I am trying to put labels for my axis and I use typeset to do that.
The code is:
plot(10^10*x, x = 0 .. 5,labels = ["x", typeset(10^10*Delta*z)],labeldirections = ["horizontal", "vertical"])
The problem is that  I get a label like below:
I mean it is not typed as 10^{10}, but 10000000000!!!
Can anyone help me in changing this to 10^10?
Given a basic list of data, is it possible to extract the distribution type /  equation / probability density function?
When I resave a worksheet that is already saved on the computer desktop, it changes the position of the icon on the desktop: it is moved to the most left-upper column-row possible. Why that? Can anyone else reproduce that odd behaviour?
A worksheet can be closed using the Windows standard shortcut Ctrl-F4. But the Maple program itself cannot be closed using the Windows standard standard shortcut Alt-F4. Why that? Can anyone else reproduce that odd behaviour?
PS: I am using Maple 2017.1
I am trying to figure out how to simplify expressions like:
2^(6p+q) mod 3 (where p,q are variables representing integers)
Anybody know how to do this?
Even better would be something that solves 2^n=2 (mod 3) -> n=1 (mod 6)
Suggestions?
After using maple as a learning aid to compliment my Calculus 2 course for the past 2 months, I really have mixed emotions...
I realize Maple is capabale of much, much more than the simple integration problems I throw at it and as such, will hopefully see much more use in my pursuit of a Biochem degree.  But I keep getting disturbing results which make me question its accuracy...
For example, before I use the integration tutor, I use maple to test my steps as I work the problem on paper, making sure I am applying the correct substitutions as I work through the integration.  If I am not applying an operation or simplification properly, the test relation operation returns false, allowing me to correct the issue at that time.  If I still can't figure out why Maple is returning false, I'll resort to the integration tutor.   Yet, Maple routinely contridicts itself, using the same solution steps which it returned as false when tested in the worksheet?!?!
As a clear illustration:
contradiction.pdf
Am I misunderstanding the proper use of the Test Relation function?  Any answers would be greatly appreciated.
I dont understand why im getting this error at all.
Error, `]` unexpected
Download ERROR_troubles.mw
I was wondering if it were possible to call only the mapping function used to grahically display using a particular plot command in general, but aside from that, this is the one in specific id really like, naturally, since thats a bit of a hole in the understanding of what you are looking at thats probably important in some way to something.
I use Maple & MapleSim 2016. I linked my MapleSim model to Maple worksheet and ran it in the Maple.
After that, I wanted to make the compiled one by using "GetCompiledProc" command in Maple.
I know that this command helps making compiled model with some user-specified parameters.
However, if I try to compile my MapleSim Model, error message appears and process stops.
Error message: (In GetCompiledProc) numeric exception: division by zero
Is there anyone how to avoid this error? I cannot find any solution for my problem.
For the security problem, I cannot upload my MapleSim model.
I appreciate any idea or tip you may have.
Let A and B be regions in space defined through f(x,y,z) > 0 and g(x,y,z) > 0, respectively.  How does one plot the surface of the object A ∩ B in Maple?
In Mathematica there is a command RegionPlot3D for that.  See sample here.  Perhaps there is an equivalent one in Maple that I don't know of.
This might be considered nit-picking, but nonetheless I think there is an issue: The metric tensor and its inverse are types (0,2) and (2,0) tensors, respectively. When once contracted with each other, the result is the Kronecker delta, which is then (necessarily) a tensor of type (1,1). I am therefore surprised to find that in Maple, this Kronecker delta is implemented as a type (0,2) tensor, via the command KroneckerDelta:
KroneckerDelta[mu,nu];
I don't think this makes any proper sense. I think that such an object of type (0,2) is, in fact, the metric itself. On a similar note, the (mixed tensor type) objects g_[mu,~nu] and g_[~mu,nu] are actually both Kronecker deltas, because they correspond to the metric having one index raised by contraction with the inverse metric itself. But, nonetheless, the following is the case:
g_[ mu,~nu],
g_[~mu, nu];
Relatedly, consider the following single contraction of the metric with its own inverse:
SumOverRepeatedIndices(g_[mu,nu]*g_[~nu,~sigma]);
Although this sum is formally quite correct, I think it should be given as just a Kronecker delta (of the correct mixed tensor type, that is).
How can I ask Maple to plot intersection of two implicitplot3d? It is explained how to draw the union in the Maple help by simply entering a list to combine plots, but I didn't see anything about intersection.
I probably worked too hard, but this result seems strange to me:
In a second example (not shown here, but in atttached file) all goes well. It is probably very simple, but at this moment I better go for a walk outside.
best regards,
Harry Garst
mapleprimes.mw
Sorry yes as the title suggests, id like to know how to execute keyboard and mouse pad actions in an automata of sorts.
I have a procedure that uses substitute. Below is my code
my_proc:=proc(func::`+`)
    ... #some calculatin
    subs([x[1] = 2, x[2] = 1], func);
func:=5 + x[1]*x[2] + 10*x[1];
my_proc(func);
But when I call the procedure, her body is no substitution. What is the error? I can't understand what I did wrong?
In the help page for invlaplace we find the statement
"If the option opt is set to 'NO_INT', then the program will not resort to integration of the original problem if all other methods fail.  This will increase the speed at which the transform will run."
This statement is found in Maple 2017 and in Maple 8 and I believe in all versions in between.
Can anyone provide an example of a function F(s), where
invlaplace( F(s) ,s, t, NO_INT);
gives a different result (or works faster) than
invlaplace( F(s) ,s, t);
## It should be added that an identical statement is made in the help page for laplace itself.
First 983 984 985 986 987 988 989 Last Page 985 of 2463
