What I want is quite simple but I have not seen it implemented anywhere yet.
I have an explicit map F from the plane into itself. (not an ODE but simply a map)
Then I have a set X, (something like a line segment or a rectangle in the plane) for which I
really need to keep track of the images $F(X), F^2(X), F^3(X)$, and so on.
Is there a way to plot the image of a set in Maple?
Thank you very much for your interests in the question.
I am a new fellow of maple software.
I am trying to run an example of Poincare package example found in
http://www.maplesoft.com/support/help/maple/view.aspx?path=examples%2Fpoincare
But when i  wrote the commands found in this site, i got this error:  Error, unable to match delimiters
The commands  are the following:
> restart;
> with(DEtools, poincare, generate_ic, zoom, hamilton_eqs);
> H := ((p1^2+p2^2)*(1/2))*((e^(2*q2+2*sqrt(3)*q1)+e^(2*q2-2*sqrt(3)*q1)+e^(-4*q2))*(1/24))-1/8;
> poincare('' '', stepsize=.05,iterations=5);
I would appreciate any helps.
Miguel
if input x^2*y+x*y+x
how to output [x^2*y, x*y, x]
Hello those in mapleprimes,
I have a question.
I opened Help and entered diff, for example, to have the explanation of how to use diff.
Whether it is diff or not, is not the problem I want to ask about now. But, what I want to ask is the following.
I cklicked the WS botton at the tool bar of the Help, so that I created the worksheet of the same contents of the help of the diff.
Then, I chose an expression in Calling Sequence. That is,
the first line shows
diff(f,x1, ..., xj)     on the left, and on the right \frac{d^j}{dx_j \cdots dx_I} f (I wrote this in the TeX ways, though
it is written in 2-D math input, actually)
I chose an expression on the right side, and from context menu, which appeared though right clicking of my mouse,
I selected convert to and 1-D math input, through which I changed 2-D math of the worksheet of the help file to 1-D math input.
Then, the expression shown is a strange one:
((ⅆ)^j)/(ⅆx[j] `...` ⅆx[`1`]) f;
This is still easier one. As for the third line in the Help, it has a more complicated form as
((ⅆ)^r)/(ⅆx[k]^m ⅆx[j] `...` ⅆx[3] ⅆx[2]^n ⅆx[1]^n) f;
Do you know how this way to notate is applied in maple worksheet?
Why does maplesoft use this way to notate expressions limited to the Help pages, if it is limited to the help pages.
taro
how to composite two system of polynomials in maple
for a o b = identity
how to composite two polynomial in maple
i would like to search a o b = 1
composite two polynomial equal identity
I am entering into Maple, but it interprets it as
How do I change this partial derivative to a total one. (Both x and y can be assumed invertible functions of parameter u and their derivatives are nonzero)
I need to find all combinations of a binary list of length 3.  For example: [0,0,0] , [1,0,0] , [0,1,0] , [0,0,1] , [1,1,0] , [1,0,1] , [0,1,1], [1,1,1].  Does anyone have a procedure or can write a loop that does this?
I want to extract information  about an ODE.
For example, having the next ODE:
ode := cos(x)*(diff(y[1](x), x, x))+sinh((1/10)*x+1)*y[2](x)+y[1](x)+exp(-x)-1:
extract information as:
the inputs system are :
{y[1](x),y[2](x)}
the independent variable is:
{x}
Some suggestion? I am tried with: indets, DEtools[odeadvisor], whattype, evaluating the function, convert it into a table and using the "indices". Probably the answer is related to dsolve/numeric/process_input
restart; with(Physics); with(Tetrads)
0, "%1 is not a command in the %2 package", Tetrads, Physics
Physics:-Setup(coordinatesystems = {X}, mathematicalnotation = true)
[coordinatesystems = {X}, mathematicalnotation = true]
Physics:-Define(Ybar[a], Y[a], GammaT[a, b, c], RicciT[b, c] = %d_[c](GammaT[`~a`, b, a])-%d_[a](GammaT[`~a`, b, c])+Physics:-`*`(GammaT[`~m`, b, a], GammaT[`~a`, m, c])-Physics:-`*`(GammaT[`~m`, b, c], GammaT[`~a`, m, a])+Physics:-`*`(GammaT[`~a`, b, m], GammaT[`~m`, c, a]-GammaT[`~m`, a, c]), RiemannT[k, l, m, n] = %d_[k](GammaT[m, n, l])-%d_[l](GammaT[m, n, k])+Physics:-`*`(GammaT[`~a`, m, l], GammaT[a, n, k])-Physics:-`*`(GammaT[`~a`, m, k], GammaT[a, n, l])+Physics:-`*`(GammaT[m, n, a], GammaT[`~a`, k, l]-GammaT[`~a`, l, k]))
RicciT[1, 3]
%d_[3](GammaT[`~1`, 1, 1]+GammaT[`~2`, 1, 2]+GammaT[`~3`, 1, 3]+GammaT[`~4`, 1, 4])+GammaT[`~4`, 1, 2]*GammaT[`~2`, 3, 4]+GammaT[`~1`, 1, 3]*GammaT[`~3`, 3, 1]+GammaT[`~2`, 1, 3]*GammaT[`~3`, 3, 2]+GammaT[`~4`, 1, 3]*GammaT[`~3`, 3, 4]-GammaT[`~2`, 1, 3]*GammaT[`~1`, 2, 1]-GammaT[`~2`, 1, 3]*GammaT[`~2`, 2, 2]-GammaT[`~2`, 1, 3]*GammaT[`~4`, 2, 4]-GammaT[`~3`, 1, 3]*GammaT[`~1`, 3, 1]-GammaT[`~3`, 1, 3]*GammaT[`~2`, 3, 2]-GammaT[`~3`, 1, 3]*GammaT[`~4`, 3, 4]-GammaT[`~4`, 1, 3]*GammaT[`~1`, 4, 1]-GammaT[`~4`, 1, 3]*GammaT[`~2`, 4, 2]-GammaT[`~4`, 1, 3]*GammaT[`~4`, 4, 4]-GammaT[`~1`, 1, 3]*GammaT[`~2`, 1, 2]-GammaT[`~1`, 1, 3]*GammaT[`~4`, 1, 4]+GammaT[`~1`, 1, 4]*GammaT[`~4`, 3, 1]+GammaT[`~2`, 1, 4]*GammaT[`~4`, 3, 2]+GammaT[`~4`, 1, 4]*GammaT[`~4`, 3, 4]+GammaT[`~1`, 1, 1]*GammaT[`~1`, 3, 1]+GammaT[`~2`, 1, 1]*GammaT[`~1`, 3, 2]+GammaT[`~4`, 1, 1]*GammaT[`~1`, 3, 4]+GammaT[`~1`, 1, 2]*GammaT[`~2`, 3, 1]+GammaT[`~2`, 1, 2]*GammaT[`~2`, 3, 2]+GammaT[`~1`, 3, 3]*GammaT[`~3`, 1, 1]+GammaT[`~2`, 3, 3]*GammaT[`~3`, 1, 2]+GammaT[`~3`, 1, 4]*GammaT[`~4`, 3, 3]-GammaT[`~3`, 4, 3]*GammaT[`~4`, 1, 3]-GammaT[`~1`, 1, 1]*GammaT[`~1`, 1, 3]-GammaT[`~1`, 1, 3]*GammaT[`~3`, 1, 3]-GammaT[`~2`, 1, 3]*GammaT[`~3`, 2, 3]-%d_[4](GammaT[`~4`, 1, 3])+%d_[1](GammaT[`~1`, 1, 3])+%d_[3](GammaT[`~3`, 1, 3])+%d_[2](GammaT[`~2`, 1, 3])
for a to 4 do for b to 4 do RicciT[a, b] end do end do
Error, (in index/PhysicsTensor) expected summation indices of type symbol, received: 1
Now, if I type the RicciT from (3) it displays the same result. However,......
RicciT[1, 3]
If I type a different RicciT, then ...
RicciT[2, 3]
The for loop is changing the tetrad definition of RicciT.
Download Question_about_tetrads_in_for_loop.mw
Dear friends,
I am trying to do an integration which consists of a list of data; let me explain it more:
I have to do
however, I do not have f(x) in the form of a function. f(x) is a list which is:
also, I have x as
How can I do the integration between 1<x<6 ?
I have a problem with creating a function contains n-dimensional independent variables with random function .. The function looks like:
f(x)=sum(U[i] * abs(x[i])^i,i=1..n)
where U is a random between 0 and 1
For 1-dimensional problem, it will be like:
f(x)=U*abs(x)
The plot by MATLAB will be:
While, for 2-dimensional problem, it will be like:
f(x[1],x[2])=U[1]*abs(x[1]) - (-U[2]*abs(x[2])^2)
and the plot with MATLAB will be:
The MATLAB code is:
x1min=-5;
x1max=5;
x2min=-5;
x2max=5;
R=1000; % steps resolution
x1=x1min:(x1max-x1min)/R:x1max;
x2=x2min:(x2max-x2min)/R:x2max;
for j=1:length(x1)
    % For 1-dimensional plotting
    f1(j)=rand*abs(x1(j));
    % For 2-dimensional plotting
    for i=1:length(x2)
        fn(i)=f1(j)+rand*abs(x2(i))^2;
    end
    fn_tot(j,:)=fn;
end
figure(1)
plot(x1,f1);
figure(2)
meshc(x1,x2,fn_tot);
I have used Maple because of its great graphics and animation, and for the mathematical analysis capability. However, to animate the above problem for 1- and 2-dimensional problems, I always fail!
My attempt has been just successed to plot 1-dimensional problem (without animation) .. And it tooks long-time with many codes!
X := Statistics:-RandomVariable(('Uniform')(0, 1));
R := Statistics:-Sample(X, 1000);
Vect := abs(Vector[column]([seq(0 .. 10, 10/999)]));
V := `~`[`-`](Vect, 5);
with(LinearAlgebra);
Mat := Multiply(V, R);
with(ArrayTools);
f := ArrayTools:-Diagonal(Mat);
F := abs(f);
Axis := Transpose(V);
f5 := plot(Axis, F, style = line);
And finally I got the graph:
But the problem is:
How can I animate it? Maybe I need to express it with new Maple code?
How can I plot and animate it when n=2?
I would like to define all the geometry parameters in a multibody model in MapleSim in mm.
Consequently, i define the mm unit for a parameter in 3 places :
1)  in the Parameters area of the subsystem
2) in the Tab Inspector of the subsystem
3) in the Tab Inspector of the rigid body frame of the subsystem
The problem is that I receive the warning "Possible double conversion unit on a parameter" and the dimension seems to be as 10^-3 *mm soit too much reduced.
I see that in some examples of the library of Maplesim the parameters of the parameters area of a subsystem are defined as real and consequently, it doesn't cause this kind of problem.
However, how can I do if I want to define my parameters in the parameters area of a subsystem as a position in mm ?
Thanks a lot for your help
I use for the 3D visualization the component CAD geometry with STL files.
My STL files are created from CATIA with parts mesured in mm.
In MapleSim, in order to keep mm, I have, of course, to set "mm" in the inspector tab of the components "CAD geometry".
But, I have also to put the scale factor to 0.001.
I don't understand why I should to set it to 0.001 because :
- the CADs from CATIA are in mm.
- and the option in the inspector tab of the components "CAD geometry" is also in mm.
Would you have some precisions about the scale factor for the "CAD geometry" element ?
Thank you for your help.
Given the following code:
for i[1] from 0 to 1 do
for i[2] from 0 to 1 do
for i[3] from 0 to  1 do                             end do:  end do:  end do:
Resulting:     000, 001, 010, 011, 100, 101,110, 111
Is anybody aware of a simplification of this code ?
Thanks to all of you.
First 1255 1256 1257 1258 1259 1260 1261 Last Page 1257 of 2459
