Knowing that log[12](27) = a. How can I find log[36](24) in term a in Maple?
I need yours hepl.  I work with the physics paсkage and I set:
with(Physics)
 Coordinates(X)
Setup(Dgammarepresentation = standard)
Setup(spaceindices = uppercaselatin)
Define(m, m5, y, p, mm, pp)
I try to square the next value:
W := Dgamma[mu]*d_[mu]+M+Psigma[A]*aa[A]-mm*Dgamma[0]-m5*Dgamma[0]*Dgamma[5]+I*Dgamma[5]*Psigma[B]*pp[B]+I*Dgamma[5]*y
("*" is multiplication)
W*W
And after that I want to simplify it:
Simplify(W*W)
I guess that matter is owing to d_[`~mu`]. If I remove this term:
E:=Psigma[A]*aa[A]-mm*Dgamma[0]-m5*Dgamma[0]*Dgamma[5]+I*Dgamma[5]*Psigma[B]*pp[B]+I*Dgamma[5]*y
And if i do:
E*E
Then next error emerges:
What is it?
here is my homework, i am new to maple and need some help!
Consider the logistic equation:
dP/dt = 3/100 * (P(M - P)),
with seasonally varying population constraint
M(t) = 20 + 1.54sin(pi t / 6)
use maple to plot the solution curve for P(0) = 25
Given 3 surfaces:
x^2+y^2=1,z=0(the xy base plane) and z=1-x^2
To plot these I suggested to use cylindrical coordiates knowing x=r*cos(t) and y=r*sin(t)
Which leads to z=1-r^2*cos^2(t)
However i got problems knowing how to plot this object and dearly ask for help.
plothelp.mw
I am an error with the use of the function "Analytic" of the packpage RootFinding. These are the procedures:
CreaCos := proc (C, n, m, t) local k, F; F := C[1][1]+(C[1][2]-C[1][1])*t; for k to n-1 do F := F, C[k+1][1]+((1/2)*C[k+1][2]-(1/2)*C[k+1][1])*(1-cos(Pi*m^k*t)) end do; return F end proc;
Then, for k=50, 100, 150... the instruction
works correctly. However, for higher values of k (for instance, k=250) returns the below error. Some idea or suggets about occurs this error?
Many thanks for your time!
Error, (in RootFinding:-Analytic) unable to evaluate `@`(evalf, proc (x) option remember; table( [( 0.524900000000000000000000000000e-1+Float(undefined)*I ) = Float(undefined)+Float(undefined)*I ] ) 31250*Pi*sin(62500*Pi*x)/(7/18-(1/2)*cos(62500*Pi*x)) end proc) at the value 0.524900000000000000000000000000e-1+Float(undefined)*I. The expression to be solved was probably not analytic.
In Maple, is it possible to define an element of a series like that:
a[n] = n^2
(i actually tried to enter := instead of =, but html editor told me its not valid maple expression)
So at any moment i enter a[5] and maple give me 5^2, or a[70] -> 70^2 ?
When transfering a particular worksheet from my home Windows 7 computer to an office Linux computer I lose some of the end of the worksheet, namely I lose a rather memory intensive animation at the end. And the office compute crashes when I attempt to run the animation. This seems strange since apparently the office computer (see below) is more powerful than my home computer.  When this happens there are apparently few if any other users of the office computer. I  would be grateful for suggestions for remedies for this problem or any ideas of what the problem could be.
Home computer: Windows 7 Intel(R) Core(TM) i7-2600 CPU@3.40GHz, 12 GB RAM 64-bit OS
Office computer: CentOS, Kernel Linux 2.6.32-573.12.1.l6.x86.64, Gnome 2.28.2, Memory 94.4GiB, 6 processors each an Intel(R) Xeon(R) CPU E5-2643 v2@3.5BHz, Available Disk Space 1061.0 BiB
I am using Maple 2016.1 and my laptop resolution is 3200x1800.So the titlebar, the palettes etc. are so small that they are invisible. In addition,some symbols and writings in the palettes are overlapped. Is there any solution suggestion?
PC: Windows 10
Thank you very much.
In Kitonums'answer of
http://www.mapleprimes.com/questions/220229-How-Do-I-Solve-A-Differential-Equation-In-Maple
I read a code of remove(t->t=".", b);
t->t="." is a Boolean-valued procedure.
But, then, why does (t->t=".")(9); not return false like (t->t^2)(3); returns 9?
How can I have maple return false?
I have solved a BVP using finite difference method in maple. But the comparsion with the dsolve solution shows big difference,
Why there is too much difference? Is there an elegant way to implement FDM?
FDM_Dbvp_sheet_1.mw
i wrote a procedure for determine a lambda symmetries and first integrals of ODEs.
Procedure is running but commands is getting error.
Can  anybody help me.
Thanks in advance. procedure.mws
If a particle that moves in only one dimension is subject to a force Fi between the time
steps ti and ti+1, the velocity vi and position xi of the particle is:
v[i] := v[i − 1] +(1/m)*F[i]*Δt
x[i] := x[i − 1] + 0.5 (v[i − 1] + v[i])
Use the mean of v between ti and ti+1 when updating xi, since the value may change
a lot from step to step. In the subsequent, we set the mass m = 1 and the time steps
are Δt = 1, since we could absorb m and Δt in the expression for the force Fi anyway.
Write a procedure that computes xi and vi for a particle subject to random forces Fi,
uniformly distributed on the interval [-0.5..0.5].
I`ve written a procedure that generates random forces (F[i]) in the given interval. How can I write a for – procedure that computes xi and vi ?
For exaqmple, the quadratic equation w^2 + uw + v = 0 corresponds to the deter minant
| -u  1  1  |
| v    0  1  |  = 0
|w^2 w w-1|
Is there any way to find a determinant corresponding to an equation, as above?
This is an issue in the preparation of a nomograph for the initial equation.
It is generally solved by trial and error.
hi
i want save result in text file?
how i can do it?
for example eta and F(eta) in two  column
sample file is attache.
printf.mw
txtop1.txt
sample for save results::::
eta                     F(eta)
0.00000000, 0.00000000
0.10000000, 0.00096663
0.20000000, 0.00373543
0.30000000, 0.00810907
0.40000000, 0.01388926
0.50000000, 0.02087683
0.60000000, 0.02887169
0.70000000, 0.03767307
0.80000000, 0.04707963
0.90000000, 0.05688968
1.00000000, 0.06690139
Download txtop1.txt
I need help to write a procedure that uses Maple`s built-in rand() - function to generate uniform random floating point numbers between -r and r, where r is an input parameter of the procedure.
>M:=600;
>R1:=rand(0..1):   R2:=() -> 2*R1()-1:
>for i from 1 to M do
    f[i]:=R2()*rand()/10.^12:
With this procedure I get random floating point numbers (+/-), but I can`t figure out how to generate numbers between +/- a parameter (in this case r).
If anyone could help me understand how to get this to work I would be very gratefull.
First 1071 1072 1073 1074 1075 1076 1077 Last Page 1073 of 2459
