psi = x^(4/5)*f(x, eta)/(1+x)^(1/20)
eta = y/(x^(1/5)*(1+x)^(1/20))
how can i (diff(psi, x))
how can i (diff(psi, y))
Has anyone solved this problem from an older Putnam paper?
An ellipse sitting in the first quadrant with its major axis parallel to the x axis is tangent to the positive x and y axes.
It slides clockwise within the first quadrant while maintaining tangency to both positive axes until its major axis is parallel to the y axis.
Prove that the locus of its centre is the arc of a circle.
I have crudely animated this motion by sliding the axes around the stationary ellipse. Is there a more elegant animation which slides the ellipse against stationary axes?
I have functions like
g := (y, t)->sin(y(t))
diff(g(y, t), t) # ok
How to determine the derivative below with maple :
diff(g(y, t), y(t))
Hi everyone,
Can anybody help me to write a programme in maple? I want to do a loop that iterate from an integer from 0 to N where I want to write a prodedure, say, MEC(N). Then I want to organise the output into a list of three lists  [[min points],[escape],[capture]], which, if correct, should include all integers from 0 to N exactly once.
> MEC := proc (N)
local IsEmpty, Escape, escape, capture, minpoints, Capture, z, MinPts, ic;
IsEmpty := array(0 .. 2*N);
Escape := array(0 .. 2*N);
Capture := array(0 .. 2*N);
MinPts := array(0 .. N);
IsEmpty := true;
Escape := true;
Capture := true;
MinPts := true;
for ic from 0 to N do
if IsEmpty then
z := ic;
MinPts[ic] := true;
z := ic;
while z <= 2*N and F(z) <= 2*N do
z := F(z);
IsEmpty[z] := true;
Escape[z] := true
z := ic;
while z <= 2*N and Finv(z) <= 2*N do
z := Finv(z);
IsEmpty[z] := true;
Capture[z] := true end do fi;
return [MinPts(z), Escape(z), Capture(z)]
There are two operations involved in the program which is the function F and F inverse called Finv.
i need to produce the output which contain the list of integers exactly once.
I could not figure out which logical expression that I do wrong.
Thank you for your help!
How to find the value of alpha and beta?
u := proc (x) options operator, arrow; sin(x)+cos(x)-4*x+(alpha-4)*x end proc; v := proc (x) options operator, arrow; sin(x)-cos(x)+beta end proc; `assuming`([solve({alpha = int(u(t)+v(t), t = 0 .. Pi), beta = int(u(t)-v(t), t = 0 .. Pi)}, {alpha, beta})], [alpha <> 0, beta <> 0])
{alpha = 4+beta*Pi+(1/2)*alpha*Pi^2-4*Pi^2, beta = -beta*Pi+(1/2)*alpha*Pi^2-4*Pi^2}
thank you for helping
Download Qu_3.mw
How evaluate system of two integral equation by laplace transform ?
with(inttrans):
L := laplace((1/2)*x^2+(1/2)*x^3+(1/12)*x^4 = int(u(t)*(-1+x-t)+v(t)*(1+x-t), t = 0 .. x), x, s);
(s^2+3*s+2)/s^5 = laplace(int(u(t)*(-1+x-t)+v(t)*(1+x-t), t = 0 .. x), x, s)
(3*s^2-s+2)/s^5 = laplace(int((1+x-t)*u(t)+(-1+x-t)*v(t), t = 0 .. x), x, s)
Download Qu_2_mapel.mwQu_2_mapel.mw
Hello everyone!
i want to make a triangle which height's is a. Sorry, my English is not very good!
And I writed it by C language, but It is not right in maple. and I don't know. Can you help me? thank you very much! triangle.mw
How can the black circle be visible?
Visible also below the 3D graph?
Best, perr7
B := spacecurve( [R*cos(t),R*sin(t),0] ,t=0..4*Pi,thickness=1, style=line, color=black);
animate( plot3d, [     P_Pi2(x,y,t)  ,  x=-4000..4000,y=-4000..4000 ], t=0..1, frames=10, transparency=0, style=surfacewireframe, labelfont=[times, roman, 25], orientation=[45,60,0], view=[-4000..4000, -4000..4000, 0..0.006], caption=typeset( theta=Pi/2 ) , axesfont=[times, 15], axes=frame, background=B   );
It's my first post on this forum so Hi everyone from Poland!
I have the following question.
Is it possible to force the Maple to obtain a result in a particular form? For example instead (a+b)3 I wan to have the result of the form: a3+3a2b+3ab2+b3. And I want to multiply the red brackets to receive a quadratic forms.
Below is a sample result that I get and I want it in a different form.
http://i65.tinypic.com/28k29hk.png
[IMG]http://i65.tinypic.com/28k29hk.png[/IMG]
with sin(x) and cos(x). how to draw  this graph:
question.mw
thanks you!!!
Download question.mw
Iam a newbie, just two weeks into my 30-days trial. I have been exploring the symmetry aspect of PDEtools, gone through materials in the help section but still having problem in some of my analysis. The answer to the titled question "Symmetry analysis with parameters" was really helpful but did not work out for me when the parameters are more than one. Attached is a sample question.
sample_question.mw
Download inf2.mw
hello
i write this set of differential equation in maple and get the following error?
Can anyon help me with this?
hi.for linear coupling equation
dsys3 := {-72.49829200*(diff(f1(x), x, x))+0.8377580411e-2*(diff(f2(x), x))-8.873545400*10^9*(diff(f3(x), x))+2.114533515*10^18*f1(x), -878.8477313*(diff(f2(x), x, x))+1.590065471*10^20*f2(x)-7.353421206*10^(-26)*(diff(f3(x), x, x))+4.891459762*10^10*f3(x), 4.027667395*10^(-20)*(diff(f3(x), x, x, x, x))-0.6274394007e-2*(diff(f3(x), x, x))+8.873545401*10^9*(diff(f1(x), x))-7.352113720*10^(-26)*(diff(f2(x), x, x))+4.904509456*10^10*f2(x)+1.208381068*10^19*f3(x)-2.499990383*10^26*omega*(diff(f3(x), x, x))}
by assuming and to expand these functions(f1-f2-f3) in polynomial form(e.g. Chebyshev, power polynomials, Legendre and etc).:
f1(x):=(&sum;)H[i] *(e)^(lambda[i] *x); f2(x):=(&sum;)alpha[i]*H[i] *(e)^(lambda[i] *x);f3(x):=(&sum;)GAMMA[i]*H[i] *(e)^(lambda[i] *x)
how i detemine lambda[i] which are roots of the  characteristic equations?in other word how i can build characteristic relation for coupling equation?
2)how i can gain value for alpha[i] and GAMMA[i]
by using equation
Q1 := subs(x = 0, sum(H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q2 := subs(x = L, sum(H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q3 := subs(x = 0, sum(alpha[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q4 := subs(x = L, sum(alpha[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q5 := subs(x = 0, sum(GAMMA[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q6 := subs(x = L, sum(GAMMA[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8)); M := diff(sum(GAMMA[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8), x); Q7 := subs(x = 0, M); Q8 := subs(x = L, M)
thanks...
chebyshev.mw
   1*  printf("degree = %f\n",a);
end proc
   2   printf("radian = %d\n",evalf(1/180*a*Pi))
When executing the following orders,
a:=0.006:
convert(a, symbol);
the result is .6e-2.
How to make Maple return the form 0.006, just as the original?
First 1224 1225 1226 1227 1228 1229 1230 Last Page 1226 of 2472
