i want to find the stability of this equation, but there is seem to have some problems..can somebody help me..
y := A*(1/x+x*exp(-2*sqrt(-1)*b))+4*(exp(h)-1)^2*(2*exp(-sqrt(-1)*b)-3*(exp(h)-1)^2*x^(-exp(h)+1)*exp(sqrt(-1)*b*(-exp(h)+1-1))+3*x^(-exp(h)+1)*exp(sqrt(-1)*b*(-exp(h)+1-1)))/(3*(1-r))-exp(-2*sqrt(-1)*b)/x-x;
subs(A = (1+r)/(1-r), %);
subs(r = (1/3)*(exp(h)-1)^2, %);
subs(b = m*Pi*(exp(h)-1), %);
subs(m = 1, %);
subs(h = 0.5e-1, %);
> ans := solve(%, x);
ans:=
> r1 := ans[1];
> r2 := ans[2];
Any suggestions (or perhaps related examples?) illustrating how I might numerically solve for f(t) in the following non-linear integral equation?  In Fortran, I would start with a guess f(t)=T0, and then search in the neighborhood for a minimum (in the error), but I am not familiar with numerical searches and methods in Maple.  Thank you for any suggestions or leads.
(a,b,... etc are all real)
T__0 := 298.
`ΔT` := 25.
0 < beta and beta <= 1
f*t = T[0]+`&Delta;T`*[1-exp(-a(int(exp(-b/f(y)), y = y[1] .. t))^beta)]
Download Integraleqn.mw
Hello, I am newbie in Maple...
I tried to make a simple iteration, and I would like to get complex results for Z2, Z4 and Z5, as they have complex tag in them.
Would anybody to be so kind, to have a look at my file, and tell me, what's the mistake?
zernike_BB.mw
Thank you:
Attila
How can I call to an external batch file (which is located in a given directory) from a Maple session?
Janos Pinter
I would like to know how could I plot an ODE for 3 values of a parameter in the same figure.
sol:=dsolve(dsys,numeric,parameters=[t]);
p:=proc(t)sol(parameters=[t]); plots:-odeplot(sol,[x,f(x)],-1..0,_rest) end proc;
p(-1); p(-0.5); p(-0.1);
Here, I have 3 figures one for each value. I used with(plots): display(p(-1); p(-0.5); p(-0.1)). But doesn't work.
Thanks for your help.
I wonder if it is possible to create standalone executables in Maple that would run in a  computer without Maple. Also if it is possible can we do that with Matlab code in it too?
Matlab does not allow to create standalone executable is you use symbolic toolbox and I want to find a solution for that. What I will need to take second derivatives and get the coefficients of polynomials.
How to find (i. e. to evaluate) the positive root of the polynomial equation
mul(x+j, j = 0 .. 2015)=1?
The command
RootFinding:-NextZero(x-> mul(x+j, j = 0 .. 2015)-1 , 0);
outputs
                              FAIL
The same with Digits:=100.
Hello people,
I've been working with a list of [x,y,z] elements, where the x and y are positions, and z is the value at given x y. I wish to be able to plot the results so that they look like this
Plot of points
 link:http://imgur.com/t6fEHee
I made the above plot using the following code
surfdata(points[1],dimension=2,colorscheme=["Orange","MediumBlue"])
where points[1] is a list of lists of points.
Glad that i was succesful, i tried to apply this method to a must larger number of points, only to be met by the following error
Error, (in makePlotFromLargeFNASet) assigning to a long list, please use Arrays
So, i made it so that points[1] became an array instead of a list of lists. When trying to apply surfdata now, using the exact same line as above, the plot is not 2D with colors as the 3rd dimension, but only returns a 3D plot as if dimension=3. It is endlessly frustrating, since there doesn't seem to be any sense to the error, and i cannot find an answer to why it does so. Any help would be appreciated!
Thanks in advance,
Mehdi
EDIT: I have uploaded the worksheet and the two files that i use on the following link:
http://www.filedropper.com/plotscript
with(ArrayTools):
M1 := Matrix([[0, 0, b], [0, e, f]], order = Fortran_order);
row, col, var := SearchArray(M1);
M2 := Matrix([[0, 0, b], [0, e, f]], order = C_order);
row2, col2, var2 := SearchArray(M2);
I guess that's a bug.
How can I access the Laplace Transform built-in package?
I want to try to modify it for something like this,
 int(f(t)*exp(-s*t), t=0..infinity);
to
 int(f(u*t)*exp(-s*t), t=0..infinity);
 or to
 int(f(u*t)*exp(-t), t=0..infinity);
Cheers!
Dear  i want to plot the graphs for different values of R[2,5,6.5]   here is the codes: Either ido loop or array i have to use or other procedure
The graph display should be at R=2, one graph, R=5 another and R=6.5
onemore graph
with(DEtools):
eta:=1+k*x+epsilon*sin(2*Pi*x):
A1(x):=-exp(-alpha*x)*J^2*R/(2*eta^3+6*xi*J^2*eta^2):
psi0:=A1(x)*y^3:
psi:=delta*psi0:
V:=-diff(psi,x):
delta:=0.1:
epsilon:=0.01:
alpha:=1:
xi:=0.001:
k:=0.1:
As:= [0, 2, 4]:
x:=0.2
plot([seq]([eval(V, J= A), y, y= 0..eval(eta, J= A)], A= As),title=" velocity at R=2.0 ",labels= ["v", "y"],color= [green, red, blue], linestyle= [solid, dash, dot],legend= [seq](J = A, A= As), axes=boxed);
Hello, I would like to customize the context menu in Maple 18 and looking for a way, to convert 2-D expressions to classical maple input using command(s) (same function as "2-D Math > Convert To > 1-D Math Input"). My main problem is, that using the standard procedures in the context menu I get the result of an expression, not the expression itself.
Can you give me an idea, how to do this? Thanks, Csaba
@Carl Love Dear Sir i am trying to solve the system of nonlinear ODE equation with semiinfinite domain by using shooting method . but i am receiving following error
"Error, (in isolate) cannot isolate for a function when it appears with different arguments"
how can i remove this error. i am unable to find the mistake. kindly help me
Hello! I'm really craving for a piece of advice from you pros.
For simplicity's sake let's start with this made-up system.
where
Here is solver options with pair of events to get idea about what I want.
Plot of solution
For my purposes it's essential to restrict variables m and D(fi1)(t), D(fi2)(t). While it's very convenient to use piecewise() operator in first case with m, I simply can't find working method for second.
I've tried various events for dsolve, but they trigger only once and I failed to provide continuous restriction on the derivatives in question.
That's what I need in the end:
If there's a way to obtain this result, please, don't make secrets of it :) Thank you in advance!
I input:
solve({My(x, -(1/2)*b) = 0, My(x, (1/2)*b) = 0, w(x, -(1/2)*b) = 0, w(x, (1/2)*b) = 0}, {Am, Bm, Cm, Dm});
and recieved:
Error, (in My) invalid input: diff received -1, which is not valid for its 2nd argument
My is
My := proc (x, y) options operator, arrow; -((1/2)*I)*Bm*(exp((2*I)*Pi*x/a)-1)*Pi^2*exp(Pi*(I*x-y)/a)/((exp(Pi*(I*x+y)/a)-1)*(-1+exp(Pi*(I*x-y)/a))^2*a^2)+I*Dm*y*(exp((2*I)*Pi*x/a)-1)*Pi^2*(exp(Pi*(I*x-y)/a))^2/((exp(Pi*(I*x+y)/a)-1)*(-1+exp(Pi*(I*x-y)/a))^3*a^2)+I*Dm*y*(exp((2*I)*Pi*x/a)-1)*Pi^2*(exp(Pi*(I*x+y)/a))^2/((exp(Pi*(I*x+y)/a)-1)^3*(-1+exp(Pi*(I*x-y)/a))*a^2)-I*Bm*(exp((2*I)*Pi*x/a)-1)*Pi^2*exp(Pi*(I*x+y)/a)*exp(Pi*(I*x-y)/a)/((exp(Pi*(I*x+y)/a)-1)^2*(-1+exp(Pi*(I*x-y)/a))^2*a^2)+I*Bm*(exp((2*I)*Pi*x/a)-1)*Pi^2*(exp(Pi*(I*x+y)/a))^2/((exp(Pi*(I*x+y)/a)-1)^3*(-1+exp(Pi*(I*x-y)/a))*a^2)-I*Dm*y*(exp((2*I)*Pi*x/a)-1)*Pi^2*exp(Pi*(I*x+y)/a)*exp(Pi*(I*x-y)/a)/((exp(Pi*(I*x+y)/a)-1)^2*(-1+exp(Pi*(I*x-y)/a))^2*a^2)-((1/2)*I)*Bm*(exp((2*I)*Pi*x/a)-1)*Pi^2*exp(Pi*(I*x+y)/a)/((exp(Pi*(I*x+y)/a)-1)^2*(-1+exp(Pi*(I*x-y)/a))*a^2)-((1/2)*I)*Dm*y*(exp((2*I)*Pi*x/a)-1)*Pi^2*exp(Pi*(I*x+y)/a)/((exp(Pi*(I*x+y)/a)-1)^2*(-1+exp(Pi*(I*x-y)/a))*a^2)-I*Dm*(exp((2*I)*Pi*x/a)-1)*Pi*exp(Pi*(I*x+y)/a)/((exp(Pi*(I*x+y)/a)-1)^2*(-1+exp(Pi*(I*x-y)/a))*a)+I*Bm*(exp((2*I)*Pi*x/a)-1)*Pi^2*(exp(Pi*(I*x-y)/a))^2/((exp(Pi*(I*x+y)/a)-1)*(-1+exp(Pi*(I*x-y)/a))^3*a^2)+I*Dm*(exp((2*I)*Pi*x/a)-1)*Pi*exp(Pi*(I*x-y)/a)/((exp(Pi*(I*x+y)/a)-1)*(-1+exp(Pi*(I*x-y)/a))^2*a)-((1/2)*I)*Dm*y*(exp((2*I)*Pi*x/a)-1)*Pi^2*exp(Pi*(I*x-y)/a)/((exp(Pi*(I*x+y)/a)-1)*(-1+exp(Pi*(I*x-y)/a))^2*a^2)+sum(-4*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(diff(d(y), y), y))/(Pi(y)^7*m(y)^7*d(y)^2)+32*(diff(po(y), y))*a(y)^3*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(a(y), y))/(Pi(y)^7*m(y)^7*d(y))-56*(diff(po(y), y))*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(Pi(y), y))/(Pi(y)^8*m(y)^7*d(y))-56*(diff(po(y), y))*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(m(y), y))/(Pi(y)^7*m(y)^8*d(y))-8*(diff(po(y), y))*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(d(y), y))/(Pi(y)^7*m(y)^7*d(y)^2)+32*po(y)*a(y)^3*(2*Pi(y)*m(y)^2*y(y)^2*(diff(Pi(y), y))+2*Pi(y)^2*m(y)*y(y)^2*(diff(m(y), y))+2*Pi(y)^2*m(y)^2*y(y)*(diff(y(y), y))+8*a(y)*(diff(a(y), y)))*sin(m*Pi*x/a)*(diff(a(y), y))/(Pi(y)^7*m(y)^7*d(y))+16*po(y)*a(y)^3*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(diff(a(y), y), y))/(Pi(y)^7*m(y)^7*d(y))-56*po(y)*a(y)^4*(2*Pi(y)*m(y)^2*y(y)^2*(diff(Pi(y), y))+2*Pi(y)^2*m(y)*y(y)^2*(diff(m(y), y))+2*Pi(y)^2*m(y)^2*y(y)*(diff(y(y), y))+8*a(y)*(diff(a(y), y)))*sin(m*Pi*x/a)*(diff(Pi(y), y))/(Pi(y)^8*m(y)^7*d(y))-56*po(y)*a(y)^4*(2*Pi(y)*m(y)^2*y(y)^2*(diff(Pi(y), y))+2*Pi(y)^2*m(y)*y(y)^2*(diff(m(y), y))+2*Pi(y)^2*m(y)^2*y(y)*(diff(y(y), y))+8*a(y)*(diff(a(y), y)))*sin(m*Pi*x/a)*(diff(m(y), y))/(Pi(y)^7*m(y)^8*d(y))-8*po(y)*a(y)^4*(2*Pi(y)*m(y)^2*y(y)^2*(diff(Pi(y), y))+2*Pi(y)^2*m(y)*y(y)^2*(diff(m(y), y))+2*Pi(y)^2*m(y)^2*y(y)*(diff(y(y), y))+8*a(y)*(diff(a(y), y)))*sin(m*Pi*x/a)*(diff(d(y), y))/(Pi(y)^7*m(y)^7*d(y)^2)-224*po(y)*a(y)^3*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(a(y), y))*(diff(Pi(y), y))/(Pi(y)^8*m(y)^7*d(y))-224*po(y)*a(y)^3*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(a(y), y))*(diff(m(y), y))/(Pi(y)^7*m(y)^8*d(y))-32*po(y)*a(y)^3*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(a(y), y))*(diff(d(y), y))/(Pi(y)^7*m(y)^7*d(y)^2)+392*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(Pi(y), y))*(diff(m(y), y))/(Pi(y)^8*m(y)^8*d(y))+56*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(Pi(y), y))*(diff(d(y), y))/(Pi(y)^8*m(y)^7*d(y)^2)+56*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(m(y), y))*(diff(d(y), y))/(Pi(y)^7*m(y)^8*d(y)^2)+4*(diff(diff(po(y), y), y))*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)/(Pi(y)^7*m(y)^7*d(y))+8*(diff(po(y), y))*a(y)^4*(2*Pi(y)*m(y)^2*y(y)^2*(diff(Pi(y), y))+2*Pi(y)^2*m(y)*y(y)^2*(diff(m(y), y))+2*Pi(y)^2*m(y)^2*y(y)*(diff(y(y), y))+8*a(y)*(diff(a(y), y)))*sin(m*Pi*x/a)/(Pi(y)^7*m(y)^7*d(y))+4*po(y)*a(y)^4*(2*(diff(Pi(y), y))^2*m(y)^2*y(y)^2+8*Pi(y)*m(y)*y(y)^2*(diff(Pi(y), y))*(diff(m(y), y))+8*Pi(y)*m(y)^2*y(y)*(diff(Pi(y), y))*(diff(y(y), y))+2*Pi(y)*m(y)^2*y(y)^2*(diff(diff(Pi(y), y), y))+2*Pi(y)^2*(diff(m(y), y))^2*y(y)^2+8*Pi(y)^2*m(y)*y(y)*(diff(m(y), y))*(diff(y(y), y))+2*Pi(y)^2*m(y)*y(y)^2*(diff(diff(m(y), y), y))+2*Pi(y)^2*m(y)^2*(diff(y(y), y))^2+2*Pi(y)^2*m(y)^2*y(y)*(diff(diff(y(y), y), y))+8*(diff(a(y), y))^2+8*a(y)*(diff(diff(a(y), y), y)))*sin(m*Pi*x/a)/(Pi(y)^7*m(y)^7*d(y))-28*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(diff(m(y), y), y))/(Pi(y)^7*m(y)^8*d(y))+48*po(y)*a(y)^2*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(a(y), y))^2/(Pi(y)^7*m(y)^7*d(y))+224*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(Pi(y), y))^2/(Pi(y)^9*m(y)^7*d(y))+224*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(m(y), y))^2/(Pi(y)^7*m(y)^9*d(y))+8*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(d(y), y))^2/(Pi(y)^7*m(y)^7*d(y)^3)-28*po(y)*a(y)^4*(Pi(y)^2*m(y)^2*y(y)^2+4*a(y)^2)*sin(m*Pi*x/a)*(diff(diff(Pi(y), y), y))/(Pi(y)^8*m(y)^7*d(y)), m = 1 .. infinity) end proc;
[Lengthy, poorly formatted, and very-difficult-to-read plaintext prettyprint of the above procedure removed by a moderator.--Carl Love]
First 1315 1316 1317 1318 1319 1320 1321 Last Page 1317 of 2464
