OK. Perfect. It runs.
Now, I would like to remove all the set of solutions where for two variables (for example a and b) are negative.
For example, if I have this :
{a=1,b=-1,c=1}, {a=1,b=1,c=1}, {a=-2,b=-1,c=1}
After filtering, I would like to have only :
{a=1,b=1,c=1}
Thanks a lot for your help.
After a solve on a system composed with trigonometric functions, i obtain several group of solutions.
Here a picture of my solutions :
How can I do to extract from thses solutions only the group composed with real components.
I read this, but there was nothing on how to write a help associated with it.
Does anyone know where I can find it?
Many thanks,
casperyc
I want to draw a contour plot like the pic below which the relating value of each curve is specified on several parts of the curve. Can anyone suggest a way? :)
As an example do it with the following function:
f(x,y)=x^2+y^2-5
Can someone please let me know if there's a command which shows the name of the current (and running) worksheet? I would like it to be exported to an output file which is the easy part but I don't know how to automatically read it. Thank you very much.
i got kernel connection lost error when memory used reach 2.87GB
how to make it fully used 3.8GB ram, total 4GB ram
indexlistresult := [];
gaga := [seq(i, i=1..512];
nops(indexlistresult);
indexlistresult := [op(indexlistresult), op(gaga)];
with(combinat):
gg := permute(indexlistresult, 3);
I actually had the same problem on Maple 16. When i go to plot an equation (usually on implicit plots) it just repeats the equation in blue text rather than showing any sort of plot. Im sure i am just missing a simple option somewhere, but for the life of me I cant find it. Any and all help would be appreciated.
I am trying to find the inverse of 8x8 generic symbolic matrix. Everytime I evaluate the program I get the following error:
Error, (in expand/bigprod) Maple was unable to allocate enough memory to complete this computation. Please see ?alloc
Can anyone guide me how to increase the memory allocation? And would that solve the problem for me?
Any help is appreciated.
Thanks!!
Hi all.  I have researched into this problem.  But I could not find a solution to this.
Here is an example.
I have a set of independent variables, say there are 5 of them.  They are 1. Gender 2. Age group 3. Full or part time 4. First language.
I have a set of dependent variables.  Let us consider for an example 6 of them.  They are (i) Develops breast cancer (ii) Develops skin cancer (iii) Develops lung cancer (iv) develops prostate cancer (v) Lives till 50 (vi) Lives till 60 ...
How do I perform the following prediction:
(A) If a person is male and above 50, what are the chances that he is likely to develop prostate cancer?
(B) If a person is female and works part time, what are the chances that she is likely to develop breast cancer and lives till 60?
I need to develop a code and formula to do this?  Can someone please advise?
Many thanks.
Kind regards,
Kris
I have a question that says write a procedure that takes a random graph and three edges of that graph and returns true if those edges share a common vertex. So I was thinking of something along the lines of
proc55 := proc (G, {a, b}, {c, d})
if evalb({a, b} = {a, c} or {a, b} = {a, d} or {a, b} = {b, c} or {a, b} = {b, d}) then print(true)
else print(false)
I guess my main question is how do I put edges in the parameters line? It will let me write proc (G, a, b, c, d) but not proc (G, {a, b}, {c, d}).
Is there just something I'm missing or am I approaching this in the wrong way?
I have a proc as follows:
F:=proc(f,n)
L:=[f];
for j from 1 to n do;
J:=int(1/subs(t=x[j],L[j]),x[j]=2..x[j+1]);
L:=[op(L),J];
I chose to use index variables. However when I try to apply a member of the output list as a function of the outermost limit, I do not get any output when I try to evaluate the function. I suspect maple is having trouble with the variables withing the integral. How can I make this work?
I'd like to have a function that I can evaluate:
g:=F(log(t),3)[3];
f:=unapply(g,x[3]);
f(2.1);
I have one question regarding to dsolve.
Let say I have simple function,
 dx/dt =A+Bx
 dy/dt =A'+B'y
when I want to get graph of x as function of time or y as fuction of time, I can use 'dsolve'
For example, I can put "" soln:=dsolve ((ABOVE EQUATION, ICs),numerical,implicit=true) ""
                                     plot(soln,x(t) or y(t))
Also, When I want to get x value or y value as function of time, I can use soln(t), t could be whatever I want.
However, I want to get or draw graph " t " as function of x or function of y. For example, I want to know  t value when x=3 or I want to know t value when y=5. Above equations are simple, so I can calculate by hand. but I want to know which command I need or which ways are in MAPLE to get the value.
hi,
I am trying to plot the polygon but it isnt working. Please help
i put
triangle := polygonpolt3d ([13,11,12], [16,10,18], [14,10,7]) :
display3d (triangle)
I have a complicated equation which you can find in the file below. I want to multiply both sides of equaiton by cos(beta[1,j__1]*z) and integrate from 1 to L. I have many such similar equations so I decided to write a procedure to do these staffs for me.
Can you give me simple suggestions on how to write such a procedure. The procedure will take the "equation", "multiplier" and "limits of integration" as inputs and gives the "integrated equation" as the output. Integration is perfomed by the inert function "Int".
Many thanks.
Equation.mw
Hello guys
I have a question:
I have an equation like below. Always it has different order for example :
T1:=q3*(r^6)+q2*(r^4)+q1*(r^2)+q0:
solve(T1=0,r):
and sometimes:
T2:=q5*(r^4)+q6*(r^2)+q7:
solve(T2=0,r):
q0,q1,q2,q3,q4,q5,q6 and q7 are constants.
We know that for T1 It has two real answer and for T2 we have any real answer.
How can I specify generally the real answers for all of them?
I want to use these real answer for another equation.
First 1408 1409 1410 1411 1412 1413 1414 Last Page 1410 of 2463
