Hi everybody,
My worksheet begins with these two instructions (this is a notional example)
Digits := 25:
interface(displayprecision = 5):
Then the instruction  evalf(1/3+x/6)  returns  0.33333+0.16667x … which is what I had expected.
I now  want to do a formatted print of  evalf(1/3+x/6)  in some file.
Unfortunately the command
 fprintf(fd, "%a\n", evalf(1/3+x/6))
generates a print with the full digits precision (0.333…..33 with 25 "3" for instance).
How could I force fprintf to print the floating point numbers with the number of digits set by interface(displayprecision = 5) ?
(PS : for now I have written some kind of “white elephant” stuff which works well only for very simple algebraic expressions)
Any suggestion or answer will be greatly appreciated
Hello everyone, why is maple not able to solve this easy system of equations?
eq1 := 1 = abs(1/(I*Pi*z*(1+I*Pi*a)));
eq2 := -(5/9)*Pi = argument(1/(I*Pi*z*(1+I*Pi*a)));
`assuming`([fsolve({eq1, eq2}, {a, z})], [a::real, z::real]);
 Thanks for helping me! Fabian
Given
Tour2:=[[[1, 2, 3, 4]], [[1, 2], [1, 3, 4]], [[1, 3], [1, 2, 4]], [[1, 4], [1, 2, 3]], [[1, 2], [1, 3], [1, 4]]]:
Kitonums code
seq(max(seq(add(d[s[i]]*x[s[i],s[i+1]], i=1..nops(s)-1) , s=t))<=K, t=Tour2); produces
18*x[1, 2]+26*x[2, 3]+11*x[3, 4] <= K, max(18*x[1, 2], 26*x[1, 3]+11*x[3, 4]) <= K, max(26*x[1, 3], 18*x[1, 2]+11*x[2, 4]) <= K, max(11*x[1, 4], 18*x[1, 2]+26*x[2, 3]) <= K, max(18*x[1, 2], 26*x[1, 3], 11*x[1, 4]) <= K
correctly. The problem is I want to pass this through LPSolve and it doesn't like it. So what I need is to convert it to a constraint it will accept. I found a method on stackexchange,
http://stackoverflow.com/questions/10792139/using-min-max-within-an-integer-linear-program
i'm not sure it even works.i would be great if a procedure could could convert the max's in the above expression, or change the code in bold.
max(6*x[1, 4],4*x[1, 2]+3*x[2, 3]), where x[i,j] are binary vars.
x4 >= 6*x[1, 4];
x4 >= 4*x[1, 2]+3*x[2, 3];
Objective:= x4;
how to count the number of decimal places if input a decimal number
Error, (in unapply) variables must be unique and of type name
The command
fd:=fopen("C:/temp/",'WRITE');
suddenly does not work. I keep getting a 'permission denied' error message. I haven't had to write anything to a file for a while so do you think the recent windows update screwed something up? In fact, I can't seem to write any file anywhere. It was working weeks ago. My apology if this ends up being a lame question. :)
Hi , I have question about poincare's theorem which needs to change the veriable and that transform the coordinates , but when I change the variable from x to y if doesn't defined any suggestion ? Please
How do I assume variables as  Matrixs for calculation?
Please help me to solve this problem :
assume(M11::Matrix);
assume(M12::Matrix);
assume(M21::Matrix);
assume(M22::Matrix);
assume(A::Matrix);
A := M12*M21+M11;
                         M12 M21 + M11
solve(A = 0, M12);
Warning, solve may be ignoring assumptions on the input variables.
                               M11
                               M21
solve(A = 0, M12, useassumptions = true);
                               M11
                               M21
How can I get solution being a matrix?
Thank you very much !!!
Each day
a:=a+5% of a -(0.1% of a+b)-10
b:=b+5%of b -(0.1% of a+b)-10
In how many days i have a+b=0?
Sirs.
Probably a brain fade, but I cant seem to code what i want.
constraints.mw
Tour2:=[[[1, 2, 3, 4]], [[1, 2], [1, 3, 4]], [[1, 3], [1, 2, 4]], [[1, 4], [1, 2, 3]], [[1, 2], [1, 3], [1, 4]]];M:=nops(Tour2):
interface(rtablesize=M):
  maxEnt:=max([seq(nops(Tour2[i]),i=1..M)]):
  Tours_Distances := Matrix
                     ( maxEnt,
                       M,
                       [ seq
                         ( [ seq
                             ( `if`( numelems(Tour2[i])>=j,
                                     d[i]*x[op(Tour2[i,j])]<=K,
                               i=1..M
                           j=1..maxEnt
Tours_Distances := Matrix(3, 5, {(1, 1) = d[1]*x[1, 2, 3, 4] <= K, (1, 2) = d[2]*x[1, 2] <= K, (1, 3) = d[3]*x[1, 3] <= K, (1, 4) = d[4]*x[1, 4] <= K, (1, 5) = d[5]*x[1, 2] <= K, (2, 1) = 0, (2, 2) = d[2]*x[1, 3, 4] <= K, (2, 3) = d[3]*x[1, 2, 4] <= K, (2, 4) = d[4]*x[1, 2, 3] <= K, (2, 5) = d[5]*x[1, 3] <= K, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (3, 5) = d[5]*x[1, 4] <= K})
convert( (2), 'list', 'nested' );
[[d[1]*x[1, 2, 3, 4] <= K, d[2]*x[1, 2] <= K, d[3]*x[1, 3] <= K, d[4]*x[1, 4] <= K, d[5]*x[1, 2] <= K], [0, d[2]*x[1, 3, 4] <= K, d[3]*x[1, 2, 4] <= K, d[4]*x[1, 2, 3] <= K, d[5]*x[1, 3] <= K], [0, 0, 0, 0, d[5]*x[1, 4] <= K]]
But what I want is:
d[1]*x[1,2]+d[2]*x[2,3]+d[3]*x[3,4]<=K,d[1]*x[1,2]<=K,d[1]*x[1,3]+d[3]*x[3,4]<=K;      #.....etc.
d[1]*x[1, 2]+d[2]*x[2, 3]+d[3]*x[3, 4] <= K, d[1]*x[1, 2] <= K, d[1]*x[1, 3]+d[3]*x[3, 4] <= K
Download constraints.mw
Hello guys,
I´ve a little bit problem by plotting an pyramid with an triangle in it. When I want to display both
parts, in the drawing the left and the right part and the top of the pyramid is missing. What is the problem ???
Abituraufgabe_2016_B2_Pyramide.mw
I wish to express the Maxwell equations in potential fields deriving from a Lagrangian in cartesian coordinates, but expressed in vectorial form; But I am receiving an message error that I do not understand.
Field_A-MaplePrimes.mw
Initial Definitions:
I wish in this work to express the Maxwell equations deriving from the Lagrangian in the fields phiand "A,"
phi
(1.1)
restart; clear; with(Physics); with(Physics[Vectors]); with(Library)interface(imaginaryunit = I)
clear
I
(1.2)
Physics:-Coordinates(X = [t, x, y, z])
`Detected \`t\`, the time variable, in position 1. Changing the signature of the spacetime metric accordingly, to: + - - - `
`Default differentiation variables for d_, D_ and dAlembertian are: `*{X = (t, x, y, z)}
`Systems of spacetime Coordinates are: `*{X = (t, x, y, z)}
{X}
(1.3)
Physics:-Vectors:-Setup(math = true, Physics:-Vectors:-diff = X)
`* Partial match of  'math' against keyword 'mathematicalnotation'`
`* Partial match of  'Physics:-Vectors:-diff' against keyword 'differentiationvariables'`
[differentiationvariables = [X], mathematicalnotation = true]
(1.4)
Some definitions
Defining the Maxwell tensor
Physics:-Define(F):``
`Defined objects with tensor properties`
(2.1)
Defining the field A with their components:
A[mu] = Vector(4, [phi(X), A__1(X), A__2(X), A__3(X)]); Define(%)
A[mu] = Vector[column](%id = 18446744074366759750)
{F, A[mu], Physics:-Dgamma[mu], Physics:-Psigma[mu], Physics:-d_[mu], Physics:-g_[mu, nu], Physics:-KroneckerDelta[mu, nu], Physics:-LeviCivita[alpha, beta, mu, nu], Physics:-SpaceTimeVector[mu](X)}
(2.2)
Physics:-CompactDisplay(phi(X), A__1(X), A__2(X), A__3(X))
phi(t, x, y, z)*`will now be displayed as`*phi
A__1(t, x, y, z)*`will now be displayed as`*A__1
A__2(t, x, y, z)*`will now be displayed as`*A__2
A__3(t, x, y, z)*`will now be displayed as`*A__3
(2.3)
Applying:
F[alpha, beta] := Physics:-Vectors:-`+`(Physics:-d_[beta](A[alpha]), -Physics:-d_[alpha](A[beta]));
Physics:-d_[beta](A[alpha], [X])-Physics:-d_[alpha](A[beta], [X])
(3.1)
Term 1:
eq1 := Physics:-d_[alpha](F[alpha, beta])
Physics:-d_[alpha](Physics:-d_[beta](A[`~alpha`], [X]), [X])-Physics:-dAlembertian(A[beta], [X])
(4.1)
Physics:-SumOverRepeatedIndices(Physics:-d_[alpha](Physics:-d_[beta](A[`~alpha`], [X]), [X])-Physics:-dAlembertian(A[beta], [X]))
Physics:-d_[beta](diff(phi(X), t), [X])-Physics:-d_[beta](diff(A__1(X), x), [X])-Physics:-d_[beta](diff(A__2(X), y), [X])-Physics:-d_[beta](diff(A__3(X), z), [X])-Physics:-dAlembertian(A[beta], [X])
(4.2)
Physics:-SubstituteTensorIndices(beta = 4, Physics:-d_[beta](diff(phi(X), t), [X])-Physics:-d_[beta](diff(A__1(X), x), [X])-Physics:-d_[beta](diff(A__2(X), y), [X])-Physics:-d_[beta](diff(A__3(X), z), [X])-Physics:-dAlembertian(A[beta], [X]))
diff(diff(phi(X), t), z)-(diff(diff(A__1(X), x), z))-(diff(diff(A__2(X), y), z))-(diff(diff(A__3(X), z), z))-Physics:-dAlembertian(A__3(X), [X])
(4.3)
Physics:-SubstituteTensorIndices(beta = 1, Physics:-d_[beta](diff(phi(X), t), [X])-Physics:-d_[beta](diff(A__1(X), x), [X])-Physics:-d_[beta](diff(A__2(X), y), [X])-Physics:-d_[beta](diff(A__3(X), z), [X])-Physics:-dAlembertian(A[beta], [X]))
diff(diff(phi(X), t), t)-(diff(diff(A__1(X), t), x))-(diff(diff(A__2(X), t), y))-(diff(diff(A__3(X), t), z))-Physics:-dAlembertian(phi(X), [X])
(4.4)
SubstituteTensorIndices(beta = 2, Physics[d_][beta](diff(phi(X), t), [X])-Physics[d_][beta](diff(A__1(X), x), [X])-Physics[d_][beta](diff(A__2(X), y), [X])-Physics[d_][beta](diff(A__3(X), z), [X])-Physics[dAlembertian](A[beta], [X]))
Error, (in dchange/info) the number of new and old independent variables must be the same. Found {x, y} as new, while {} as old
SubstituteTensorIndices(beta = 3, Physics[d_][beta](diff(phi(X), t), [X])-Physics[d_][beta](diff(A__1(X), x), [X])-Physics[d_][beta](diff(A__2(X), y), [X])-Physics[d_][beta](diff(A__3(X), z), [X])-Physics[dAlembertian](A[beta], [X]))
(4.5)
What is the origin of the two error messages above? I did some wrong definition? Why this works in t and z but not in x and y?
Download Field_A-MaplePrimes.mw
I want to maximize a total profit (TP) function which is dependent on five independent variables (E,W,T, theta, tp). All these five variables can have non negative values. The TP function is given below- ( first TP is directly copied from maple worksheet and than copied again as a picture for clear viewing).
 TP = (p1*(Q-q)+p1*(1-theta)*(q-E)+s*E-c*Q-o-h*((1/6)*alpha*W^beta*a*p1^(-b)*tp^3/m-(1/2)*alpha*W^beta*a*p1^(-b)*tp^2+Q*tp)-(t1-tp)*h*((1/2*(-(2/3)*t1+m-(1/3)*tp))*W^beta*a*alpha*(t1-tp)*(-p1*(-1+theta))^(-b)+W*m)/m-(1/2)*h*(W+E)*(T-t1))/T-u*W
I am trying the maximize TP with respect to above five independent variables. I tried to solve  five equations ( representing first order partial derivative of TP with respect to each of the independent variables equated to zero) simultaneously by "solve" and "fsolve" command but both these commands fail to give any output. I have also tried three other commands in optimization package ( QPSolve, NLPSolve, Maximize) but all these three commands also doesn't give any output. I want to prove the concavity of TP function with respect to five independent variables, please guide how it can be done. ( I have computed the Hessian matrix but since five first order equations doesn't give output ( through fsolve command) so I am unable to compute Hessian at these first order optimiality condition solution.). The values of the paramters in the TP equation are -
[alpha = 50, beta = .7, c = 20, h = 4, m = .4, o = 10, p1 = 40, s = 10, u = 5, a = 15000, b = 2]
Dear sir,
I tried to solve a fourth order problem. But I got the error message as better to use midpoint method. Can I know what is midpoint method and here I uploading the problem please verify it if I did anything mistake?program.mw
with(plots); with(DEtools);
`&epsilon;` := .1;
de1 := x[0](t)+`&epsilon;`*x[1](t);
ode2 := sin(t)-`&epsilon;`*t*sin(t);
MODEL := {ode1, ode2};
VARS := {x(t), y(t)};
DOMAIN := t = 0 .. 20;
RANGE := x = -3 .. 3, y = -3 .. 3; COLORS := [BLACK, BLUE];
IC1 := [x[0](0) = 0, x[1](0) = 0]; IC2 := [(D(x[0]))(0) = 1, (D(x[1]))(0) = 0];
DEplot(MODEL, VARS, DOMAIN, RANGE, [IC1, IC2], stepsize = .1, arrows = THIN, linecolor = COLORS);
Error, (in DEtools/DEplot/CheckInitial) the 'number' option must be specified before initial conditions
First 1012 1013 1014 1015 1016 1017 1018 Last Page 1014 of 2459
