=diff(u(t),t$2)-0.1*(1-64*u(t)^2)*diff(u(t),t$1)+16*u(t)=0
Q1:=v/4*sin(4*t)+epsilon*(1/8*(v-v^3)*t*sin(4*t)+v^3/128*(cos(4*t)-cos(12*t)))
A:=DEplot(ode,u(t),t=0..10, [[u(0)=0, D(u)(0)=v]], u=-0.5..0.5, linecolor=black, linestyle=dash, title="Numerical Solution"):
B:=plot(Q1, t=0..10, u=-0.5..0.5,color=blue, legend="Regular Perturbation Expansion"):
display([A,B],title="Comparing the regular perturbation expansion to the numerical solution")
Many thanks
I would like to convert a symbolic expression to text commands.  I recently used the expression palette to create a series summation; however, I was confused whether the sigma represented Sum vs sum.  I attempted to convert to string, but MAPLE attempts to evaluate the symbolic series prior to outputting the text commands.  Unfortunately, the evaluation of the series is computationally expensive & MAPLE will run out of memory.  I do not need MAPLE to evaluate the series.  How can it simply spell out the text commands that represent the symbolic form without resorting to evaluating the expression?
restart; T := M*tau; w := N*tau; M := Kappa*N; Ck := -2*(T*(4*tau^2*k^2*Pi^2*(4*tau-w)-w*T^2)*exp(-(1/2)*w/tau)*sin(w*Pi*k/T)+2*Pi*k*tau*(4*tau^2*k^2*Pi^2*(2*tau-w)-T^2*(2*tau+w))*exp(-(1/2)*w/tau)*cos(w*Pi*k/T)+4*Pi*k*tau^2*(T^2-(2*Pi*k*tau)^2))/(T^2+(2*Pi*k*tau)^2)^2
-2*(Kappa*N*tau*(4*tau^2*k^2*Pi^2*(4*tau-N*tau)-N^3*tau^3*Kappa^2)*exp(-(1/2)*N)*sin(Pi*k/Kappa)+2*Pi*k*tau*(4*tau^2*k^2*Pi^2*(2*tau-N*tau)-Kappa^2*N^2*tau^2*(2*tau+N*tau))*exp(-(1/2)*N)*cos(Pi*k/Kappa)+4*Pi*k*tau^2*(Kappa^2*N^2*tau^2-4*Pi^2*k^2*tau^2))/(Kappa^2*N^2*tau^2+4*Pi^2*k^2*tau^2)^2
sum(Ck*sin(2*Pi*k*x/T), k = 1 .. m)
Download convert_to_text_command.mw
I need to find the intersection points of two circles (x-7)^2+(y-2)^2=100 and (x-11)^2+(y-5)^2=75 using the modified Newton secant method.
I have already done this by using these two equations to make one in terms of x. But, i am looking for suggestions on how to make a multiple variable version of the secant method.
Given a sequence for example: 8, 32,128,512,2048 and so on. Suppose we do not know it is 2^(2n +1). How to make Maple to find the principle?
Letter_Lrotate2D.mws
   I've asked a similar question before, and got the letters to rotate in 3D using the rotate command.  The resulting size in a 3D plot is relatively small..  The program gives a plotted letter L.  I wish to get some animation of it being rotated about the y-axis - but remaining in 2D.  ie looking at the letter it appears to be rotating.  To do thisI have multiplied the x-coords by the cosine of the angle of rotation.
   In the for loop towards the end of the program there is a variable c1 which is incremented by one in the loop - yet it remains at 2, regardless of the angle increments.   Why is that?
  Again, any help or comments much appreciated.
Download test.mw
Udp: document attached.
Q__gr := Typesetting[delayDotProduct](Vector[row](8, {(1) = 0, (2) = 5, (3) = 10, (4) = 15, (5) = 20, (6) = 25, (7) = 30, (8) = 35}), Unit('m'^3/'day'), true)
Vector[row](%id = 18446746861178193550)
`&eta;__gr` := Vector[row](8, {(1) = 0, (2) = 9.324, (3) = 17, (4) = 23.232, (5) = 27.192, (6) = 29.6, (7) = 29.516, (8) = 24.592})
Vector[row](%id = 18446746861214593262)
`points&eta;` := [seq([Q__gr[i], `&eta;__gr`[i]], i = 1 .. 8)]
[[0, 0], [5*Units:-Unit(m^3/d), 9.324], [10*Units:-Unit(m^3/d), 17], [15*Units:-Unit(m^3/d), 23.232], [20*Units:-Unit(m^3/d), 27.192], [25*Units:-Unit(m^3/d), 29.6], [30*Units:-Unit(m^3/d), 29.516], [35*Units:-Unit(m^3/d), 24.592]]
CurveFitting[PolynomialInterpolation](`points&eta;`, q)
0.2348698413e-7*q^7/Units:-Unit(m^3/d)^7-0.2980622223e-5*q^6/Units:-Unit(m^3/d)^6+0.1482222222e-3*q^5/Units:-Unit(m^3/d)^5-0.3663955556e-2*q^4/Units:-Unit(m^3/d)^4+0.4666528890e-1*q^3/Units:-Unit(m^3/d)^3-.3165382223*q^2/Units:-Unit(m^3/d)^2+2.655161905*q/Units:-Unit(m^3/d)
eta := proc (q) options operator, arrow; 0.2348698413e-7*q^7/Units:-Unit(m^3/d)^7-0.2980622223e-5*q^6/Units:-Unit(m^3/d)^6+0.1482222222e-3*q^5/Units:-Unit(m^3/d)^5-0.3663955556e-2*q^4/Units:-Unit(m^3/d)^4+0.4666528890e-1*q^3/Units:-Unit(m^3/d)^3-.3165382223*q^2/Units:-Unit(m^3/d)^2+2.655161905*q/Units:-Unit(m^3/d) end proc
eta(12*Unit('m'^3/'day'))
.8415811058*Units:-Unit(m^3/d)^7/Units:-Unit(m^3/d)^7-8.900090268*Units:-Unit(m^3/d)^6/Units:-Unit(m^3/d)^6+36.88243199*Units:-Unit(m^3/d)^5/Units:-Unit(m^3/d)^5-75.97578241*Units:-Unit(m^3/d)^4/Units:-Unit(m^3/d)^4+80.63761922*Units:-Unit(m^3/d)^3/Units:-Unit(m^3/d)^3-45.58150401*Units:-Unit(m^3/d)^2/Units:-Unit(m^3/d)^2+31.86194286*Units:-Unit(m^3/d)/Units:-Unit(m^3/d)
simplify(19.76619849)
Error, (in Units:-Standard:-+) the units `m^21/s^7` and `m^18/s^6` have incompatible dimensions
Download test.mw
I got a function (from CurveFitting), that produce a polynomial with the some units inside:
As i can see, it can be easy simplified, but i get:
Is where any trick to do it, without stripping units with convert(unit_free) or something?
Thank you!
Dear, I want to plot the graph for differerent values of F=10,20,30 one after the other  in the title automatic it should take the values of F and shown in the following sample here is my codes,  and sample graph
h:=z->1-(delta2/2)*(1 + cos(2*(Pi/L1)*(z - d1 - L1))):
K1:=((4/h(z)^4)-(sin(alpha)/F)-h(z)^2+Nb*h(z)^4):
lambda:=Int(K1,z=0..1):
L1:=0.2:
d1:=0.2:
alpha:=Pi/6:
plot( [seq(eval(lambda, Nb=j), j in [0.1,0.2,0.3])], delta2=0.02..0.1);
Letter_L_rotate.mws
The attached program is of the letter L rotating.  about an axis which is the outer side of the 'upright' of the L.  I want to give the illusion that the letter L is rotating about a y-axis, where the x, y axes are in the plane of the screen, with the x-axis going from left to right.  The program at present 'works', in the sense that the letter L is rotating about an axis.  ...but it's not quite what I want.  My eventual aim is to plot the letters A and L side by side, AL, and as the letter L rotates the leg of the L would bump into the A,  so I want the A to rise in sync with movement of the letter L.   ...but that's a long way off!  For the moment I just want to know how to orientate the letter L, so that it is in its usual L state
   I think I have two options: either to change the coordinate positions of L, (long and tedious..) or quicker might be to change the axis of rotation.  Any suggestions on making the animation smoother would also be appreciated.
Thanks, David
First 894 895 896 897 898 899 900 Last Page 896 of 2459
