Please find the attachment
It seems a singularity has been occurred at left end point for n less than unit (say n=0.5, n>0)
Is there a way to fix it?
n.mw
I apologize, as I'm still very new. I've flipped through a lot of pages, but I'm unsure of how Maple code translates to Maple TA.
I have randomly assigned an integer for the value of a year in Maple TA. I'd like it to appear as "2013" for example, but it will instead appear as "2,013". Is there a way to set the output formatting of a variable individually within a problem in TA?
I would like to determine a closed form solution (=analytical solution) of the following trigonometric equations system.
TrigonometricSystem2.mw
The unknowns are :
ListAllUnknowns := [Psi(t), Theta[1](t), Theta[2](t), x[1](t), x[2](t), z[1](t), z[2](t)]
Do you have ideas so as to conduct the symbolic resolution of this trigonometric equations system ?
I have been told that the use of Grobner basis could be useful but I have never try this.
Thanks a lot for yours feedbacks.
how can active that math mode not run in maple 2016
This is a specific Maple 2016 question: I find that plots no longer remember their attributes (like size on the screen) upon re-execution of a worksheet, even though I have set the appropriate flag in the Interface pane of the preferences.
Can someone confirm this; or am I just being dense? Is this an OS X issue? An El Capitan issue?? Maple 2015 on Yosemite behaves as expected.
Maple 2016.1 on Mac OS X 10.11.5.
M.D.
hi .please help me for this error
Error, (in fprintf) number expected for floating point format...
float.mw
T(r, t) := -(1.082744105*(.4426072302*BesselJ(1, 1.511248492*r)+.5201541352*BesselY(1, 1.511248492*r)))*Besselj(0, 3.588021808)*(1.-1.*exp(-3.218475123670897216*t))/Besselj(1, 1.794010904)-(0.7489242453e-1*(-.4693819312*BesselJ(1, 2.197141326*r)+.6841159909*BesselY(1, 2.197141326*r)))*Besselj(0, 9.604121522)*(1.-1.*exp(-23.059787552335899121*t))/Besselj(1, 4.802060761)-(0.1290812036e-1*(-.6766364675*BesselJ(1, 3.111788255*r)-.7242359729*BesselY(1, 3.111788255*r)))*Besselj(0, 15.817923424)*(1.-1.*exp(-62.551675361881970944*t))/Besselj(1, 7.908961712)-(0.5633715672e-1*(.8435152108*BesselJ(1, 4.692507174*r)+.8812474286*BesselY(1, 4.692507174*r)))*Besselj(0, 9.604121522)*(1.-1.*exp(-23.059787552335899121*t))/Besselj(1, 4.802060761)-(0.6254981294e-1*(-.8481299777*BesselJ(1, 5.429681040*r)+1.002082035*BesselY(1, 5.429681040*r)))*Besselj(0, 9.604121522)*(1.-1.*exp(-23.059787552335899121*t))/Besselj(1, 4.802060761)
-1.082744105*(.4426072302*BesselJ(1, 1.511248492*r)+.5201541352*BesselY(1, 1.511248492*r))*Besselj(0, 3.588021808)*(1.-1.*exp(-3.218475123670897216*t))/Besselj(1, 1.794010904)-0.7489242453e-1*(-.4693819312*BesselJ(1, 2.197141326*r)+.6841159909*BesselY(1, 2.197141326*r))*Besselj(0, 9.604121522)*(1.-1.*exp(-23.059787552335899121*t))/Besselj(1, 4.802060761)-0.1290812036e-1*(-.6766364675*BesselJ(1, 3.111788255*r)-.7242359729*BesselY(1, 3.111788255*r))*Besselj(0, 15.817923424)*(1.-1.*exp(-62.551675361881970944*t))/Besselj(1, 7.908961712)-0.5633715672e-1*(.8435152108*BesselJ(1, 4.692507174*r)+.8812474286*BesselY(1, 4.692507174*r))*Besselj(0, 9.604121522)*(1.-1.*exp(-23.059787552335899121*t))/Besselj(1, 4.802060761)-0.6254981294e-1*(-.8481299777*BesselJ(1, 5.429681040*r)+1.002082035*BesselY(1, 5.429681040*r))*Besselj(0, 9.604121522)*(1.-1.*exp(-23.059787552335899121*t))/Besselj(1, 4.802060761)
F53 := proc (t) options operator, arrow; eval(T(r, t), r = 1.5) end proc; G53 := proc (t) options operator, arrow; Re(evalf[20](F53(t))) end proc; Temp3 := cat("T-t (N=", No, ",r=1.5).dat"); fd53 := fopen(Temp3, WRITE, TEXT); i := 0; for i from 0 by 0.5e-1 to 500 do tt := i; y := eval(G53(t), t = tt); fprintf(fd53, "%10.5e %10.5e  \n", tt, y) end do; fclose(fd53)
Download float.mw
Hi to all.
Is possible to use Maple in Excel ? How ?
Where can I search a brief description of Maple's product ?
how to convert GeneralLinearGroup and GeneralOrthogonalGroup to permutation group for small parameters
GL23 := GeneralLinearGroup(2, 3);
Generators(GL23);
i use generators , is it correct to find permutation group?
but there is a comma,
[((1, 2)(3, 5))(4, 7), (1, 3, 6)(2, 4, 8)]
does it mean that it has two different solutions?
if not, it is only one solution,
does it mean that permutation matrix is
permutationmatrix of  ((1, 2)(3, 5))(4, 7) + (matrix plus) permutation matrix of  (1, 3, 6)(2, 4, 8) ?
Dear All
I have 3D plot
y := 0; 1; z := 0
plot3d(abs((2*(-exp(-t-x-z)+exp(t+x+z)))/(exp(-t-x-z)+tanh((1+I)*t+(1/2-1/2*I)*y+z)+exp(t+x+z))), x = -5 .. 5, t = -5 .. 5)
How I can Improve this plot so that it look more aesthetic ?
Secondly, the resulotion of plot is not so good, and when I export this plot as jpeg file, quality of resolution deteriotate even more, I mean pixel tear out on zooming the image. How I fix this issue which I guess might be due to wrong way of exporting plot ?
Download Improving_3D-_plot.mw
i work on Maple 18 and recently maple standard worksheet interface not run properly.
i already have  uninstall and again i have same problems
Dear friends!
Please, suggest me, how to build a plot loocking as the following
plot
where the values on the axis X (1, 5, 10, 50, ...) are categories, not numbers?
Hi, I am a student and a recent new MapleSim user. I downloaded the MapleSim Wind Turbine Vibrations model from the Model Gallery (http://www.maplesoft.com/products/maplesim/modelgallery/detail.aspx?id=162).
I do not understand the model diagram, and find it difficult to visualize the way all the components work. Also, how can I change the mass moment of inertia of each blade?
This is my first question, apologies if it sounds silly. Thank you :)
I try to connect Maple with C# by using OpenMaple at http://www.mapleprimes.com/posts/38048-Using-OpenMaple-With-C
But OpenMaple just excuted in x64 mode, I want to excute OpenMaple in "Any CPU" mode. How can I do this?
P/s: I'm using Windows 7 Ultimate x64 and Visual Studio Ultimate 2013.
First 1143 1144 1145 1146 1147 1148 1149 Last Page 1145 of 2468
