I occasionally need single left quotes placed around the value of number.
Let's say x=3. Is there a command on x that will make x=`3`?
mapleatha
Let x = `3`. How do we get the number 3 out of x?
mapleatha
Here's something neat to be done in Maple.
This anaglyph or stereo image uses the red green glasses to make the model appear more 3 dimensional.  The static-non-stereo image of the animated plot below is done in maple by plot3d(sin(x*y)^2,x=-2..2,y=-2..2,scaling=constrained)
Anyone?
Why is this happening?
mapleatha
I have modeled a delta type parallel manipulator for performing CPR operation.
The model does 100 compressions per minute with a vertical displacement of 4-5 cm, which is the requirement of the CPR.
A rigid body is attached to the end effector and I need to model a human chest using a spring damper system.
The exists a spring-damper block in the 1D Mechanical translation category. I have previosly modeled a spring damper mechanical system using these blocks but I have never tried connecting these to a Multibody.
The spring and damper coefficients of a human chest are k=8350 N/m and c=500 Ns/m.
My model is here:
Can you help me model the human chest?
how to find infinitisimals of system of differential equations?
i have system of two dependent variables and two independent variables.
[-(diff(psi[2], x))+diff(psi[1], t, t)-2*n*(psi[1]^2+psi[2]^2)*psi[1]-beta*(diff(psi[1], x, t)) = 0,
diff(psi[1], x)+diff(psi[2], t, t)-2*n*(psi[1]^2+psi[2]^2)*psi[2]-beta*(diff(psi[2], x, t)) = 0]
Here is a possible situation tha appears very often in presentations:
How do I add a colon ":" after "ss3" in the second red line? And, while we are at it, how do I add the word "and" between ss2 and ss3?
Thank you all so much for your continuous and inexhaustible help!
mapleatha
Question:I've defined wave, but it's after that it gets sticky. This is my attempt:As you can see, not very fruitful. I have tried wave(x=-infinity..infinity, t=-infinity, infinity) which returns an error.
When i sub in wave(1,1) i get an answer, or any other number for that matter, but I'm not sure how to actually aswer this question.
Any and all help appreciated
Question: You will observe that the two curves intersect at one or more places in the displayed region. Use fsolve to find the (x; y) coordinates of all the points of intersection in this region.
In theory this question has a very simple answer, but i am struggling no end finding it.
P1 := y^2 = x^3+x^2
P2 := y = 2*x+1
This is what the graph looks like when plotted, and as we have already got the two equasions assigned as H and J, i just type in fsolve({P1,P2})?
Apparently not, as this returns {x = 4.048917340, y = 9.097834679}, which is correct, but is only one of three points of intersection, and just so happens to be the one not shown in my plot (although it is still a valid point of intersection) and i need the ones within the region i have set for the graph (x=-1..2 and y=-1..1).
How do i get maple to show me the two points of intersection i need using the fsolve command?
I've tried rearranging the equasions for y, rearranging for x, adding an option to solve for x [fsolve({P1,P2},x) but this returned an error] and am pretty stumped. For something so seemingly simple i dont really know where to turn.
Thank you :)
i have a matrix m[10,10] with some values, i want to PointPlot every rows with Explore command , here is my code:
Explore(PointPlot(m[a, 1 .. 10], [.1, .2, .3, .4, .5, .6, .7, .8, .9, 1]), parameters = [a = 1 .. 10])
but it does'nt work! how can i fix it?
thank you in advance
I have the following situation that I'm having trouble with . I am a total beginner in Maple, btw.
I have a long equation, involving a variable (x) , several other variables, and a function of x, F(x). A priory, this function is unspecified (its a probability density function, that may depend on whichever distribution it follows). I would like to have Maple operate on this function as if its a function of x, but without specifying. For example, lets say I have
x + yF(x)=0
I would like to derive it and have Maple return me
1 + yF'(x)=0
Is this possible?
restart; with(LinearAlgebra)
kernelopts(version); interface(version)
`Maple 2017.3, X86 64 WINDOWS, Sep 27 2017, Build ID 1265877`
`Standard Worksheet Interface, Maple 2017.3, Windows 10, September 27 2017 Build ID 1265877`
The following equation contains so many regularities, that it is tantalizing to find a compact matrix formulation.
I found a matrix expression, but it seems unnecessairy complex. Is there a Maple procedure that can help me to find a more concise matrix formulation?
eq1 := i2*i3*i4*(i2+i3+i4)+i1*i3*i4*(i1+i3+i4)+i1*i2*i4*(i1+i2+i4)+i1*i2*i3*(i1+i2+i3)
expand(eq1)
i1^2*i2*i3+i1^2*i2*i4+i1^2*i3*i4+i1*i2^2*i3+i1*i2^2*i4+i1*i2*i3^2+i1*i2*i4^2+i1*i3^2*i4+i1*i3*i4^2+i2^2*i3*i4+i2*i3^2*i4+i2*i3*i4^2
V := Matrix(4, 1, [i1, i2, i3, i4])
Matrix(%id = 18446745919887783806)
one := Matrix(4, 1, 1)
Matrix(%id = 18446745919887784886)
This matrix expression works, but seems overly complex. Using Maple, is there a way to simplify it?
Trace(MatrixScalarMultiply(one^%T.(V.one^%T-DiagonalMatrix(Diagonal(V.one^%T))).convert(Diagonal(Adjoint(V.one^%T-DiagonalMatrix(Diagonal(V.one^%T)))), Matrix), 1/2))-eq1
Alternatively, but also not very simple:
Trace(DiagonalMatrix(Diagonal(MatrixScalarMultiply(1/(V.one^%T-DiagonalMatrix(Diagonal(V.one^%T))), (1/2)*Determinant(V.one^%T-DiagonalMatrix(Diagonal(V.one^%T)))))).(KroneckerProduct(V^%T.one, IdentityMatrix(4))-DiagonalMatrix(V)))-eq1
Obviously, this does not help:
A, B := LinearAlgebra:-GenerateMatrix([eq1], [x])
Matrix(%id = 18446745919887762006), Vector[column](%id = 18446745919887761886)
Download Matrix_formulation.mw
When i input: i get returned.and with this i have no idea what im supposed to do. I dont understand what it means, how to correct it or how to actually answer the question using the information.
This is what i am returned with when i try to input a sequence using my previous result.
Could someone please put me on the right tracks and help me with this problem?
I'm new to maple and have a problem when using the dsolve in a for loop. I get the error message Error, (in dsolve/numeric/process_input) the independent variable (t in phi(t)) cannot be a procedure name and I dont now why.
The code design is
for k to kk do
vars := x(t), y(t), phi(t);
ic := x(0) = xx, y(0) = yy, phi(0) = zz;
sys := diff(x(t), t) = y(t),
diff(y(t), t) = -2*gamma*y(t)-alpha*x(t)-beta*x(t)^3+F*cos(phi(t)),
diff(phi(t), t) = 1;
sol := dsolve({ic, sys}, {vars}, numeric, output = listprocedure, numeric = -1);
assign(sol);
x := x(t);
y := y(t);
phi := phi(t);
numpts := 50;
pts := seq([x(2*Pi*i), y(2*Pi*i)], i = 1 .. numpts);
plt(k) := plot([pts], view = [-1.5 .. 1.5, -.5 .. 1], color = black);
xx := 'xx'; yy := 'yy'; zz := 'zz';
xx := x(2*Pi*numpts);
yy := y(2*Pi*numpts);
zz := phi(2*Pi*numpts);
unassign(x, y, phi);
end do
Let's say you have a m times n matrix and you want to ask Maple to computes all of its p minors (p smaller than minimum of m and n). Is there any prepared command for it at Maple? I can write a procedure myself, I just want to know if there is a command in Maple or not. The minor command in LinearAlgebra package is just computing determinant of a square matrix after removing a given row and a given column which is not what I'm talking about.
First 940 941 942 943 944 945 946 Last Page 942 of 2463
