Hi, I build my simulation system in MapleSim, using the module 'Stepper Permanent Magnet' like this
But when I run this system, I get the followiing error:
System is underdetermined
When I delete the part about 'Stepper Permanent Magnet', the system runs well.
How to solve this problem? How to use 'Stepper Permanent Magnet'?
The Help file of MapleSim cannot proviod such help information.
sh.mw
guys i have a metric and i want to find its d'alembertian. what is your idea ?
I was trying to obtain the field equations for the QED Lagrangian and I was not sucessfull.
All my calculations are equal to 0.
Can someone give a hand?
QED.mw
Thanks a lot.
hphphphphphphphphphphphphphphphphphhphphghpgmhfphmgflkhmgfklhmsfgmhfglkhmlfgkmhflgkmhklfgh
The program below coredumps once executed:
Engine mapleEngine = new Engine(new String[]{"java"}, new EngineCallBacksCustom(), null, null );
mapleEngine.evaluate("Groebner:-Basis(numer([lend2-lend2, lenh1-lenh1, trig7-lenh1/lenk1, degb1-degb1, degc1+degb1+degz1-180, degf1+degb1-degy1, degb1+degi1+degf1-180, degc1+degb1-degr1, degi1+degb1-degg1, degc2+degb1+dege1-180, degi2+dego1+degh2+degb1-360, lenl1-lenl1, lenb2/lenl1-lena2/lenn1, areat2-(1/2)*lenl1*lenh1, trig6-lenh1/lenj1, -lend1^2+lenh1^2+lenj1^2, lenb2/lenl1-lenl1/lend1, lend1+lend2-lenb2, lend1-lend1, lenl1/lend1-lena2/lenn1, trig2-lenj1/lend1, trig3-lenh1/lend1, trig4-lenh1/lend1, trig1-lenj1/lend1, areas2-(1/2)*lenh1*lenj1, lenj1+lenk1-lenl1, lenj1-lenj1, trig5-lenj1/lenh1, degb1+degi1-90, degz1-degm1-degi1, degi2-degx1-degm1-degi1, degi1-degi1, lenb2-lenb2, lena2-lena2, areaq2-(1/2)*lene2*lenn1, lene2^2+lenn1^2-lenp1^2, lenn1-lenn1, trig8-lenn1/lenp1, trig9-lenn1/lenp1, trig10-lene2/lenn1, trig11-lenn1/lene2, lenh1^2+lenk1^2-lenn1^2, lene2/lenk1-lenn1/lenh1, lene2/lenk1-lenp1/lenn1, lenn1/lenh1-lenp1/lenn1, trig12-lenk1/lenn1, trig13-lenh1/lenn1, trig14-lenh1/lenn1, trig15-lenk1/lenn1, arear2-(1/2)*lenh1*lenk1, lenk1-lenk1, trig16-lenk1/lenh1, degb1-45, degc1-60, lend1-3*2^(1/2)]), 'tord');");
The coredump Information:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_STACK_OVERFLOW (0xc00000fd) at pc=0x0000000012a53f47, pid=1860, tid=7456
# JRE version: Java(TM) SE Runtime Environment (7.0_51-b13) (build 1.7.0_51-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.51-b03 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [fgbuni.dll+0xc3f47]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000002d94800): JavaThread "main" [_thread_in_native, id=7456, stack(0x0000000002c90000,0x0000000002d90000)]
siginfo: ExceptionCode=0xc00000fd, ExceptionInformation=0x0000000000000001 0x0000000002c90000
Registers:
RAX=0x0000000000042f40, RBX=0x0000000000010bd0, RCX=0x00000000183ec740, RDX=0x0000000000010711
RSP=0x0000000002cc7c98, RBP=0x0000000002cc7cd0, RSI=0x0000000000000000, RDI=0x00000000183ec740
R8 =0x0000000000010bd0, R9 =0x0000000000042f40, R10=0x0000000002c84000, R11=0x0000000002c90000
R12=0x0000000019821178, R13=0x0000000000010711, R14=0x00000000132c9040, R15=0x0000000000010bd0
RIP=0x0000000012a53f47, EFLAGS=0x0000000000010206
Top of Stack: (sp=0x0000000002cc7c98)
0x0000000002cc7c98: 0000000000010bd0 0000000017ab3ec8
0x0000000002cc7ca8: 000000001299ff7c 000000000002783a
0x0000000002cc7cb8: 000000000002e025 00000000132c9050
0x0000000002cc7cc8: 0000000000000001 000000001345abac
0x0000000002cc7cd8: 0000000012997bdd 0000000000000018
0x0000000002cc7ce8: 00010bd000010bce 0000000000010711
0x0000000002cc7cf8: 00000000183ec740 000000001345abdc
0x0000000002cc7d08: 0000000000000000 00000000132c9050
0x0000000002cc7d18: 0000000000000000 0000000000000068
0x0000000002cc7d28: 0000000000010bd0 00007e5476285214
0x0000000002cc7d38: 0000000000010711 0000000000010bd0
0x0000000002cc7d48: 00000000132c9040 0000000000010711
0x0000000002cc7d58: 0000000019821178 0000000000000012
0x0000000002cc7d68: 00000000129a110a 0000000000010bd0
0x0000000002cc7d78: 0000000000000000 00000000183ec740
0x0000000002cc7d88: 000000001345abc4 00000000132c9040
Instructions: (pc=0x0000000012a53f47)
0x0000000012a53f27: d0 4d 0f 42 d3 65 4c 8b 1c 25 10 00 00 00 4d 3b
0x0000000012a53f37: d3 73 16 66 41 81 e2 00 f0 4d 8d 9b 00 f0 ff ff
0x0000000012a53f47: 41 c6 03 00 4d 3b d3 75 f0 4c 8b 14 24 4c 8b 5c
0x0000000012a53f57: 24 08 48 83 c4 10 c3 cc cc 48 83 ec 28 ff 15 26
Register to memory mapping:
RAX=0x0000000000042f40 is an unknown value
RBX=0x0000000000010bd0 is an unknown value
RCX=0x00000000183ec740 is an unknown value
RDX=0x0000000000010711 is an unknown value
RSP=0x0000000002cc7c98 is pointing into the stack for thread: 0x0000000002d94800
RBP=0x0000000002cc7cd0 is pointing into the stack for thread: 0x0000000002d94800
RSI=0x0000000000000000 is an unknown value
RDI=0x00000000183ec740 is an unknown value
R8 =0x0000000000010bd0 is an unknown value
R9 =0x0000000000042f40 is an unknown value
R10=0x0000000002c84000 is an unknown value
R11=0x0000000002c90000 is an unknown value
R12=0x0000000019821178 is an unknown value
R13=0x0000000000010711 is an unknown value
R14=0x00000000132c9040 is an unknown value
R15=0x0000000000010bd0 is an unknown value
Stack: [0x0000000002c90000,0x0000000002d90000], sp=0x0000000002cc7c98, free space=223k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.maplesoft.openmaple.Engine.evaluate(Ljava/lang/String;)Lcom/maplesoft/openmaple/Algebraic;+0
j com.tsinghuabigdata.TestMaple.main([Ljava/lang/String;)V+29
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x000000000b214000 JavaThread "Service Thread" daemon [_thread_blocked, id=8032, stack(0x000000000c910000,0x000000000ca10000)]
0x0000000002e8e000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=3304, stack(0x000000000c810000,0x000000000c910000)]
0x0000000002e89000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=7072, stack(0x000000000c710000,0x000000000c810000)]
0x000000000b205800 JavaThread "Attach Listener" daemon [_thread_blocked, id=432, stack(0x000000000c610000,0x000000000c710000)]
0x000000000b1ae000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=7280, stack(0x000000000c510000,0x000000000c610000)]
0x0000000002e7f000 JavaThread "Finalizer" daemon [_thread_blocked, id=8060, stack(0x000000000c410000,0x000000000c510000)]
0x0000000002e74000 JavaThread "Reference Handler" daemon [_thread_blocked, id=4448, stack(0x000000000c310000,0x000000000c410000)]
=>0x0000000002d94800 JavaThread "main" [_thread_in_native, id=7456, stack(0x0000000002c90000,0x0000000002d90000)]
Other Threads:
0x000000000b183000 VMThread [stack: 0x000000000c210000,0x000000000c310000] [id=7992]
0x000000000b21e000 WatcherThread [stack: 0x000000000ce10000,0x000000000cf10000] [id=8124]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 38400K, used 2663K [0x00000007d5c80000, 0x00000007d8700000, 0x0000000800000000)
eden space 33280K, 8% used [0x00000007d5c80000,0x00000007d5f19db0,0x00000007d7d00000)
from space 5120K, 0% used [0x00000007d8200000,0x00000007d8200000,0x00000007d8700000)
to space 5120K, 0% used [0x00000007d7d00000,0x00000007d7d00000,0x00000007d8200000)
ParOldGen total 86016K, used 0K [0x0000000781600000, 0x0000000786a00000, 0x00000007d5c80000)
object space 86016K, 0% used [0x0000000781600000,0x0000000781600000,0x0000000786a00000)
PSPermGen total 21504K, used 2827K [0x000000077c400000, 0x000000077d900000, 0x0000000781600000)
object space 21504K, 13% used [0x000000077c400000,0x000000077c6c2c38,0x000000077d900000)
Card table byte_map: [0x0000000005f50000,0x0000000006370000] byte_map_base: 0x000000000236e000
Polling page: 0x0000000001080000
Code Cache [0x0000000002e90000, 0x0000000003100000, 0x0000000005e90000)
total_blobs=216 nmethods=26 adapters=143 free_code_cache=48704Kb largest_free_block=49836288
Compilation events (10 events):
Event: 0.238 Thread 0x0000000002e8e000 nmethod 15 0x0000000002eff2d0 code [0x0000000002eff4e0, 0x0000000002f00240]
Event: 0.238 Thread 0x0000000002e8e000 23 sun.nio.cs.UTF_8$Decoder::decodeArrayLoop (543 bytes)
Event: 0.252 Thread 0x0000000002e89000 nmethod 22 0x0000000002f01090 code [0x0000000002f01260, 0x0000000002f024e0]
Event: 0.252 Thread 0x0000000002e89000 24 java.lang.String::replace (127 bytes)
Event: 0.255 Thread 0x0000000002e8e000 nmethod 23 0x0000000002efb610 code [0x0000000002efb840, 0x0000000002efc3b8]
Event: 0.255 Thread 0x0000000002e8e000 25 sun.nio.cs.UTF_8$Encoder::encode (361 bytes)
Event: 0.261 Thread 0x0000000002e89000 nmethod 24 0x0000000002efd010 code [0x0000000002efd160, 0x0000000002efd598]
Event: 0.261 Thread 0x0000000002e89000 26 sun.net.www.ParseUtil::encodePath (336 bytes)
Event: 0.262 Thread 0x0000000002e8e000 nmethod 25 0x0000000002ef69d0 code [0x0000000002ef6b20, 0x0000000002ef7008]
Event: 0.278 Thread 0x0000000002e89000 nmethod 26 0x0000000002f071d0 code [0x0000000002f07400, 0x0000000002f084d8]
GC Heap History (0 events):
No events
Deoptimization events (1 events):
Event: 0.229 Thread 0x0000000002d94800 Uncommon trap: reason=unreached action=reinterpret pc=0x0000000002ef7c70 method=java.lang.String.equals(Ljava/lang/Object;)Z @ 2
Internal exceptions (10 events):
Event: 0.033 Thread 0x0000000002d94800 Threw 0x00000007d5c90778 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:3991
Event: 0.161 Thread 0x0000000002d94800 Threw 0x00000007d5d5ca68 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 0.167 Thread 0x0000000002d94800 Threw 0x00000007d5d62858 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 0.200 Thread 0x0000000002d94800 Threw 0x00000007d5e000c0 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 0.200 Thread 0x0000000002d94800 Threw 0x00000007d5e001e8 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 0.236 Thread 0x0000000002d94800 Threw 0x00000007d5eb4ef8 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 0.238 Thread 0x0000000002d94800 Threw 0x00000007d5ec5658 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 0.239 Thread 0x0000000002d94800 Threw 0x00000007d5ecfe40 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 0.243 Thread 0x0000000002d94800 Threw 0x00000007d5edb170 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 0.281 Thread 0x0000000002d94800 Threw 0x00000007d5ede4e8 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Events (10 events):
Event: 0.243 loading class 0x0000000002e82650
Event: 0.243 loading class 0x0000000002e82650 done
Event: 0.281 loading class 0x0000000002e31450
Event: 0.281 loading class 0x0000000002e313f0
Event: 0.281 loading class 0x0000000002e313f0 done
Event: 0.281 loading class 0x0000000002e31450 done
Event: 0.281 loading class 0x000000000cdbc760
Event: 0.281 loading class 0x000000000cdbc760 done
Event: 4.173 Executing VM operation: EnableBiasedLocking
Event: 4.173 Executing VM operation: EnableBiasedLocking done
Dynamic libraries:
0x00007ff66ea10000 - 0x00007ff66ea43000 C:\Program Files\Java\jdk1.7.0_51\bin\javaw.exe
0x00007ffc4d3d0000 - 0x00007ffc4d57c000 C:\Windows\SYSTEM32\ntdll.dll
0x00007ffc4c160000 - 0x00007ffc4c29e000 C:\Windows\system32\KERNEL32.DLL
0x00007ffc4a2c0000 - 0x00007ffc4a3d5000 C:\Windows\system32\KERNELBASE.dll
0x00007ffc48d50000 - 0x00007ffc48dde000 C:\Windows\system32\apphelp.dll
0x00007ffc33070000 - 0x00007ffc330c3000 C:\Windows\AppPatch\AppPatch64\AcGenral.DLL
0x00007ffc4cb80000 - 0x00007ffc4cc2a000 C:\Windows\system32\msvcrt.dll
0x00007ffc49f40000 - 0x00007ffc49f6e000 C:\Windows\SYSTEM32\SspiCli.dll
0x00007ffc4cc30000 - 0x00007ffc4cc84000 C:\Windows\system32\SHLWAPI.dll
0x00007ffc4d090000 - 0x00007ffc4d207000 C:\Windows\system32\USER32.dll
0x00007ffc4c630000 - 0x00007ffc4c7c4000 C:\Windows\system32\ole32.dll
0x00007ffc4a750000 - 0x00007ffc4bc68000 C:\Windows\system32\SHELL32.dll
0x00007ffc49720000 - 0x00007ffc49741000 C:\Windows\SYSTEM32\USERENV.dll
0x00007ffc4c9a0000 - 0x00007ffc4ca4a000 C:\Windows\system32\ADVAPI32.dll
0x00007ffc3fe10000 - 0x00007ffc3fe2e000 C:\Windows\SYSTEM32\MPR.dll
0x00007ffc4c4d0000 - 0x00007ffc4c611000 C:\Windows\system32\RPCRT4.dll
0x00007ffc4cca0000 - 0x00007ffc4ccf9000 C:\Windows\SYSTEM32\sechost.dll
0x00007ffc4bc70000 - 0x00007ffc4be81000 C:\Windows\SYSTEM32\combase.dll
0x00007ffc4d270000 - 0x00007ffc4d3c1000 C:\Windows\system32\GDI32.dll
0x00007ffc4a130000 - 0x00007ffc4a145000 C:\Windows\SYSTEM32\profapi.dll
0x00007ffc48990000 - 0x00007ffc48a42000 C:\Windows\SYSTEM32\SHCORE.dll
0x00007ffc4be90000 - 0x00007ffc4bec6000 C:\Windows\system32\IMM32.DLL
0x00007ffc4c370000 - 0x00007ffc4c4c2000 C:\Windows\system32\MSCTF.dll
0x00007ffc480b0000 - 0x00007ffc4832b000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9600.17415_none_6240486fecbd8abb\COMCTL32.dll
0x00000000521a0000 - 0x0000000052272000 C:\Program Files\Java\jdk1.7.0_51\jre\bin\msvcr100.dll
0x00000000519d0000 - 0x0000000052199000 C:\Program Files\Java\jdk1.7.0_51\jre\bin\server\jvm.dll
0x00007ffc43dd0000 - 0x00007ffc43dd9000 C:\Windows\SYSTEM32\WSOCK32.dll
0x00007ffc4a720000 - 0x00007ffc4a742000 C:\Windows\system32\WINMM.dll
0x00007ffc4ca50000 - 0x00007ffc4ca57000 C:\Windows\system32\PSAPI.DLL
0x00007ffc4d210000 - 0x00007ffc4d26a000 C:\Windows\system32\WS2_32.dll
0x00007ffc4a210000 - 0x00007ffc4a23a000 C:\Windows\system32\WINMMBASE.dll
0x00007ffc4cc90000 - 0x00007ffc4cc99000 C:\Windows\system32\NSI.dll
0x00007ffc4a490000 - 0x00007ffc4a4df000 C:\Windows\SYSTEM32\cfgmgr32.dll
0x00007ffc4a1e0000 - 0x00007ffc4a208000 C:\Windows\system32\DEVOBJ.dll
0x00000000527f0000 - 0x00000000527ff000 C:\Program Files\Java\jdk1.7.0_51\jre\bin\verify.dll
0x00000000519a0000 - 0x00000000519c8000 C:\Program Files\Java\jdk1.7.0_51\jre\bin\java.dll
0x0000000051980000 - 0x0000000051995000 C:\Program Files\Java\jdk1.7.0_51\jre\bin\zip.dll
0x00007ffc30810000 - 0x00007ffc3082d000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\jopenmaple.dll
0x00007ffc293b0000 - 0x00007ffc293c1000 C:\Windows\SYSTEM32\maplec.dll
0x00007ffc24060000 - 0x00007ffc249a1000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\maple.dll
0x00007ffc46bf0000 - 0x00007ffc46c06000 C:\Windows\SYSTEM32\NETAPI32.dll
0x00007ffc4c120000 - 0x00007ffc4c136000 C:\Windows\system32\imagehlp.dll
0x00007ffc40ea0000 - 0x00007ffc40ea8000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\libhf.dll
0x0000000180000000 - 0x000000018000e000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\pthreadVC2.dll
0x00007ffc4cac0000 - 0x00007ffc4cb76000 C:\Windows\system32\COMDLG32.dll
0x00007ffc493c0000 - 0x00007ffc493cc000 C:\Windows\SYSTEM32\netutils.dll
0x00007ffc49d60000 - 0x00007ffc49d86000 C:\Windows\SYSTEM32\srvcli.dll
0x00007ffc46bb0000 - 0x00007ffc46bc7000 C:\Windows\SYSTEM32\wkscli.dll
0x000000000d710000 - 0x000000000da54000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\libmmd.dll
0x0000000052d60000 - 0x0000000052e29000 C:\Windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.8428_none_88dcdb0b2fb19957\MSVCR80.dll
0x00007ffc49990000 - 0x00007ffc499e9000 C:\Windows\system32\mswsock.dll
0x00007ffc40280000 - 0x00007ffc40295000 C:\Windows\system32\napinsp.dll
0x00007ffc402a0000 - 0x00007ffc402ba000 C:\Windows\system32\pnrpnsp.dll
0x00007ffc46c80000 - 0x00007ffc46c9b000 C:\Windows\system32\NLAapi.dll
0x00007ffc49790000 - 0x00007ffc49834000 C:\Windows\SYSTEM32\DNSAPI.dll
0x00007ffc40270000 - 0x00007ffc4027d000 C:\Windows\System32\winrnr.dll
0x00007ffc402c0000 - 0x00007ffc402d4000 C:\Windows\system32\wshbth.dll
0x00007ffc40ed0000 - 0x00007ffc40eda000 C:\Windows\System32\rasadhlp.dll
0x00000000669c0000 - 0x0000000066a4a000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\libmaplegmp-10.dll
0x00007ffc37130000 - 0x00007ffc37133000 C:\Windows\SYSTEM32\icmp.Dll
0x00007ffc43d50000 - 0x00007ffc43d7a000 C:\Windows\SYSTEM32\iphlpapi.DLL
0x00007ffc43d30000 - 0x00007ffc43d3a000 C:\Windows\SYSTEM32\WINNSI.DLL
0x00007ffc43590000 - 0x00007ffc435fb000 C:\Windows\System32\fwpuclnt.dll
0x00007ffc22c70000 - 0x00007ffc24051000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\mstring.dll
0x00007ffc25f40000 - 0x00007ffc26026000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\modLA.dll
0x00007ffc26e70000 - 0x00007ffc26e87000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\arraytools.dll
0x0000000012990000 - 0x0000000012d69000 C:\Program Files\Maple 18\bin.X86_64_WINDOWS\fgbuni.dll
0x00007ffc364a0000 - 0x00007ffc3662a000 C:\Windows\SYSTEM32\dbghelp.dll
VM Arguments:
jvm_args: -Djava.library.path=C:\Program Files\Maple 18\bin.X86_64_WINDOWS;D:\smartmatch\autojudge_V3\dll -Dfile.encoding=UTF-8
java_command: com.tsinghuabigdata.TestMaple
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=C:\Program Files\Java\jdk1.6.0_45
CLASSPATH=.;C:\Program Files\Java\jdk1.6.0_45\lib;C:\Program Files\Java\jdk1.6.0_45\lib\tools.jar;D:\JAVA_PATH
PATH=C:\Program Files\Maple 18\jre\bin\client;C:\Program Files\Maple 18\bin.X86_64_WINDOWS;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\NetSarang;c:\Program Files (x86)\Intel\iCLS Client\;c:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Windows Live\Shared;JAVA_HOME\bin;JAVA_HOME\jre\bin;C:\Program Files\TortoiseSVN\bin;C:\Program Files (x86)\IDM Computer Solutions\UltraEdit\;C:\Program Files\Java\jdk1.6.0_45\bin;C:\Program Files\Java\jdk1.6.0_45\jre\bin;D:\Program Files\maven\bin;C:\Python27;C:\Python27\Scripts
USERNAME=bq
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 69 Stepping 1, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 8 , 64 bit Build 9200
CPU:total 4 (2 cores per cpu, 2 threads per core) family 6 model 69 stepping 1, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, erms, ht, tsc, tscinvbit
Memory: 4k page, physical 8290760k(3738828k free), swap 9601480k(3195268k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (24.51-b03) for windows-amd64 JRE (1.7.0_51-b13), built on Dec 18 2013 18:40:56 by "java_re" with unknown MS VC++:1600
time: Fri Apr 24 13:48:05 2015
elapsed time: 5 seconds
I have the following functional
I was wondering how I would evaluate the following in Maple
James
Hi....how can i multiply the 9*4 matrix on the left side of this table to the 9*1 vector on the right side of it (last column) with a kind of product of cells that results a 9*4 matrix made up of cells like this one's [(a,b,c,d)⊗(e,f,g,h)=(ae,bf,cg,dh)]
can anyone help me please?
SO
ST
WO
WT
Weight
C1
(0.55,0.67,0.78,0.89)
(0.7,0.8,0.8,0.9)
(0.767,0.867,0.93,0.967)
(0.72,0.83,0.83,0.93)
(0.7,0.8,0.8,0.9)
C2
(0.67,0.78,0.89,0.97)
(0.8,0.9,1,1)
(0.73,0.83,0.867,0.93)
(0.66,0.76,0.79,0.90)
(0.8,0.9,1,1)
C3
(0.78,0.89,0.89,1)
(0.8,0.9,1,1)
(7.67,8.67,9.3,9.67)
(0.55,0.66,0.69,0.79)
C4
(0.78,0.89,0.89,1)
(0.06,0.13,0.167.0.267)
(0.8,0.9,1,1)
(0.76,0.86,0.90,0.97)
(0.43,0.53,0.567,0.667)
C5
(0.78,0.89,0.89,1)
(0.8,0.9,1,1)
C6
(0.74,0.85,0.93,1)
(0.67,0.767,0.83,0.9)
(0.62,0.72,0.83,0.90)
(0.8,0.9,1,1)
C7
(0.59,0.70,0.74,0.85)
(0.567,0.667,0.73,0.83)
(0.667,0.767,0.83,0.9)
(0.69,0.79,0.86,0.93)
(0.067,0.1,0.2,0.3)
C8
(0.74,0.85,0.93,1)
(0.7,0.8,0.9,0.93)
(0.79,0.90,0.97,1)
C9
(0.70,0.81,0.85,0.96)
(0.7,0.8,0.9,0.93)
(0.7,0.8,0.8,0.9)
(0.59,69,0.76,0.86)
(0.53,0.63,0.667,0.767)
Dear all;
Thank you very much for helping me to understand this problem.
I need your help for this question, it's seem for correct but when I run the code there is no dispaly of the solution with this command  dsolve({ode,ics}) ;
ode:=x*diff(y(x),x)+y(x)=x*exp(-x^2);
ics:=y(0)=1;
dsolve(ode);
dsolve({ode,ics}) ;
Hye, have a good day everyone..
can anyone know why I got this error? :(second_grade.mw
Here I have attached the file. thank you in advance :)
Why can't I run a produce on the Maple IDE? I can't add Maple environment to Maple IDE. The error is this.
License expires in 29 days
|\^/| Maple 18 (X86 64 WINDOWS)
._|\| |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2014
\ MAPLE / All rights reserved. Maple is a trademark of
<____ ____> Waterloo Maple Inc.
| Type ? for help.
Error: EnvUtils:-KernelSummary("could not validate license %1, required by %2. Please check the Install.html file under the toolbox directory for instructions on how to activate a license.\nLicense manager error: %3")
memory used=0.7MB, alloc=8.3MB, time=0.11
what means the command that `linsolve` and
when
a:=matrix([[a1,a2],[b1,b2]])
b:=vector([c1,c2])
c:=transpose(a)
linsolve(c&*a,c&*b)
&* <<--- what is it
hi , kindly guide me how to draw combine graphs for velocity profile at different values of one parameter.  For example we have 3rd order ODE and A is parameter that is multiple of equation. now we want to see the effects of that parameter on this 3rd  order ODE.  Now  how can i sketch the  combine graph of Df(o) at A=1, 2, 3. (for example.)
i want to plot the graph based on this equation to know the stability of this equation :
y := A*(1/x+x*exp(-2*sqrt(-1)*b))+4*sin(h)^2*(2*exp(-sqrt(-1)*b)-3*sin(h)^2*x^(-sin(h))*exp(sqrt(-1)*b*(-sin(h)-1))+3*x^(-sin(h))*exp(sqrt(-1)*b*(-sin(h)-1)))/(3*(1-r))-exp(-2*sqrt(-1)*b)/x-x;
with A = (1+r)/(1-r), r = (1/3)*sin(h)^2, b = m*Pi*h, m = 1, h=0.05
can somebody help me..??
I need to make a lot of similar calculations and wonder if it can be done in a smart way in Maple. Microsoft Excel is perfect for this kind of calculations, because you can downcopy cells. I would like to do everything in Maple, if possible, though. I have a number of points A, B, C, D, E, ... , which all lie on various circles in the plane. For every point radius and angle is given, so actually you can say that every point is delivered with polar coordinates. I want to have their rectangular coordinates.
Maybe I could deliver their radii in a list and their angles in degrees in another list?
r:=[12,56,29,...., 78]:
v:=[15,45,75,..., 102]:
I need to be able to refer to a certain point thorugh an index. At best it would be A, B, C, ... , but 1, 2, 3, ... will be acceptable. So in the end I need to be able to access say x_C and y_C or x_3 and y_3 (understood as index lowered). I hope someone can help me do the task in a nice a efefctive way.
NB! Maybe you have a solution, which involve transformation from polar to rectangular coordinates. That will be nice, but please also tell me how it can be done from scratch, because I want to be able to know about handling many points at once for other purposes, when the function is not r*cos(v), but an arbitrary function.
Erik
First 1316 1317 1318 1319 1320 1321 1322 Last Page 1318 of 2464
