I am trying to see how do I have initial conditions in a system of differential equations. This is an example problem, which doesn't work. What is wrong? Thank you.
I am looking to extract exponents from a sum of products of three variables A, B and C. An example being:
f:=5*A^4*B^3*C^7   +   3*A^2*B^1*C^7  +  31*A^3*B^6*C^11  + ...
I used the following procedure to extract the exponents of each variable:
Exponents:= proc(p, x::name)
    local
    t;
    coeffs(p,x,t);
    map(degree, [t], x)
This works great and will extract the powers for each term:
Exponents(f,A):        [4,2,3]
Exponents(f,B):        [3,1,6]
However, when the exponents are the same it does not count them twice. An example of this being with the variable C above where two of them have an exponent = 7 and it only counts it once.
Exponents(f,C):        [7,11]
Is there a simple way to modify the procedure to list the powers regardless of if they appear more than once?
Many thanks in advance.
I want to make a package that I have created work with the LinearAlgebra package that comes with Maple. My package loads into a worksheet fine, but when I try to use one of my procedures, most of which depend upon procedures in the Linear Algebra package, the executable part of my procedure from my package is simply echoed to the screen and not executed. If I then copy the echoed part to a command prompt then it executes fine. How do I make my package use the commands in the Linear Algebra package?
Try to consider the following system of differential equations:
sys := diff(U(ksi), ksi) = (y(ksi)-(1.5*(1+0.01*ksi))*U(ksi)/ksi)/(1.5+0.015*ksi+0.002*ksi^2),
diff(y(ksi), ksi) = U(ksi)*(0.002+(1.5*(1+0.01*ksi))*(0.002*ksi^2)/(ksi^2*(1.5+0.015*ksi+0.002*ksi^2))-19.3^2)-y(ksi)*(0.002*ksi^2)/(ksi*(1.5+0.015*ksi+0.002*ksi^2))
with the boundary conditions: cond:= y(0.8) = 0, y(1) = 0
And Maple gives me zero solution for this system , i mean U(from 0.8  to 1) = 0 and y(from 0.8 to 1) = 0
How can i get some other solutions?
P.S. i need numerical solution => dsolve( [sys,cond],type= numeric)
Please, i need some help.
I want to calculate this limit
limit((b^(d+1)-1)/((b-1)*b^d), d = infinity)
but it always return limit((b^(d+1)-1)/((b-1)*b^d), d = infinity)
Is it becaus it cant recognize what b symbol is ?
Another easy question from a newbie:
Say I have a procedure which, along the its execution, needs to pass a parameter to a different procedure (which, in this case, would be a subroutine) to be elaborated and returned to go on.
This process may happen a few times during the execution and the passing parameter, which may have the same name but different value, needs to be worked on by the subrooutine.
My question is: how do I invoke a procedure from a parent procedure passing one or more parameters and have them returned?
I am trying to use implicit plot. The plot is OK but I want to put labels such as what Latex produces :
$\frac{\Omega}{\omega_n}$ for x axis and $a_0 \mathrm{(m)}$ for y axis
How can I apply this in my maple code as below:
plot1:=implicitplot(a3, Omega_r=1.5..2.5, a=0.00000001..0.1, labeldirections=[horizontal, horizontal], axes=boxed, labels=["W/w_n",typeset("a_0 (m)")], labelfont=[SYMBOL]):
What I have put as bold does not work for me, it is making everything in Greek :) . I want combination of Greek and math.
Thasnks,
Bahareh
I am trying to design a question, where studenst have to find the equation of a linear function given its graph. For this to work, I have to be able to draw gridlines, which for some reason is not possible in Maple TA with the ordinary plot function. I know it should be possible using an applet; given the problems this is going to create with all the different browsers, however, this is not a viable solution. I have found another solution which is unreasonably complex but should work. The problem is that sometimes it doesn't work. When I press Refresh algorithm preview in the Question Designer I get "Broken Maple plot. Verify your plot statement" roughly every third time I refresh the preview. Any help would be greatly appreciated.
The algorithm is here:
$a1=range(-4,4,1);
$a2=range(1,4,1);
condition:not(eq($a1,$a2));
$px=range(0,5,1);
$y0=range(0,5,1);
$x0=if(gt($a1,0),$px,-$px);
$f=$a1/$a2*(x-$x0)+$y0;
$G=plotmaple("
 plots[display](
  [plots[coordplot](cartesian, [-10 .. 10, -10 .. 10], grid = [11, 11], color = grey),
   plot($f, x = -10 .. 10, y = -10 .. 10, color = [green, blue, red], thickness = 2, tickmarks = [[1], [1]], labels = [``, ``]),
   plots[textplot]([0, 10, 'y'], align = {above, right}),
   plots[textplot]([10, 0, 'x'], align = {above, right})
  labels = [``, ``], axes = normal, view = [-10 .. 10, -10 .. 10]),
 plotoptions='width=350,height=350'");
$g=gcd($a1,$a2);
$at=$a1/$g;
$an=$a2/$g;
$a=if(eq($an,1),$at,$at/$an);
$ans=$a*x+($y0-$a*$x0);
This question is related to http://www.mapleprimes.com/questions/204419-Derivatives-Of-Splines-Are-Not-Defined and http://www.mapleprimes.com/questions/42114-Problem-With-Spline-Integrating , however I have not been able to apply the solutions given there to my problem.
I have a set of points given by
and certain function value points given by
where e1 is the function I am approximating.
Using
I come up with my piecewise function.
When I do diff(e4,x), however, the points at the nodes show "float(undefined) x=0.2..."(the node).
As it turns out, the value of the derivative on the left of the node is not equal to that of the right side by a factor of 10^(-7), in other words, numerically unimportant but high enough for maple to realise it is not the same number. How could I tell Maple that I am happy choosing, for example, the value given by the function on right side of the node?
I welcome any suggestions.
Every time I try to write a procedure I get stuck.
This time is no different:
global a:=0.081819221, PI:=3.1415926535897932384626433832795;
Ecce:=proc(lt)
lat:=lt*(PI/180);
b:=((1-a*sin(lat))/(1+a*sin(lat)))^(a/2));
t:=ln((tan(PI/4)+lat/2));
d:=3437.7468*t*b;
return d;
I digit the following to get a result
Ecce(45.2112);
and this is what I get (in blue)
Ecce(45.2112)
Every single time. I can never have a procedure that works right away. It's getting on my nerves
I want to extract all the symbols and last trade from
http://finance.yahoo.com/q/cp?s=%5EIXIC
I have tried:
status, data, headers := HTTP:-Get("http://finance.yahoo.com/q/cp?s=%5EIXIC");
data;
but it just gives me a bunch of jiberish! Any ideas?
The equation tan(y) = 2*tan(x) defines y implicitly as a function of x.  Well, perphas "defines" is too strong a word, since there are multiple solutions for y.  However, if I am not mistaken, there exists a unique continuous solution y(x) that goes through the origin, that is, y(0)=0, and is defined for all x.
Question 1: How do we plot the graph of y(x)?
I have a roundabout solution as follows.  Differentiate the equation tan(y(x)) = 2*tan(x) with respect to x and arrive at a first order differential equation in y(x).  Solve the differential equation with the initial condition y(0)=0.  Surprisingly, Maple obtains an explicit solution:
which we can plot:
plot(rhs(%), x=0..2*Pi);
Question 2: Is there a neat way of getting that solution with algebra only, without appealing to differential equations?
please i would love make a 3d plot of this Bessel function expression against the parameter p and T[0] using maple (p^(((2+deltaT[0])/(2)))*(C[1]*BesselJ((delta)/(-2)*sqrt(T[0]-4 T[g]),(-((T[g])/(T^(2)[0])*gamma*G*delta*sqrt(alpha*k))/(p))+C[2]*BesselY((delta)/(-2)*sqrt(T[0]-4 T[g]),(-((T[g])/(T^(2)[0])*gamma*G*delta*sqrt(alpha*k))/(p)) where [delta = 0.2e-2, T[g] = (1.1, .615, .48, .2962), k = (1.2, 1.3, 1.4, 1.5), G = .2, gamma = .2, alpha = 5.36, C[1] = 500, C[2] = 100,p = (.22, .23, .24, .25), T[0] = (3.666667, 2.307692, 1.714286, 1.377778)
we can get the continued fraction of cot(x) with the command
> convert(cot(x), confrac, x, 6)
the result is
(1+x^2/(-3+x^2/(5-(1/7)*x^2)))/x
how could I convert this result to a form like
1/x-(1/10)*x+49*x/(20*x^2-210)
First 1273 1274 1275 1276 1277 1278 1279 Last Page 1275 of 2459
