ii := evalr(csch(INTERVAL(-infinity .. -1, 1 .. infinity)));
             INTERVAL(-csch(1) .. 0, csch(1) .. 0)
evalr(ii-ii);
                            -csch(1)
(Make sure you don't have the Typesetting level set to Extended, or ii won't be displayed correctly.)
There are no functions to test for interval membership (or to compute intersections/unions of intervals), so it's unclear how Maple treats the interval csch(1)..0, but apparently evalr is getting tripped up by it.
Also:
evalr(sech(INTERVAL(-infinity .. -1, 1 .. infinity)));
evalr(arccsch(INTERVAL(-infinity .. -1, 1 .. infinity)));
Error, (in evalr/arccsch) too many levels of recursion
For example, let's say we have the following function
Now if we want to calculate the value of a function we have to
subs([x1=10,x2=20],eval(hf));
My question is the following: How to substitute values for x1 and x2 using values from vector? something like that
x:=[10,20];
subs([x],eval(hf));
Best,
Rariusz
I solve a partial differential equation using the THETA METHOD on Maple17, but what is also of essence is the skin friction and Nusselt Number which are {diff(u(x, t), x)} at x = 0 and {diff(T(x, t), x)} at x = 0 respectively. How can I achieve the two using the THETA METHOD? This is the PDE in it full flesh.
 PDE := {diff(phi(x, t), t) = (diff(phi(x, t), x, x))/S__c, diff(u(x, t), t) = diff(u(x, t), x, x)-M^2*(u(x, t)+m*w(x, t))/(m^2+1)-u(x, t)/`ϰ`-2*Omega^2*w(x, t), diff(w(x, t), t) = diff(w(x, t), x, x)+M^2*(m*u(x, t)-w(x, t))/(m^2+1)-w(x, t)/`ϰ`+2*Omega^2*u(x, t), diff(theta(x, t), t) = lambda*(diff(theta(x, t), x, x))/P__r+D__r*(diff(phi(x, t), x, x))}
With conditions: BC := {phi(0, t) = 1, phi(12, t) = 0, phi(x, 0) = 0, u(0, t) = t, u(12, t) = 0, u(x, 0) = 0, w(0, t) = 0, w(12, t) = 0, w(x, 0) = 0, theta(0, t) = 1, theta(12, t) = 0, theta(x, 0) = 0}
Where the parameter like P_r, S_c  e.t.c are constants to assign value to.
I want to plot the compex solutions of a single equation. I do
> plot([fsolve(x^3 = 1, complex)])
The output consists of a warning:
"Warning, unable to evaluate 2 of the 3 functions to numeric values in the region; complex values were detected"
and a horizontal line.
What am I doing wrong?
The linked worksheet displays the geodesic between two points on a surface z(x,y).
Surfacepath.mw
Gradient descent will find a stepped approximate path of fastest descent between the points, but is there a way to find a function defining an exact i.e. smooth path of fastest descent? If so, how can a precise time of fastest descent be determined?
Namely, I mean
solve({y >= 4*x^4+4*x^2*y+1/2, sqrt((1/2)*(x-y)^2-(x-y)^4) = -2*x^2+y^2}, [x, y]);
The answer (no solution) is not correct in view of
eval({y >= 4*x^4+4*x^2*y+1/2, sqrt((1/2)*(x-y)^2-(x-y)^4) = -2*x^2+y^2}, [x = 0, y = 1/2]);
      {(1/8)*sqrt(4) = 1/4, 1/2 <= 1/2}
eval({y >= 4*x^4+4*x^2*y+1/2, sqrt((1/2)*(x-y)^2-(x-y)^4) = -2*x^2+y^2}, [x = -1, y = -3/2]);
      {(1/8)*sqrt(4) = 1/4, -3/2 <= -3/2}
Hi all, I want to ask how to use for loop reverse in Maple.
Example, i have array . In Java then
for(int i = arr.size(); i > 0; i--) {
    //do something
What is simillar for loop in Maple?
Thank you very much.
Hi, when I wan to generate results, it shows this; What should I do?
Error, (in solve) a constant is invalid as a variable, I.
I have a system of equations that can't be solved analytically, but can be solved using fsolve. I would like to plot the solution for one of the unknowns as a function of a parameter "DV" that is in a few of the equations. There are two issues at hand. First, even if I give DV a numerical value, the solutions are of the form { x = 0.23, y = 4.56 }, a form that plot( ) obviously can't handle directly. Generally I have dealt with this by using the op( ) command to pick out the solution I want; is there a better way?
But even after I have the solution I want, fsolve( ) won't work until I give it a value for DV. Thus a plot( ) command like
   plot(op(2, op(2, fsolve({e1, e2}, {x, y})), DV = -1 .. 1)
fails with an "Error, (in fsolve) DV is in the equation, and is not solved for" error.
There's got to be an esy way to do this!
Here Maple treats the intervals as independent, as I think it should:
INTERVAL(1 .. 2)+INTERVAL(1 .. 2);
              INTERVAL(1 .. 2) + INTERVAL(1 .. 2)
INTERVAL(1 .. 2)-INTERVAL(1 .. 2);
              INTERVAL(1 .. 2) - INTERVAL(1 .. 2)
(even though for the first one an autosimplification to 2*INTERVAL(1..2) wouldn't matter). But as soon as there are non-linear terms, Maple ignores that rule:
INTERVAL(1 .. 2)^2-INTERVAL(1 .. 2)^2;
INTERVAL(1 .. 2)/INTERVAL(1 .. 2);
INTERVAL(-1 .. 1)*INTERVAL(-1 .. 1);
                       INTERVAL(-1 .. 1)
That means I cannot substitute intervals for variables in a formula. In fact, I don't know how INTERVAL(-1 .. 1)*INTERVAL(-1 .. 1) can be computed as a product of two independent intervals at all, there doesn't seem to be any way to pass it to evalr.
This is a problem encountered in most engineering equations. An equation is given with some variables very small that they can be ignored. Basically the mathematical equivalent of an engineering approximation.
Below is a very simple example:
Both R and r are between 10E3 and 50E3.
gm is between 1 and 10.
So regardless of actual values the answer to 4significant figures can always be approximated by:
eqn1~ R*gm*r
Is there any way to tell MAPLE to approximate an equation such that it is only accurate to certain decimal places? I have tried using "fnormal()" with "assuming"  statements but it always requires some of the variables be assigned actual numeric values.
I was wondering if there was a way to get this approximation without having to assign values to any of the variables but only by specifying the range of values for each variable.
How can ı write 3d^2+f^2-4e^2+2td^2-4te^2+2tf^2+3f^2+4td^2+....... as  (.......)d^2 +(......)e^2+ (.......)f^2
so
3d^2+f^2-4e^2+2td^2-4te^2+2tf^2+3f^2+4td^2+....... = (.......)d^2 +(......)e^2+ (.......)f^2  ??????
hi
i have an Integral equation like below
now i want to use Parts That u=op(1,A), but when I use Parts it dont work properly, actually i want to get
but when i use
A := Expand(Parts(Int(A, x), op(1, A)))
maple solve it like bellow
i know that i can separate these terms One by one, but there are many functions like this in my code , so i want to know if there is any way to solve this function.
thank you.
I am quite new to maple.
I have uploaded two printscreens of two similar procedures. The only difference is that in prosedure nr. 2 the number "a"(rate of change given in the exercise), is supposed to variate in term of k.
I assume that i have to define an if-sentence that will tell the procedure to use a=0.15 when, n=0, and a1:=a(1-(k/Km)) when n>0.  Can someone please help me with solving this?
Regards Paul
I am now working on differential equations like the following, and wonder how I can deal with diff(C(x,t),x).  In particular, I would like to know the values of diff(C(x,t),x) at specific sets of (x, t).  I also would like to know how to integrate diff(C(x,t),x) for a time period (at x = 0.5L or x = L).
C0 := 10;
K  := 3.0e6;
d  := 5.0E-14;
hm := 5.0E-4;
L  := 0.001;
DE1 := diff(C(x, t), t) = d*diff(C(x,t), x, x);
IC := C(x, 0) = piecewise(x < 0, 0, 0 <=x <= L, C0, L < x, 0);
BC1 := D[1](C)(0, t) = 0;
BC2 := -d*D[1](C)(L, t) = hm * C(L, t) / K;
pds:=pdsolve(DE1, {IC, BC1, BC2}, type=numeric, spacestep=L/10000, timestep=10000);
T := 60*60*24*100;
pds:-plot(t=T, x=0..L);
#I tried the following, but these seem to always return zero (while the plot suggests some negative value of diff(C(x, t), x));
v1 := pds:-value(diff(C(x, t), x));
v1(L, T);
v2 := pds:-value(int(diff(C(x, t), x), t = 0 .. T));
v2(L, 0);
First 959 960 961 962 963 964 965 Last Page 961 of 2463
