I have an arrays of data. One for x values, and one for y values. How can I obtain a numerical integration of y for a range of x values?
I have tried defining a function of X using ArrayInterpolation(x,y,X) and then calling evalf(Int(f,xmin..xmax)) but that gives an error message. (I don't seem to be able to paste into this window) The error message says
"Error, invalid input: evalf expects its 2nd argument, n, to be of type posint, but received numeric."
I thought I was using a form of the equation right from the help system.
I also tried the 2D version of integration, but it returns the difference of my limits times my function name.
I aslo tried AdaptiveQuadrature, but I can't get that to work either.
-Mike McDermott
Newbie Maple user
by_parts.mwhi, plz someone tell me what I have to do for such type of error
i posted these ealier without any responds,pls i need some assistance my project supervisor has made it mandatory that i build a maple maplet of the bessel equation:
  i would have loved my maplet to have four knobs/sliders to vary the value of the parameters(T[g],T[0],k,p)  and also a play puase and stop bottons while texts boxes to type in the value of the unvaried parameters(gamma,G,alpha,delta,C[1],C[2]) and this maplet should show a 3d and 2d plot of the equation of which the various varying parameters can be varied to see effect on the plots.1.e 3d plots of (F against p and T[o]),(F against k and T[o]),(F against tortuosity and T[o]) which can be assigned to three different plot bottons but to be ploted on the same plotter and 2d plots of (F against p) and (F against k), (F against tortuosity) which can also be assigned to three different plot bottons but to be plotted on a second plotter aside that of the 3d plots.
i will really gratefull if anyone can help me out,thanks in advance<
I'm new at maple and have a problem/question with the rkf45 numerical ODE Solver.
At first, my computer need a lot of time to calculate an analytic solution.
Therefor, I use the numerical way.
I have the following second order ODE:
ODE:=m*((D@@2)(x))(t)+d*(D(x))(t)+k*x(t) = d*(eval(diff(y(x), x), x = t))+k*y(t)
where y(t) is a realy big piecewise function, defined by me.
My initial conditions are:
x(0) = 0, (D(x))(0) = 0
With dsolve, I get the solution x(t) and the first derivative x'(t). I'm able to plot them with odeplot.
But...
Problem 1:
I need also the second derivative x''(t).
On this page: http://www.maplesoft.com/support/help/maple/view.aspx?path=dsolve%2Frkf45there is an example (eq 13 and 14) where the second derivative is useable, but this doesn't work with my differential equation.
I have add
(D(D(x)))(0) = 0
to my initial conditions but then, I got the error that only 2 initial conditions are required.
What could I do, so that rkf45 returns also the second derivative?
Problem 2:
And in addition to this, I want to calculate with x(t), x'(t), x''(t) but I found no way to use them.
Only plots are possible.
If I reduce y(t) to a minimum, I can do everything with the analytic solution: plot, d/dt, d2/dt2, +, -, ...
I tried also to convert the procedure to a function but in this case, there is no way to derivate it.
Many thanks...
https://drive.google.com/file/d/0Bxs_ao6uuBDUVkE1b2pmcnljcnc/view?usp=sharing
https://drive.google.com/file/d/0Bxs_ao6uuBDUbE56R3Z1c0tLRkE/view?usp=sharing
changering := proc(Equation1, f3,g3)
g1 := (x,y)-> f3;
f1 := (x,y)-> g3;
h:=subs(g=g1, Equation1);
h:=subs(f=f1, h);
h:=subs(0=0, h);
return h;
Eq1 := f(x,g(x,y)) + f(x,y);
h2 := changering(Eq1,x+y, x+y);
h2;
g1 := (x,y)-> x+y;
f1 := (x,y)-> x+y;
h:=subs(g=g1, Eq1);
h:=subs(f=f1, h);
h:=subs(0=0, h);
Dear All
I am trying to integrate a function, however Maple is not giving me the results. I have tried to use int as well as evalf however I am still not getting the results.
I would be grateful if you could please suggest me a way out. I have attached the maple file for your reference.
ThanksExample.mw
I have this data I want to import in to Maple.
In Maple I type:
ImportMatrix("C:\\Users\\marc\\Desktop\\data1.csv", delimiter = ",");
then I get the following:
My question now becomes how can I import the data with the correct dates and not just -Aug, 1-Aug etc ?
The method should also work when I have many more columns of dates.
Ps I cant upload the data on MaplePrimes since it is a csv file.
how to show chain rules result when diff this
Eq1 := f(x,g(x,t)) + f(x,y);
diff(Eq1, x);
 http://math.stackexchange.com/questions/372093/chain-rule-definition-f-fx-gx-y
https://drive.google.com/file/d/0Bxs_ao6uuBDUanVWYm1SMWc4R3M/view?usp=sharing
Hello All,
I have the PDE system shown below. It is a simple system for 2 unknown functions f1(x,t) and f2(x,t). Also, say we have x=x(t)=e^t for example. How does one solve such PDE system with Maple? I tried including the condition x=e^t in the PDE system itself, but got "System inconsistent" error message. x=x(t) can be looked at as an additional constraint and I am baffled how do I feed it into the PDE solver.
Perhaps someone has experience with such systems?
  My question is related to this one http://www.mapleprimes.com/questions/37447-How-Can-I-Sort-A-List-Of-List-According
but not exactly the same.
  Suppose I have lists
f[1]:=[1,3,2];
f[2]:=[2,1,3];
f[3]:=[1,2,3];
f[4]:=[2,3,1];
f[5]:=[3,2,1];
f[6]:=[3,1,2];
  The aim of sorting is first, arrange by ascending order of the first variable, then the second, then the third.
I could program manually by explicitly comparision, is there any robust way in maple can do it (possibly a few build-in function)?
Thank you very much!
Just trying Maple again after 10+ years, so please bear with me. I am basically trying to do a symbolic integration, where the output should be the antiderivative of the function I am integrating. However, I have not been able to succesfully get the output I expect.
I defined a function Cp(T), with constants C1, C2, etc. like so:
C__p := T -> C__1+C__2(C__3/(T*sinh(C__3/T)))^2+C__4(C__5/(T*cosh(C__5/T)))^2
But when I integrate the function using int(Cp(T), T=Tref..Tsys) it does not output the antiderivative as I would expect. This is what I am looking for, but it just gives me the equation within the integral sign without symbolically solving integral. Can this be done?
It should be,
int(Cp(T), T=Tref..Tsys) = C1*(T2-T1) + C2*C3[coth(C3/T2) - coth(C3/T1)] - C4*C5[tanh(C5/T2)-tanh(C5/T1)]
Trivial integrals such as int(x2,x) = 2x solve okay, so I am assuming I setup the problem incorrectly. I just cannot figure out what I did wrong, and it is driving me crazy. I already wasted more time than is healthy on this. Any help would be greatly appreciated. Thanks.
f(x, g(x,y)) + f(g(x,y), y) >= f(g(x,y), g(x,y))
f(x, g(x,y)) + f(x, g(x,y)) >= f(g(x,y), y)
f(x, g(x,y)) + f(x, g(x,y)) >= g(f(x,y), y)
f(x, g(x,y))*f(x, g(x,y)) >= f(g(x,y), y)
how to create a combinations of function of another function in maple
I'm writing an algorithm that takes a while and I'd like to print status messages periodically. I typically use the command line interface, and this is no problem. I just do a printf whenever I need.
However, some people who will use this code prefer to use the GUI, and I've found that the GUI tends to buffer the output from printf, printing 20-30 printf statements in clumps instead of as they're called. Is there any remedy for this?
hi.i am a problem with rule solve or fsolve in maple....please see attached file and say your comments
equ.mw
sum(xj*(sum(yi, i = k .. n)), j = k .. n)
How do I solve this? Can anone help?
Here x and y both are variables.
First 1271 1272 1273 1274 1275 1276 1277 Last Page 1273 of 2459
